path: root/include/asm-frv/page.h
2008-02-08CONFIG_HIGHPTE vs. sub-page page tables.Martin Schwidefsky
Background: I've implemented 1K/2K page tables for s390. These sub-page page tables are required to properly support the s390 virtualization instruction with KVM. The SIE instruction requires that the page tables have 256 page table entries (pte) followed by 256 page status table entries (pgste). The pgstes are only required if the process is using the SIE instruction. The pgstes are updated by the hardware and by the hypervisor for a number of reasons, one of them is dirty and reference bit tracking. To avoid wasting memory the standard pte table allocation should return 1K/2K (31/64 bit) and 2K/4K if the process is using SIE. Problem: Page size on s390 is 4K, page table size is 1K or 2K. That means the s390 version for pte_alloc_one cannot return a pointer to a struct page. Trouble is that with the CONFIG_HIGHPTE feature on x86 pte_alloc_one cannot return a pointer to a pte either, since that would require more than 32 bit for the return value of pte_alloc_one (and the pte * would not be accessible since its not kmapped). Solution: The only solution I found to this dilemma is a new typedef: a pgtable_t. For s390 pgtable_t will be a (pte *) - to be introduced with a later patch. For everybody else it will be a (struct page *). The additional problem with the initialization of the ptl lock and the NR_PAGETABLE accounting is solved with a constructor pgtable_page_ctor and a destructor pgtable_page_dtor. The page table allocation and free functions need to call these two whenever a page table page is allocated or freed. pmd_populate will get a pgtable_t instead of a struct page pointer. To get the pgtable_t back from a pmd entry that has been installed with pmd_populate a new function pmd_pgtable is added. It replaces the pmd_page call in free_pte_range and apply_to_pte_range. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07Cleanup asm/{elf,page,user}.h: #ifdef __KERNEL__ is no longer neededKirill A. Shutemov
asm/elf.h, asm/page.h and asm/user.h don't export to userspace now, so we can drop #ifdef __KERNEL__ for them. [k.shutemov@gmail.com: remove #ifdef __KERNEL_] Signed-off-by: Kirill A. Shutemov <k.shutemov@gmail.com> Reviewed-by: David Woodhouse <dwmw2@infradead.org> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Kirill A. Shutemov <k.shutemov@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05frv: remove dead config symbol from FRV codeJiri Olsa
Remove dead config symbol from FRV code. Signed-off-by: Jiri Olsa <olsajiri@gmail.com> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-01[PATCH] fix frv headers_checkAl Viro
a) registers.h is really needed there b) include of asm-generic/termios should be under __KERNEL__ c) includes of asm-generic/{memory_model,page} should be under __KERNEL (nothing in there that would work in userland) d) a lot of stuff in ptrace.h should be under __KERNEL__. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-04-26Don't include linux/config.h from anywhere else in include/David Woodhouse
2006-03-27[PATCH] unify pfn_to_page: FRV pfn_to_pageKAMEZAWA Hiroyuki
FRV can use generic funcs. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-28[PATCH] FRV: Make the FRV arch work againDavid Howells
The attached patch implements a bunch of small changes to the FRV arch to make it work again. It deals with the following problems: (1) SEM_DEBUG should be SEMAPHORE_DEBUG. (2) The argument list to pcibios_penalize_isa_irq() has changed. (3) CONFIG_HIGHMEM can't be used directly in #if as it may not be defined. (4) page->private is no longer directly accessible. (5) linux/hardirq.h assumes asm/hardirq.h will include linux/irq.h (6) The IDE MMIO access functions are given pointers, not integers, and so get type casting errors. (7) __pa() is passed an explicit u64 type in drivers/char/mem.c, but that can't be cast directly to a pointer on a 32-bit platform. (8) SEMAPHORE_DEBUG should not be contingent on WAITQUEUE_DEBUG as that no longer exists. (9) PREEMPT_ACTIVE is too low a value. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] mm: consolidate get_orderStephen Rothwell
Someone mentioned that almost all the architectures used basically the same implementation of get_order. This patch consolidates them into asm-generic/page.h and includes that in the appropriate places. The exceptions are ia64 and ppc which have their own (presumably optimised) versions. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
