David Vrabel identified a regression when using automatic NUMA balancing
under Xen whereby page table entries were getting corrupted due to the
use of native PTE operations. Quoting him
Xen PV guest page tables require that their entries use machine
addresses if the preset bit (_PAGE_PRESENT) is set, and (for
successful migration) non-present PTEs must use pseudo-physical
addresses. This is because on migration MFNs in present PTEs are
translated to PFNs (canonicalised) so they may be translated back
to the new MFN in the destination domain (uncanonicalised).
pte_mknonnuma(), pmd_mknonnuma(), pte_mknuma() and pmd_mknuma()
set and clear the _PAGE_PRESENT bit using pte_set_flags(),
pte_clear_flags(), etc.
In a Xen PV guest, these functions must translate MFNs to PFNs
when clearing _PAGE_PRESENT and translate PFNs to MFNs when setting
_PAGE_PRESENT.
His suggested fix converted p[te|md]_[set|clear]_flags to using
paravirt-friendly ops but this is overkill. He suggested an alternative
of using p[te|md]_modify in the NUMA page table operations but this is
does more work than necessary and would require looking up a VMA for
protections.
This patch modifies the NUMA page table operations to use paravirt
friendly operations to set/clear the flags of interest. Unfortunately
this will take a performance hit when updating the PTEs on
CONFIG_PARAVIRT but I do not see a way around it that does not break
Xen.
Acked-by: David Vrabel <david.vrabel@citrix.com>
Tested-by: David Vrabel <david.vrabel@citrix.com>
Cc: Peter Anvin <hpa@zytor.com>
Cc: Fengguang Wu <fengguang.wu@intel.com>
Cc: Steven Noonan <steven@uplinklabs.net>
Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com>
Cc: Cyrill Gorcunov <gorcunov@gmail.com>
Cc: <stable@vger.kernel.org>
In a virtualized environment and given an appropriate interface the guest
can mark pages as unused while they are free (for the s390 implementation
see git commit 45e576b1c3d00206 "guest page hinting light"). For the host
the unused state is a property of the pte.
This patch adds the primitive 'pte_unused' and code to the host swap out
handler so that pages marked as unused by all mappers are not swapped out
but discarded instead, thus saving one IO for swap out and potentially
another one for swap in.
[ Martin Schwidefsky: patch reordering and simplification ]
Signed-off-by: Konstantin Weitz <konstantin.weitz@gmail.com>
Archs like ppc64 doesn't do tlb flush in set_pte/pmd functions when using
a hash table MMU for various reasons (the flush is handled as part of
the PTE modification when necessary).
ppc64 thus doesn't implement flush_tlb_range for hash based MMUs.
Additionally ppc64 require the tlb flushing to be batched within ptl locks.
The reason to do that is to ensure that the hash page table is in sync with
linux page table.
We track the hpte index in linux pte and if we clear them without flushing
hash and drop the ptl lock, we can have another cpu update the pte and can
end up with duplicate entry in the hash table, which is fatal.
We also want to keep set_pte_at simpler by not requiring them to do hash
flush for performance reason. We do that by assuming that set_pte_at() is
never *ever* called on a PTE that is already valid.
This was the case until the NUMA code went in which broke that assumption.
Fix that by introducing a new pair of helpers to set _PAGE_NUMA in a
way similar to ptep/pmdp_set_wrprotect(), with a generic implementation
using set_pte_at() and a powerpc specific one using the appropriate
mechanism needed to keep the hash table in sync.
Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
This patch fix the below crash
NIP [c00000000004cee4] .__hash_page_thp+0x2a4/0x440
LR [c0000000000439ac] .hash_page+0x18c/0x5e0
Call Trace:
[c000000736103c40] [00001ffffb000000] 0x1ffffb000000(unreliable)
[437908.479693] [c000000736103d50] [c0000000000439ac] .hash_page+0x18c/0x5e0
[437908.479699] [c000000736103e30] [c00000000000924c] .do_hash_page+0x4c/0x58
On ppc64 we use the pgtable for storing the hpte slot information and
store address to the pgtable at a constant offset (PTRS_PER_PMD) from
pmd. On mremap, when we switch the pmd, we need to withdraw and deposit
the pgtable again, so that we find the pgtable at PTRS_PER_PMD offset
from new pmd.
We also want to move the withdraw and deposit before the set_pmd so
that, when page fault find the pmd as trans huge we can be sure that
pgtable can be located at the offset.
Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
Sasha Levin found a NULL pointer dereference that is due to a missing
page table lock, which in turn is due to the pmd entry in question being
a transparent huge-table entry.
The code - introduced in commit 1998cc048901 ("mm: make
madvise(MADV_WILLNEED) support swap file prefetch") - correctly checks
for this situation using pmd_none_or_trans_huge_or_clear_bad(), but it
turns out that that function doesn't work correctly.
pmd_none_or_trans_huge_or_clear_bad() expected that pmd_bad() would
trigger if the transparent hugepage bit was set, but it doesn't do that
if pmd_numa() is also set. Note that the NUMA bit only gets set on real
NUMA machines, so people trying to reproduce this on most normal
development systems would never actually trigger this.
Fix it by removing the very subtle (and subtly incorrect) expectation,
and instead just checking pmd_trans_huge() explicitly.
Reported-by: Sasha Levin <sasha.levin@oracle.com>
Acked-by: Andrea Arcangeli <aarcange@redhat.com>
[ Additionally remove the now stale test for pmd_trans_huge() inside the
pmd_bad() case - Linus ]
There are a few subtle races, between change_protection_range (used by
mprotect and change_prot_numa) on one side, and NUMA page migration and
compaction on the other side.
The basic race is that there is a time window between when the PTE gets
made non-present (PROT_NONE or NUMA), and the TLB is flushed.
During that time, a CPU may continue writing to the page.
This is fine most of the time, however compaction or the NUMA migration
code may come in, and migrate the page away.
When that happens, the CPU may continue writing, through the cached
translation, to what is no longer the current memory location of the
process.
This only affects x86, which has a somewhat optimistic pte_accessible.
All other architectures appear to be safe, and will either always flush,
or flush whenever there is a valid mapping, even with no permissions
(SPARC).
