Vaguely based on upstream commit 574c4866e33d 'consolidate kernel-side
struct sigaction declarations'.
flush_signal_handlers() needs to know whether sigaction::sa_restorer
is defined, not whether SA_RESTORER is defined. Define the
__ARCH_HAS_SA_RESTORER macro to indicate this.
commit 53a59fc67f97374758e63a9c785891ec62324c81 upstream.
Since commit e303297e6c3a ("mm: extended batches for generic
mmu_gather") we are batching pages to be freed until either
tlb_next_batch cannot allocate a new batch or we are done.
This works just fine most of the time but we can get in troubles with
non-preemptible kernel (CONFIG_PREEMPT_NONE or CONFIG_PREEMPT_VOLUNTARY)
on large machines where too aggressive batching might lead to soft
lockups during process exit path (exit_mmap) because there are no
scheduling points down the free_pages_and_swap_cache path and so the
freeing can take long enough to trigger the soft lockup.
The lockup is harmless except when the system is setup to panic on
softlockup which is not that unusual.
The simplest way to work around this issue is to limit the maximum
number of batches in a single mmu_gather. 10k of collected pages should
be safe to prevent from soft lockups (we would have 2ms for one) even if
they are all freed without an explicit scheduling point.
This patch doesn't add any new explicit scheduling points because it
relies on zap_pmd_range during page tables zapping which calls
cond_resched per PMD.
The following lockup has been reported for 3.0 kernel with a huge
process (in order of hundreds gigs but I do know any more details).
BUG: soft lockup - CPU#56 stuck for 22s! [kernel:31053]
Modules linked in: af_packet nfs lockd fscache auth_rpcgss nfs_acl sunrpc mptctl mptbase autofs4 binfmt_misc dm_round_robin dm_multipath bonding cpufreq_conservative cpufreq_userspace cpufreq_powersave pcc_cpufreq mperf microcode fuse loop osst sg sd_mod crc_t10dif st qla2xxx scsi_transport_fc scsi_tgt netxen_nic i7core_edac iTCO_wdt joydev e1000e serio_raw pcspkr edac_core iTCO_vendor_support acpi_power_meter rtc_cmos hpwdt hpilo button container usbhid hid dm_mirror dm_region_hash dm_log linear uhci_hcd ehci_hcd usbcore usb_common scsi_dh_emc scsi_dh_alua scsi_dh_hp_sw scsi_dh_rdac scsi_dh dm_snapshot pcnet32 mii edd dm_mod raid1 ext3 mbcache jbd fan thermal processor thermal_sys hwmon cciss scsi_mod
Supported: Yes
CPU 56
Pid: 31053, comm: kernel Not tainted 3.0.31-0.9-default #1 HP ProLiant DL580 G7
RIP: 0010: _raw_spin_unlock_irqrestore+0x8/0x10
RSP: 0018:ffff883ec1037af0 EFLAGS: 00000206
RAX: 0000000000000e00 RBX: ffffea01a0817e28 RCX: ffff88803ffd9e80
RDX: 0000000000000200 RSI: 0000000000000206 RDI: 0000000000000206
RBP: 0000000000000002 R08: 0000000000000001 R09: ffff887ec724a400
R10: 0000000000000000 R11: dead000000200200 R12: ffffffff8144c26e
R13: 0000000000000030 R14: 0000000000000297 R15: 000000000000000e
FS: 00007ed834282700(0000) GS:ffff88c03f200000(0000) knlGS:0000000000000000
CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
CR2: 000000000068b240 CR3: 0000003ec13c5000 CR4: 00000000000006e0
Process kernel (pid: 31053, threadinfo ffff883ec1036000, task ffff883ebd5d4100)
Call Trace:
release_pages+0xc5/0x260
free_pages_and_swap_cache+0x9d/0xc0
tlb_flush_mmu+0x5c/0x80
tlb_finish_mmu+0xe/0x50
exit_mmap+0xbd/0x120
mmput+0x49/0x120
exit_mm+0x122/0x160
do_exit+0x17a/0x430
do_group_exit+0x3d/0xb0
get_signal_to_deliver+0x247/0x480
do_signal+0x71/0x1b0
do_notify_resume+0x98/0xb0
int_signal+0x12/0x17
DWARF2 unwinder stuck at int_signal+0x12/0x17
commit 0bce9c46bf3b15f485d82d7e81dabed6ebcc24b1 upstream.
