Macros like Fld() or FShft used in regs-lcd.h are defined in bitfield.h, but
the latter is not included.
Also fix one whitespace issue while being there.
Signed-off-by: Antonio Ospite <ao2@openezx.org>
Signed-off-by: Stefan Schmidt <stefan@datenfreihafen.org>
Acked-by: Eric Miao <eric.miao@marvell.com>
The current __raw_write_can_lock macro tests whether the lock can be
locked by checking if it is equal to 0x80000000, whereas the lock
should be lockable if its value is 0 i.e. unlocked state is
represented by 0. Hence the macro should test the value of lock
against 0 and not 0x80000000.
Signed-off-by: Surinder Pal Singh <srplsnh@gmail.com>
PSKTSEL can be routed to GPIO pin 104. This configuration is used by
HP iPAQ hx4700.
Signed-off-by: Philipp Zabel <philipp.zabel@gmail.com>
Acked-by: Jrgen Schindele <linux@schindele.name>
Some additional alternate gpio definitions relating
to FFUART and USB on the pxa27x. These are used on
the xbow imote2 platform.
Signed-off-by: Jonathan Cameron <jic23@cam.ac.uk>
Follow suit from kprobe implementations on other archs and make kretprobe_trampoline non-static. Ftrace implmentation (more specifically, kernel/trace/trace.c) requires access to it (see-> http://kerneltrap.org/mailarchive/linux-kernel/2008/5/27/1955234).
Signed-off-by: Abhishek Sagar <sagar.abhishek@gmail.com>
Remove unnecessary include of asm/io.h.
Signed-off-by: Greg Ungerer <gerg@uclinux.org>
AT91 has one include loop in its header files:
include/asm-arm/io.h <- include/asm-arm/arch-at91/io.h <-
Circular include dependencies are dangerous since they can result in
inconsistent definitions being provided to other code, especially if
'#ifndef' constructs are used.
Solve this by removing the offending includes. Built tested using my
AT91 configuration.
Acked-by: Andrew Victor <linux@maxim.org.za>
OMAP has two include loops in its header files:
asm-arm/hardware.h <- asm-arm/arch-omap/io.h <-
asm-arm/arch-omap/hardware.h <- asm-arm/hardware.h
asm-arm/arch-omap/board-palmte.h <-
asm-arm/arch-omap/hardware.h <- asm-arm/hardware.h <-
asm-arm/arch-omap/gpio.h <- asm-arm/arch-omap/board-palmte.h
Solve these by removing the offending includes, and add additional
includes where necessary.
For the simple read_cpuid() macro case the variable processor_id has
no definition on use of the macro. Add an extern for it. Move all the
processor ID macros into the #ifndef __ASSEMBLEY__ block.
The non-MMU case also needs the type definition of pgtable_t.
So move it out of a CONFIG_MMU conditional section.
arch/arm/plat-omap/clock.c:397: warning: "struct cpufreq_frequency_table" declared inside parameter list
arch/arm/plat-omap/clock.c:397: warning: its scope is only this definition or declaration, which is probably not what you want
arch/arm/plat-omap/clock.c: In function `clk_init_cpufreq_table':
arch/arm/plat-omap/clock.c:402: error: structure has no member named `clk_init_cpufreq_table'
arch/arm/plat-omap/clock.c:403: error: structure has no member named `clk_init_cpufreq_table'
collie.h:
* add some meaningfull names to some gpios
collie.c:
* initialize cpu registers correctly
Signed-off-by: Thomas Kunze <thommycheck@gmx.de>
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6
Parenthesis fix in include/asm-arm/arch-omap/control.h
Signed-off-by: Mariusz Kozlowski <m.kozlowski@tuxland.pl>
Cc: Paul Walmsley <paul@pwsan.com>
Cc: Tony Lindgren <tony@atomide.com>
irqs.h:
* rename IRQ_LOCOMO_SPI_OVRN to IRQ_LOCOMO_SPI_REND
locomo.h:
* add some definition for locomo spi controller
* correct some errors
locomo.c:
* add set_type for locomo gpio irq chip
Add the omap2_set_globals_{242x,243x,343x}() functions. These
functions are called early upon boot in the map_io() functions in the
board-specific init files.
This patch was accidentally left out of the earlier series.
This fixes omap2 booting as noted by Kyungmin Park <kmpark@infradead.org>.
Signed-off-by: Paul Walmsley <paul@pwsan.com>
Cc: Kyungmin Park <kmpark@infradead.org>
Update MMC header from linux-omap tree to match the recent
MMC driver updates.