The basic race looks like this:
CPU A CPU B CPU C
load TLB entry
make entry PTE/PMD_NUMA
fault on entry
read/write old page
start migrating page
change PTE/PMD to new page
read/write old page [*]
flush TLB
reload TLB from new entry
read/write new page
lose data
[*] the old page may belong to a new user at this point!
The obvious fix is to flush remote TLB entries, by making sure that
pte_accessible aware of the fact that PROT_NONE and PROT_NUMA memory may
still be accessible if there is a TLB flush pending for the mm.
This should fix both NUMA migration and compaction.
[mgorman@suse.de: fix build]
Signed-off-by: Rik van Riel <riel@redhat.com>
Cc: Alex Thorlton <athorlton@sgi.com>
The last remaining use for the storage key of the s390 architecture
is reference counting. The alternative is to make page table entries
invalid while they are old. On access the fault handler marks the
pte/pmd as young which makes the pte/pmd valid if the access rights
allow read access. The pte/pmd invalidations required for software
managed reference bits cost a bit of performance, on the other hand
the RRBE/RRBM instructions to read and reset the referenced bits are
quite expensive as well.
Reviewed-by: Gerald Schaefer <gerald.schaefer@de.ibm.com>
Andy reported that if file page get reclaimed we lose the soft-dirty bit
if it was there, so save _PAGE_BIT_SOFT_DIRTY bit when page address get
encoded into pte entry. Thus when #pf happens on such non-present pte
we can restore it back.
Reported-by: Andy Lutomirski <luto@amacapital.net>
Signed-off-by: Cyrill Gorcunov <gorcunov@openvz.org>
Acked-by: Pavel Emelyanov <xemul@parallels.com>
Cc: Matt Mackall <mpm@selenic.com>
Cc: Xiao Guangrong <xiaoguangrong@linux.vnet.ibm.com>
Cc: Marcelo Tosatti <mtosatti@redhat.com>
Cc: KOSAKI Motohiro <kosaki.motohiro@gmail.com>
Cc: "Aneesh Kumar K.V" <aneesh.kumar@linux.vnet.ibm.com>
Cc: Minchan Kim <minchan@kernel.org>
Cc: Wanpeng Li <liwanp@linux.vnet.ibm.com>
Andy Lutomirski reported that if a page with _PAGE_SOFT_DIRTY bit set
get swapped out, the bit is getting lost and no longer available when
pte read back.
To resolve this we introduce _PTE_SWP_SOFT_DIRTY bit which is saved in
pte entry for the page being swapped out. When such page is to be read
back from a swap cache we check for bit presence and if it's there we
clear it and restore the former _PAGE_SOFT_DIRTY bit back.
One of the problem was to find a place in pte entry where we can save
the _PTE_SWP_SOFT_DIRTY bit while page is in swap. The _PAGE_PSE was
chosen for that, it doesn't intersect with swap entry format stored in
pte.
Reviewed-by: Minchan Kim <minchan@kernel.org>
Reviewed-by: Wanpeng Li <liwanp@linux.vnet.ibm.com>
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc
Pull powerpc updates from Ben Herrenschmidt:
"This is the powerpc changes for the 3.11 merge window. In addition to
the usual bug fixes and small updates, the main highlights are:
- Support for transparent huge pages by Aneesh Kumar for 64-bit
server processors. This allows the use of 16M pages as transparent
huge pages on kernels compiled with a 64K base page size.
- Base VFIO support for KVM on power by Alexey Kardashevskiy
- Wiring up of our nvram to the pstore infrastructure, including
putting compressed oopses in there by Aruna Balakrishnaiah
- Move, rework and improve our "EEH" (basically PCI error handling
and recovery) infrastructure. It is no longer specific to pseries
but is now usable by the new "powernv" platform as well (no
hypervisor) by Gavin Shan.
- I fixed some bugs in our math-emu instruction decoding and made it
usable to emulate some optional FP instructions on processors with
hard FP that lack them (such as fsqrt on Freescale embedded
processors).
- Support for Power8 "Event Based Branch" facility by Michael
Ellerman. This facility allows what is basically "userspace
interrupts" for performance monitor events.
- A bunch of Transactional Memory vs. Signals bug fixes and HW
breakpoint/watchpoint fixes by Michael Neuling.
And more ... I appologize in advance if I've failed to highlight
something that somebody deemed worth it."
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (156 commits)
pstore: Add hsize argument in write_buf call of pstore_ftrace_call
powerpc/fsl: add MPIC timer wakeup support
powerpc/mpic: create mpic subsystem object
powerpc/mpic: add global timer support
powerpc/mpic: add irq_set_wake support
powerpc/85xx: enable coreint for all the 64bit boards
powerpc/8xx: Erroneous double irq_eoi() on CPM IRQ in MPC8xx
powerpc/fsl: Enable CONFIG_E1000E in mpc85xx_smp_defconfig
powerpc/mpic: Add get_version API both for internal and external use
powerpc: Handle both new style and old style reserve maps
powerpc/hw_brk: Fix off by one error when validating DAWR region end
powerpc/pseries: Support compression of oops text via pstore
powerpc/pseries: Re-organise the oops compression code
pstore: Pass header size in the pstore write callback
powerpc/powernv: Fix iommu initialization again
powerpc/pseries: Inform the hypervisor we are using EBB regs
powerpc/perf: Add power8 EBB support
powerpc/perf: Core EBB support for 64-bit book3s
powerpc/perf: Drop MMCRA from thread_struct
powerpc/perf: Don't enable if we have zero events
The soft-dirty is a bit on a PTE which helps to track which pages a task
writes to. In order to do this tracking one should
1. Clear soft-dirty bits from PTEs ("echo 4 > /proc/PID/clear_refs)
2. Wait some time.
3. Read soft-dirty bits (55'th in /proc/PID/pagemap2 entries)
To do this tracking, the writable bit is cleared from PTEs when the
soft-dirty bit is. Thus, after this, when the task tries to modify a
page at some virtual address the #PF occurs and the kernel sets the
soft-dirty bit on the respective PTE.
Note, that although all the task's address space is marked as r/o after
the soft-dirty bits clear, the #PF-s that occur after that are processed
fast. This is so, since the pages are still mapped to physical memory,
and thus all the kernel does is finds this fact out and puts back
writable, dirty and soft-dirty bits on the PTE.
