path: root/include/asm-arm/arch-pxa/hardware.h
2008-01-10[ARM] pxa: silence warnings from cpu_is_xxx() macrosRussell King
If only a single CPU type is selected, __cpu_is_xxx() doesn't use its argument. This causes the compiler to issue a warning about an unused variable in the parent function. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-10-15[ARM] 4576/1: CM-X270 machine supportMike Rapoport
This patch provides core support for CM-X270 platform. Signed-off-by: Mike Rapoport <mike@compulab.co.il> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-10-15[ARM] pxa: Make cpu_is_pxaXXX dependent on configuration symbolsRussell King
Make the cpu_is_pxaXXX() macros define to zero when support for a particular CPU is disabled. This allows us to eliminate code for CPUs which aren't enabled. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-10-12[ARM] pxa: add PXA3 cpu_is_xxx() macroseric miao
Extracted from patch by Eric Miao, this adds the cpu_is_xxx() macros for identifying PXA3 SoCs. Signed-off-by: eric miao <eric.y.miao@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-10-12[ARM] pxa: mark pxa_set_cken deprecatedRussell King
Allow the generic clock support code to fiddle with the CKEN register and mark pxa_set_cken() deprecated. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-10-12[ARM] pxa: remove get_lcdclk_frequency_10khz()Russell King
get_lcdclk_frequency_10khz() is now redundant, remove it. Hide pxa27x_get_lcdclk_frequency_10khz() from public view. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-07-12[ARM] pxa: introduce cpu_is_pxaXXX macrosRussell King
2007-02-20[PATCH] GPIO API: PXA wrapper cleanupPhilipp Zabel
Based on the discussion last december (http://lkml.org/lkml/2006/12/20/242), this patch: - moves the PXA_LAST_GPIO check into pxa_gpio_mode - fixes comment and includes in gpio.h - replaces the gpio_set/get_value macros with inline functions and adds a non-inline version to avoid code explosion when gpio is not a constant. Signed-off-by: Philipp Zabel <philipp.zabel@gmail.com> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Nicolas Pitre <nico@cam.org> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2005-10-28[ARM] 3044/1: Fix sparse warnings about incompatible pointer types for ↵Ian Campbell
register defined in pxa-regs.h Patch from Ian Campbell The sparse warning initially surfaced in sound/arm/pxa2xx-ac97.c because it was using u32 * variables to hold the unsigned long * register addresses. I submitted an ALSA patch for this http://thread.gmane.org/gmane.linux.alsa.devel/27804 issue and it was suggested that it might be preferable to change the register definitions to use u32. Most other subarches seem to use u32 for their register type, at least the ones which use a __REG macro (like the PXA) do. Nico indicated in the thread above that he wouldn't mind this patch. Changing the type required fixes for opposite warnings in the pxa2xx usb gadget code but that was the only new warning introduced on defconfig or lubbock, mainstone and our own PXA255 boards. Signed-off-by: Ian Campbell <icampbell@arcom.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-09-08[ARM] 2892/1: remove gcc workaround for direct access to absolute memory ↵Nicolas Pitre
addresses Patch from Nicolas Pitre It used to make a difference in the gcc-2.95 era. However these days modern gcc apparently got better at not being influenced by such constructs (which is good in general) and therefore such workaround is of no real advantage anymore. The good news is that gcc (from version 4.1.0) is now fixed with regards to the defficiency this workaround was trying to address. For those interested the patch can easily be backported to older gcc versions and can be found here: http://gcc.gnu.org/cgi-bin/cvsweb.cgi/gcc/gcc/config/arm/arm.c.diff?r1=1.476&r2=1.478 and also here: http://savannah.gnu.org/cgi-bin/viewcvs/gcc/gcc/gcc/config/arm/arm.c.diff?r1=text&tr1=1.476&r2=text&tr2=1.478&diff_format=u Signed-off-by: Nicolas Pitre <nico@cam.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
