path: root/include/asm-generic/mutex-dec.h
2008-02-08asm-generic: remove fastcallHarvey Harrison
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-10-03fix file specification in commentsUwe Zeisberger
Many files include the filename at the beginning, serveral used a wrong one. Signed-off-by: Uwe Zeisberger <Uwe_Zeisberger@digi.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-03-31[PATCH] mutex: some cleanupsNicolas Pitre
Turn some macros into inline functions and add proper type checking as well as being more readable. Also a minor comment adjustment. Signed-off-by: Nicolas Pitre <nico@cam.org> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-11Fix mutex_trylock() copy-and-paste bug (x86, x86-64, generic mutex-dec.h)Linus Torvalds
Noticed by Arjan originally on x86-64, then Ingo on x86, and finally me grepping for it in the generic version. Bad parenthesis nesting. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-09[PATCH] mutex subsystem, add asm-generic/mutex-[dec|xchg|null].h implementationsIngo Molnar
Add three (generic) mutex fastpath implementations. The mutex-xchg.h implementation is atomic_xchg() based, and should work fine on every architecture. The mutex-dec.h implementation is atomic_dec_return() based - this one too should work on every architecture, but might not perform the most optimally on architectures that have no atomic-dec/inc instructions. The mutex-null.h implementation forces all calls into the slowpath. This is used for mutex debugging, but it can also be used on platforms that do not want (or need) a fastpath at all. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arjan van de Ven <arjan@infradead.org>