Another thing to note, is that when mremap moves PTEs they are marked
with soft-dirty as well, since from the user perspective mremap modifies
the virtual memory at mremap's new address.
Signed-off-by: Pavel Emelyanov <xemul@parallels.com>
Cc: Glauber Costa <glommer@parallels.com>
This will be later used by powerpc THP support. In powerpc we want to use
pgtable for storing the hash index values. So instead of adding them to
mm_context list, we would like to store them in the second half of pmd
Reviewed-by: Andrea Arcangeli <aarcange@redhat.com>
Reviewed-by: David Gibson <david@gibson.dropbear.id.au>
On architectures where a pgd entry may be shared between user and kernel
(e.g. ARM+LPAE), freeing page tables needs a ceiling other than 0.
This patch introduces a generic USER_PGTABLES_CEILING that arch code can
override. It is the responsibility of the arch code setting the ceiling
to ensure the complete freeing of the page tables (usually in
pgd_free()).
[catalin.marinas@arm.com: commit log; shift_arg_pages(), asm-generic/pgtables.h changes]
Cc: <stable@vger.kernel.org> [3.3+]
The s390 architecture is unique in respect to dirty page detection,
it uses the change bit in the per-page storage key to track page
modifications. All other architectures track dirty bits by means
of page table entries. This property of s390 has caused numerous
problems in the past, e.g. see git commit ef5d437f71afdf4a
"mm: fix XFS oops due to dirty pages without buffers on s390".
To avoid future issues in regard to per-page dirty bits convert
s390 to a fault based software dirty bit detection mechanism. All
user page table entries which are marked as clean will be hardware
read-only, even if the pte is supposed to be writable. A write by
the user process will trigger a protection fault which will cause
the user pte to be marked as dirty and the hardware read-only bit
is removed.
With this change the dirty bit in the storage key is irrelevant
for Linux as a host, but the storage key is still required for
KVM guests. The effect is that page_test_and_clear_dirty and the
related code can be removed. The referenced bit in the storage
key is still used by the page_test_and_clear_young primitive to
provide page age information.
For page cache pages of mappings with mapping_cap_account_dirty
there will not be any change in behavior as the dirty bit tracking
already uses read-only ptes to control the amount of dirty pages.
Only for swap cache pages and pages of mappings without
mapping_cap_account_dirty there can be additional protection faults.
To avoid an excessive number of additional faults the mk_pte
primitive checks for PageDirty if the pgprot value allows for writes
and pre-dirties the pte. That avoids all additional faults for
tmpfs and shmem pages until these pages are added to the swap cache.
Commit 816422ad7647 ("asm-generic, mm: pgtable: consolidate zero page
helpers") broke the compile on MIPS if SPARSEMEM is enabled. We get
this:
In file included from arch/mips/include/asm/pgtable.h:552,
from include/linux/mm.h:44,
from arch/mips/kernel/asm-offsets.c:14:
include/asm-generic/pgtable.h: In function 'my_zero_pfn':
include/asm-generic/pgtable.h:466: error: implicit declaration of function 'page_to_section'
In file included from arch/mips/kernel/asm-offsets.c:14:
include/linux/mm.h: At top level:
include/linux/mm.h:738: error: conflicting types for 'page_to_section'
include/asm-generic/pgtable.h:466: note: previous implicit declaration of 'page_to_section' was here
Due header files inter-dependencies, the only way I see to fix it is
convert my_zero_pfn() for __HAVE_COLOR_ZERO_PAGE to macros.
Signed-off-by: Kirill A. Shutemov <kirill@shutemov.name>
Tested-by: Aaro Koskinen <aaro.koskinen@iki.fi>
Acked-by: David Daney <david.daney@cavium.com>
git://git.kernel.org/pub/scm/linux/kernel/git/mel/linux-balancenuma
Pull Automatic NUMA Balancing bare-bones from Mel Gorman:
"There are three implementations for NUMA balancing, this tree
(balancenuma), numacore which has been developed in tip/master and
autonuma which is in aa.git.
In almost all respects balancenuma is the dumbest of the three because
its main impact is on the VM side with no attempt to be smart about
scheduling. In the interest of getting the ball rolling, it would be
desirable to see this much merged for 3.8 with the view to building
scheduler smarts on top and adapting the VM where required for 3.9.
The most recent set of comparisons available from different people are
mel: https://lkml.org/lkml/2012/12/9/108
mingo: https://lkml.org/lkml/2012/12/7/331
tglx: https://lkml.org/lkml/2012/12/10/437
srikar: https://lkml.org/lkml/2012/12/10/397
The results are a mixed bag. In my own tests, balancenuma does
reasonably well. It's dumb as rocks and does not regress against
mainline. On the other hand, Ingo's tests shows that balancenuma is
incapable of converging for this workloads driven by perf which is bad
but is potentially explained by the lack of scheduler smarts. Thomas'
results show balancenuma improves on mainline but falls far short of
numacore or autonuma. Srikar's results indicate we all suffer on a
large machine with imbalanced node sizes.
My own testing showed that recent numacore results have improved
dramatically, particularly in the last week but not universally.
We've butted heads heavily on system CPU usage and high levels of
migration even when it shows that overall performance is better.
There are also cases where it regresses. Of interest is that for
specjbb in some configurations it will regress for lower numbers of
warehouses and show gains for higher numbers which is not reported by
the tool by default and sometimes missed in treports. Recently I
reported for numacore that the JVM was crashing with
NullPointerExceptions but currently it's unclear what the source of
this problem is. Initially I thought it was in how numacore batch
handles PTEs but I'm no longer think this is the case. It's possible
numacore is just able to trigger it due to higher rates of migration.
These reports were quite late in the cycle so I/we would like to start
with this tree as it contains much of the code we can agree on and has
not changed significantly over the last 2-3 weeks."