ARM recently moved to asm-generic/mutex-xchg.h for its mutex
implementation after the previous implementation was found to be missing
some crucial memory barriers. However, this has revealed some problems
running hackbench on SMP platforms due to the way in which the
MUTEX_SPIN_ON_OWNER code operates.
The symptoms are that a bunch of hackbench tasks are left waiting on an
unlocked mutex and therefore never get woken up to claim it. This boils
down to the following sequence of events:
Task A Task B Task C Lock value
0 1
1 lock() 0
2 lock() 0
3 spin(A) 0
4 unlock() 1
5 lock() 0
6 cmpxchg(1,0) 0
7 contended() -1
8 lock() 0
9 spin(C) 0
10 unlock() 1
11 cmpxchg(1,0) 0
12 unlock() 1
At this point, the lock is unlocked, but Task B is in an uninterruptible
sleep with nobody to wake it up.
This patch fixes the problem by ensuring we put the lock into the
contended state if we fail to acquire it on the fastpath, ensuring that
any blocked waiters are woken up when the mutex is released.
Cc: Chris Mason <chris.mason@fusionio.com>
Reviewed-by: Nicolas Pitre <nico@linaro.org>
Link: http://lkml.kernel.org/n/tip-6e9lrw2avczr0617fzl5vqb8@git.kernel.org
commit 26c191788f18129af0eb32a358cdaea0c7479626 upstream.
When holding the mmap_sem for reading, pmd_offset_map_lock should only
run on a pmd_t that has been read atomically from the pmdp pointer,
otherwise we may read only half of it leading to this crash.
PID: 11679 TASK: f06e8000 CPU: 3 COMMAND: "do_race_2_panic"
#0 [f06a9dd8] crash_kexec at c049b5ec
#1 [f06a9e2c] oops_end at c083d1c2
#2 [f06a9e40] no_context at c0433ded
#3 [f06a9e64] bad_area_nosemaphore at c043401a
#4 [f06a9e6c] __do_page_fault at c0434493
#5 [f06a9eec] do_page_fault at c083eb45
#6 [f06a9f04] error_code (via page_fault) at c083c5d5
EAX: 01fb470c EBX: fff35000 ECX: 00000003 EDX: 00000100 EBP:
00000000
DS: 007b ESI: 9e201000 ES: 007b EDI: 01fb4700 GS: 00e0
CS: 0060 EIP: c083bc14 ERR: ffffffff EFLAGS: 00010246
#7 [f06a9f38] _spin_lock at c083bc14
#8 [f06a9f44] sys_mincore at c0507b7d
#9 [f06a9fb0] system_call at c083becd
start len
EAX: ffffffda EBX: 9e200000 ECX: 00001000 EDX: 6228537f
DS: 007b ESI: 00000000 ES: 007b EDI: 003d0f00
SS: 007b ESP: 62285354 EBP: 62285388 GS: 0033
CS: 0073 EIP: 00291416 ERR: 000000da EFLAGS: 00000286
This should be a longstanding bug affecting x86 32bit PAE without THP.
Only archs with 64bit large pmd_t and 32bit unsigned long should be
affected.
With THP enabled the barrier() in pmd_none_or_trans_huge_or_clear_bad()
would partly hide the bug when the pmd transition from none to stable,
by forcing a re-read of the *pmd in pmd_offset_map_lock, but when THP is
enabled a new set of problem arises by the fact could then transition
freely in any of the none, pmd_trans_huge or pmd_trans_stable states.
So making the barrier in pmd_none_or_trans_huge_or_clear_bad()
unconditional isn't good idea and it would be a flakey solution.
This should be fully fixed by introducing a pmd_read_atomic that reads
the pmd in order with THP disabled, or by reading the pmd atomically
with cmpxchg8b with THP enabled.
Luckily this new race condition only triggers in the places that must
already be covered by pmd_none_or_trans_huge_or_clear_bad() so the fix
is localized there but this bug is not related to THP.
NOTE: this can trigger on x86 32bit systems with PAE enabled with more
than 4G of ram, otherwise the high part of the pmd will never risk to be
truncated because it would be zero at all times, in turn so hiding the
SMP race.
This bug was discovered and fully debugged by Ulrich, quote:
pmd_none_or_trans_huge_or_clear_bad() loads the content of edx and
eax.
