path: root/include/asm-blackfin/mach-bf533/bf533.h
2007-08-05Blackfin arch: fix up header for BF533Robin Getz
Signed-off-by: Robin Getz <robin.getz@analog.com> Signed-off-by: Bryan Wu <bryan.wu@analog.com>
2007-10-10Blackfin arch: to do some consolidation of common code and common name spacesRobin Getz
now all BLKFIN should be BFIN, should be no functional changes. Signed-off-by: Robin Getz <robin.getz@analog.com> Signed-off-by: Bryan Wu <bryan.wu@analog.com>
2007-08-03Blackfin arch: Fix CCLK and SCLK checksRobin Getz
Fix CCLK and SCLK checks, combine all arch checks into one file for maintance. Checkins that remove more lines than they add are always good. Signed-off-by: Robin Getz <robin.getz@analog.com> Signed-off-by: Bryan Wu <bryan.wu@analog.com>
2007-07-25Blackfin arch: revise anomaly handling by basing things on the compiler not ↵Mike Frysinger
the kconfig defines revise anomaly handling by basing things on the compiler not the kconfig defines, so the header is stable and usable outside of the kernel. This also allows us to move some code from preprocessing to compiling (gcc culls dead code) which should help with code quality (readability, catch minor bugs, etc...). Signed-off-by: Mike Frysinger <michael.frysinger@analog.com> Signed-off-by: Bryan Wu <bryan.wu@analog.com>
2007-05-07blackfin architectureBryan Wu
This adds support for the Analog Devices Blackfin processor architecture, and currently supports the BF533, BF532, BF531, BF537, BF536, BF534, and BF561 (Dual Core) devices, with a variety of development platforms including those avaliable from Analog Devices (BF533-EZKit, BF533-STAMP, BF537-STAMP, BF561-EZKIT), and Bluetechnix! Tinyboards. The Blackfin architecture was jointly developed by Intel and Analog Devices Inc. (ADI) as the Micro Signal Architecture (MSA) core and introduced it in December of 2000. Since then ADI has put this core into its Blackfin processor family of devices. The Blackfin core has the advantages of a clean, orthogonal,RISC-like microprocessor instruction set. It combines a dual-MAC (Multiply/Accumulate), state-of-the-art signal processing engine and single-instruction, multiple-data (SIMD) multimedia capabilities into a single instruction-set architecture. The Blackfin architecture, including the instruction set, is described by the ADSP-BF53x/BF56x Blackfin Processor Programming Reference http://blackfin.uclinux.org/gf/download/frsrelease/29/2549/Blackfin_PRM.pdf The Blackfin processor is already supported by major releases of gcc, and there are binary and source rpms/tarballs for many architectures at: http://blackfin.uclinux.org/gf/project/toolchain/frs There is complete documentation, including "getting started" guides available at: http://docs.blackfin.uclinux.org/ which provides links to the sources and patches you will need in order to set up a cross-compiling environment for bfin-linux-uclibc This patch, as well as the other patches (toolchain, distribution, uClibc) are actively supported by Analog Devices Inc, at: http://blackfin.uclinux.org/ We have tested this on LTP, and our test plan (including pass/fails) can be found at: http://docs.blackfin.uclinux.org/doku.php?id=testing_the_linux_kernel [m.kozlowski@tuxland.pl: balance parenthesis in blackfin header files] Signed-off-by: Bryan Wu <bryan.wu@analog.com> Signed-off-by: Mariusz Kozlowski <m.kozlowski@tuxland.pl> Signed-off-by: Aubrey Li <aubrey.li@analog.com> Signed-off-by: Jie Zhang <jie.zhang@analog.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