* tag 'balancenuma-v11' of git://git.kernel.org/pub/scm/linux/kernel/git/mel/linux-balancenuma: (50 commits)
mm/rmap, migration: Make rmap_walk_anon() and try_to_unmap_anon() more scalable
mm/rmap: Convert the struct anon_vma::mutex to an rwsem
mm: migrate: Account a transhuge page properly when rate limiting
mm: numa: Account for failed allocations and isolations as migration failures
mm: numa: Add THP migration for the NUMA working set scanning fault case build fix
mm: numa: Add THP migration for the NUMA working set scanning fault case.
mm: sched: numa: Delay PTE scanning until a task is scheduled on a new node
mm: sched: numa: Control enabling and disabling of NUMA balancing if !SCHED_DEBUG
mm: sched: Adapt the scanning rate if a NUMA hinting fault does not migrate
mm: numa: Use a two-stage filter to restrict pages being migrated for unlikely task<->node relationships
mm: numa: migrate: Set last_nid on newly allocated page
mm: numa: split_huge_page: Transfer last_nid on tail page
mm: numa: Introduce last_nid to the page frame
sched: numa: Slowly increase the scanning period as NUMA faults are handled
mm: numa: Rate limit setting of pte_numa if node is saturated
mm: numa: Rate limit the amount of memory that is migrated between nodes
mm: numa: Structures for Migrate On Fault per NUMA migration rate limiting
mm: numa: Migrate pages handled during a pmd_numa hinting fault
mm: numa: Migrate on reference policy
We have two different implementation of is_zero_pfn() and my_zero_pfn()
helpers: for architectures with and without zero page coloring.
Let's consolidate them in <asm-generic/pgtable.h>.
Implement pte_numa and pmd_numa.
We must atomically set the numa bit and clear the present bit to
define a pte_numa or pmd_numa.
Once a pte or pmd has been set as pte_numa or pmd_numa, the next time
a thread touches a virtual address in the corresponding virtual range,
a NUMA hinting page fault will trigger. The NUMA hinting page fault
will clear the NUMA bit and set the present bit again to resolve the
page fault.
The expectation is that a NUMA hinting page fault is used as part
of a placement policy that decides if a page should remain on the
current node or migrated to a different node.
Signed-off-by: Andrea Arcangeli <aarcange@redhat.com>
We need pte_present to return true for _PAGE_PROTNONE pages, to indicate that
the pte is associated with a page.
However, for TLB flushing purposes, we would like to know whether the pte
points to an actually accessible page. This allows us to skip remote TLB
flushes for pages that are not actually accessible.
Fill in this method for x86 and provide a safe (but slower) method
on other architectures.
Fixed-by: Linus Torvalds <torvalds@linux-foundation.org>
Link: http://lkml.kernel.org/n/tip-66p11te4uj23gevgh4j987ip@git.kernel.org
[ Added Linus's review fixes. ]
The CONFIG_TRANSPARENT_HUGEPAGE implementation of pmdp_get_and_clear()
calls pmd_clear() with 3 arguments instead of 1.
This happens only for !__HAVE_ARCH_PMDP_GET_AND_CLEAR which doesn't seem
to happen because x86 defines this and it uses pmd_update.
[mhocko@suse.cz: changelog addition]
Signed-off-by: Steve Capper <steve.capper@arm.com>
Reviewed-by: Michal Hocko <mhocko@suse.cz>
Reviewed-by: Kirill A. Shutemov <kirill@shutemov.name>
Cc: Gerald Schaefer <gerald.schaefer@de.ibm.com>
Cc: Chris Metcalf <cmetcalf@tilera.com>
On s390, a valid page table entry must not be changed while it is attached
to any CPU. So instead of pmd_mknotpresent() and set_pmd_at(), an IDTE
operation would be necessary there. This patch introduces the
pmdp_invalidate() function, to allow architecture-specific
implementations.
Signed-off-by: Gerald Schaefer <gerald.schaefer@de.ibm.com>
Cc: Hillf Danton <dhillf@gmail.com>
The thp page table pre-allocation code currently assumes that pgtable_t is
of type "struct page *". This may not be true for all architectures, so
this patch removes that assumption by replacing the functions
prepare_pmd_huge_pte() and get_pmd_huge_pte() with two new functions that
can be defined architecture-specific.
It also removes two VM_BUG_ON checks for page_count() and page_mapcount()
operating on a pgtable_t. Apart from the VM_BUG_ON removal, there will be
no functional change introduced by this patch.
Replace the generic vma-flag VM_PFN_AT_MMAP with x86-only VM_PAT.
We can toss mapping address from remap_pfn_range() into
track_pfn_vma_new(), and collect all PAT-related logic together in
arch/x86/.
This patch also restores orignal frustration-free is_cow_mapping() check
in remap_pfn_range(), as it was before commit v2.6.28-rc8-88-g3c8bb73
("x86: PAT: store vm_pgoff for all linear_over_vma_region mappings - v3")
is_linear_pfn_mapping() checks can be removed from mm/huge_memory.c,
because it already handled by VM_PFNMAP in VM_NO_THP bit-mask.
[suresh.b.siddha@intel.com: Reset the VM_PAT flag as part of untrack_pfn_vma()]
Signed-off-by: Konstantin Khlebnikov <khlebnikov@openvz.org>
Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com>
Cc: Venkatesh Pallipadi <venki@google.com>
Cc: Nick Piggin <npiggin@kernel.dk>
Cc: Carsten Otte <cotte@de.ibm.com>
Cc: Cyrill Gorcunov <gorcunov@openvz.org>
Cc: Eric Paris <eparis@redhat.com>
Cc: James Morris <james.l.morris@oracle.com>
Cc: Jason Baron <jbaron@redhat.com>
Cc: Kentaro Takeda <takedakn@nttdata.co.jp>
Cc: Matt Helsley <matthltc@us.ibm.com>
Cc: Robert Richter <robert.richter@amd.com>
Cc: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp>
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
vm_insert_pfn
With PAT enabled, vm_insert_pfn() looks up the existing pfn memory
attribute and uses it. Expectation is that the driver reserves the
memory attributes for the pfn before calling vm_insert_pfn().
remap_pfn_range() (when called for the whole vma) will setup a new
attribute (based on the prot argument) for the specified pfn range.
This addresses the legacy usage which typically calls remap_pfn_range()
with a desired memory attribute. For ranges smaller than the vma size
(which is typically not the case), remap_pfn_range() will use the
existing memory attribute for the pfn range.
Expose two different API's for these different behaviors.
track_pfn_insert() for tracking the pfn attribute set by vm_insert_pfn()
and track_pfn_remap() for the remap_pfn_range().
This cleanup also prepares the ground for the track/untrack pfn vma
routines to take over the ownership of setting PAT specific vm_flag in
the 'vma'.