496 static inline int pmd_none_or_trans_huge_or_clear_bad(pmd_t
*pmd)
497 {
498 /* depend on compiler for an atomic pmd read */
499 pmd_t pmdval = *pmd;
// edi = pmd pointer
0xc0507a74 <sys_mincore+548>: mov 0x8(%esp),%edi
// edx = PTE page table high address
0xc0507a84 <sys_mincore+564>: mov 0x4(%edi),%edx
// eax = PTE page table low address
0xc0507a8e <sys_mincore+574>: mov (%edi),%eax
Please note that the PMD is not read atomically. These are two "mov"
instructions where the high order bits of the PMD entry are fetched
first. Hence, the above machine code is prone to the following race.
- The PMD entry {high|low} is 0x0000000000000000.
The "mov" at 0xc0507a84 loads 0x00000000 into edx.
- A page fault (on another CPU) sneaks in between the two "mov"
instructions and instantiates the PMD.
- The PMD entry {high|low} is now 0x00000003fda38067.
The "mov" at 0xc0507a8e loads 0xfda38067 into eax.
Reported-by: Ulrich Obergfell <uobergfe@redhat.com>
Signed-off-by: Andrea Arcangeli <aarcange@redhat.com>
Cc: Larry Woodman <lwoodman@redhat.com>
Cc: Petr Matousek <pmatouse@redhat.com>
commit f5c2347ee20a8d6964d6a6b1ad04f200f8d4dfa7 upstream.
<asm-generic/statfs.h> is exported to userspace, so using
BITS_PER_LONG is invalid. We need to use __BITS_PER_LONG instead.
This is kernel bugzilla 43165.
Reported-by: H.J. Lu <hjl.tools@gmail.com>
Link: http://lkml.kernel.org/r/1335465916-16965-1-git-send-email-hpa@linux.intel.com
commit 1631fcea8399da5e80a80084b3b8c5bfd99d21e7 upstream.
<asm-generic/unistd.h> was set up to use sys_sendfile() for the 32-bit
compat API instead of sys_sendfile64(), but in fact the right thing to
do is to use sys_sendfile64() in all cases. The 32-bit sendfile64() API
in glibc uses the sendfile64 syscall, so it has to be capable of doing
full 64-bit operations. But the sys_sendfile() kernel implementation
has a MAX_NON_LFS test in it which explicitly limits the offset to 2^32.
So, we need to use the sys_sendfile64() implementation in the kernel
for this case.
Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
commit 1a5a9906d4e8d1976b701f889d8f35d54b928f25 upstream.
In some cases it may happen that pmd_none_or_clear_bad() is called with
the mmap_sem hold in read mode. In those cases the huge page faults can
allocate hugepmds under pmd_none_or_clear_bad() and that can trigger a
false positive from pmd_bad() that will not like to see a pmd
materializing as trans huge.
It's not khugepaged causing the problem, khugepaged holds the mmap_sem
in write mode (and all those sites must hold the mmap_sem in read mode
to prevent pagetables to go away from under them, during code review it
seems vm86 mode on 32bit kernels requires that too unless it's
restricted to 1 thread per process or UP builds). The race is only with
the huge pagefaults that can convert a pmd_none() into a
pmd_trans_huge().
Effectively all these pmd_none_or_clear_bad() sites running with
mmap_sem in read mode are somewhat speculative with the page faults, and
the result is always undefined when they run simultaneously. This is
probably why it wasn't common to run into this. For example if the
madvise(MADV_DONTNEED) runs zap_page_range() shortly before the page
fault, the hugepage will not be zapped, if the page fault runs first it
will be zapped.
Altering pmd_bad() not to error out if it finds hugepmds won't be enough
to fix this, because zap_pmd_range would then proceed to call
zap_pte_range (which would be incorrect if the pmd become a
pmd_trans_huge()).
The simplest way to fix this is to read the pmd in the local stack
(regardless of what we read, no need of actual CPU barriers, only
compiler barrier needed), and be sure it is not changing under the code
that computes its value. Even if the real pmd is changing under the
value we hold on the stack, we don't care. If we actually end up in
zap_pte_range it means the pmd was not none already and it was not huge,
and it can't become huge from under us (khugepaged locking explained
above).
