path: root/include/asm-generic/iomap.h
2011-07-25iomap: make IOPORT/PCI mapping functions conditionalRandy Dunlap
When CONFIG_PCI is not enabled, CONFIG_EISA=y, and CONFIG_GENERIC_IOMAP=y, drivers/net/3c59x.c build fails due to a recent small change to <asm-generic/iomap.h> that surrounds pci_iomap() and pci_iounmap() with #ifdef CONFIG_PCI/#endif. Since that patch to iomap.h looks correct, add stubs for pci_iomap() and pci_iounmap() with CONFIG_PCI is not enabled to fix the build errors. drivers/net/3c59x.c:1026: error: implicit declaration of function 'pci_iomap' drivers/net/3c59x.c:1038: error: implicit declaration of function 'pci_iounmap' Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Cc: Jonas Bonn <jonas@southpole.se> Cc: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-22iomap: make IOPORT/PCI mapping functions conditionalJonas Bonn
Use the CONFIG_HAS_IOPORT and CONFIG_PCI options to decide whether or not functions for mapping these areas are provided. Signed-off-by: Jonas Bonn <jonas@southpole.se> Acked-by: Arnd Bergmann <arnd@arndb.de>
2008-04-24generic: add ioremap_wc() interface wrappervenkatesh.pallipadi@intel.com
x86 has ioremap_wc for wc remap. Also introduce a generic ioremap_wc aliased to ioremap_uc so that drivers can use this interface transparently. Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-02-08asm-generic: remove fastcallHarvey Harrison
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2005-04-16[PATCH] add Big Endian variants of ioread/iowriteJames Bottomley
In the new io infrastructure, all of our operators are expecting the underlying device to be little endian (because the PCI bus, their main consumer, is LE). However, there are a fair few devices and busses in the world that are actually Big Endian. There's even evidence that some of these BE bus and chip types are attached to LE systems. Thus, there's a need for a BE equivalent of our io{read,write}{16,32} operations. The attached patch adds this as io{read,write}{16,32}be. When it's in, I'll add the first consume (the 53c700 SCSI chip driver). Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