[khlebnikov@openvz.org: Clear checks in track_pfn_remap()]
[akpm@linux-foundation.org: tweak a few comments]
Cc: Konstantin Khlebnikov <khlebnikov@openvz.org>
Cc: Suresh Siddha <suresh.b.siddha@intel.com>
In the x86 32bit PAE CONFIG_TRANSPARENT_HUGEPAGE=y case while holding the
mmap_sem for reading, cmpxchg8b cannot be used to read pmd contents under
Xen.
So instead of dealing only with "consistent" pmdvals in
pmd_none_or_trans_huge_or_clear_bad() (which would be conceptually
simpler) we let pmd_none_or_trans_huge_or_clear_bad() deal with pmdvals
where the low 32bit and high 32bit could be inconsistent (to avoid having
to use cmpxchg8b).
The only guarantee we get from pmd_read_atomic is that if the low part of
the pmd was found null, the high part will be null too (so the pmd will be
considered unstable). And if the low part of the pmd is found "stable"
later, then it means the whole pmd was read atomically (because after a
pmd is stable, neither MADV_DONTNEED nor page faults can alter it anymore,
and we read the high part after the low part).
In the 32bit PAE x86 case, it is enough to read the low part of the pmdval
atomically to declare the pmd as "stable" and that's true for THP and no
THP, furthermore in the THP case we also have a barrier() that will
prevent any inconsistent pmdvals to be cached by a later re-read of the
*pmd.
Cc: Jonathan Nieder <jrnieder@gmail.com>
Cc: Ulrich Obergfell <uobergfe@redhat.com>
Cc: Larry Woodman <lwoodman@redhat.com>
Cc: Petr Matousek <pmatouse@redhat.com>
Cc: Jan Beulich <jbeulich@suse.com>
Tested-by: Andrew Jones <drjones@redhat.com>
When holding the mmap_sem for reading, pmd_offset_map_lock should only
run on a pmd_t that has been read atomically from the pmdp pointer,
otherwise we may read only half of it leading to this crash.
PID: 11679 TASK: f06e8000 CPU: 3 COMMAND: "do_race_2_panic"
#0 [f06a9dd8] crash_kexec at c049b5ec
#1 [f06a9e2c] oops_end at c083d1c2
#2 [f06a9e40] no_context at c0433ded
#3 [f06a9e64] bad_area_nosemaphore at c043401a
#4 [f06a9e6c] __do_page_fault at c0434493
#5 [f06a9eec] do_page_fault at c083eb45
#6 [f06a9f04] error_code (via page_fault) at c083c5d5
EAX: 01fb470c EBX: fff35000 ECX: 00000003 EDX: 00000100 EBP:
00000000
DS: 007b ESI: 9e201000 ES: 007b EDI: 01fb4700 GS: 00e0
CS: 0060 EIP: c083bc14 ERR: ffffffff EFLAGS: 00010246
#7 [f06a9f38] _spin_lock at c083bc14
#8 [f06a9f44] sys_mincore at c0507b7d
#9 [f06a9fb0] system_call at c083becd
start len
EAX: ffffffda EBX: 9e200000 ECX: 00001000 EDX: 6228537f
DS: 007b ESI: 00000000 ES: 007b EDI: 003d0f00
SS: 007b ESP: 62285354 EBP: 62285388 GS: 0033
CS: 0073 EIP: 00291416 ERR: 000000da EFLAGS: 00000286
This should be a longstanding bug affecting x86 32bit PAE without THP.
Only archs with 64bit large pmd_t and 32bit unsigned long should be
affected.
With THP enabled the barrier() in pmd_none_or_trans_huge_or_clear_bad()
would partly hide the bug when the pmd transition from none to stable,
by forcing a re-read of the *pmd in pmd_offset_map_lock, but when THP is
enabled a new set of problem arises by the fact could then transition
freely in any of the none, pmd_trans_huge or pmd_trans_stable states.
So making the barrier in pmd_none_or_trans_huge_or_clear_bad()
unconditional isn't good idea and it would be a flakey solution.
This should be fully fixed by introducing a pmd_read_atomic that reads
the pmd in order with THP disabled, or by reading the pmd atomically
with cmpxchg8b with THP enabled.
Luckily this new race condition only triggers in the places that must
already be covered by pmd_none_or_trans_huge_or_clear_bad() so the fix
is localized there but this bug is not related to THP.
NOTE: this can trigger on x86 32bit systems with PAE enabled with more
than 4G of ram, otherwise the high part of the pmd will never risk to be
truncated because it would be zero at all times, in turn so hiding the
SMP race.
This bug was discovered and fully debugged by Ulrich, quote:
pmd_none_or_trans_huge_or_clear_bad() loads the content of edx and
eax.
496 static inline int pmd_none_or_trans_huge_or_clear_bad(pmd_t
*pmd)
497 {
498 /* depend on compiler for an atomic pmd read */
499 pmd_t pmdval = *pmd;
// edi = pmd pointer
0xc0507a74 <sys_mincore+548>: mov 0x8(%esp),%edi
// edx = PTE page table high address
0xc0507a84 <sys_mincore+564>: mov 0x4(%edi),%edx
// eax = PTE page table low address
0xc0507a8e <sys_mincore+574>: mov (%edi),%eax
Please note that the PMD is not read atomically. These are two "mov"
instructions where the high order bits of the PMD entry are fetched
first. Hence, the above machine code is prone to the following race.
- The PMD entry {high|low} is 0x0000000000000000.
The "mov" at 0xc0507a84 loads 0x00000000 into edx.
- A page fault (on another CPU) sneaks in between the two "mov"
instructions and instantiates the PMD.
- The PMD entry {high|low} is now 0x00000003fda38067.
The "mov" at 0xc0507a8e loads 0xfda38067 into eax.
Reported-by: Ulrich Obergfell <uobergfe@redhat.com>
The change adds some infrastructure for managing tile pmd's more generally,
using pte_pmd() and pmd_pte() methods to translate pmd values to and
from ptes, since on TILEPro a pmd is really just a nested structure
holding a pgd (aka pte). Several existing pmd methods are moved into
this framework, and a whole raft of additional pmd accessors are defined
that are used by the transparent hugepage framework.
The tile PTE now has a "client2" bit. The bit is used to indicate a
transparent huge page is in the process of being split into subpages.
