path: root/include/asm-generic/Kbuild.asm
2010-08-14include: replace unifdef-y with header-ySam Ravnborg
unifdef-y and header-y has same semantic. So there is no need to have both. Drop the unifdef-y variant and sort all lines again Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2009-09-10KVM: export kvm_para.hMichael S. Tsirkin
kvm_para.h contains userspace interface and so should be exported. Signed-off-by: Michael S. Tsirkin <mst@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-06-11asm-generic: introduce asm/bitsperlong.hArnd Bergmann
This provides a reliable way for asm-generic/types.h and other files to find out if it is running on a 32 or 64 bit platform. We cannot use CONFIG_64BIT for this in headers that are included from user space because CONFIG symbols are not available there. We also cannot do it inside of asm/types.h because some headers need the word size but cannot include types.h. The solution is to introduce a new header <asm/bitsperlong.h> that defines both __BITS_PER_LONG for user space and BITS_PER_LONG for usage in the kernel. The asm-generic version falls back to 32 bit unless the architecture overrides it, which I did for all 64 bit platforms. Signed-off-by: Remis Lima Baima <remis.developer@googlemail.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2009-01-14byteorder: make swab.h include asm/swab.h like a regular headerHarvey Harrison
Add swab.h to kbuild.asm and remove the individual entries from each arch, mark as unifdef as some arches have some kernel-only bits inside. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-09-05Fix conditional export of kvh.h and a.out.h to userspace.Khem Raj
Some architectures have moved the asm/ into arch/ and some have not. This patch checks for a.out.h and kvh.h in both places before exporting the corresponding file from linux/ [dwmw2: simplified a little] Signed-off-by: Khem Raj <raj.khem@gmail.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2008-07-25remove dummy asm/kvm.h filesAdrian Bunk
This patch removes the dummy asm/kvm.h files on architectures not (yet) supporting KVM and uses the same conditional headers installation as already used for a.out.h . Also removed are superfluous install rules in the s390 and x86 Kbuild files (they are already in Kbuild.asm). Signed-off-by: Adrian Bunk <bunk@kernel.org> Acked-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2008-06-27kbuild: fix a.out.h export to userspace with O= build.David Woodhouse
We need to check for existence of the a.out.h header in the source tree, not the object tree, if we want it to get the right answer with O=. Signed-off-by: David Woodhouse <david.woodhouse@intel.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-04-02kvm: provide kvm.h for all architecture: fixes headers_installChristian Borntraeger
Currently include/linux/kvm.h is not considered by make headers_install, because Kbuild cannot handle " unifdef-$(CONFIG_FOO) += foo.h. This problem was introduced by commit fb56dbb31c4738a3918db81fd24da732ce3b4ae6 Author: Avi Kivity <avi@qumranet.com> Date: Sun Dec 2 10:50:06 2007 +0200 KVM: Export include/linux/kvm.h only if $ARCH actually supports KVM Currently, make headers_check barfs due to <asm/kvm.h>, which <linux/kvm.h> includes, not existing. Rather than add a zillion <asm/kvm.h>s, export kvm. only if the arch actually supports it. Signed-off-by: Avi Kivity <avi@qumranet.com> which makes this an 2.6.25 regression. One way of solving the issue is to enhance Kbuild, but Avi and David conviced me, that changing headers_install is not the way to go. This patch changes the definition for linux/kvm.h to unifdef-y. If  unifdef-y is used for linux/kvm.h "make headers_check" will fail on all architectures without asm/kvm.h. Therefore, this patch also provides asm/kvm.h on all architectures. Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Acked-by: Avi Kivity <avi@qumranet.com> Cc: Sam Ravnborg <sam@ravnborg.org Cc: David Woodhouse <dwmw2@infradead.org> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08aout: suppress A.OUT library support if !CONFIG_ARCH_SUPPORTS_AOUTDavid Howells