Related to d3930614e68bdf83a120d904c039a64e9f75dba1.
RCSR is only present on PXA2xx CPUs, not on PXA3xx CPUs. Therefore,
we should not be unconditionally writing to RCSR from generic code.
Since we now clear the RCSR status from the SoC specific PXA PM code
and before reset in the arch_reset() function, the duplication in
the corgi, poodle, spitz and tosa code can be removed.
Acked-by: Richard Purdie <rpurdie@rpsys.net>
Each time a pxa type cpu went in suspend, a portion of
kmalloc memory was corrupted.
The issue was an incorrect length allocation introduced by
the commit 711be5ccfe9a02ba560aa918a008c31ea4760163 for
the save registers array (=> overflow).
Signed-off-by: Robert Jarzmik <rjarzmik@free.fr>
This modifies <asm-arm/types.h> to use the <asm-generic/int-*.h>
generic include files.
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
Cc: Lennert Buytenhek <kernel@wantstofly.org>
Cc: Ben Dooks <ben-linux@fluff.org>
Rename div64_64 to div64_u64 to make it consistent with the other divide
functions, so it clearly includes the type of the divide. Move its definition
to math64.h as currently no architecture overrides the generic implementation.
They can still override it of course, but the duplicated declarations are
avoided.
Signed-off-by: Roman Zippel <zippel@linux-m68k.org>
Cc: Avi Kivity <avi@qumranet.com>
Cc: Jeff Dike <jdike@addtoit.com>
Cc: Patrick McHardy <kaber@trash.net>
Signed-off-by: Daniel Mack <daniel@caiaq.de>
Signed-off-by: Eric Miao <eric.miao@marvell.com>
Cc: "Antonino A. Daplas" <adaplas@pol.net>
Reasons:
1. straight forward: the name "LCD_COLOR_DSTN_16BPP" is much better
than "LCCR0_Pas | LCCR0_Color | LCCR0_Dual"
2. by defining LCD connection types as constants, it allows only
valid possibilities
3. by removing the dependency of register bits definitions, those
can be later moved into the body of pxafb.c, instead of having
a regs-lcd.h around
Currently, only lubbock, mainstone, zylonite and littleton have been
modified to support these types (see coming patches after this).
Other platforms are encouraged to change their way describing the
LCD controller connections.
Signed-off-by: eric miao <eric.miao@marvell.com>
This is part of the effort moving peripheral registers outside of pxa-regs.h,
and using ioremap() make it possible the same IP can be re-used on different
processors with different registers space
As a result, the fixed mapping in pxa_map_io() is removed.
The regs-lcd.h can actually moved to where closer to pxafb.c but some of its
bit definitions are directly used by various platform code, though this is not
a good style.
* master.kernel.org:/home/rmk/linux-2.6-arm: (26 commits)
[ARM] pxa: fix 1c104e0e4f6ab396960c058e95e18bdedcac945b
[ARM] serial: s3c2410: platform_get_irq() may return signed unnoticed
[ARM] am79c961a: platform_get_irq() may return signed unnoticed
[ARM] Feroceon: Feroceon-specific WA-cache compatible {copy,clear}_user_page()
[ARM] Feroceon: fix function alignment in proc-feroceon.S
[ARM] Orion: catch a couple more alternative spellings of PCIe
[ARM] Orion: fix orion-ehci platform resource end addresses
[ARM] Orion: fix ->map_irq() PCIe bus number check
[ARM] Orion: fix ioremap() optimization
[ARM] feroceon: remove CONFIG_CPU_CACHE_ROUND_ROBIN check
[ARM] feroceon: remove CONFIG_CPU_DCACHE_WRITETHROUGH check
kprobes/arm: fix decoding of arithmetic immediate instructions
kprobes/arm: fix cache flush address for instruction stub
[ARM] 5022/1: Race in ARM MMCI PL18x driver, V2
[ARM] 5021/1: at91: buildfix for sam9263 + PM
[ARM] 5018/1: RealView: Fix the ARM11MPCore Oprofile compilation
[ARM] 5016/1: AT91: typo in mci configuration for at91cap at91sam9263
[ARM] 5017/1: pxa3xx: Report unsupported wakeup sources in pxa3xx_set_wake()
[ARM] 5020/1: magician: remove __devinit marker from pasic3_leds_info
[ARM] 5014/1: Cleanup reset state before entering suspend or resetting.
