path: root/include/asm-arm
2007-05-09Merge branch 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (28 commits) ARM: OMAP: Fix GCC-reported compile time bug ARM: OMAP: restore CONFIG_GENERIC_TIME ARM: OMAP: partial LED fixes ARM: OMAP: add SoSSI clock (call propagate_rate for childrens) ARM: OMAP: FB sync with N800 tree (support for dynamic SRAM allocations) ARM: OMAP: Sync framebuffer headers with N800 tree ARM: OMAP: Mostly cosmetic to sync up with linux-omap tree ARM: OMAP: Fix gpmc header ARM: OMAP: Add mailbox support for IVA [ARM] armv7: add Makefile and Kconfig entries [ARM] armv7: add support for asid-tagged VIVT I-cache [ARM] armv7: add dedicated ARMv7 barrier instructions [ARM] armv7: Add ARMv7 cacheid macros [ARM] armv7: add support for ARMv7 cores. [ARM] Fix ARM branch relocation range [ARM] 4363/1: AT91: Remove legacy PIO definitions [ARM] 4361/1: AT91: Build error ARM: OMAP: Sync core code with linux-omap ARM: OMAP: Sync headers with linux-omap ARM: OMAP: h4 must have blinky leds!! ...
2007-05-09Merge git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivialLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivial: (25 commits) sound: convert "sound" subdirectory to UTF-8 MAINTAINERS: Add cxacru website/mailing list include files: convert "include" subdirectory to UTF-8 general: convert "kernel" subdirectory to UTF-8 documentation: convert the Documentation directory to UTF-8 Convert the toplevel files CREDITS and MAINTAINERS to UTF-8. remove broken URLs from net drivers' output Magic number prefix consistency change to Documentation/magic-number.txt trivial: s/i_sem /i_mutex/ fix file specification in comments drivers/base/platform.c: fix small typo in doc misc doc and kconfig typos Remove obsolete fat_cvf help text Fix occurrences of "the the " Fix minor typoes in kernel/module.c Kconfig: Remove reference to external mqueue library Kconfig: A couple of grammatical fixes in arch/i386/Kconfig Correct comments in genrtc.c to refer to correct /proc file. Fix more "deprecated" spellos. Fix "deprecated" typoes. ... Fix trivial comment conflict in kernel/relay.c.
2007-05-09Use common cpu_is_xxx() macros on AT91 and AVR32Haavard Skinnemoen
Several drivers shared between AT91 and AVR32 chips use cpu_is_xxx() to handle CPU-specific differences. Currently, such code needs to be inside #ifdef CONFIG_ARCH_AT91 because the macros don't exist on AVR32. By defining the same macros on both AT91 and AVR32, these #ifdefs can be eliminated. Since the macros will evaluate to a constant value for CPUs that aren't supported by the current architecture, any code that is only needed on AT91 will be optimized away on AVR32 and vice versa. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: David Brownell <david-b@pacbell.net> Acked-by: Andrew Victor <andrew@sanpeople.com> Cc: Nicolas Ferre <nicolas.ferre@rfo.atmel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09Merge branches 'armv7', 'at91', 'misc' and 'omap' into develRussell King
2007-05-09ARM: OMAP: FB sync with N800 tree (support for dynamic SRAM allocations)Imre Deak
- in addition to fixed FB regions - as passed by the bootloader - allow dynamic allocations - do some more checking against overlapping / reserved regions - move the FB specific parts out from sram.c to fb.c Signed-off-by: Imre Deak <imre.deak@solidboot.com> Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-05-09ARM: OMAP: Sync framebuffer headers with N800 treeKai Svahn
This patch syncs framebuffer headers with N800 tree. Signed-off-by: Kai Svahn <kai.svahn@nokia.com> Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-05-09ARM: OMAP: Fix gpmc headerTony Lindgren
Fix gpmc header Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-05-09ARM: OMAP: Add mailbox support for IVAHiroshi DOYU
This patch adds a generic mailbox interface for for DSP and IVA (Image Video Accelerator). This patch itself doesn't contain any IVA driver. Signed-off-by: Hiroshi DOYU <Hiroshi.DOYU@nokia.com> Signed-off-by: Juha Yrjola <juha.yrjola@solidboot.com> Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-05-09[ARM] armv7: add support for asid-tagged VIVT I-cacheCatalin Marinas