This change also fixes a generic bug where the return value of the
generic pmdp_splitting_flush() was incorrect.
Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux
Pull <linux/bug.h> cleanup from Paul Gortmaker:
"The changes shown here are to unify linux's BUG support under the one
<linux/bug.h> file. Due to historical reasons, we have some BUG code
in bug.h and some in kernel.h -- i.e. the support for BUILD_BUG in
linux/kernel.h predates the addition of linux/bug.h, but old code in
kernel.h wasn't moved to bug.h at that time. As a band-aid, kernel.h
was including <asm/bug.h> to pseudo link them.
This has caused confusion[1] and general yuck/WTF[2] reactions. Here
is an example that violates the principle of least surprise:
CC lib/string.o
lib/string.c: In function 'strlcat':
lib/string.c:225:2: error: implicit declaration of function 'BUILD_BUG_ON'
make[2]: *** [lib/string.o] Error 1
$ grep linux/bug.h lib/string.c
#include <linux/bug.h>
We've included <linux/bug.h> for the BUG infrastructure and yet we
still get a compile fail! [We've not kernel.h for BUILD_BUG_ON.] Ugh -
very confusing for someone who is new to kernel development.
With the above in mind, the goals of this changeset are:
1) find and fix any include/*.h files that were relying on the
implicit presence of BUG code.
2) find and fix any C files that were consuming kernel.h and hence
relying on implicitly getting some/all BUG code.
3) Move the BUG related code living in kernel.h to <linux/bug.h>
4) remove the asm/bug.h from kernel.h to finally break the chain.
During development, the order was more like 3-4, build-test, 1-2. But
to ensure that git history for bisect doesn't get needless build
failures introduced, the commits have been reorderd to fix the problem
areas in advance.
[1] https://lkml.org/lkml/2012/1/3/90
[2] https://lkml.org/lkml/2012/1/17/414"
Fix up conflicts (new radeon file, reiserfs header cleanups) as per Paul
and linux-next.
* tag 'bug-for-3.4' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux:
kernel.h: doesn't explicitly use bug.h, so don't include it.
bug: consolidate BUILD_BUG_ON with other bug code
BUG: headers with BUG/BUG_ON etc. need linux/bug.h
bug.h: add include of it to various implicit C users
lib: fix implicit users of kernel.h for TAINT_WARN
spinlock: macroize assert_spin_locked to avoid bug.h dependency
x86: relocate get/set debugreg fcns to include/asm/debugreg.
In some cases it may happen that pmd_none_or_clear_bad() is called with
the mmap_sem hold in read mode. In those cases the huge page faults can
allocate hugepmds under pmd_none_or_clear_bad() and that can trigger a
false positive from pmd_bad() that will not like to see a pmd
materializing as trans huge.
It's not khugepaged causing the problem, khugepaged holds the mmap_sem
in write mode (and all those sites must hold the mmap_sem in read mode
to prevent pagetables to go away from under them, during code review it
seems vm86 mode on 32bit kernels requires that too unless it's
restricted to 1 thread per process or UP builds). The race is only with
the huge pagefaults that can convert a pmd_none() into a
pmd_trans_huge().
Effectively all these pmd_none_or_clear_bad() sites running with
mmap_sem in read mode are somewhat speculative with the page faults, and
the result is always undefined when they run simultaneously. This is
probably why it wasn't common to run into this. For example if the
madvise(MADV_DONTNEED) runs zap_page_range() shortly before the page
fault, the hugepage will not be zapped, if the page fault runs first it
will be zapped.
Altering pmd_bad() not to error out if it finds hugepmds won't be enough
to fix this, because zap_pmd_range would then proceed to call
zap_pte_range (which would be incorrect if the pmd become a
pmd_trans_huge()).
The simplest way to fix this is to read the pmd in the local stack
(regardless of what we read, no need of actual CPU barriers, only
compiler barrier needed), and be sure it is not changing under the code
that computes its value. Even if the real pmd is changing under the
value we hold on the stack, we don't care. If we actually end up in
zap_pte_range it means the pmd was not none already and it was not huge,
and it can't become huge from under us (khugepaged locking explained
above).
All we need is to enforce that there is no way anymore that in a code
path like below, pmd_trans_huge can be false, but pmd_none_or_clear_bad
can run into a hugepmd. The overhead of a barrier() is just a compiler
tweak and should not be measurable (I only added it for THP builds). I
don't exclude different compiler versions may have prevented the race
too by caching the value of *pmd on the stack (that hasn't been
verified, but it wouldn't be impossible considering
pmd_none_or_clear_bad, pmd_bad, pmd_trans_huge, pmd_none are all inlines
and there's no external function called in between pmd_trans_huge and
pmd_none_or_clear_bad).
if (pmd_trans_huge(*pmd)) {
if (next-addr != HPAGE_PMD_SIZE) {
VM_BUG_ON(!rwsem_is_locked(&tlb->mm->mmap_sem));
split_huge_page_pmd(vma->vm_mm, pmd);
} else if (zap_huge_pmd(tlb, vma, pmd, addr))
continue;
/* fall through */
if (pmd_none_or_clear_bad(pmd))
Because this race condition could be exercised without special
privileges this was reported in CVE-2012-1179.
The race was identified and fully explained by Ulrich who debugged it.
I'm quoting his accurate explanation below, for reference.
====== start quote =======
mapcount 0 page_mapcount 1
kernel BUG at mm/huge_memory.c:1384!
At some point prior to the panic, a "bad pmd ..." message similar to the
following is logged on the console:
mm/memory.c:145: bad pmd ffff8800376e1f98(80000000314000e7).
The "bad pmd ..." message is logged by pmd_clear_bad() before it clears
the page's PMD table entry.
143 void pmd_clear_bad(pmd_t *pmd)
144 {
-> 145 pmd_ERROR(*pmd);
146 pmd_clear(pmd);
147 }
After the PMD table entry has been cleared, there is an inconsistency
between the actual number of PMD table entries that are mapping the page
and the page's map count (_mapcount field in struct page). When the page
is subsequently reclaimed, __split_huge_page() detects this inconsistency.