Unaligned access is ok for the following arches:
cris, m68k, mn10300, powerpc, s390, x86
Arches that use the memmove implementation for native endian, and
the byteshifting for the opposite endianness.
h8300, m32r, xtensa
Packed struct for native endian, byteshifting for other endian:
alpha, blackfin, ia64, parisc, sparc, sparc64, mips, sh
m86knommu is generic_be for Coldfire, otherwise unaligned access is ok.
frv, arm chooses endianness based on compiler settings, uses the byteshifting
versions. Remove the unaligned trap handler from frv as it is now unused.
v850 is le, uses the byteshifting versions for both be and le.
Remove the now unused asm-generic implementation.
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
Cc: <linux-arch@vger.kernel.org>
This patch implements a set of Feroceon-specific
{copy,clear}_user_page() routines that perform more optimally than
the generic implementations. This also deals with write-allocate
caches (Feroceon can run L1 D in WA mode) which otherwise prevents
Linux from booting.
[nico: optimized the code even further]
Signed-off-by: Lennert Buytenhek <buytenh@marvell.com>
Tested-by: Sylver Bruneau <sylver.bruneau@googlemail.com>
Tested-by: Martin Michlmayr <tbm@cyrius.com>
Signed-off-by: Nicolas Pitre <nico@marvell.com>
The ioremap() optimization used for internal register didn't cope
with the fact that paddr + size can wrap to zero if the area extends
to the end of the physical address space.
Issue isolated by Sylver Bruneau <sylver.bruneau@googlemail.com>.
s390 for one, cannot implement VM_MIXEDMAP with pfn_valid, due to their memory
model (which is more dynamic than most). Instead, they had proposed to
implement it with an additional path through vm_normal_page(), using a bit in
the pte to determine whether or not the page should be refcounted:
vm_normal_page()
if (unlikely(vma->vm_flags & (VM_PFNMAP|VM_MIXEDMAP))) {
if (vma->vm_flags & VM_MIXEDMAP) {
#ifdef s390
if (!mixedmap_refcount_pte(pte))
return NULL;
#else
if (!pfn_valid(pfn))
return NULL;
#endif
goto out;
This is fine, however if we are allowed to use a bit in the pte to determine
refcountedness, we can use that to _completely_ replace all the vma based
schemes. So instead of adding more cases to the already complex vma-based
scheme, we can have a clearly seperate and simple pte-based scheme (and get
slightly better code generation in the process):
vm_normal_page()
#ifdef s390
return NULL;
return pte_page(pte);
#else
#endif
And finally, we may rather make this concept usable by any architecture rather
than making it s390 only, so implement a new type of pte state for this.
Unfortunately the old vma based code must stay, because some architectures may
not be able to spare pte bits. This makes vm_normal_page a little bit more
ugly than we would like, but the 2 cases are clearly seperate.
So introduce a pte_special pte state, and use it in mm/memory.c. It is
currently a noop for all architectures, so this doesn't actually result in any
compiled code changes to mm/memory.o.
BTW:
I haven't put vm_normal_page() into arch code as-per an earlier suggestion.
The reason is that, regardless of where vm_normal_page is actually
implemented, the *abstraction* is still exactly the same. Also, while it
depends on whether the architecture has pte_special or not, that is the
only two possible cases, and it really isn't an arch specific function --
the role of the arch code should be to provide primitive functions and
accessors with which to build the core code; pte_special does that. We do
not want architectures to know or care about vm_normal_page itself, and
we definitely don't want them being able to invent something new there
out of sight of mm/ code. If we made vm_normal_page an arch function, then
we have to make vm_insert_mixed (next patch) an arch function too. So I
don't think moving it to arch code fundamentally improves any abstractions,
while it does practically make the code more difficult to follow, for both
mm and arch developers, and easier to misuse.
[akpm@linux-foundation.org: build fix]
Signed-off-by: Nick Piggin <npiggin@suse.de>
Acked-by: Carsten Otte <cotte@de.ibm.com>
Cc: Jared Hulbert <jaredeh@gmail.com>
* Add struct ide_io_ports and use it instead of `unsigned long io_ports[]`
in ide_hwif_t.
* Rename io_ports[] in hw_regs_t to io_ports_array[].
* Use un-named union for 'unsigned long io_ports_array[]' and 'struct
ide_io_ports io_ports' in hw_regs_t.
* Remove IDE_*_OFFSET defines.
v2:
* scc_pata.c build fix from Stephen Rothwell.
v3:
* Fix ctl_adrr typo in Sparc-specific part of ns87415.c.
(Noticed by Andrew Morton)
Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
The kernel should clean stale bits from reset status, so that
they won't confuse the bootloader.
Signed-off-by: Dmitry Baryshkov <dbaryshkov@gmail.com>
The patch kills the use of IRQ_GPIO() and adds
#if NR_IRQS < (IT8152_LAST_IRQ+1) statement.
