path: root/include/asm-arm/arch-omap
2008-08-07[ARM] Move include/asm-arm/arch-* to arch/arm/*/include/machRussell King
This just leaves include/asm-arm/plat-* to deal with. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-07[ARM] Remove asm/hardware.h, use asm/arch/hardware.h insteadRussell King
Remove includes of asm/hardware.h in addition to asm/arch/hardware.h. Then, since asm/hardware.h only exists to include asm/arch/hardware.h, update everything to directly include asm/arch/hardware.h and remove asm/hardware.h. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-02[ARM] Fix explicit asm(-arm)?/arch-foo referencesRussell King
No file should be explicitly referencing its own platform headers by specifying an absolute include path. Fix these paths to use standard <asm/arch/...> includes. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-07-03ARM: OMAP2: Clock: New OMAP2/3 DPLL rate rounding algorithmPaul Walmsley
This patch adds a new rate rounding algorithm for DPLL clocks on the OMAP2/3 architecture. For a desired DPLL target rate, there may be several multiplier/divider (M, N) values which will generate a sufficiently close rate. Lower N values result in greater power economy. However, lower N values can cause the difference between the rounded rate and the target rate ("rate error") to be larger than it would be with a higher N. This can cause downstream devices to run more slowly than they otherwise would. This DPLL rate rounding algorithm: - attempts to find the lowest possible N (DPLL divider) to reach the target_rate (since, according to Richard Woodruff <r-woodruff@ti.com>, lower N values save more power than higher N values). - allows developers to set an upper bound on the error between the rounded rate and the desired target rate ("rate tolerance"), so an appropriate balance between rate fidelity and power savings can be set. This maximum rate error tolerance is set via omap2_set_dpll_rate_tolerance(). - never returns a rounded rate higher than the target rate. The rate rounding algorithm caches the last rounded M, N, and rate computation to avoid rounding the rate twice for each clk_set_rate() call. (This patch does not yet implement set_rate for DPLLs; that follows in a future patch.) The algorithm trades execution speed for rate accuracy. It will find the (M, N) set that results in the least rate error, within a specified rate tolerance. It does this by evaluating each divider setting - on OMAP3, this involves 128 steps. Another approach to DPLL rate rounding would be to bail out as soon as a valid rate is found within the rate tolerance, which would trade rate accuracy for execution speed. Alternate implementations welcome. This code is not yet used by the OMAP24XX DPLL clock, since it is currently defined as a composite clock, fusing the DPLL M,N and the M2 output divider. This patch also renames the existing OMAP24xx DPLL programming functions to highlight that they program both the DPLL and the DPLL's output multiplier. Signed-off-by: Paul Walmsley <paul@pwsan.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-07-03ARM: OMAP2: Clock: Add OMAP3 DPLL autoidle functionsPaul Walmsley
This patch adds support for DPLL autoidle control to the OMAP3 clock framework. These functions will be used by the noncore DPLL enable and disable code - this is because, according to the CDP code, the DPLL autoidle status must be saved and restored across DPLL lock/bypass/off transitions. N.B.: the CORE DPLL (DPLL3) has three autoidle mode options, rather than just two. This code currently does not support the third option, low-power bypass autoidle. Signed-off-by: Paul Walmsley <paul@pwsan.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-07-03ARM: OMAP: Add OMAP chip type structure; clean up mach-omap2/id.cPaul Walmsley
Add a new OMAP chip identification interface, omap_chip_id. omap_chip_id is a structure which contains one bit for each OMAP2/3 CPU type, and on 3430, ES level. For example, the CHIP_IS_OMAP2420 bit is set in omap_chip at boot on an OMAP2420. On OMAP3430ES2, both CHIP_IS_OMAP3430 and CHIP_IS_OMAP3430ES2 bits are set. omap_chip is set in mach-omap2/id.c by _set_omap_chip(). Other code should use the omap_chip_is() function to test against omap_chip. Also, clean up id.c by splitting some code out of omap_check_revision() into its own function, _set_system_rev(); and converting some debug printk()s into pr_debug(). Second revision. Signed-off-by: Paul Walmsley <paul@pwsan.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-07-03ARM: OMAP: Introduce omap_globals and prcm access functions for multi-omapTony Lindgren