ARMv7 can have VIPT, PIPT or ASID-tagged VIVT I-cache. This patch adds the necessary invalidation of the I-cache when the ASID numbers are re-used. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-05-09include files: convert "include" subdirectory to UTF-8John Anthony Kazos Jr
Convert the "include" subdirectory to UTF-8. Signed-off-by: John Anthony Kazos Jr. <jakj@j-a-k-j.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-05-09fix file specification in commentsUwe Kleine-König
Many files include the filename at the beginning, serveral used a wrong one. Signed-off-by: Uwe Kleine-König <ukleinek@informatik.uni-freiburg.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-05-09Fix occurrences of "the the "Michael Opdenacker
Signed-off-by: Michael Opdenacker <michael@free-electrons.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-05-08[ARM] armv7: add dedicated ARMv7 barrier instructionsCatalin Marinas
Starting with ARMv7, there are dedicated instruction for the ISB, DSB and DMB barriers and there is no need to execute them as CP15 operations. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-05-08[ARM] armv7: Add ARMv7 cacheid macrosCatalin Marinas
This patch renames the old __cacheid_* macros to __cacheid_*_prev7 and adds support for the new format. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-05-08[ARM] armv7: add support for ARMv7 cores.Catalin Marinas
This patch adds support for the ARMv7 cores. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-05-08[ARM] 4363/1: AT91: Remove legacy PIO definitionsAndrew Victor
Remove the legacy PIO pin definitions for the AT91 processors. The standard (and portable between the different AT91 processors) method is to use the AT91_PIN_* defines and the GPIO API. Signed-off-by: Andrew Victor <andrew@sanpeople.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-05-08[ARM] 4361/1: AT91: Build errorAndrew Victor
Fix a build error due to a missing semicolon. Signed-off-by: Andrew Victor <andrew@sanpeople.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-05-08ARM: OMAP: Sync headers with linux-omapTony Lindgren
This patch syncs omap specific headers with linux-omap. Most of the changes needed because of bitrot caused by driver changes in linux-omap tree. Integrating this is needed for adding support for various omap drivers. Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-05-08ARM: OMAP: FB: add controller platform dataImre Deak
Add controller platform data Signed-off-by: Imre Deak <imre.deak@solidboot.com> Signed-off-by: Juha Yrjola <juha.yrjola@solidboot.com> Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-05-08[ARM] Fix ASID version switchRussell King
Close a hole in the ASID version switch, particularly the following scenario: CPU0 MM PID CPU1 MM PID idle A pid(A) A idle(lazy tlb) * new asid version triggered by B * B pid(B) A pid(A) * MM A gets new asid version * A idle(lazy tlb) A pid(A) * CPU1 doesn't see the new ASID * The result is that CPU1 continues running with the hardware set for the original (stale) ASID value, but mm->context.id contains the new ASID value. The result is that the next MM fault on CPU1 updates the page table entries, but flush_tlb_page() fails due to wrong ASID. There is a related case with a threaded application is allocated a new ASID on one CPU while another of its threads is running on some different CPU. This scenario is not fixed by this commit. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-05-08Remove tas()Jeff Dike
tas() has no users, so get rid of it. Signed-off-by: Jeff Dike <jdike@linux.intel.com> Cc: <linux-arch@vger.kernel.org> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08atomic.h: atomic_add_unless as inline. Remove system.h atomic.h circular ↵Mathieu Desnoyers
