path: root/include/asm-blackfin/mach-bf533/cdefBF532.h
2008-04-24[Blackfin] arch: Prevent potential Core Hang situationMichael Hennerich
If the new value written to the PLL_CTL or VR_CTL register is the same as the previous value, the PLL wake-up will occur immediately (PLL is already locked), but the core and system clock will be bypassed for the PLL_LOCKCNT duration. For this interval, code will execute at the CLKIN rate instead of at the expected CCLK rate. Software should guard against this condition by comparing the current value to the new value before writing the new value. Signed-off-by: Michael Hennerich <michael.hennerich@analog.com> Signed-off-by: Bryan Wu <cooloney@kernel.org>
2007-09-12Blackfin arch: Add ANOMALY_05000311 Workaround - for those who doesnt use ↵Michael Hennerich
the generic GPIO driver Signed-off-by: Michael Hennerich <michael.hennerich@analog.com> Signed-off-by: Bryan Wu <bryan.wu@analog.com>
2007-07-25Blackfin arch: reorganize headers slightly so we can be sure things are ↵Mike Frysinger
defined early enough Signed-off-by: Mike Frysinger <michael.frysinger@analog.com> Signed-off-by: Bryan Wu <bryan.wu@analog.com>
2007-07-25Blackfin arch: use the [CS]SYNC() macros which include anomaly workarounds ↵Mike Frysinger
rather than __builtin_bfin_[cs]sync() Signed-off-by: Mike Frysinger <michael.frysinger@analog.com> Signed-off-by: Bryan Wu <bryan.wu@analog.com>
2007-05-21Blackfin arch: update blackfin header files to latest one in VDSP.Bryan Wu
a) add new processor BF52x/BF54x header files b) update blackfin BF533/BF537/BF561 header files to latest one in VDSP. c) scrub watchdog/rtc masks from headers as we dont need/want them (too generic and the drivers dont use them) Signed-off-by: Mike Frysinger <michael.frysinger@analog.com> Signed-off-by: Roy Huang <roy.huang@analog.com> Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Bryan Wu <bryan.wu@analog.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-21Blackfin arch: Move write to VR_CTL closer to IDLEMichael Hennerich
Signed-off-by: Michael Hennerich <michael.hennerich@analog.com> Signed-off-by: Bryan Wu <bryan.wu@analog.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07blackfin architectureBryan Wu
This adds support for the Analog Devices Blackfin processor architecture, and currently supports the BF533, BF532, BF531, BF537, BF536, BF534, and BF561 (Dual Core) devices, with a variety of development platforms including those avaliable from Analog Devices (BF533-EZKit, BF533-STAMP, BF537-STAMP, BF561-EZKIT), and Bluetechnix! Tinyboards. The Blackfin architecture was jointly developed by Intel and Analog Devices Inc. (ADI) as the Micro Signal Architecture (MSA) core and introduced it in December of 2000. Since then ADI has put this core into its Blackfin processor family of devices. The Blackfin core has the advantages of a clean, orthogonal,RISC-like microprocessor instruction set. It combines a dual-MAC (Multiply/Accumulate), state-of-the-art signal processing engine and single-instruction, multiple-data (SIMD) multimedia capabilities into a single instruction-set architecture. The Blackfin architecture, including the instruction set, is described by the ADSP-BF53x/BF56x Blackfin Processor Programming Reference http://blackfin.uclinux.org/gf/download/frsrelease/29/2549/Blackfin_PRM.pdf The Blackfin processor is already supported by major releases of gcc, and there are binary and source rpms/tarballs for many architectures at: http://blackfin.uclinux.org/gf/project/toolchain/frs There is complete documentation, including "getting started" guides available at: http://docs.blackfin.uclinux.org/ which provides links to the sources and patches you will need in order to set up a cross-compiling environment for bfin-linux-uclibc This patch, as well as the other patches (toolchain, distribution, uClibc) are actively supported by Analog Devices Inc, at: http://blackfin.uclinux.org/ We have tested this on LTP, and our test plan (including pass/fails) can be found at: http://docs.blackfin.uclinux.org/doku.php?id=testing_the_linux_kernel [m.kozlowski@tuxland.pl: balance parenthesis in blackfin header files] Signed-off-by: Bryan Wu <bryan.wu@analog.com> Signed-off-by: Mariusz Kozlowski <m.kozlowski@tuxland.pl> Signed-off-by: Aubrey Li <aubrey.li@analog.com> Signed-off-by: Jie Zhang <jie.zhang@analog.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
