path: root/include/asm-arm/hardware
2007-05-12[ARM] Use new get_irqnr_preambleRussell King
Use the new get_irqnr_preamble macro to move the address of the IRQ controller outside the IRQ handling loop. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-05-05[ARM] iop: add missing parens in macroRussell King
Fix: drivers/serial/8250.c:1837: warning: suggest parentheses around arithmetic in operand of | due to a macro argument being used without required parenthesis. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-05-03[ARM] 4348/4: iop3xx: Give Linux control over PCI initializationDan Williams
Currently the iop3xx platform support code assumes that RedBoot is the bootloader and has already initialized the ATU. Linux should handle this initialization for three reasons: 1/ The memory map that RedBoot sets up is not optimal (page_to_dma and virt_to_phys return different addresses). The effect of this is that using the dma mapping API for the internal bus dma units generates pci bus addresses that are incorrect for the internal bus. 2/ Not all iop platforms use RedBoot 3/ If the ATU is already initialized it indicates that the iop is an add-in card in another host, it does not own the PCI bus, and should not be re-initialized. Changelog: * rather than change nr_controllers to zero, simply do not call pci_common_init Cc: Lennert Buytenhek <kernel@wantstofly.org> Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-03-05[PATCH] gpio_keys driver shouldn't be ARM-specificDavid Brownell
The gpio_keys driver is wrongly ARM-specific; it can't build on other platforms with GPIO suport. This fixes that problem. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Dmitry Torokhov <dtor@mail.ru> Cc: pHilipp Zabel <philipp.zabel@gmail.com> Cc: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Ben Nizette <ben.nizette@iinet.net.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-20Merge ARM fixesRussell King
2007-02-20[ARM] Merge remaining IOP codeRussell King
Conflicts: include/asm-arm/arch-at91rm9200/entry-macro.S Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-02-19Merge branch 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (117 commits) [ARM] 4058/2: iop32x: set ->broken_parity_status on n2100 onboard r8169 ports [ARM] 4140/1: AACI stability add ac97 timeout and retries [ARM] 4139/1: AACI record support [ARM] 4138/1: AACI: multiple channel support for IRQ handling [ARM] 4211/1: Provide a defconfig for ns9xxx [ARM] 4210/1: base for new machine type "NetSilicon NS9360" [ARM] 4222/1: S3C2443: Remove reference to missing S3C2443_PM [ARM] 4221/1: S3C2443: DMA support [ARM] 4220/1: S3C24XX: DMA system initialised from sysdev [ARM] 4219/1: S3C2443: DMA source definitions [ARM] 4218/1: S3C2412: fix CONFIG_CPU_S3C2412_ONLY wrt to S3C2443 [ARM] 4217/1: S3C24XX: remove the dma channel show at startup [ARM] 4090/2: avoid clash between PXA and SA1111 defines [ARM] 4216/1: add .gitignore entries for ARM specific files [ARM] 4214/2: S3C2410: Add Armzone QT2410 [ARM] 4215/1: s3c2410 usb device: per-platform vbus_draw [ARM] 4213/1: S3C2410 - Update definition of ADCTSC_XY_PST [ARM] 4098/1: ARM: rtc_lock only used with rtc_cmos [ARM] 4137/1: Add kexec support [ARM] 4201/1: SMP barriers pair needed for the secondary boot process ... Fix up conflict due to typedef removal in sound/arm/aaci.h
2007-02-18Merge the easy part of the IOP branchRussell King
2007-02-17Merge AT91, EP93xx, General devel, PXA, S3C, V6+ and Xscale treesRussell King
2007-02-17[ARM] 4187/1: iop: unify time implementation across iop32x, iop33x, and iop13xxDan Williams
* architecture specific details are handled in asm/arch/time.h * ARCH_IOP13XX now selects PLAT_IOP * as suggested by Lennert use ifdef CONFIG_XSCALE to skip the cp_wait on XSC3 Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-02-17[ARM] 4186/1: iop: remove cp6_enable/disable routinesDan Williams
This functionality is replaced by cp6_trap Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-02-17[ARM] 4090/2: avoid clash between PXA and SA1111 definesNicolas Pitre