dependency atomic_add_unless as inline. Remove system.h atomic.h circular dependency. I agree (with Andi Kleen) this typeof is not needed and more error prone. All the original atomic.h code that uses cmpxchg (which includes the atomic_add_unless) uses defines instead of inline functions, probably to circumvent a circular dependency between system.h and atomic.h on powerpc (which my patch addresses). Therefore, it makes sense to use inline functions that will provide type checking. atomic_add_unless as inline. Remove system.h atomic.h circular dependency. Digging into the FRV architecture shows me that it is also affected by such a circular dependency. Here is the diff applying this against the rest of my atomic.h patches. It applies over the atomic.h standardization patches. Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08Clean up mostly unused IOSPACE macrosDavid Gibson
Most architectures defined three macros, MK_IOSPACE_PFN(), GET_IOSPACE() and GET_PFN() in pgtable.h. However, the only callers of any of these macros are in Sparc specific code, either in arch/sparc, arch/sparc64 or drivers/sbus. This patch removes the redundant macros from all architectures except sparc and sparc64. Signed-off-by: David Gibson <david@gibson.dropbear.id.au> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08kdump/kexec: calculate note size at compile timeSimon Horman
Currently the size of the per-cpu region reserved to save crash notes is set by the per-architecture value MAX_NOTE_BYTES. Which in turn is currently set to 1024 on all supported architectures. While testing ia64 I recently discovered that this value is in fact too small. The particular setup I was using actually needs 1172 bytes. This lead to very tedious failure mode where the tail of one elf note would overwrite the head of another if they ended up being alocated sequentially by kmalloc, which was often the case. It seems to me that a far better approach is to caclculate the size that the area needs to be. This patch does just that. If a simpler stop-gap patch for ia64 to be squeezed into 2.6.21(.X) is needed then this should be as easy as making MAX_NOTE_BYTES larger in arch/asm-ia64/kexec.h. Perhaps 2048 would be a good choice. However, I think that the approach in this patch is a much more robust idea. Acked-by: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Simon Horman <horms@verge.net.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08move die notifier handling to common codeChristoph Hellwig
This patch moves the die notifier handling to common code. Previous various architectures had exactly the same code for it. Note that the new code is compiled unconditionally, this should be understood as an appel to the other architecture maintainer to implement support for it aswell (aka sprinkling a notify_die or two in the proper place) arm had a notifiy_die that did something totally different, I renamed it to arm_notify_die as part of the patch and made it static to the file it's declared and used at. avr32 used to pass slightly less information through this interface and I brought it into line with the other architectures. [akpm@linux-foundation.org: build fix] [akpm@linux-foundation.org: fix vmalloc_sync_all bustage] [bryan.wu@analog.com: fix vmalloc_sync_all in nommu] Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: <linux-arch@vger.kernel.org> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Bryan Wu <bryan.wu@analog.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-06Merge branch 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (82 commits) [ARM] Add comments marking in-use ptrace numbers [ARM] Move syscall saving out of the way of utrace [ARM] 4360/1: S3C24XX: regs-udc.h remove unused macro [ARM] 4358/1: S3C24XX: mach-qt2410.c: remove linux/mmc/protocol.h header [ARM] mm 10: allow memory type to be specified with ioremap [ARM] mm 9: add additional device memory types [ARM] mm 8: define mem_types table L1 bit 4 to be for ARMv6 [ARM] iop: add missing parens in macro [ARM] mm 7: remove duplicated __ioremap() prototypes ARM: OMAP: fix OMAP1 mpuio suspend/resume oops ARM: OMAP: MPUIO wake updates ARM: OMAP: speed up gpio irq handling ARM: OMAP: plat-omap changes for 2430 SDP ARM: OMAP: gpio object shrinkage, cleanup ARM: OMAP: /sys/kernel/debug/omap_gpio ARM: OMAP: Implement workaround for GPIO wakeup bug in OMAP2420 silicon ARM: OMAP: Enable 24xx GPIO autoidling [ARM] 4318/2: DSM-G600 Board Support [ARM] 4227/1: minor head.S fixups [ARM] 4328/1: Move i.MX UART regs to driver ...
