path: root/include/asm-frv/scatterlist.h
2008-02-05FRV: move DMA macros to scatterlist.h for consistency.Robert P. J. Day
To be consistent with other architectures, these two DMA macros should be defined in scatterlist.h as opposed to dma-mapping.h Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-24SG: Change sg_set_page() to take length and offset argumentJens Axboe
Most drivers need to set length and offset as well, so may as well fold those three lines into one. Add sg_assign_page() for those two locations that only needed to set the page, where the offset/length is set outside of the function context. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-10-23frv: update comment in scatterlist to reflect new setupJens Axboe
2007-10-22Add CONFIG_DEBUG_SG sg validationJens Axboe
Add a Kconfig entry which will toggle some sanity checks on the sg entry and tables. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-10-22Change table chaining layoutJens Axboe
Change the page member of the scatterlist structure to be an unsigned long, and encode more stuff in the lower bits: - Bits 0 and 1 zero: this is a normal sg entry. Next sg entry is located at sg + 1. - Bit 0 set: this is a chain entry, the next real entry is at ->page_link with the two low bits masked off. - Bit 1 set: this is the final entry in the sg entry. sg_next() will return NULL when passed such an entry. It's thus important that sg table users use the proper accessors to get and set the page member. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-05-02PCI: scatterlist.h needs types.hJean Delvare
Most architectures' scatterlist.h use the type dma_addr_t, but omit to include <asm/types.h> which defines it. This could lead to build failures, so let's add the missing includes. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