New struct omap_globals contains the omap processor specific module bases. Use omap_globals to set the various base addresses to make detecting omap chip type simpler. Also introduce OMAP1_IO_ADDRESS and OMAP2_IO_ADDRESS for future multi-omap patches. Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-07-03ARM: OMAP: Remove __REG access for multi-omapTony Lindgren
This does not play nicely with multi-omap as it cannot be replaced by a function in io.c for omaps with different IO bases. Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-07-03ARM: OMAP: USB: Change omap USB code to use omap_read/write instead of __REGTony Lindgren
Change omap USB code to use omap_read/write instead of __REG for multi-omap Cc: David Brownell <david-b@pacbell.net> Cc: linux-usb@vger.kernel.org Cc: i2c@lm-sensors.org Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-07-03ARM: OMAP: Change omap_cf.c and omap_nor.c to use omap_readw/writew instead ↵Tony Lindgren
of __REG Change omap_cf.c and omap_nor.c to use omap_readw/writew instead of __REG. This is needed for multi-omap in the future. Cc: David Brownell <david-b@pacbell.net> Cc: linux-pcmcia@lists.infradead.org Cc: linux-mtd@lists.infradead.org Signed-off-by: Tony Lindren <tony@atomide.com>
2008-07-03ARM: OMAP: CLKFW: Initial debugfs support for omap clock frameworkHiroshi DOYU
debugfs can provide the infrastructure to trace the dependencies of clock tree hierarchy quite visibly. This patch enables to keep track of clock tree hierarchy and expose their attributes under each clock directry as below: omap:~# tree -d -L 2 /debug/clock/omap_32k_fck/ /debug/clock/omap_32k_fck/ |-- gpt10_fck |-- gpt11_fck |-- gpt1_fck |-- per_32k_alwon_fck | |-- gpio2_fck | |-- gpio3_fck | |-- gpio4_fck | |-- gpio5_fck | |-- gpio6_fck | `-- wdt3_fck |-- ts_fck `-- wkup_32k_fck |-- gpio1_fck `-- wdt2_fck 14 directories omap:~# tree /debug/clock/omap_32k_fck/gpt10_fck/ /debug/clock/omap_32k_fck/gpt10_fck/ |-- flags |-- rate `-- usecount 0 directories, 3 files Although, compared with David Brownell's small patch, this may look bit overkilling, I expect that this debugfs can deal with other PRCM complexities at the same time. For example, powerdomain dependencies can be expressed by using symbolic links of these clocks if powerdomain supports dubgfs as well. Signed-off-by: Hiroshi DOYU <Hiroshi.DOYU@nokia.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-07-03ARM: OMAP: Clean up interrupt lines to fix warnings for multi-omapTony Lindgren
If boards with different NR_IRQS are compiled together, tons of compiler warnings are emitted about redefining NR_IRQS. This patch fixes the problem by adding up NR_IRQS in a common place. Patch also removes quite a bit of now unnecessary code. Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-07-03ARM: OMAP: McBSP: Prepare for splitting into omap1 and omap2 codeEduardo Valentin
This patch transform mcbsp code to use platform data from arch/arm/plat-omap/devices.c It also gets ride of ifdefs on mcbsp.c code. To do it, a platform data structure was defined. Signed-off-by: Eduardo Valentin <eduardo.valentin@indt.org.br> Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-07-03ARM: OMAP: SRAM: Split sram24xx.S into sram242x.S and sram243x.STony Lindgren
Split sram24xx.S into sram242x.S and sram243x.S Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-07-03ARM: OMAP: DMA: Clean-up codeTony Lindgren
DMA clean-up, mostly checkpatch.pl fixes. Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-07-03ARM: OMAP: DMA: Remove __REG accessTony Lindgren
Remove __REG access in DMA code, use dma_read/write instead: - dynamically set the omap_dma_base based on the omap type - omap_read/write becomes dma_read/write - dma channel registers are read with dma_ch_read/write Cc: David Brownell <david-b@pacbell.net> Cc: linux-usb@vger.kernel.org Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-07-03ARM: OMAP: DMA: Make channels dynamic for multi-bootTony Lindgren
Make DMA channels dynamic for multi-boot Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-07-03ARM: OMAP: Add OMAP3430 base definesPaul Walmsley
Add symbolic constants for OMAP3430 base addresses; include that file in hardware.h. Signed-off-by: Paul Walmsley <paul@pwsan.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-07-03ARM: OMAP: DMTimer: Optimize by adding load and startRichard Woodruff