All we need is to enforce that there is no way anymore that in a code
path like below, pmd_trans_huge can be false, but pmd_none_or_clear_bad
can run into a hugepmd. The overhead of a barrier() is just a compiler
tweak and should not be measurable (I only added it for THP builds). I
don't exclude different compiler versions may have prevented the race
too by caching the value of *pmd on the stack (that hasn't been
verified, but it wouldn't be impossible considering
pmd_none_or_clear_bad, pmd_bad, pmd_trans_huge, pmd_none are all inlines
and there's no external function called in between pmd_trans_huge and
pmd_none_or_clear_bad).
if (pmd_trans_huge(*pmd)) {
if (next-addr != HPAGE_PMD_SIZE) {
VM_BUG_ON(!rwsem_is_locked(&tlb->mm->mmap_sem));
split_huge_page_pmd(vma->vm_mm, pmd);
} else if (zap_huge_pmd(tlb, vma, pmd, addr))
continue;
/* fall through */
if (pmd_none_or_clear_bad(pmd))
Because this race condition could be exercised without special
privileges this was reported in CVE-2012-1179.
The race was identified and fully explained by Ulrich who debugged it.
I'm quoting his accurate explanation below, for reference.
====== start quote =======
mapcount 0 page_mapcount 1
kernel BUG at mm/huge_memory.c:1384!
At some point prior to the panic, a "bad pmd ..." message similar to the
following is logged on the console:
mm/memory.c:145: bad pmd ffff8800376e1f98(80000000314000e7).
The "bad pmd ..." message is logged by pmd_clear_bad() before it clears
the page's PMD table entry.
143 void pmd_clear_bad(pmd_t *pmd)
144 {
-> 145 pmd_ERROR(*pmd);
146 pmd_clear(pmd);
147 }
After the PMD table entry has been cleared, there is an inconsistency
between the actual number of PMD table entries that are mapping the page
and the page's map count (_mapcount field in struct page). When the page
is subsequently reclaimed, __split_huge_page() detects this inconsistency.
1381 if (mapcount != page_mapcount(page))
1382 printk(KERN_ERR "mapcount %d page_mapcount %d\n",
1383 mapcount, page_mapcount(page));
-> 1384 BUG_ON(mapcount != page_mapcount(page));
The root cause of the problem is a race of two threads in a multithreaded
process. Thread B incurs a page fault on a virtual address that has never
been accessed (PMD entry is zero) while Thread A is executing an madvise()
system call on a virtual address within the same 2 MB (huge page) range.
virtual address space
| | |<-- B(fault)
2 MB | |/////////////////////|-.
huge < |/////////////////////| > A(range)
page | |/////////////////////|-'
- Thread A is executing an madvise(..., MADV_DONTNEED) system call
on the virtual address range "A(range)" shown in the picture.
sys_madvise
// Acquire the semaphore in shared mode.
down_read(¤t->mm->mmap_sem)
madvise_vma
switch (behavior)
case MADV_DONTNEED:
madvise_dontneed
zap_page_range
unmap_vmas
unmap_page_range
zap_pud_range
zap_pmd_range
// Assume that this huge page has never been accessed.
// I.e. content of the PMD entry is zero (not mapped).
// We don't get here due to the above assumption.
// Assume that Thread B incurred a page fault and
.---------> // sneaks in here as shown below.
| if (unlikely(pmd_bad(*pmd)))
| pmd_clear_bad
| pmd_ERROR
| // Log "bad pmd ..." message here.
| pmd_clear
| // Clear the page's PMD entry.
| // Thread B incremented the map count
| // in page_add_new_anon_rmap(), but
| // now the page is no longer mapped
| // by a PMD entry (-> inconsistency).
v
- Thread B is handling a page fault on virtual address "B(fault)" shown
in the picture.
do_page_fault
__do_page_fault
down_read_trylock(&mm->mmap_sem)
handle_mm_fault
if (pmd_none(*pmd) && transparent_hugepage_enabled(vma))
// We get here due to the above assumption (PMD entry is zero).
do_huge_pmd_anonymous_page
alloc_hugepage_vma
// Allocate a new transparent huge page here.
__do_huge_pmd_anonymous_page
spin_lock(&mm->page_table_lock)
// Here we increment the page's map count (starts at -1).
atomic_set(&page->_mapcount, 0)
set_pmd_at
// Here we set the page's PMD entry which will be cleared
// when Thread A calls pmd_clear_bad().
spin_unlock(&mm->page_table_lock)
The mmap_sem does not prevent the race because both threads are acquiring
it in shared mode (down_read). Thread B holds the page_table_lock while
the page's map count and PMD table entry are updated. However, Thread A
does not synchronize on that lock.