The Lubbock platform uses both a PXA25x and a SA1111 at the same time. Both chips have the same "Serial Audio Controller" registers although the SA1111 one is never expected to be used in preference to the PXA25x one. So let's disable the SA1111 defines whenever compilation is for a PXA architecture and make the PXA defines always defined. This removes a bunch of "already defined" warnings as well since the current hack to prevent them depended on include ordering which wasn't always right. While at it, clean up the SA1111 defines allowing to get rid of the __CCREG() macro. Signed-off-by: Nicolas Pitre <nico@cam.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-02-15Merge Realview GIC codeRussell King
2007-02-15[ARM] 4109/2: Add support for the RealView/EB MPCore revC platformCatalin Marinas
The kernel originally supported revB only. This patch enables revC by default and adds a config option for building the kernel for the revB platform. Since the SCU base address was hard-coded in the proc-v6.S file (and only valid for RealView/EB revB), this patch also adds a more generic support for defining the SCU information. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-02-15[ARM] 4108/2: Allow multiple GIC interrupt controllers in a systemCatalin Marinas
The current implementation only assumes one GIC to be present in the system. However, there are platforms with more than one cascaded interrupt controllers (RealView/EB MPCore for example). Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-02-14[ARM] 4184/1: iop: cp6 access handler (undef_hook)Dan Williams
Enable svc access to cp6 via an undefined instruction hook. Do not enable access for usr code. This patch also makes iop13xx select PLAT_IOP, this requires a small change to drivers/i2c/busses/i2c-iop3xx.c. Per Lennert Buytenhek's note, the cp6 trap routine is moved to arch/arm/plat-iop Per Nicolas Pitre's note, the cp_wait is skipped since the latency to return to the faulting function is longer than cp_wait. Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-02-14[ARM] 4182/1: iop3xx: fix the ioremap implementation to not remap static rangesDan Williams
Implement a custom ioremap implementation for iop3xx. This saves establishing new mappings. It also cleans up the PCI IO resource to be a physical address rather than a virtual address as Russell pointed out on the original iop13xx port. Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-02-11[ARM] 4135/1: Add support for the L210/L220 cache controllersCatalin Marinas
This patch adds the support for the L210/L220 (outer) cache controller. The cache range operations are done by index/way since L2 cache controller only accepts physical addresses. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-02-10Merge rsync://rsync.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6Dmitry Torokhov
2007-01-18Input: gpio-keys - keyboard driver for GPIO buttonsPhil Blundell
This is an interrupt-driven keyboard driver for simple buttons connected directly to CPU GPIO lines of embedded ARM systems. It supports pxa architectures and is used by a number of PDAs and PocketPC phones in the handhelds.org kernel. Support for other architectures, such as sa11xx and sc2410, will be added once generic GPIO API is available. Signed-off-by: Paul Sokolovsky <pmiscml@gmail.com> Signed-off-by: Philipp Zabel <philipp.zabel@gmail.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2007-01-06[ARM] 4082/1: iop3xx: fix iop33x gpio register offsetDan Williams
iop33x gpio offset is correct in include/asm-arm/arch-iop33x/iop33x.h, but include/asm-arm/hardware/iop3xx.h adds 4. Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-10-06Initial blind fixup for arm for irq changesLinus Torvalds
Untested, but this should fix up the bulk of the totally mechanical issues, and should make the actual detail fixing easier. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-03fix file specification in commentsUwe Zeisberger
Many files include the filename at the beginning, serveral used a wrong one. Signed-off-by: Uwe Zeisberger <Uwe_Zeisberger@digi.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-09-27[ARM] 3864/1: Refactore sharpsl_pmDirk Opfer
This patch adds another hook into sharpsl_pm to notify the machine specific driver immediately after resume. This is needed to support the Sharp SL-6000 (Tosa). Signed-off-by: Dirk Opfer <Dirk@Opfer-Online.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-09-27[ARM] 3863/1: Add Locomo SPI DeviceDirk Opfer