1381 if (mapcount != page_mapcount(page))
1382 printk(KERN_ERR "mapcount %d page_mapcount %d\n",
1383 mapcount, page_mapcount(page));
-> 1384 BUG_ON(mapcount != page_mapcount(page));
The root cause of the problem is a race of two threads in a multithreaded
process. Thread B incurs a page fault on a virtual address that has never
been accessed (PMD entry is zero) while Thread A is executing an madvise()
system call on a virtual address within the same 2 MB (huge page) range.
virtual address space
| | |<-- B(fault)
2 MB | |/////////////////////|-.
huge < |/////////////////////| > A(range)
page | |/////////////////////|-'
- Thread A is executing an madvise(..., MADV_DONTNEED) system call
on the virtual address range "A(range)" shown in the picture.
sys_madvise
// Acquire the semaphore in shared mode.
down_read(¤t->mm->mmap_sem)
madvise_vma
switch (behavior)
case MADV_DONTNEED:
madvise_dontneed
zap_page_range
unmap_vmas
unmap_page_range
zap_pud_range
zap_pmd_range
// Assume that this huge page has never been accessed.
// I.e. content of the PMD entry is zero (not mapped).
// We don't get here due to the above assumption.
// Assume that Thread B incurred a page fault and
.---------> // sneaks in here as shown below.
| if (unlikely(pmd_bad(*pmd)))
| pmd_clear_bad
| pmd_ERROR
| // Log "bad pmd ..." message here.
| pmd_clear
| // Clear the page's PMD entry.
| // Thread B incremented the map count
| // in page_add_new_anon_rmap(), but
| // now the page is no longer mapped
| // by a PMD entry (-> inconsistency).
v
- Thread B is handling a page fault on virtual address "B(fault)" shown
in the picture.
do_page_fault
__do_page_fault
down_read_trylock(&mm->mmap_sem)
handle_mm_fault
if (pmd_none(*pmd) && transparent_hugepage_enabled(vma))
// We get here due to the above assumption (PMD entry is zero).
do_huge_pmd_anonymous_page
alloc_hugepage_vma
// Allocate a new transparent huge page here.
__do_huge_pmd_anonymous_page
spin_lock(&mm->page_table_lock)
// Here we increment the page's map count (starts at -1).
atomic_set(&page->_mapcount, 0)
set_pmd_at
// Here we set the page's PMD entry which will be cleared
// when Thread A calls pmd_clear_bad().
spin_unlock(&mm->page_table_lock)
The mmap_sem does not prevent the race because both threads are acquiring
it in shared mode (down_read). Thread B holds the page_table_lock while
the page's map count and PMD table entry are updated. However, Thread A
does not synchronize on that lock.
====== end quote =======
[akpm@linux-foundation.org: checkpatch fixes]
Cc: Dave Jones <davej@redhat.com>
Acked-by: Larry Woodman <lwoodman@redhat.com>
Cc: <stable@vger.kernel.org> [2.6.38+]
Cc: Mark Salter <msalter@redhat.com>
If a header file is making use of BUG, BUG_ON, BUILD_BUG_ON, or any
other BUG variant in a static inline (i.e. not in a #define) then
that header really should be including <linux/bug.h> and not just
expecting it to be implicitly present.
We can make this change risk-free, since if the files using these
headers didn't have exposure to linux/bug.h already, they would have
been causing compile failures/warnings.
Signed-off-by: Nicolas Kaiser <nikai@nikai.net>
The page_clear_dirty primitive always sets the default storage key
which resets the access control bits and the fetch protection bit.
That will surprise a KVM guest that sets non-zero access control
bits or the fetch protection bit. Merge page_test_dirty and
page_clear_dirty back to a single function and only clear the
dirty bit from the storage key.
In addition move the function page_test_and_clear_dirty and
page_test_and_clear_young to page.h where they belong. This
requires to change the parameter from a struct page * to a page
frame number.
Commit e2cda3226481 ("thp: add pmd mangling generic functions") replaced
some macros in <asm-generic/pgtable.h> with inline functions.
If the functions are to be defined (not all architectures need them)
then struct vm_area_struct must be defined first. So include
<linux/mm_types.h>.
Fixes a build failure seen in Debian:
CC [M] drivers/media/dvb/mantis/mantis_pci.o
In file included from arch/arm/include/asm/pgtable.h:460,
from drivers/media/dvb/mantis/mantis_pci.c:25:
include/asm-generic/pgtable.h: In function 'ptep_test_and_clear_young':
include/asm-generic/pgtable.h:29: error: dereferencing pointer to incomplete type
pmdp_get_and_clear/pmdp_clear_flush/pmdp_splitting_flush were trapped as
BUG() and they were defined only to diminish the risk of build issues on
not-x86 archs and to be consistent with the generic pte methods previously
defined in include/asm-generic/pgtable.h.
But they are causing more trouble than they were supposed to solve, so
it's simpler not to define them when THP is off.
This is also correcting the export of pmdp_splitting_flush which is
currently unused (x86 isn't using the generic implementation in
mm/pgtable-generic.c and no other arch needs that [yet]).
Sam Ravnborg <sam@ravnborg.org>
Cc: "Luck, Tony" <tony.luck@intel.com>
Cc: James Bottomley <James.Bottomley@HansenPartnership.com>
Some are needed to build but not actually used on archs not supporting
transparent hugepages. Others like pmdp_clear_flush are used by x86 too.
Acked-by: Mel Gorman <mel@csn.ul.ie>
These returns 0 at compile time when the config option is disabled, to
allow gcc to eliminate the transparent hugepage function calls at compile
time without additional #ifdefs (only the export of those functions have
to be visible to gcc but they won't be required at link time and
huge_memory.o can be not built at all).
_PAGE_BIT_UNUSED1 is never used for pmd, only on pte.
Improve performance of the sske operation by using the nonquiescing
variant if the affected page has no mappings established. On machines
with no support for the new sske variant the mask bit will be ignored.
In x86, access and dirty bits are set automatically by CPU when CPU accesses
memory. When we go into the code path of below flush_tlb_fix_spurious_fault(),
we already set dirty bit for pte and don't need flush tlb. This might mean
tlb entry in some CPUs hasn't dirty bit set, but this doesn't matter. When
the CPUs do page write, they will automatically check the bit and no software
involved.
On the other hand, flush tlb in below position is harmful. Test creates CPU
number of threads, each thread writes to a same but random address in same vma
range and we measure the total time. Under a 4 socket system, original time is
1.96s, while with the patch, the time is 0.8s. Under a 2 socket system, there is
20% time cut too. perf shows a lot of time are taking to send ipi/handle ipi for
tlb flush.
