path: root/include/asm-arm/termbits.h
2007-05-28[ARM] enable arbitary speed tty ioctls and split input/output speedAlan Cox
Add the ioctls and values needed for this to the ARM26/ARM32 ports. The actual code has been in the base kernel for a while and automatically turns on when a port sets the required defines. [RMK: also added termbits.h changes to avoid build breakage] Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-12-08[PATCH] tty: preparatory structures for termios revampAlan Cox
In order to sort out our struct termios and add proper speed control we need to separate the kernel and user termios structures. Glibc is fine but the other libraries rely on the kernel exported struct termios and we need to extend this without breaking the ABI/API To do so we add a struct ktermios which is the kernel view of a termios structure and overlaps the struct termios with extra fields on the end for now. (That limitation will go away in later patches). Some platforms (eg alpha) planned ahead and thus use the same struct for both, others did not. This just adds the structures but does not use them, it seems a sensible splitting point for bisect if there are compile failures (not that I expect them) Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