The Locomo chip has a SPI interface which is used for SD/MMC cards (only collie). This patch adds the definition for the SPI device inside the Locomo chip. Signed-off-by: Dirk Opfer <Dirk@Opfer-Online.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-09-27[ARM] 3847/2: Convert LOMOMO to use struct device for GPIOsRichard Purdie
Convert LOMOMO to use struct device * for GPIOs instead of struct locomo_dev. This enables access to the GPIOs from code which is not a locomo device itself (such as audio). Access for gpio 31 is removed for error handling (no such hardware exists). Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-09-25[ARM] 3831/1: iop3xx: factor out common register definesLennert Buytenhek
Factor out the register defines for a number of other peripherals common to the iop32x and iop33x. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-09-25[ARM] 3827/1: iop3xx: add common gpio moduleLennert Buytenhek
Implement the gpio_line_{config,get,set} API for iop3xx. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-09-25[ARM] 3824/1: iop3xx: add cp6 enable/disable macrosLennert Buytenhek
Add macros to enable and disable access to CP6. On the iop3xx, enabling CP6 access unfortunately also enables access to that coprocessor from unprivileged code, so we need these macros to enable and disable access to the coprocessor whenever we need to access it. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-09-25[ARM] 3822/1: iop3xx: rewrite time handlingLennert Buytenhek
Merge and rewrite the iop32x/iop33x time code to do lost jiffy tracking properly, and put the result in plat-iop/time.c. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-09-25[ARM] 3820/1: iop3xx: factor out shared pci codeLennert Buytenhek
Merge the iop32x PCI code and iop33x PCI code into plat-iop/pci.c. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-09-25[ARM] 3819/1: iop3xx: factor out shared i2c codeLennert Buytenhek
Move the i2c bits shared between iop32x and iop33x to plat-iop/i2c.c and include/asm-arm/hardware/iop3xx.h. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-09-25[ARM] 3818/1: iop3xx: introduce arch/arm/plat-iop for shared iop32x/iop33x codeLennert Buytenhek
Introduce the arch/arm/plat-iop directory, for code shared between the iop32x and iop33x, and move the common memory map setup bits there. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-08-27[ARM] 3760/1: This patch adds timeouts while working with SSP registers. ↵Paul Sokolovsky
Such timeouts were en Patch from Paul Sokolovsky This patch adds timeouts while working with SSP registers. Such timeouts were envisioned by docstrings in ssp.c, but were not implemented. There were actual lockups while accessing touchscreen for iPaqs h1910, h4000 due to lack of the timeouts. This is updated version of previously submitted patch: 3738/1. Signed-off-by: Paul Sokolovsky <pmiscml@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-06-26[PATCH] backlight: LOCOMO Backlight Driver updatesRichard Purdie
Add backlight intensity control to the LOCOMO lcd/backlight driver using the backlight class and add basic power management support. This is a reimplementation and improvement of patches by John Lenz and Pavel Machek Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Antonino Daplas <adaplas@pol.net> Cc: Pavel Machek <pavel@ucw.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-20Merge branch 'devel' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'devel' of master.kernel.org:/home/rmk/linux-2.6-arm: (42 commits) [ARM] Fix tosa build error [ARM] 3610/1: Make reboot work on Versatile [ARM] 3609/1: S3C24XX: defconfig update for s3c2410_defconfig [ARM] 3591/1: Anubis: IDE device definitions [ARM] Include asm/hardware.h not asm/arch/hardware.h [ARM] 3594/1: Poodle: Add touchscreen support + other updates [ARM] 3564/1: sharpsl_pm: Abstract some machine specific parameters [ARM] 3561/1: Poodle: Correct the MMC/SD power control [ARM] 3593/1: Add reboot and shutdown handlers for Zaurus handhelds [ARM] 3599/1: AT91RM9200 remove global variables [ARM] 3607/1: AT91RM9200 misc fixes [ARM] 3605/1: AT91RM9200 Power Management [ARM] 3604/1: AT91RM9200 New boards [ARM] 3603/1: AT91RM9200 remove old files [ARM] 3592/1: AT91RM9200 Serial driver update [ARM] 3590/1: AT91RM9200 Platform devices support [ARM] 3589/1: AT91RM9200 DK/EK board update [ARM] 3588/1: AT91RM9200 CSB337/637 board update [ARM] 3587/1: AT91RM9200 hardware headers [ARM] 3586/1: AT91RM9200 header update ...
