path: root/include/asm-arm/arch-versatile
2007-05-12[ARM] Use new get_irqnr_preambleRussell King
Use the new get_irqnr_preamble macro to move the address of the IRQ controller outside the IRQ handling loop. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-02-17[ARM] 4185/2: entry: introduce get_irqnr_preamble and arch_ret_to_userDan Williams
get_irqnr_preamble allows machines to take some action before entering the get_irqnr_and_base loop. On iop we enable cp6 access. arch_ret_to_user is added to the userspace return path to allow individual architectures to take actions, like disabling coprocessor access, before the final return to userspace. Per Nicolas Pitre's note, there is no need to cp_wait on the return to user as the latency to return is sufficient. Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-10-11[PATCH] arm-versatile iomem annotationsAl Viro
2006-07-11[ARM] Allow Versatile to be built for AB and PBRussell King
If a configuration was chosen to support both the Versatile AB and PB boards, the result would write to registers not available on the PB version of the board. Resolve this by using machine_is_xxx(). Also, for the CLCD, despite how the code looks, both the AB and PB access the same location to control the clock rate - it's just called something different between the two board versions. Invent our own name for this location and use it unconditionally. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-06-24[ARM] 3631/1: Remove legacy __mem_isa() definitionsAndrew Victor
Patch from Andrew Victor Remove the remaining legacy __mem_isa() definitions for the ARM platforms. Signed-off-by: Andrew Victor <andrew@sanpeople.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-06-20[ARM] 3610/1: Make reboot work on VersatileDeepak Saxena
Patch from Deepak Saxena This patch makes soft reboot work on the Versatile board. Thanks to Catalin Marinas @ ARM for pointing out the proper way to do this. Signed-off-by: Deepak Saxena <dsaxena@plexity.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-03-28[ARM] Fix decompressor serial IO to give CRLF not LFCRRussell King
As per the corresponding change to the serial drivers, arrange for ARM decompressors to give CRLF. Move the common putstr code into misc.c such that machines only need to supply "putc" and "flush" functions. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-03-21[ARM] Collect Primecell PL01x-based debug implementations togetherRussell King
Several ARM machine implementations used a PL01x primecell compatible serial port for debugging purposes, and indepdently implemented the low level debug macros every time. Provide a common implementation and convert these implementations to use this version. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-03-21[ARM] Move HZ definition into KconfigRussell King
Move the HZ definition into Kconfig, and set appropriate defaults for platforms. Remove mostly empty asm/arch/param.h include file. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-01-13[ARM] Separate VIC (vectored interrupt controller) support from VersatileRussell King
Other machines may wish to make use of the VIC support code, so move it to arch/arm/common. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-01-07[ARM] Move AMBA include files to include/linux/amba/Russell King
Since the ARM AMBA bus is used on MIPS as well as ARM, we need to make the bus available for other architectures to use. Move the AMBA include files from include/asm-arm/hardware/ to include/linux/amba/ Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-01-04[ARM] Remove definition of MAX_DMA_CHANNELS to zeroRussell King
Since we now only build arch/arm/kernel/dma.c on machine types which set ISA_DMA_API, we don't need to define MAX_DMA_CHANNELS to 0 to indicate this - this definition becomes superfluous. Remove it. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-01-04[ARM] Move common definition of MAX_DMA_ADDRESS to asm/dma.hRussell King
2006-01-03[ARM] Cleanup ARM includesRussell King
arch/arm/kernel/entry-armv.S has contained a comment suggesting that asm/hardware.h and asm/arch/irqs.h should be moved into the asm/arch/entry-macro.S include. So move the includes to these two files as required. Add missing includes (asm/hardware.h, asm/io.h) to asm/arch/system.h includes which use those facilities, and remove asm/io.h from kernel/process.c. Remove other unnecessary includes from arch/arm/kernel, arch/arm/mm and arch/arm/mach-footbridge. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-10-29[ARM] 3060/1: allow constants found in asm/memory.h to be used in asm codeNicolas Pitre
Patch from Nicolas Pitre This patch allows for assorted type of cleanups by letting assembly code use the same set of defines for constant values and avoid duplicated definitions that might not always be in sync, or that might simply be confusing due to the different names for the same thing. Signed-off-by: Nicolas Pitre <nico@cam.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-09-29[PATCH] arm/versatile iomem annotationsAl Viro
2005-06-20[PATCH] ARM: 2693/1: Add PCI support for Versatile/PBCatalin Marinas
Patch from Catalin Marinas This patch adds PCI support for the Versatile PB926 platform. Signed-off-by: Colin King Signed-off-by: Catalin Marinas Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-06-16[PATCH] ARM: 2714/1: Fix the IB2 definitions for the Versatile platformCatalin Marinas
Patch from Catalin Marinas The initial IB2 addresses did not depend on the IB2 base. This patch defines them as (VERSATILE_IB2_BASE + offset). Signed-off-by: Catalin Marinas Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-05-03[PATCH] ARM: cleanup vmalloc start/offset macrosRussell King
VMALLOC_START and VMALLOC_OFFSET are common between all ARM machine classes. Move them into include/asm-arm/pgtable.h, but allow a machine class to override them if required. Signed-off-by: Russell King <rmk@arm.linux.org.uk>