====== end quote =======
[akpm@linux-foundation.org: checkpatch fixes]
Cc: Dave Jones <davej@redhat.com>
Acked-by: Larry Woodman <lwoodman@redhat.com>
Cc: Mark Salter <msalter@redhat.com>
commit d80e731ecab420ddcb79ee9d0ac427acbc187b4b upstream.
This patch is intentionally incomplete to simplify the review.
It ignores ep_unregister_pollwait() which plays with the same wqh.
See the next change.
epoll assumes that the EPOLL_CTL_ADD'ed file controls everything
f_op->poll() needs. In particular it assumes that the wait queue
can't go away until eventpoll_release(). This is not true in case
of signalfd, the task which does EPOLL_CTL_ADD uses its ->sighand
which is not connected to the file.
This patch adds the special event, POLLFREE, currently only for
epoll. It expects that init_poll_funcptr()'ed hook should do the
necessary cleanup. Perhaps it should be defined as EPOLLFREE in
eventpoll.
__cleanup_sighand() is changed to do wake_up_poll(POLLFREE) if
->signalfd_wqh is not empty, we add the new signalfd_cleanup()
helper.
ep_poll_callback(POLLFREE) simply does list_del_init(task_list).
This make this poll entry inconsistent, but we don't care. If you
share epoll fd which contains our sigfd with another process you
should blame yourself. signalfd is "really special". I simply do
not know how we can define the "right" semantics if it used with
epoll.
The main problem is, epoll calls signalfd_poll() once to establish
the connection with the wait queue, after that signalfd_poll(NULL)
returns the different/inconsistent results depending on who does
EPOLL_CTL_MOD/signalfd_read/etc. IOW: apart from sigmask, signalfd
has nothing to do with the file, it works with the current thread.
In short: this patch is the hack which tries to fix the symptoms.
It also assumes that nobody can take tasklist_lock under epoll
locks, this seems to be true.
Note:
- we do not have wake_up_all_poll() but wake_up_poll()
is fine, poll/epoll doesn't use WQ_FLAG_EXCLUSIVE.
- signalfd_cleanup() uses POLLHUP along with POLLFREE,
we need a couple of simple changes in eventpoll.c to
make sure it can't be "lost".
Reported-by: Maxime Bizon <mbizon@freebox.fr>
git://git.secretlab.ca/git/linux-2.6
* 'gpio/merge' of git://git.secretlab.ca/git/linux-2.6:
gpio: add GPIOF_ values regardless on kconfig settings
gpio: include linux/gpio.h where needed
gpio/omap4: Fix missing interrupts during device wakeup due to IOPAD.
* 'spi/merge' of git://git.secretlab.ca/git/linux-2.6:
spi/bfin_spi: fix handling of default bits per word setting
Make GPIOF_ defined values available even when GPIOLIB nor GENERIC_GPIO
is enabled by moving them to <linux/gpio.h>.
Fixes these build errors in linux-next:
sound/soc/codecs/ak4641.c:524: error: 'GPIOF_OUT_INIT_LOW' undeclared (first use in this function)
sound/soc/codecs/wm8915.c:2921: error: 'GPIOF_OUT_INIT_LOW' undeclared (first use in this function)
Signed-off-by: Nicolas Kaiser <nikai@nikai.net>
Reviewed-by: Andrea Arcangeli <aarcange@redhat.com>
* 'gpio/next' of git://git.secretlab.ca/git/linux-2.6:
gpio/pch_gpio: Support new device ML7223
gpio: make gpio_{request,free}_array gpio array parameter const
GPIO: OMAP: move to drivers/gpio
GPIO: OMAP: move register offset defines into <plat/gpio.h>
gpio: Convert gpio_is_valid to return bool
gpio: Move the s5pc100 GPIO to drivers/gpio
gpio: Move the s5pv210 GPIO to drivers/gpio
gpio: Move the exynos4 GPIO to drivers/gpio
gpio: Move to Samsung common GPIO library to drivers/gpio
gpio/nomadik: add function to read GPIO pull down status
gpio/nomadik: show all pins in debug
gpio: move Nomadik GPIO driver to drivers/gpio
gpio: move U300 GPIO driver to drivers/gpio
langwell_gpio: add runtime pm support
gpio/pca953x: Add support for pca9574 and pca9575 devices
gpio/cs5535: Show explicit dependency between gpio_cs5535 and mfd_cs5535
* setns:
ns: Wire up the setns system call
Done as a merge to make it easier to fix up conflicts in arm due to
addition of sendmmsg system call
32bit and 64bit on x86 are tested and working. The rest I have looked
at closely and I can't find any problems.
setns is an easy system call to wire up. It just takes two ints so I
don't expect any weird architecture porting problems.