2007-05-06Merge branch 'ixp4xx' into develRussell King
Conflicts: include/asm-arm/arch-ixp4xx/io.h
2007-05-06Merge branches 'arm-mm', 'at91', 'clkevts', 'imx', 'iop', 'misc', 'netx', ↵Russell King
'ns9xxx', 'omap', 'pxa', 'rpc', 's3c' and 'sa1100' into devel
2007-05-06[ARM] Add comments marking in-use ptrace numbersRussell King
2007-05-06[ARM] Move syscall saving out of the way of utraceRussell King
utrace removes the ptrace_message field in task_struct. Move our use of this field into a new member in thread_info called "syscall" Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-05-05Merge branch 'for-linus' of git://one.firstfloor.org/home/andi/git/linux-2.6Linus Torvalds
* 'for-linus' of git://one.firstfloor.org/home/andi/git/linux-2.6: (231 commits) [PATCH] i386: Don't delete cpu_devs data to identify different x86 types in late_initcall [PATCH] i386: type may be unused [PATCH] i386: Some additional chipset register values validation. [PATCH] i386: Add missing !X86_PAE dependincy to the 2G/2G split. [PATCH] x86-64: Don't exclude asm-offsets.c in Documentation/dontdiff [PATCH] i386: avoid redundant preempt_disable in __unlazy_fpu [PATCH] i386: white space fixes in i387.h [PATCH] i386: Drop noisy e820 debugging printks [PATCH] x86-64: Fix allnoconfig error in genapic_flat.c [PATCH] x86-64: Shut up warnings for vfat compat ioctls on other file systems [PATCH] x86-64: Share identical video.S between i386 and x86-64 [PATCH] x86-64: Remove CONFIG_REORDER [PATCH] x86-64: Print type and size correctly for unknown compat ioctls [PATCH] i386: Remove copy_*_user BUG_ONs for (size < 0) [PATCH] i386: Little cleanups in smpboot.c [PATCH] x86-64: Don't enable NUMA for a single node in K8 NUMA scanning [PATCH] x86: Use RDTSCP for synchronous get_cycles if possible [PATCH] i386: Add X86_FEATURE_RDTSCP [PATCH] i386: Implement X86_FEATURE_SYNC_RDTSC on i386 [PATCH] i386: Implement alternative_io for i386 ... Fix up trivial conflict in include/linux/highmem.h manually. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-05[ARM] 4360/1: S3C24XX: regs-udc.h remove unused macroArnaud Patard
The S3C2410_UDC_SETIX() macro is not used and won't be used by the udc driver, so delete it. Signed-off-by: Arnaud Patard <arnaud.patard@rtp-net.org> Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-05-05[ARM] mm 10: allow memory type to be specified with ioremapRussell King
__ioremap() took a set of page table flags (specifically the cacheable and bufferable bits) to control the mapping type. However, with the advent of ARMv6, this is far too limited. Replace the page table flags with a memory type index, so that the desired attributes can be selected from the mem_type table. Finally, to prevent silent miscompilation due to the differing arguments, rename the __ioremap() and __ioremap_pfn() functions. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-05-05[ARM] mm 9: add additional device memory typesRussell King
Add cached device type for ioremap_cached(). Group all device memory types together, and ensure that they all have a "MT_DEVICE" prefix. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-05-05[ARM] iop: add missing parens in macroRussell King
Fix: drivers/serial/8250.c:1837: warning: suggest parentheses around arithmetic in operand of | due to a macro argument being used without required parenthesis. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-05-05[ARM] mm 7: remove duplicated __ioremap() prototypesRussell King
2007-05-05[ARM] 4318/2: DSM-G600 Board SupportMichael-Luke Jones
This patch adds support for the D-Link DSM-G600 Rev A. This is an ARM XScale IXP4xx system relatively similar to the NSLU2 and NAS-100D already supported by mainline. An important difference is Gigabit Ethernet support using the Via Velocity chipset. This patch is the combined work of Michael Westerhof and Alessandro Zummo, with contributions from Michael-Luke Jones. This version addresses review comments from rmk and Deepak Saxena. Signed-off-by: Michael-Luke Jones <mlj28@cam.ac.uk> Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Michael Westerhof <mwester@dls.net> Signed-off-by: Deepak Saxena <dsaxena@plexity.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-05-04Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/drzeus/mmc * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/drzeus/mmc: (46 commits) mmc-omap: Clean up omap set_ios and make MMC_POWER_ON work mmc-omap: Fix omap to use MMC_POWER_ON mmc-omap: add missing '\n' mmc: make tifm_sd_set_dma_data() static mmc: remove old card states mmc: support unsafe resume of cards mmc: separate out reading EXT_CSD mmc: break apart switch function MMC: Fix handling of low-voltage cards MMC: Consolidate voltage definitions mmc: add bus handler wbsd: check for data opcode earlier mmc: Separate out protocol ops mmc: Move core functions to subdir mmc: deprecate mmc bus topology mmc: remove card upon suspend mmc: allow suspended block driver to be removed mmc: Flush pending detects on host removal mmc: Move host and card drivers to subdirs mmc: Move queue functions to mmc_block ...