This patch optimizes the timer load and start sequence. By combining the load and start a needless posted wait can be removed from the system timer execution path. * Before patch register writes are taking up .078% @ 500MHz during idle. Address |total |min |max |avr |count|ratio% old\process\default_idle|7.369s |0.0us|999.902ms|14.477ms|509. |62.661% ld\Global\cpu_v7_do_idle|4.265s |0.0us|375.786ms|24.374ms|175. |36.270% (UNKNOWN)|17.503ms|0.us|531.080us|5.119us|3419. |0.148% r\omap_dm_timer_set_load|8.135ms|0.0us|79.887us|15.065us|540. |0.069% <-- \vmlinux-old\Global\_end|2.023ms|0.0us|4.000us|0.560us|3613. |0.017% -old\Global\__raw_readsw|1.962ms|0.0us|108.610us|9.167us|214. |0.016% old\smc91x\smc_interrupt|1.353ms|0.0us|10.212us|2.348us|576. |0.011% s/namei\__link_path_walk|1.161ms|0.0us|4.310us|0.762us| 1524. |0.009% \omap_dm_timer_write_reg|1.085ms|0.0us|126.150us|2.153us|504. |0.009% <-- * After patch timer functions do not show up in top listings for long captures. Signed-off-by: Richard Woodruff <r-woodruff2@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-05-23[ARM] fix OMAP include loopsRussell King
OMAP has two include loops in its header files: asm-arm/hardware.h <- asm-arm/arch-omap/io.h <- asm-arm/arch-omap/hardware.h <- asm-arm/hardware.h asm-arm/arch-omap/board-palmte.h <- asm-arm/arch-omap/hardware.h <- asm-arm/hardware.h <- asm-arm/arch-omap/gpio.h <- asm-arm/arch-omap/board-palmte.h Circular include dependencies are dangerous since they can result in inconsistent definitions being provided to other code, especially if '#ifndef' constructs are used. Solve these by removing the offending includes, and add additional includes where necessary. Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-05-22[ARM] omap: fix omap clk support build errorsRussell King
arch/arm/plat-omap/clock.c:397: warning: "struct cpufreq_frequency_table" declared inside parameter list arch/arm/plat-omap/clock.c:397: warning: its scope is only this definition or declaration, which is probably not what you want arch/arm/plat-omap/clock.c: In function `clk_init_cpufreq_table': arch/arm/plat-omap/clock.c:402: error: structure has no member named `clk_init_cpufreq_table' arch/arm/plat-omap/clock.c:403: error: structure has no member named `clk_init_cpufreq_table' Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-05-17Merge branch 'omap-fixes' of ↵Russell King
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6
2008-05-17[ARM] fix parenthesis in include/asm-arm/arch-omap/control.hMariusz Kozlowski
Parenthesis fix in include/asm-arm/arch-omap/control.h Signed-off-by: Mariusz Kozlowski <m.kozlowski@tuxland.pl> Cc: Paul Walmsley <paul@pwsan.com> Cc: Tony Lindgren <tony@atomide.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-05-09ARM: OMAP: Add calls to omap2_set_globals_*()Paul Walmsley
Add the omap2_set_globals_{242x,243x,343x}() functions. These functions are called early upon boot in the map_io() functions in the board-specific init files. This patch was accidentally left out of the earlier series. This fixes omap2 booting as noted by Kyungmin Park <kmpark@infradead.org>. Signed-off-by: Paul Walmsley <paul@pwsan.com> Cc: Kyungmin Park <kmpark@infradead.org> Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-05-09ARM: OMAP: Update MMC header to fix compileTony Lindgren
Update MMC header from linux-omap tree to match the recent MMC driver updates. Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-04-21Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/drzeus/mmc * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/drzeus/mmc: (26 commits) mmc: sdio_ops.c should #include "sdio_ops.h" mmc: proper prototypes for mmc_attach_*() mmc: make __mmc_release_bus() static sdhci: improve no card, no reset quirk MMC: OMAP: Do not busy wait for end of command for ever MMC: OMAP: Start new commands from work queue instead of irq MMC: OMAP: Lazy clock shutdown MMC: OMAP: Move failing command abortion to workqueue MMC: OMAP: Use tasklet instead of workqueue for cover switch notification MMC: OMAP: Check the get_cover_state function pointer if not set MMC: OMAP: Using setup_timer instead of init_timer MMC: OMAP: Abort stuck commands MMC: OMAP: General cleanup for MMC multislot support MMC: OMAP: Power functions modified to MMC multislot support MMC: OMAP: Fix timeout calculation for MMC multislot support MMC: OMAP: New release dma and abort xfer functions MMC: OMAP: Add back cover switch support MMC: OMAP: Introduce new multislot structure and change driver to use it MMC: OMAP: Remove cover switch handling to allow adding multislot support MMC: OMAP: Fix the BYTEBLOCK capability removal ...