2006-06-19[ARM] 3564/1: sharpsl_pm: Abstract some machine specific parametersRichard Purdie
Patch from Richard Purdie Abstract some machine specific parameters from the sharpsl_pm core into the machine specific drivers. This allows the core to support tosa/poodle. Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-04-26Don't include linux/config.h from anywhere else in include/David Woodhouse
2006-03-21[ARM] 3373/1: move uengine loader to arch/arm/commonLennert Buytenhek
Patch from Lennert Buytenhek Move the uengine loader from arch/arm/mach-ixp2000 to arch/arm/common so that ixp23xx can use it too. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-03-21[ARM] Collect Primecell PL01x-based debug implementations togetherRussell King
Several ARM machine implementations used a PL01x primecell compatible serial port for debugging purposes, and indepdently implemented the low level debug macros every time. Provide a common implementation and convert these implementations to use this version. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-03-21[ARM] Collect 8250-based debug implementations togetherRussell King
Several ARM machine implementations used an 8250 compatible port for debugging purposes, and indepdently implemented the low level debug macros every time. Provide a common implementation and convert these implementations to use this version. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-03-21[ARM] Adapt vic.c to allow for multiple VICs in a system.Russell King
Some SoCs have multiple VIC devices. Adapt the generic vic code to allow multiple implementations to be handled. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-01-13[ARM] Separate VIC (vectored interrupt controller) support from VersatileRussell King
Other machines may wish to make use of the VIC support code, so move it to arch/arm/common. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-01-07[ARM] Move asm/hardware/clock.h to linux/clk.hRussell King
This is needs to be visible to other architectures using the AMBA bus and peripherals. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-01-07[ARM] Move AMBA include files to include/linux/amba/Russell King
Since the ARM AMBA bus is used on MIPS as well as ARM, we need to make the bus available for other architectures to use. Move the AMBA include files from include/asm-arm/hardware/ to include/linux/amba/ Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-01-05[ARM] 3228/1: SharpSL: Move PM code to arch/arm/commonRichard Purdie
Patch from Richard Purdie This patch moves a large chunk of the sharpsl_pm driver to arch/arm/common so that it can be reused on other devices such as the SL-5500 (collie). It also abstracts some functions from the core into the machine and platform specific parts of the driver to aid reuse. Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-01-03[ARM] Remove clk_use()/clk_unuse()Russell King
It seems that clk_use() and clk_unuse() are additional complexity which isn't required anymore. Remove them from the clock framework to avoid the additional confusion which they cause, and update all ARM machine types except for OMAP. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-01-03[ARM] Add additional documentation to the clock source frameworkRussell King
It seems that there's some confusion over how the clock source framework should be used. Add some additional comments to explain the ambiguous areas. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-11-19[SERIAL] Fix status reporting with PL011 serial driverRussell King
The receiver status register reports latched error conditions, which must be cleared by writing to it. However, the data register reports unlatched conditions which are associated with the current character. Use the data register to interpret error status rather than the RSR. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-11-16[ARM] Include asm/hardware.h instead of asm/arch/hardware.hRussell King
Rationalise hardware.h include. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
