path: root/include/asm-blackfin/io.h
2008-05-17Blackfin arch: IO Port functions to read/write unalligned memoryMichael Hennerich
Signed-off-by: Michael Hennerich <michael.hennerich@analog.com> Signed-off-by: Bryan Wu <cooloney@kernel.org>
2008-02-06remove mm_{ptov,vtop}()Adrian Bunk
This patch removes the unused mm_{ptov,vtop}(). Signed-off-by: Adrian Bunk <bunk@kernel.org> Acked-by: Greg Ungerer <gerg@uclinux.org> Acked-by: Bryan Wu <bryan.wu@analog.com> Cc: Miles Bader <miles.bader@necel.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-11-17Blackfin arch: Add assembly function insl_16Michael Hennerich
/* * CPUs often take a performance hit when accessing unaligned memory * locations. The actual performance hit varies, it can be small if the * hardware handles it or large if we have to take an exception and fix * it * in software. * * Since an ethernet header is 14 bytes network drivers often end up * with * the IP header at an unaligned offset. The IP header can be aligned by * shifting the start of the packet by 2 bytes. Drivers should do this * with: * * skb_reserve(NET_IP_ALIGN); * * The downside to this alignment of the IP header is that the DMA is * now * unaligned. On some architectures the cost of an unaligned DMA is high * and this cost outweighs the gains made by aligning the IP header. * * Since this trade off varies between architectures, we allow * NET_IP_ALIGN * to be overridden. */ This new function insl_16 allows to read form 32-bit IO and writes to 16-bit aligned memory. This is useful in above described scenario - In particular with the AXIS AX88180 Gigabit Ethernet MAC. Once the device is in 32-bit mode, reads from the RX FIFO always decrements 4bytes. While on the other side the destination address in SDRAM is always 16-bit aligned. If we use skb_reserve(0) the receive buffer is 32-bit aligned but later we hit a unaligned exception in the IP code. Signed-off-by: Michael Hennerich <michael.hennerich@analog.com> Signed-off-by: Bryan Wu <bryan.wu@analog.com>
2007-10-17Remove dma_cache_(wback|inv|wback_inv) functionsRalf Baechle
dma_cache_(wback|inv|wback_inv) were the earliest attempt on a generalized cache managment API for I/O purposes. Originally it was basically the raw MIPS low level cache API exported to the entire world. The API has suffered from a lack of documentation, was not very widely used unlike it's more modern brothers and can easily be replaced by dma_cache_sync. So remove it rsp. turn the surviving bits back into an arch private API, as discussed on linux-arch. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Acked-by: Paul Mundt <lethal@linux-sh.org> Acked-by: Paul Mackerras <paulus@samba.org> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Kyle McMartin <kyle@parisc-linux.org> Acked-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-09Blackfin arch: modify the insX/outsX and dma_insX/dma_outsX to be compatible ↵Bryan Wu
with other archs Signed-off-by: Bryan Wu <bryan.wu@analog.com>
2007-09-12Blackfin arch: cleanup IO and DMA_IO API function definitions according to ↵Bryan Wu
other arches Signed-off-by: Bryan Wu <bryan.wu@analog.com>
2007-06-21Blackfin arch: add proper const volatile to addr argument to the read functionsMike Frysinger
Signed-off-by: Mike Frysinger <michael.frysinger@analog.com> Signed-off-by: Bryan Wu <bryan.wu@analog.com>
2007-05-21Blackfin arch: DMA operation cleanupMichael Hennerich
1) Disable Interrupts during DMA memcpy to avoid raise conditions. 2) Mark MDMA channel 0 as reserved, since were using it internally. 3) Add DMA based equivalents for insX and outsX. 4) Our insX and outsX only handles len <= 2^16. Signed-off-by: Michael Hennerich <michael.hennerich@analog.com> Signed-off-by: Bryan Wu <bryan.wu@analog.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07blackfin architectureBryan Wu
This adds support for the Analog Devices Blackfin processor architecture, and currently supports the BF533, BF532, BF531, BF537, BF536, BF534, and BF561 (Dual Core) devices, with a variety of development platforms including those avaliable from Analog Devices (BF533-EZKit, BF533-STAMP, BF537-STAMP, BF561-EZKIT), and Bluetechnix! Tinyboards. The Blackfin architecture was jointly developed by Intel and Analog Devices Inc. (ADI) as the Micro Signal Architecture (MSA) core and introduced it in December of 2000. Since then ADI has put this core into its Blackfin processor family of devices. The Blackfin core has the advantages of a clean, orthogonal,RISC-like microprocessor instruction set. It combines a dual-MAC (Multiply/Accumulate), state-of-the-art signal processing engine and single-instruction, multiple-data (SIMD) multimedia capabilities into a single instruction-set architecture. The Blackfin architecture, including the instruction set, is described by the ADSP-BF53x/BF56x Blackfin Processor Programming Reference http://blackfin.uclinux.org/gf/download/frsrelease/29/2549/Blackfin_PRM.pdf The Blackfin processor is already supported by major releases of gcc, and there are binary and source rpms/tarballs for many architectures at: http://blackfin.uclinux.org/gf/project/toolchain/frs There is complete documentation, including "getting started" guides available at: http://docs.blackfin.uclinux.org/ which provides links to the sources and patches you will need in order to set up a cross-compiling environment for bfin-linux-uclibc This patch, as well as the other patches (toolchain, distribution, uClibc) are actively supported by Analog Devices Inc, at: http://blackfin.uclinux.org/ We have tested this on LTP, and our test plan (including pass/fails) can be found at: http://docs.blackfin.uclinux.org/doku.php?id=testing_the_linux_kernel [m.kozlowski@tuxland.pl: balance parenthesis in blackfin header files] Signed-off-by: Bryan Wu <bryan.wu@analog.com> Signed-off-by: Mariusz Kozlowski <m.kozlowski@tuxland.pl> Signed-off-by: Aubrey Li <aubrey.li@analog.com> Signed-off-by: Jie Zhang <jie.zhang@analog.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