2008-04-18MMC: OMAP: Introduce new multislot structure and change driver to use itJuha Yrjola
Introduce new MMC multislot structure and change driver to use it. Note that MMC clocking is now enabled in mmc_omap_select_slot() and disabled in mmc_omap_release_slot(). Signed-off-by: Juha Yrjola <juha.yrjola@solidboot.com> Signed-off-by: Jarkko Lavinen <jarkko.lavinen@nokia.com> Signed-off-by: Carlos Eduardo Aguiar <carlos.aguiar@indt.org.br> Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
2008-04-14ARM: OMAP2: New DPLL clock frameworkRoman Tereshonkov
These changes is the result of the discussion with Paul Walmsley. His ideas are included into this patch. Remove DPLL output divider handling from DPLLs and CLKOUTX2 clocks, and place it into specific DPLL output divider clocks (e.g., dpll3_m2_clk). omap2_get_dpll_rate() now returns the correct DPLL rate, as represented by the DPLL's CLKOUT output. Also add MPU and IVA2 subsystem clocks, along with high-frequency bypass support. Add support for DPLLs function in locked and bypass clock modes. Signed-off-by: Roman Tereshonkov <roman.tereshonkov@nokia.com> Acked-by: Paul Walmsley <paul@pwsan.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-04-14ARM: OMAP2: Add 34xx clocksPaul Walmsley
This patch defines 34xx clocks. Signed-off-by: Paul Walmsley <paul@pwsan.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-04-14ARM: OMAP2: Change 24xx to use shared clock code and new reg accessPaul Walmsley
This patch changes 24xx to use shared clock code and new register access. Note that patch adds some temporary OLD_CK defines to keep patch more readable. These temporary defines will be removed in the next patch. Also not all clocks are changed in this patch to limit the size. Also, the patch fixes few incorrect clock defines in clock24xx.h. Signed-off-by: Paul Walmsley <paul@pwsan.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-04-14ARM: OMAP2: Change 24xx to use new register accessPaul Walmsley
This patch changes 24xx to use new register access, except for clock framework. Clock framework register access will get updates in the next patch. Note that board-*.c files change GPMC (General Purpose Memory Controller) access to use gpmc_cs_write_reg() instead of accessing the registers directly. The code also uses gpmc_fck instead of it's parent clock core_l3_ck for GPMC clock. The H4 board file also adds h4_init_flash() function, which specify the flash start and end addresses. Also note that sleep.S removes some unused registers addresses. Signed-off-by: Paul Walmsley <paul@pwsan.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-04-14ARM: OMAP2: Add common register access for 24xx and 34xxPaul Walmsley
This patch adds common register access for 24xx and 34xx power and clock management in order to share code between 24xx and 34xx. Only change USB platform init code to use new register access, other access will be changed in later patches. Signed-off-by: Paul Walmsley <paul@pwsan.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-04-14ARM: OMAP2: Clean-up mux codeTony Lindgren
Misc clean-up for the mux code and remove some unnecessary ifdefs. Patch changes debug function so it can be used on both 24xx and 34xx. Changes are mostly for omap2, but patch also cleans up some omap1 and common mux code. Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-04-14ARM: OMAP2: Add new pin multiplexing configurationsTony Lindgren
Add new pin multiplexing configurations Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-04-14ARM: OMAP: Allow registering pin mux functionTony Lindgren
This patch changes pin multiplexing init to allow registering custom function. The omap_cfg_reg() func will be split into omap processor specific functions in later patch. This is done to make adding omap3 pin multiplexing easier. Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-04-14ARM: OMAP: Use gpiolib with tps65010 for OSK 5912David Brownell
Convert OSK board to use new tps65010 gpiolib support. This includes moving its LED support from leds-osk to gpio-leds, giving more trigger options and a net platform code shrink. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-04-14ARM: OMAP: Use gpiolibDavid Brownell
Update OMAP to use the new GPIO implementation framework. This is just a quick'n'dirty update ... more code could now be removed, ideally as part of cleaning up the entire OMAP GPIO infrastructure ... Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-03-20[ARM] 4869/1: ARM: OMAP: Fix compile for mcbspTony Lindgren