Signed-off-by: Shaohua Li <shaohua.li@intel.com>
LKML-Reference: <20100816011655.GA362@sli10-desk.sh.intel.com>
Acked-by: Suresh Siddha <suresh.b.siddha@intel.com>
Cc: Andrea Archangeli <aarcange@redhat.com>
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
Most architectures now provide a pgprot_noncached(), the
remaining ones can simply use an dummy default implementation,
except for cris and xtensa, which should override the
default appropriately.
Cc: Jesper Nilsson <jesper.nilsson@axis.com>
Cc: Chris Zankel <chris@zankel.net>
Cc: Magnus Damm <magnus.damm@gmail.com>
Impact: fix lazy context switch API
Pass the previous and next tasks into the context switch start
end calls, so that the called functions can properly access the
task state (esp in end_context_switch, in which the next task
is not yet completely current).
Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com>
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
Impact: simplification, prepare for later changes
Make lazy cpu mode more specific to context switching, so that
it makes sense to do more context-switch specific things in
the callbacks.
Impact: cleanup
Change the protection parameter for track_pfn_vma_new() into a pgprot_t pointer.
Subsequent patch changes the x86 PAT handling to return a compatible
memtype in pgprot_t, if what was requested cannot be allowed due to conflicts.
No fuctionality change in this patch.
Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com>
Impact: Cleanup and branch hints only.
Move the track and untrack pfn stub routines from memory.c to asm-generic.
Also add unlikely to pfnmap related calls in fork and exit path.
Impact: New mm functionality.
Add pgprot_writecombine. pgprot_writecombine will be aliased to
pgprot_noncached when not supported by the architecture.
Commit 1ea0704e0d aka "mm: add a ptep_modify_prot transaction abstraction"
caused:
| CC init/main.o
|In file included from include2/asm/pgtable.h:68,
| from /home/bigeasy/git/linux-2.6-m68k/include/linux/mm.h:39,
| from include2/asm/uaccess.h:8,
| from /home/bigeasy/git/linux-2.6-m68k/include/linux/poll.h:13,
| from /home/bigeasy/git/linux-2.6-m68k/include/linux/rtc.h:113,
| from /home/bigeasy/git/linux-2.6-m68k/include/linux/efi.h:19,
| from /home/bigeasy/git/linux-2.6-m68k/init/main.c:43:
|/linux-2.6/include/asm-generic/pgtable.h: In function '__ptep_modify_prot_start':
|/linux-2.6/include/asm-generic/pgtable.h:209: error: implicit declaration of function 'ptep_get_and_clear'
|/linux-2.6/include/asm-generic/pgtable.h:209: error: incompatible types in return
|/linux-2.6/include/asm-generic/pgtable.h: In function '__ptep_modify_prot_commit':
|/linux-2.6/include/asm-generic/pgtable.h:220: error: implicit declaration of function 'set_pte_at'
|make[2]: *** [init/main.o] Error 1
|make[1]: *** [init] Error 2
|make: *** [sub-make] Error 2
on my m68knommu box.
Acked-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com>
Cc: Hugh Dickins <hugh@veritas.com>
Signed-off-by: Sebastian Siewior <bigeasy@linutronix.de>
This patch adds an API for doing read-modify-write updates to a pte's
protection bits which may race against hardware updates to the pte.
After reading the pte, the hardware may asynchonously set the accessed
or dirty bits on a pte, which would be lost when writing back the
modified pte value.
The existing technique to handle this race is to use
ptep_get_and_clear() atomically fetch the old pte value and clear it
in memory. This has the effect of marking the pte as non-present,
which will prevent the hardware from updating its state. When the new
value is written back, the pte will be present again, and the hardware
can resume updating the access/dirty flags.
When running in a virtualized environment, pagetable updates are
relatively expensive, since they generally involve some trap into the
hypervisor. To mitigate the cost of these updates, we tend to batch
them.
However, because of the atomic nature of ptep_get_and_clear(), it is
inherently non-batchable. This new interface allows batching by
giving the underlying implementation enough information to open a
transaction between the read and write phases:
ptep_modify_prot_start() returns the current pte value, and puts the
pte entry into a state where either the hardware will not update the
pte, or if it does, the updates will be preserved on commit.
ptep_modify_prot_commit() writes back the updated pte, makes sure that
any hardware updates made since ptep_modify_prot_start() are
preserved.
ptep_modify_prot_start() and _commit() must be exactly paired, and
used while holding the appropriate pte lock. They do not protect
against other software updates of the pte in any way.
The current implementations of ptep_modify_prot_start and _commit are
functionally unchanged from before: _start() uses ptep_get_and_clear()
fetch the pte and zero the entry, preventing any hardware updates.
_commit() simply writes the new pte value back knowing that the
hardware has not updated the pte in the meantime.
The only current user of this interface is mprotect
Acked-by: Hugh Dickins <hugh@veritas.com>
Current ia64 kernel flushes icache by lazy_mmu_prot_update() *after*
set_pte(). This is too late. This patch removes lazy_mmu_prot_update and
add modfied set_pte() for flushing if necessary.
This patch flush icache of a page when
new pte has exec bit.
&& new pte has present bit
&& new pte is user's page.
&& (old *ptep is not present
|| new pte's pfn is not same to old *ptep's ptn)
&& new pte's page has no Pg_arch_1 bit.
Pg_arch_1 is set when a page is cache consistent.
I think this condition checks are much easier to understand than considering
"Where sync_icache_dcache() should be inserted ?".
pte_user() for ia64 was removed by http://lkml.org/lkml/2007/6/12/67 as
clean-up. So, I added it again.
Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Cc: Christoph Lameter <clameter@sgi.com>
Cc: Nick Piggin <nickpiggin@yahoo.com.au>
There are some parts of include/asm-generic/pgtable.h that are relevant to
the non-mmu architectures. To make it easier to include this from them I
would like to ifdef the relevant parts.
Without this there is a handful of functions that are referenced in here
that are not defined on many non-mmu architectures. They could be defined
out of course, as an alternative approach.
Nobody is using ptep_test_and_clear_dirty and ptep_clear_flush_dirty. Remove
the functions from all architectures.