Signed-off-by: Mike Rapoport <mike@compulab.co.il>
Add support to disable ECC checking for a given chip
when passed by the board via the platform data.
Signed-off-by: Ben Dooks <ben-linux@fluff.org>
Add support for the ECC layout to be passed via the
platform data specified by the board.
If a block's ecc field is all 0xff, then ignore the ECC
correction. This is for systems where some of the blocks,
such as the initial cramfs are written without ECC and
need to be loaded on start.
This is preliminary since:
1. It supports only _one_ chip select at the moment. As there is no
existing platforms available using two chip selects of the NAND
controller, it shall really not include code for supporting the
2nd chip select for now, as such code cannot be verified.
2. It resorts to the default and simpliest memory based badblock
table
3. Only limited types of nand flash are currently supported. Most
PXA3xx processors come with on-chip NAND flash dies, so there
isn't much flexibility for other types of NAND.
4. The NAND controller should be configured to detect the device's
ID, thus making it difficult to use nand_scan_ident() to assist
the detection process (though it's not impossible)
TODO: fix all the above limitations of cuz :-)
Cc: Sergey Podstavin <spodstavin@ru.mvista.com>
git://git.kernel.org/pub/scm/linux/kernel/git/drzeus/mmc
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/drzeus/mmc: (26 commits)
mmc: sdio_ops.c should #include "sdio_ops.h"
mmc: proper prototypes for mmc_attach_*()
mmc: make __mmc_release_bus() static
sdhci: improve no card, no reset quirk
MMC: OMAP: Do not busy wait for end of command for ever
MMC: OMAP: Start new commands from work queue instead of irq
MMC: OMAP: Lazy clock shutdown
MMC: OMAP: Move failing command abortion to workqueue
MMC: OMAP: Use tasklet instead of workqueue for cover switch notification
MMC: OMAP: Check the get_cover_state function pointer if not set
MMC: OMAP: Using setup_timer instead of init_timer
MMC: OMAP: Abort stuck commands
MMC: OMAP: General cleanup for MMC multislot support
MMC: OMAP: Power functions modified to MMC multislot support
MMC: OMAP: Fix timeout calculation for MMC multislot support
MMC: OMAP: New release dma and abort xfer functions
MMC: OMAP: Add back cover switch support
MMC: OMAP: Introduce new multislot structure and change driver to use it
MMC: OMAP: Remove cover switch handling to allow adding multislot support
MMC: OMAP: Fix the BYTEBLOCK capability removal
git://git.kernel.org/pub/scm/linux/kernel/git/juhl/trivial
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/juhl/trivial: (24 commits)
DOC: A couple corrections and clarifications in USB doc.
Generate a slightly more informative error msg for bad HZ
fix typo "is" -> "if" in Makefile
ext*: spelling fix prefered -> preferred
DOCUMENTATION: Use newer DEFINE_SPINLOCK macro in docs.
KEYS: Fix the comment to match the file name in rxrpc-type.h.
RAID: remove trailing space from printk line
DMA engine: typo fixes
Remove unused MAX_NODES_SHIFT
MAINTAINERS: Clarify access to OCFS2 development mailing list.
V4L: Storage class should be before const qualifier (sn9c102)
sonypi: Storage class should be before const qualifier
intel_menlow: Storage class should be before const qualifier
DVB: Storage class should be before const qualifier
arm: Storage class should be before const qualifier
ALSA: Storage class should be before const qualifier
acpi: Storage class should be before const qualifier
firmware_sample_driver.c: fix coding style
MAINTAINERS: Add ati_remote2 driver
Fixed up trivial conflicts in firmware_sample_driver.c
The C99 specification states in section 6.11.5:
The placement of a storage-class specifier other than at the
beginning of the declaration specifiers in a declaration is an
obsolescent feature.
Signed-off-by: Tobias Klauser <tklauser@distanz.ch>
Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com>
Alternate function and direction setting is now handled
by the MFP config code or the generic GPIO API.
'ns9x', 'orion', 'pxa', 'sa1100', 's3c' and 'sparsemem' into devel
This patch adds a driver for the Quick Capture Interface on the PXA270.
It is based on the original driver from Intel, but has been re-worked
multiple times since then, now it also supports the V4L2 API.
Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@pengutronix.de>
Adds support for the generic GPIO lib to the EP93xx family. The gpio
handling code has been moved from core.c to a new file called gpio.c.
The GPIO based IRQ code has not been changed.
Signed-off-by: Ryan Mallon <ryan@bluewatersys.com>
