path: root/include/asm-generic/hugetlb.h
2013-10-02mm: Fix generic hugetlb pte check return type.David Miller
The include/asm-generic/hugetlb.h stubs that just vector huge_pte_*() calls to the pte_*() implementations won't work in certain situations. x86 and sparc, for example, return "unsigned long" from the bit checks, and just go "return pte_val(pte) & PTE_BIT_FOO;" But since huge_pte_*() returns 'int', if any high bits on 64-bit are relevant, they get chopped off. The net effect is that we can loop forever trying to COW a huge page, because the huge_pte_write() check signals false all the time. Reported-by: Gurudas Pai <gurudas.pai@oracle.com> Tested-by: Gurudas Pai <gurudas.pai@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net> Acked-by: David Rientjes <rientjes@google.com>
2013-04-29mm/hugetlb: add more arch-defined huge_pte functionsGerald Schaefer
Commit abf09bed3cce ("s390/mm: implement software dirty bits") introduced another difference in the pte layout vs. the pmd layout on s390, thoroughly breaking the s390 support for hugetlbfs. This requires replacing some more pte_xxx functions in mm/hugetlbfs.c with a huge_pte_xxx version. This patch introduces those huge_pte_xxx functions and their generic implementation in asm-generic/hugetlb.h, which will now be included on all architectures supporting hugetlbfs apart from s390. This change will be a no-op for those architectures. [akpm@linux-foundation.org: fix warning] Signed-off-by: Gerald Schaefer <gerald.schaefer@de.ibm.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Hugh Dickins <hughd@google.com> Cc: Hillf Danton <dhillf@gmail.com> Acked-by: Michal Hocko <mhocko@suse.cz> [for !s390 parts] Cc: Tony Luck <tony.luck@intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Paul Mundt <lethal@linux-sh.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