Until DSP MMU code is merged, dsp_request_mem() does not exist. Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-03-05ARM: OMAP1: Fix compile for boards depending on old gpio expanderTony Lindgren
The long term fix is to switch boards to use drivers/gpio/pcf857x.c. Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-03-05ARM: OMAP1: omap h3 regression and build fixDavid Brownell
Get rid of build warnings and errors in mainline for H3 boards; not all the H3 updates were correct, it seems like the OMAP1 boards are not getting proper build testing. Also, commit e27a93a944a5ba6a0112750c8243abba86d56e94 introduced a regression related to the tps65013 chip. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-03-05ARM: OMAP: Remove compiler warning when i2c is not setKyungmin Park
Remove compiler warning when i2c is not set Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Acked-by: Jarkko Nikula <jarkko.nikula@nokia.com>
2008-02-08ARM: OMAP1: Use MMC multislot structures for Siemens SX1 boardCarlos Eduardo Aguiar
Use MMC multislot structures for Siemens SX1 board Signed-off-by: Carlos Eduardo Aguiar <carlos.aguiar@indt.org.br> Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-02-08ARM: OMAP1: Make omap1 use MMC multislot structuresFelipe Balbi
Make omap1 use new MMC multislot structures. The related MMC patches will be sent separately. Signed-off-by: Felipe Balbi <felipe.lima@indt.org.br> Signed-off-by: Anderson Briglia <anderson.briglia@indt.org.br> Signed-off-by: Carlos Eduardo Aguiar <carlos.aguiar@indt.org.br> Signed-off-by: David Cohen <david.cohen@indt.org.br> Signed-off-by: Eduardo Valentin <eduardo.valentin@indt.org.br> Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-02-08ARM: OMAP1: Make omap1 boards to use omap_nand_platform_dataTony Lindgren
This patch adds omap_nand_platform data based on a patch by Shahrom Sharif-Kashani <sshahrom@micron.com>, and makes omap1 boards to use omap_nand_platform_data instead of nand_platform_data used earlier. Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-02-08ARM: OMAP: Add helper module for board specific I2C bus registrationJarkko Nikula
This helper module simplifies I2C bus registration for different OMAP platforms by doing registration in one place only and to allow board specific bus configuration like clock rate and number of busses configured. Helper should cover OMAP processors from first to third generation. This patch just adds the feature and current implementation cleanup and board file modifications will be done in following patches. Signed-off-by: Jarkko Nikula <jarkko.nikula@nokia.com> Acked-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-02-08ARM: OMAP: Add DMA support for chaining and 3430Anand Gadiyar
Add DMA support for chaining and 3430. Also remove old DEBUG_PRINTS as noted by Russell King. Signed-off-by: Anand Gadiyar <gadiyar@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-02-08ARM: OMAP: Add 24xx GPIO debounce supportKevin Hilman
Add 24xx GPIO debounce support. Also minor formatting clean-up. Signed-off-by: Kevin Hilman <khilman@mvista.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-02-08ARM: OMAP: Add 3430 gpio supportSyed Mohammed, Khasim
This patch adds 3430 gpio support. It also contains a fix by Paul Walmsley <paul@pwsan.com> to use the correct clock names for OMAP3430. Signed-off-by: Syed Mohammed Khasim <x0khasim@ti.com> Signed-off-by: Paul Walmsley <paul@pwsan.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-02-08ARM: OMAP: Add 3430 CPU identification macrosSyed Mohammed Khasim
This patch adds omap3430 CPU identification macros. Silicon revision check macros added by Girish S G <girishsg@ti.com>. CPU identification macro and silicon revision check macros cleaned up by Paul Walmsley <paul@pwsan.com>. Signed-off-by: Syed Mohammed Khasim <x0khasim@ti.com> Signed-off-by: Girish S G <girishsg@ti.com> Signed-off-by: Paul Walmsley <paul@pwsan.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2008-01-31[ALSA] Remove sound/driver.hTakashi Iwai
This header file exists only for some hacks to adapt alsa-driver tree. It's useless for building in the kernel. Let's move a few lines in it to sound/core.h and remove it. With this patch, sound/driver.h isn't removed but has just a single compile warning to include it. This should be really killed in future. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
