path: root/include/asm-frv/system.h
2009-04-10FRV: Move to arch/frv/include/asm/David Howells
Move arch headers from include/asm-frv/ to arch/frv/include/asm/. Signed-off-by: David Howells <dhowells@redhat.com>
2008-07-12frv: fix irqs_disabled() to return an int, not an unsigned longDavid Howells
Fix FRV irqs_disabled() to return an int, not an unsigned long to avoid this warning: kernel/sched.c: In function '__might_sleep': kernel/sched.c:8198: warning: format '%d' expects type 'int', but argument 3 has type 'long unsigned int' Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-14read_barrier_depends arch fixletsNick Piggin
read_barrie_depends has always been a noop (not a compiler barrier) on all architectures except SMP alpha. This brings UP alpha and frv into line with all other architectures, and fixes incorrect documentation. Signed-off-by: Nick Piggin <npiggin@suse.de> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-21frv: remove HARD_RESET_NOW()Adrian Bunk
HARD_RESET_NOW() was unused. And one of the few remaining cli() users. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-10FRV: Don't make smp_{r, w, }mb() interpolate MEMBAR when CONFIG_SMP=n [try #2]David Howells
Don't make smp_{r,w,}mb() interpolate a MEMBAR instruction when CONFIG_SMP=n as SMP memory barries on UP systems should interpolate a compiler barrier only. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-30NULL noise: frv cmpxchg()Al Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Acked-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08Fix FRV cmpxchg_localMathieu Desnoyers
Fix the FRV cmpxchg_local by breaking the following header dependency loop : linux/kernel.h -> linux/bitops.h -> asm-frv/bitops.h -> asm-frv/atomic.h -> asm-frv/system.h -> asm-generic/cmpxchg_local.h -> typecheck() defined in linux/kernel.h and linux/kernel.h -> linux/bitops.h -> asm-frv/bitops.h -> asm-frv/atomic.h -> asm-generic/cmpxchg_local.h -> typecheck() defined in linux/kernel.h In order to fix this : - Move the atomic_test_and_ *_mask inlines from asm-frv/atomic.h (why are they there at all anyway ? They are not touching atomic_t variables!) to asm-frv/bitops.h. Also fix a build issue with cmpxchg : it does not cast to (unsigned long *) like other architectures, to deal with it in the cmpxchg_local macro. FRV builds fine with this patch. Thanks to Adrian Bunk <bunk@kernel.org> for spotting this bug. Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Cc: Adrian Bunk <bunk@kernel.org> Cc: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07Add cmpxchg_local to frvMathieu Desnoyers
Use the new generic cmpxchg_local (disables interrupt) for 8, 16 and 64 bits arguments. Use the 32 bits cmpxchg available on the architecture for 32 bits arguments. Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Cc: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-14frv: missing casts in cmpxchg()Al Viro
2007-06-07frv: build fixPeter Zijlstra
In file included from /usr/src/linux-2.6-2/net/ipv4/ip_input.c:118: include2/asm/system.h:245: error: parse error before "__cmpxchg_32" include2/asm/system.h:245: error: parse error before '*' token include2/asm/system.h:245: warning: type defaults to `int' in declaration of `__cmpxchg_32' include2/asm/system.h:245: warning: function declaration isn't a prototype include2/asm/system.h:245: warning: data definition has no type or storage class Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08atomic.h: atomic_add_unless as inline. Remove system.h atomic.h circular ↵Mathieu Desnoyers
dependency atomic_add_unless as inline. Remove system.h atomic.h circular dependency. I agree (with Andi Kleen) this typeof is not needed and more error prone. All the original atomic.h code that uses cmpxchg (which includes the atomic_add_unless) uses defines instead of inline functions, probably to circumvent a circular dependency between system.h and atomic.h on powerpc (which my patch addresses). Therefore, it makes sense to use inline functions that will provide type checking. atomic_add_unless as inline. Remove system.h atomic.h circular dependency. Digging into the FRV architecture shows me that it is also affected by such a circular dependency. Here is the diff applying this against the rest of my atomic.h patches. It applies over the atomic.h standardization patches. Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-07-14[PATCH] remove set_wmb - arch removalSteven Rostedt