master.kernel.org:/pub/scm/linux/kernel/git/dtor/input * 'for-linus' of master.kernel.org:/pub/scm/linux/kernel/git/dtor/input: (65 commits) Input: gpio_keys - add support for switches (EV_SW) Input: cobalt_btns - convert to use polldev library Input: add skeleton for simple polled devices Input: update some documentation Input: wistron - fix typo in keymap for Acer TM610 Input: add input_set_capability() helper Input: i8042 - add Fujitsu touchscreen/touchpad PNP IDs Input: i8042 - add Panasonic CF-29 to nomux list Input: lifebook - split into 2 devices Input: lifebook - add signature of Panasonic CF-29 Input: lifebook - activate 6-byte protocol on select models Input: lifebook - work properly on Panasonic CF-18 Input: cobalt buttons - separate device and driver registration Input: ati_remote - make button repeat sensitivity configurable Input: pxa27x - do not use deprecated SA_INTERRUPT flag Input: ucb1400 - make delays configurable Input: misc devices - switch to using input_dev->dev.parent Input: joysticks - switch to using input_dev->dev.parent Input: touchscreens - switch to using input_dev->dev.parent Input: mice - switch to using input_dev->dev.parent ... Fixed up conflicts with core device model removal of "struct subsystem" manually. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-03[ARM] 4328/1: Move i.MX UART regs to driverSascha Hauer
This patch moves the i.MX UART register descriptions from include/asm-arm/arch-imx/imx-regs.h to the serial driver itself. This helps using the driver on other architectures like mx31 Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-05-03[ARM] 4329/1: fix position of NETX_SYSTEM_REGSascha Hauer
This patch fixes the position of the netx reset control register Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-05-03[ARM] ecard: Convert card type enum to a flagRussell King
'type' in the struct expansion_card is only used to indicate whether this card is an EASI card or not. Therefore, having it as an enum is wasteful (and introduces additional noise when we come to remove the enum.) Convert it to a mere flag instead. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-05-03[ARM] ecard: Move private ecard junk out of asm/ecard.hRussell King
Move ecard.c private junk from asm/ecard.h to a local header file. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-05-03[ARM] 4352/1: AT91: Platform data for LCD and AC97.Andrew Victor
Define resources, platform_device and device registration functions for the LCD and AC97 controllers on the AT91SAM9263. Also update the AT91SAM9261 to use the common atmel_lcdfb driver. Signed-off-by: Nicolas Ferre <nicolas.ferre@rfo.atmel.com> Signed-off-by: Andrew Victor <andrew@sanpeople.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-05-03[ARM] 4350/1: AT91: Hardware header for ADC peripheralAndrew Victor
Definitions for Analog-to-Digital Converter (ADC) found on the Atmel AT91SAM9260 processor. Signed-off-by: Andrew Victor <andrew@sanpeople.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-05-03[ARM] 4342/2: iop13xx: add resource definitions for the tpmi unitsDan Williams
The tpmi units interface with the SAS controller on iop348. Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-05-03[ARM] 4348/4: iop3xx: Give Linux control over PCI initializationDan Williams
