path: root/include/asm-generic/mutex-dec.h
2015-10-06locking/mutex: Use acquire/release semanticsDavidlohr Bueso
As of 654672d4ba1 (locking/atomics: Add _{acquire|release|relaxed}() variants of some atomic operations) and 6d79ef2d30e (locking, asm-generic: Add _{relaxed|acquire|release}() variants for 'atomic_long_t'), weakly ordered archs can benefit from more relaxed use of barriers when locking and unlocking, instead of regular full barrier semantics. While currently only arm64 supports such optimizations, updating corresponding locking primitives serves for other archs to immediately benefit as well, once the necessary machinery is implemented of course. Signed-off-by: Davidlohr Bueso <dbueso@suse.de> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Paul E.McKenney <paulmck@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Will Deacon <will.deacon@arm.com> Cc: linux-kernel@vger.kernel.org Link: http://lkml.kernel.org/r/1443643395-17016-3-git-send-email-dave@stgolabs.net Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-06-26arch: Make __mutex_fastpath_lock_retval return whether fastpath succeeded or notMaarten Lankhorst
This will allow me to call functions that have multiple arguments if fastpath fails. This is required to support ticket mutexes, because they need to be able to pass an extra argument to the fail function. Originally I duplicated the functions, by adding __mutex_fastpath_lock_retval_arg. This ended up being just a duplication of the existing function, so a way to test if fastpath was called ended up being better. This also cleaned up the reservation mutex patch some by being able to call an atomic_set instead of atomic_xchg, and making it easier to detect if the wrong unlock function was previously used. Signed-off-by: Maarten Lankhorst <maarten.lankhorst@canonical.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: dri-devel@lists.freedesktop.org Cc: linaro-mm-sig@lists.linaro.org Cc: robclark@gmail.com Cc: rostedt@goodmis.org Cc: daniel@ffwll.ch Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/20130620113105.4001.83929.stgit@patser Signed-off-by: Ingo Molnar <mingo@kernel.org>
2008-10-23mutex: speed up generic mutex implementationsNick Piggin
- atomic operations which both modify the variable and return something imply full smp memory barriers before and after the memory operations involved (failing atomic_cmpxchg, atomic_add_unless, etc don't imply a barrier because they don't modify the target). See Documentation/atomic_ops.txt. So remove extra barriers and branches. - All architectures support atomic_cmpxchg. This has no relation to __HAVE_ARCH_CMPXCHG. We can just take the atomic_cmpxchg path unconditionally This reduces a simple single threaded fastpath lock+unlock test from 590 cycles to 203 cycles on a ppc970 system. Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08asm-generic: remove fastcallHarvey Harrison
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-10-03fix file specification in commentsUwe Zeisberger
Many files include the filename at the beginning, serveral used a wrong one. Signed-off-by: Uwe Zeisberger <Uwe_Zeisberger@digi.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-03-31[PATCH] mutex: some cleanupsNicolas Pitre
Turn some macros into inline functions and add proper type checking as well as being more readable. Also a minor comment adjustment. Signed-off-by: Nicolas Pitre <nico@cam.org> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-11Fix mutex_trylock() copy-and-paste bug (x86, x86-64, generic mutex-dec.h)Linus Torvalds
Noticed by Arjan originally on x86-64, then Ingo on x86, and finally me grepping for it in the generic version. Bad parenthesis nesting. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-09[PATCH] mutex subsystem, add asm-generic/mutex-[dec|xchg|null].h implementationsIngo Molnar
Add three (generic) mutex fastpath implementations. The mutex-xchg.h implementation is atomic_xchg() based, and should work fine on every architecture. The mutex-dec.h implementation is atomic_dec_return() based - this one too should work on every architecture, but might not perform the most optimally on architectures that have no atomic-dec/inc instructions. The mutex-null.h implementation forces all calls into the slowpath. This is used for mutex debugging, but it can also be used on platforms that do not want (or need) a fastpath at all. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arjan van de Ven <arjan@infradead.org>
