path: root/include/asm-arm/arch-omap/mux.h
2008-04-14ARM: OMAP2: Clean-up mux codeTony Lindgren
Misc clean-up for the mux code and remove some unnecessary ifdefs. Patch changes debug function so it can be used on both 24xx and 34xx. Changes are mostly for omap2, but patch also cleans up some omap1 and common mux code. Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-04-14ARM: OMAP2: Add new pin multiplexing configurationsTony Lindgren
Add new pin multiplexing configurations Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-04-14ARM: OMAP: Allow registering pin mux functionTony Lindgren
This patch changes pin multiplexing init to allow registering custom function. The omap_cfg_reg() func will be split into omap processor specific functions in later patch. This is done to make adding omap3 pin multiplexing easier. Signed-off-by: Tony Lindgren <tony@atomide.com>
2007-09-20ARM: OMAP: omap camera builds again; Mistral init and muxDavid Brownell
Support the camera connector on the OSK Mistral add-on board: - define muxing for both camera controllers - mux both of them for Mistral - teach ov9640 glue about mistral powerup/powerdown Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Tony Lindgren <tony@atomide.com>
2007-05-10ARM: OMAP: 24xx pinmux updatesKyungmin Park
Add some OMAP 24xx pin mux declarations to support: - TUSB 6010 EVM (on H4) - All three full speed USB ports - GPIOs used with USB0 on Apollon and H4 For OMAP2, issue MUX_WARNINGS and debug messages correctly; and make the message look more like the OMAP1 message. Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Tony Lindgren <tony@atomide.com>
2006-09-25ARM: OMAP: mux: add config for 16xx SPI pinsMark Howell
This patch adds pin mux info for the SPI master/slave interface on OMAP16xx. Data from OMAP 1611/1612 TRM and errata. Works for me on my 1611/H2 with current git kernel. Signed-off-by: Mark Howell <mhowell@northlink.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2006-09-25ARM: OMAP: Apollon MMC supportKyungmin Park
Apollon board MMC supports on OMAP2 TODO: We have to check MMC on H4 Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2006-06-26ARM: OMAP: Multiplexing for 24xx GPMC wait pin monitoringTony Lindgren
Multiplexing for 24xx GPMC wait pin monitoring Signed-off-by: Tony Lindgren <tony@atomide.com>
2006-06-26ARM: OMAP: Mux updates for external DMA and GPIOTony Lindgren
Mux updates for external DMA and GPIO. GPIO updates by Igor Stoppa. Signed-off-by: Tony Lindgren <tony@atomide.com>
2006-04-02[ARM] 3428/1: ARM: OMAP: 3/8 Update pin multiplexingTony Lindgren
Patch from Tony Lindgren Update OMAP pin multiplexing code from linux-omap tree. This patch adds new pin configurations by various OMAP developers, and suport for omap730 by Brian Swetland. Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-11-10[ARM] 3143/1: OMAP 4/5: Update omap include filesTony Lindgren
Patch from Tony Lindgren This patch syncs the mainline kernel with linux-omap tree. This patch contains changes to common header files for omap1xxx and omap24xx by various omap developers, and improved cpu detection by Imre Deak Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-09-07[ARM] 2888/1: OMAP 3/4: Update omap include files, take 2Tony Lindgren
Patch from Tony Lindgren This patch syncs the mainline kernel with linux-omap tree. The highlights of the patch are: - Start adding 24xx support by Paul Mundt - Clean-up of cpu detection by Dirk Behme and Tony Lindgren - Add DSP header by Toshihiro Kobayashi - Add support for mtd-xip by Vladimir Barinov - Add various new mux registers - Move OMAP specific serial defines back to serial.h Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-07-10[PATCH] ARM: 2804/1: OMAP update 9/11: Update OMAP arch filesTony Lindgren
Patch from Tony Lindgren This patch by various OMAP developers syncs the OMAP specific arch files with the linux-omap tree. Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