Suppress A.OUT library support if CONFIG_ARCH_SUPPORTS_AOUT is not set. Not all architectures support the A.OUT binfmt, so the ELF binfmt should not be permitted to go looking for A.OUT libraries to load in such a case. Not only that, but under such conditions A.OUT core dumps are not produced either. To make this work, this patch also does the following: (1) Makes the existence of the contents of linux/a.out.h contingent on CONFIG_ARCH_SUPPORTS_AOUT. (2) Renames dump_thread() to aout_dump_thread() as it's only called by A.OUT core dumping code. (3) Moves aout_dump_thread() into asm/a.out-core.h and makes it inline. This is then included only where needed. This means that this bit of arch code will be stored in the appropriate A.OUT binfmt module rather than the core kernel. (4) Drops A.OUT support for Blackfin (according to Mike Frysinger it's not needed) and FRV. This patch depends on the previous patch to move STACK_TOP[_MAX] out of asm/a.out.h and into asm/processor.h as they're required whether or not A.OUT format is available. [jdike@addtoit.com: uml: re-remove accidentally restored code] Signed-off-by: David Howells <dhowells@redhat.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Jeff Dike <jdike@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07Unexport asm/page.hKirill A. Shutemov
Do not export asm/page.h during make headers_install. This removes PAGE_SIZE from userspace headers. Signed-off-by: Kirill A. Shutemov <k.shutemov@gmail.com> Reviewed-by: David Woodhouse <dwmw2@infradead.org> Cc: David Howells <dhowells@redhat.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07Unexport asm/elf.hKirill A. Shutemov
Do not export asm/elf.h during make headers_install. Signed-off-by: Kirill A. Shutemov <k.shutemov@gmail.com> Reviewed-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07Unexport asm/user.h and linux/user.hKirill A. Shutemov
Do not export asm/user.h and linux/user.h during make headers_install. Signed-off-by: Kirill A. Shutemov <k.shutemov@gmail.com> Reviewed-by: David Woodhouse <dwmw2@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Acked-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17unexport asm/shmparam.hOlaf Hering
SHMLBA cant possible be used in userspace, see sparc versions of that header. Do not export asm/shmparam.h during make headers_install_all This removes another uservisible place of PAGE_SIZE Signed-off-by: Olaf Hering <olaf@aepfle.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-07[PATCH] cleanup asm/setup.h userspace visibilityAdrian Bunk
Make the contents of the userspace asm/setup.h header consistent on all architectures: - export setup.h to userspace on all architectures - export only COMMAND_LINE_SIZE to userspace - frv: move COMMAND_LINE_SIZE from param.h - i386: remove duplicate COMMAND_LINE_SIZE from param.h - arm: - export ATAGs to userspace - change u8/u16/u32 to __u8/__u16/__u32 Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-19[HEADERS] One line per header in Kbuild files to reduce conflictsDavid Woodhouse
2006-09-13[PATCH] headers_check: remove <asm/timex.h> from user exportDavid Woodhouse
There's useful stuff in <linux/timex.h> but <asm/timex.h> has nothing for userspace. Stop exporting it, and include it only from within the existing #ifdef __KERNEL__ part of <linux/timex.h> This fixes a 'make headers_check' failure on i386 because asm-i386/timex.h includes both asm-i386/tsc.h and asm-i386/processor.h, neither of which are exported to userspace. It's not entirely clear _why_ it includes either of these, but it does. Signed-off-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-14[PATCH] hdrinstall: remove asm/io.h from user visibilityDavid Woodhouse
There's no excuse for userspace abusing this kernel header -- the kernel's headers are not intended to provide a library of helper routines for userspace. Using <asm/io.h> from userspace is broken on most architectures anyway. Just say 'no'. Signed-off-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-14[PATCH] hdrinstall: remove asm/atomic.h from user visibilityDavid Woodhouse
This isn't suitable for userspace to see -- the kernel headers are not a random library of stuff for userspace; they're only there to define the kernel<->user ABI for system libraries and tools. Anything which _was_ abusing asm/atomic.h from userspace was probably broken anyway -- as it often didn't even give atomic operation. Signed-off-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-14[PATCH] hdrinstall: remove asm/irq.h from user visibilityDavid Woodhouse
Remove asm/irq.h from the exported headers -- there was never any good reason for it to have been listed. Signed-off-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-18Add generic Kbuild files for 'make headers_install'David Woodhouse
This adds the Kbuild files listing the files which are to be installed by the 'headers_install' make target, in generic directories. Signed-off-by: David Woodhouse <dwmw2@infradead.org>