set_wmb should not be used in the kernel because it just confuses the code more and has no benefit. Since it is not currently used in the kernel this patch removes it so that new code does not include it. All archs define set_wmb(var, value) to do { var = value; wmb(); } while(0) except ia64 and sparc which use a mb() instead. But this is still moot since it is not used anyway. Hasn't been tested on any archs but x86 and x86_64 (and only compiled tested) Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-26Don't include linux/config.h from anywhere else in include/David Woodhouse
2006-04-11[PATCH] Remove unused prepare_to_switch macroHirokazu Takata
Remove unused prepare_to_switch() macros. Signed-off-by: Hirokazu Takata <takata@linux-m32r.org> Cc: Mikael Starvik <starvik@axis.com> Cc: David Howells <dhowells@redhat.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Miles Bader <uclinux-v850@lsi.nec.co.jp> Cc: Chris Zankel <chris@zankel.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-14[PATCH] FRV: Use virtual interrupt disablementDavid Howells
Make the FRV arch use virtual interrupt disablement because accesses to the processor status register (PSR) are relatively slow and because we will soon have the need to deal with multiple interrupt controls at the same time (separate h/w and inter-core interrupts). The way this is done is to dedicate one of the four integer condition code registers (ICC2) to maintaining a virtual interrupt disablement state whilst inside the kernel. This uses the ICC2.Z flag (Zero) to indicate whether the interrupts are virtually disabled and the ICC2.C flag (Carry) to indicate whether the interrupts are physically disabled. ICC2.Z is set to indicate interrupts are virtually disabled. ICC2.C is set to indicate interrupts are physically enabled. Under normal running conditions Z==0 and C==1. Disabling interrupts with local_irq_disable() doesn't then actually physically disable interrupts - it merely sets ICC2.Z to 1. Should an interrupt then happen, the exception prologue will note ICC2.Z is set and branch out of line using one instruction (an unlikely BEQ). Here it will physically disable interrupts and clear ICC2.C. When it comes time to enable interrupts (local_irq_enable()), this simply clears the ICC2.Z flag and invokes a trap #2 if both Z and C flags are clear (the HI integer condition). This can be done with the TIHI conditional trap instruction. The trap then physically reenables interrupts and sets ICC2.C again. Upon returning the interrupt will be taken as interrupts will then be enabled. Note that whilst processing the trap, the whole exceptions system is disabled, and so an interrupt can't happen till it returns. If no pending interrupt had happened, ICC2.C would still be set, the HI condition would not be fulfilled, and no trap will happen. Saving interrupts (local_irq_save) is simply a matter of pulling the ICC2.Z flag out of the CCR register, shifting it down and masking it off. This gives a result of 0 if interrupts were enabled and 1 if they weren't. Restoring interrupts (local_irq_restore) is then a matter of taking the saved value mentioned previously and XOR'ing it against 1. If it was one, the result will be zero, and if it was zero the result will be non-zero. This result is then used to affect the ICC2.Z flag directly (it is a condition code flag after all). An XOR instruction does not affect the Carry flag, and so that bit of state is unchanged. The two flags can then be sampled to see if they're both zero using the trap (TIHI) as for the unconditional reenablement (local_irq_enable). This patch also: (1) Modifies the debugging stub (break.S) to handle single-stepping crossing into the trap #2 handler and into virtually disabled interrupts. (2) Removes superseded fixup pointers from the second instructions in the trap tables (there's no a separate fixup table for this). (3) Declares the trap #3 vector for use in .org directives in the trap table. (4) Moves irq_enter() and irq_exit() in do_IRQ() to avoid problems with virtual interrupt handling, and removes the duplicate code that has now been folded into irq_exit() (softirq and preemption handling). (5) Tells the compiler in the arch Makefile that ICC2 is now reserved. (6) Documents the in-kernel ABI, including the virtual interrupts. (7) Renames the old irq management functions to different names. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
