path: root/include/asm-generic/percpu.h
2009-06-30alpha: fix percpu build breakageTejun Heo
alpha percpu access requires custom SHIFT_PERCPU_PTR() definition for modules to work around addressing range limitation. This is done via generating inline assembly using C preprocessing which forces the assembler to generate external reference. This happens behind the compiler's back and makes the compiler think that static percpu variables in modules are unused. This used to be worked around by using __unused attribute for percpu variables which prevent the compiler from omitting the variable; however, recent declare/definition attribute unification change broke this as __used can't be used for declaration. Also, in the process, PER_CPU_ATTRIBUTES definition in alpha percpu.h got broken. This patch adds PER_CPU_DEF_ATTRIBUTES which is only used for definitions and make alpha use it to add __used for percpu variables in modules. This also fixes the PER_CPU_ATTRIBUTES double definition bug. Signed-off-by: Tejun Heo <tj@kernel.org> Tested-by: maximilian attems <max@stro.at> Acked-by: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Richard Henderson <rth@twiddle.net> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-21PERCPU: Collect the DECLARE/DEFINE declarations togetherDavid Howells
Collect the DECLARE/DEFINE declarations together in linux/percpu-defs.h so that they're in one place, and give them descriptive comments, particularly the SHARED_ALIGNED variant. It would be nice to collect these in linux/percpu.h, but that's not possible without sorting out the severe #include recursion between the x86 arch headers and the general headers (and possibly other arches too). Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-21FRV: Fix the section attribute on UP DECLARE_PER_CPU()David Howells
In non-SMP mode, the variable section attribute specified by DECLARE_PER_CPU() does not agree with that specified by DEFINE_PER_CPU(). This means that architectures that have a small data section references relative to a base register may throw up linkage errors due to too great a displacement between where the base register points and the per-CPU variable. On FRV, the .h declaration says that the variable is in the .sdata section, but the .c definition says it's actually in the .data section. The linker throws up the following errors: kernel/built-in.o: In function `release_task': kernel/exit.c:78: relocation truncated to fit: R_FRV_GPREL12 against symbol `per_cpu__process_counts' defined in .data section in kernel/built-in.o kernel/exit.c:78: relocation truncated to fit: R_FRV_GPREL12 against symbol `per_cpu__process_counts' defined in .data section in kernel/built-in.o To fix this, DECLARE_PER_CPU() should simply apply the same section attribute as does DEFINE_PER_CPU(). However, this is made slightly more complex by virtue of the fact that there are several variants on DEFINE, so these need to be matched by variants on DECLARE. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-10percpu: unbreak alpha percpuTejun Heo
For the time being, move the generic percpu_*() accessors to linux/percpu.h. asm-generic/percpu.h is meant to carry generic stuff for low level stuff - declarations, definitions and pointer offset calculation and so on but not for generic interface. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-01-16percpu: add optimized generic percpu accessorsIngo Molnar
It is an optimization and a cleanup, and adds the following new generic percpu methods: percpu_read() percpu_write() percpu_add() percpu_sub() percpu_and() percpu_or() percpu_xor() and implements support for them on x86. (other architectures will fall back to a default implementation) The advantage is that for example to read a local percpu variable, instead of this sequence: return __get_cpu_var(var); ffffffff8102ca2b: 48 8b 14 fd 80 09 74 mov -0x7e8bf680(,%rdi,8),%rdx ffffffff8102ca32: 81 ffffffff8102ca33: 48 c7 c0 d8 59 00 00 mov $0x59d8,%rax ffffffff8102ca3a: 48 8b 04 10 mov (%rax,%rdx,1),%rax We can get a single instruction by using the optimized variants: return percpu_read(var); ffffffff8102ca3f: 65 48 8b 05 91 8f fd mov %gs:0x7efd8f91(%rip),%rax I also cleaned up the x86-specific APIs and made the x86 code use these new generic percpu primitives. tj: * fixed generic percpu_sub() definition as Roel Kluin pointed out * added percpu_and() for completeness's sake * made generic percpu ops atomic against preemption Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Tejun Heo <tj@kernel.org>
2008-02-23percpu: fix DEBUG_PREEMPT per_cpu checkingHugh Dickins
2.6.25-rc1 percpu changes broke CONFIG_DEBUG_PREEMPT's per_cpu checking on several architectures. On s390, sparc64 and x86 it's been weakened to not checking at all; whereas on powerpc64 it's become too strict, issuing warnings from __raw_get_cpu_var in io_schedule and init_timer for example. Fix this by weakening powerpc's __my_cpu_offset to use the non-checking local_paca instead of get_paca (which itself contains such a check); and strengthening the generic my_cpu_offset to go the old slow way via smp_processor_id when CONFIG_DEBUG_PREEMPT (debug_smp_processor_id is where all the knowledge of what's correct when lives). Signed-off-by: Hugh Dickins <hugh@veritas.com> Reviewed-by: Mike Travis <travis@sgi.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-30x86/non-x86: percpu, node ids, apic ids x86.git fixupMike Travis
Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-01-30percpu: make the asm-generic/percpu.h more "generic"travis@sgi.com
- add support for PER_CPU_ATTRIBUTES - fix generic smp percpu_modcopy to use per_cpu_offset() macro. Add the ability to use generic/percpu even if the arch needs to override several aspects of its operations. This will enable the use of generic percpu.h for all arches. An arch may define: __per_cpu_offset Do not use the generic pointer array. Arch must define per_cpu_offset(cpu) (used by x86_64, s390). __my_cpu_offset Can be defined to provide an optimized way to determine the offset for variables of the currently executing processor. Used by ia64, x86_64, x86_32, sparc64, s/390. SHIFT_PTR(ptr, offset) If an arch defines it then special handling of pointer arithmentic may be implemented. Used by s/390. (Some of these special percpu arch implementations may be later consolidated so that there are less cases to deal with.) Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Mike Travis <travis@sgi.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-01-30percpu: move arch XX_PER_CPU_XX definitions into linux/percpu.htravis@sgi.com
