path: root/include/asm-blackfin/mach-bf527/bfin_serial_5xx.h
2008-08-27Blackfin arch: move include/asm-blackfin header files to arch/blackfinBryan Wu
Signed-off-by: Bryan Wu <cooloney@kernel.org>
2008-06-19Blackfin Serial Driver: Use timer to poll CTS PIN instead of workqueue.Sonic Zhang
This allows other threads to run when the serial driver polls the CTS PIN in a loop. Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Bryan Wu <cooloney@kernel.org>
2008-06-03Blackfin Serial Driver: Clean up BF54x macro in blackfin UART driver.Sonic Zhang
Hide difference in head file. Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Bryan Wu <cooloney@kernel.org>
2008-05-07Blackfin Serial Driver: abstract away DLAB differences into headerMike Frysinger
Signed-off-by: Mike Frysinger <vapier.adi@gmail.com> Signed-off-by: Bryan Wu <cooloney@kernel.org>
2008-05-07Blackfin Serial Driver: macro away the IER differences between processorsMike Frysinger
2008-04-25[Blackfin] arch: add Blackfin on-chip SIR IrDA driver supportGraf Yang
- add platform device resources in board files - add new bfin_sir.h to each machines Signed-off-by: Graf Yang <graf.yang@analog.com> Signed-off-by: Bryan Wu <cooloney@kernel.org>
2008-02-02[Blackfin] serial driver: Fix bug Poll RTS/CTS status in DMA mode as wellSonic Zhang
https://blackfin.uclinux.org/gf/project/uclinux-dist/tracker/?action=TrackerItemEdit&tracker_item_id=3858 Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Bryan Wu <bryan.wu@analog.com>
2007-12-24[Blackfin] serial driver: fix bug - cache the bits of the LSR on systems ↵Mike Frysinger
where the LSR is read-to-clear Cache the bits of the LSR on systems where the LSR is read-to-clear so that we can safely read the LSR in random places. this fixes older parts where break/framing/parity/overflow was not being detected at all in PIO mode, and this fixes newer parts where break/framing/parity/overflow was being reported all the time without being cleared. Signed-off-by: Mike Frysinger <michael.frysinger@analog.com> Signed-off-by: Bryan Wu <bryan.wu@analog.com>
2008-01-22[Blackfin] arch: Fix BUG gpio_direction_output API is not compatitable with ↵Michael Hennerich
GENERIC_GPIO API interface signef-off-by: Michael Hennerich <michael.hennerich@analog.com> Signed-off-by: Bryan Wu <bryan.wu@analog.com>
2007-10-21Blackfin arch: add new processor ADSP-BF52x arch/mach supportMichael Hennerich
Signed-off-by: Michael Hennerich <michael.hennerich@analog.com> Signed-off-by: Bryan Wu <bryan.wu@analog.com>