Currently the iop3xx platform support code assumes that RedBoot is the bootloader and has already initialized the ATU. Linux should handle this initialization for three reasons: 1/ The memory map that RedBoot sets up is not optimal (page_to_dma and virt_to_phys return different addresses). The effect of this is that using the dma mapping API for the internal bus dma units generates pci bus addresses that are incorrect for the internal bus. 2/ Not all iop platforms use RedBoot 3/ If the ATU is already initialized it indicates that the iop is an add-in card in another host, it does not own the PCI bus, and should not be re-initialized. Changelog: * rather than change nr_controllers to zero, simply do not call pci_common_init Cc: Lennert Buytenhek <kernel@wantstofly.org> Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-05-02PCI: Cleanup the includes of <linux/pci.h>Jean Delvare
I noticed that many source files include <linux/pci.h> while they do not appear to need it. Here is an attempt to clean it all up. In order to find all possibly affected files, I searched for all files including <linux/pci.h> but without any other occurence of "pci" or "PCI". I removed the include statement from all of these, then I compiled an allmodconfig kernel on both i386 and x86_64 and fixed the false positives manually. My tests covered 66% of the affected files, so there could be false positives remaining. Untested files are: arch/alpha/kernel/err_common.c arch/alpha/kernel/err_ev6.c arch/alpha/kernel/err_ev7.c arch/ia64/sn/kernel/huberror.c arch/ia64/sn/kernel/xpnet.c arch/m68knommu/kernel/dma.c arch/mips/lib/iomap.c arch/powerpc/platforms/pseries/ras.c arch/ppc/8260_io/enet.c arch/ppc/8260_io/fcc_enet.c arch/ppc/8xx_io/enet.c arch/ppc/syslib/ppc4xx_sgdma.c arch/sh64/mach-cayman/iomap.c arch/xtensa/kernel/xtensa_ksyms.c arch/xtensa/platform-iss/setup.c drivers/i2c/busses/i2c-at91.c drivers/i2c/busses/i2c-mpc.c drivers/media/video/saa711x.c drivers/misc/hdpuftrs/hdpu_cpustate.c drivers/misc/hdpuftrs/hdpu_nexus.c drivers/net/au1000_eth.c drivers/net/fec_8xx/fec_main.c drivers/net/fec_8xx/fec_mii.c drivers/net/fs_enet/fs_enet-main.c drivers/net/fs_enet/mac-fcc.c drivers/net/fs_enet/mac-fec.c drivers/net/fs_enet/mac-scc.c drivers/net/fs_enet/mii-bitbang.c drivers/net/fs_enet/mii-fec.c drivers/net/ibm_emac/ibm_emac_core.c drivers/net/lasi_82596.c drivers/parisc/hppb.c drivers/sbus/sbus.c drivers/video/g364fb.c drivers/video/platinumfb.c drivers/video/stifb.c drivers/video/valkyriefb.c include/asm-arm/arch-ixp4xx/dma.h sound/oss/au1550_ac97.c I would welcome test reports for these files. I am fine with removing the untested files from the patch if the general opinion is that these changes aren't safe. The tested part would still be nice to have. Note that this patch depends on another header fixup patch I submitted to LKML yesterday: [PATCH] scatterlist.h needs types.h http://lkml.org/lkml/2007/3/01/141 Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-05-02[PATCH] x86: PARAVIRT: add hooks to intercept mm creation and destructionJeremy Fitzhardinge
Add hooks to allow a paravirt implementation to track the lifetime of an mm. Paravirtualization requires three hooks, but only two are needed in common code. They are: arch_dup_mmap, which is called when a new mmap is created at fork arch_exit_mmap, which is called when the last process reference to an mm is dropped, which typically happens on exit and exec. The third hook is activate_mm, which is called from the arch-specific activate_mm() macro/function, and so doesn't need stub versions for other architectures. It's called when an mm is first used. Signed-off-by: Jeremy Fitzhardinge <jeremy@xensource.com> Signed-off-by: Andi Kleen <ak@suse.de> Cc: linux-arch@vger.kernel.org Cc: James Bottomley <James.Bottomley@SteelEye.com> Acked-by: Ingo Molnar <mingo@elte.hu>
2007-05-01mmc: Move OCR bit definesPierre Ossman
All host drivers were #include:ing mmc/protocol.h just to get access to the OCR bit defines. Move these to host.h instead. Signed-off-by: Pierre Ossman <drzeus@drzeus.cx>