- Special consideration for IA64: Add the ability to specify arch specific per cpu flags - remove .data.percpu attribute from DEFINE_PER_CPU for non-smp case. The arch definitions are all the same. So move them into linux/percpu.h. We cannot move DECLARE_PER_CPU since some include files just include asm/percpu.h to avoid include recursion problems. Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Mike Travis <travis@sgi.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-01-30percpu: use a kconfig variable to signal arch specific percpu setuptravis@sgi.com
The use of the __GENERIC_PERCPU is a bit problematic since arches may want to run their own percpu setup while using the generic percpu definitions. Replace it through a kconfig variable. Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Mike Travis <travis@sgi.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-07-19define new percpu interface for shared dataFenghua Yu
per cpu data section contains two types of data. One set which is exclusively accessed by the local cpu and the other set which is per cpu, but also shared by remote cpus. In the current kernel, these two sets are not clearely separated out. This can potentially cause the same data cacheline shared between the two sets of data, which will result in unnecessary bouncing of the cacheline between cpus. One way to fix the problem is to cacheline align the remotely accessed per cpu data, both at the beginning and at the end. Because of the padding at both ends, this will likely cause some memory wastage and also the interface to achieve this is not clean. This patch: Moves the remotely accessed per cpu data (which is currently marked as ____cacheline_aligned_in_smp) into a different section, where all the data elements are cacheline aligned. And as such, this differentiates the local only data and remotely accessed data cleanly. Signed-off-by: Fenghua Yu <fenghua.yu@intel.com> Acked-by: Suresh Siddha <suresh.b.siddha@intel.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Christoph Lameter <clameter@sgi.com> Cc: <linux-arch@vger.kernel.org> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-02[PATCH] i386: Use per-cpu variables for GDT, PDARusty Russell
Allocating PDA and GDT at boot is a pain. Using simple per-cpu variables adds happiness (although we need the GDT page-aligned for Xen, which we do in a followup patch). [akpm@linux-foundation.org: build fix] Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andi Kleen <ak@suse.de> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org>
2006-10-06[PATCH] Fix typo in "syntax error if percpu macros are incorrectly used" patchJan Blunck
Trivial typo fix in the "syntax error if percpu macros are incorrectly used" patch. I misspelled "identifier" in all places. D'Oh! Thanks to Dirk Mueller to point this out. Signed-off-by: Jan Blunck <jblunck@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-26[PATCH] trigger a syntax error if percpu macros are incorrectly usedJan Blunck
get_cpu_var()/per_cpu()/__get_cpu_var() arguments must be simple identifiers. Otherwise the arch dependent implementations might break. This patch enforces the correct usage of the macros by producing a syntax error if the variable is not a simple identifier. Signed-off-by: Jan Blunck <jblunck@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-03[PATCH] lockdep: add per_cpu_offset()Ingo Molnar
Add the per_cpu_offset() generic method. (used by the lock validator) Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] Define __raw_get_cpu_var and use itPaul Mackerras
There are several instances of per_cpu(foo, raw_smp_processor_id()), which is semantically equivalent to __get_cpu_var(foo) but without the warning that smp_processor_id() can give if CONFIG_DEBUG_PREEMPT is enabled. For those architectures with optimized per-cpu implementations, namely ia64, powerpc, s390, sparc64 and x86_64, per_cpu() turns into more and slower code than __get_cpu_var(), so it would be preferable to use __get_cpu_var on those platforms. This defines a __raw_get_cpu_var(x) macro which turns into per_cpu(x, raw_smp_processor_id()) on architectures that use the generic per-cpu implementation, and turns into __get_cpu_var(x) on the architectures that have an optimized per-cpu implementation. Signed-off-by: Paul Mackerras <paulus@samba.org> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Ingo Molnar <mingo@elte.hu> Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-28[PATCH] for_each_possible_cpu: fixes for generic partKAMEZAWA Hiroyuki
replaces for_each_cpu with for_each_possible_cpu(). Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-23[PATCH] more for_each_cpu() conversionsAndrew Morton
When we stop allocating percpu memory for not-possible CPUs we must not touch the percpu data for not-possible CPUs at all. The correct way of doing this is to test cpu_possible() or to use for_each_cpu(). This patch is a kernel-wide sweep of all instances of NR_CPUS. I found very few instances of this bug, if any. But the patch converts lots of open-coded test to use the preferred helper macros. Cc: Mikael Starvik <starvik@axis.com> Cc: David Howells <dhowells@redhat.com> Acked-by: Kyle McMartin <kyle@parisc-linux.org> Cc: Anton Blanchard <anton@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: William Lee Irwin III <wli@holomorphy.com> Cc: Andi Kleen <ak@muc.de> Cc: Christian Zankel <chris@zankel.net> Cc: Philippe Elie <phil.el@wanadoo.fr> Cc: Nathan Scott <nathans@sgi.com> Cc: Jens Axboe <axboe@suse.de> Cc: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-23[PATCH] adjust per_cpu definition in non-SMP caseJan Beulich
Fix (in the architectures I'm actually building for) the UP definition of per_cpu so that the cpu specified may be any expression, not just an identifier or a suffix expression. Signed-off-by: Jan Beulich <jbeulich@novell.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