While doing this I have noticed that we have some architectures that are
very slow to get new system calls. cris seems to be the slowest where
the last system calls wired up were preadv and pwritev. avr32 is weird
in that recvmmsg was wired up but never declared in unistd.h. frv is
behind with perf_event_open being the last syscall wired up. On h8300
the last system call wired up was epoll_wait. On m32r the last system
call wired up was fallocate. mn10300 has recvmmsg as the last system
call wired up. The rest seem to at least have syncfs wired up which was
new in the 2.6.39.
v2: Most of the architecture support added by Daniel Lezcano <dlezcano@fr.ibm.com>
v3: ported to v2.6.36-rc4 by: Eric W. Biederman <ebiederm@xmission.com>
v4: Moved wiring up of the system call to another patch
v5: ported to v2.6.39-rc6
v6: rebased onto parisc-next and net-next to avoid syscall conflicts.
v7: ported to Linus's latest post 2.6.39 tree.
> arch/blackfin/include/asm/unistd.h | 3 ++-
> arch/blackfin/mach-common/entry.S | 1 +
Oh - ia64 wiring looks good.
Acked-by: Tony Luck <tony.luck@intel.com>
gpio_{request,free}_array should not (and do not) modify the passed gpio
array, so make the parameter const.
Acked-by: Eric Miao <eric.y.miao@gmail.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6:
net: Kill ratelimit.h dependency in linux/net.h
net: Add linux/sysctl.h includes where needed.
net: Kill ether_table[] declaration.
inetpeer: fix race in unused_list manipulations
atm: expose ATM device index in sysfs
IPVS: bug in ip_vs_ftp, same list heaad used in all netns.
bug.h: Move ratelimit warn interfaces to ratelimit.h
bonding: cleanup module option descriptions
net:8021q:vlan.c Fix pr_info to just give the vlan fullname and version.
net: davinci_emac: fix dev_err use at probe
can: convert to %pK for kptr_restrict support
net: fix ETHTOOL_SFEATURES compatibility with old ethtool_ops.set_flags
netfilter: Fix several warnings in compat_mtw_from_user().
netfilter: ipset: fix ip_set_flush return code
netfilter: ipset: remove unused variable from type_pf_tdel()
netfilter: ipset: Use proper timeout value to jiffies conversion
Make the code a bit more readable.
Instead of casting an int to an unsigned then comparing to
MAX_NR_GPIOS, add a >= 0 test and let the compiler optimizer
do the conversion to unsigned.
The generated code should be the same.
The style that we normally use in asm-generic is to test the macro itself
for existence, so in asm-generic, do:
#ifndef find_next_zero_bit_le
extern unsigned long find_next_zero_bit_le(const void *addr,
unsigned long size, unsigned long offset);
#endif
and in the architectures, write
static inline unsigned long find_next_zero_bit_le(const void *addr,
#define find_next_zero_bit_le find_next_zero_bit_le
This adds the #ifndef for each of the find bitops in the generic header
and source files.
Suggested-by: Arnd Bergmann <arnd@arndb.de>
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
Cc: Greg Ungerer <gerg@uclinux.org>
This is a series of low level ptrace unification steps to make it easier
for common code (like KGDB) to poke at register state. This also avoids
having to duplicate higher level operations for most ports which don't
have special needs for accessing things.
This patch:
This implements a bunch of helper funcs for poking the registers of a
ptrace structure. Now common code should be able to portably update
specific registers (like kgdb updating the PC).
Cc: Jason Wessel <jason.wessel@windriver.com>
Cc: Sergei Shtylyov <sshtylyov@mvista.com>
Cc: Dongdong Deng <dongdong.deng@windriver.com>
As reported by Ingo Molnar, we still have configuration combinations
where use of the WARN_RATELIMIT interfaces break the build because
dependencies don't get met.
Instead of going down the long road of trying to make it so that
ratelimit.h can get included by kernel.h or asm-generic/bug.h,
just move the interface into ratelimit.h and make users have
to include that.
Reported-by: Ingo Molnar <mingo@elte.hu>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (89 commits)
bonding: documentation and code cleanup for resend_igmp
bonding: prevent deadlock on slave store with alb mode (v3)
net: hold rtnl again in dump callbacks
Add Fujitsu 1000base-SX PCI ID to tg3
bnx2x: protect sequence increment with mutex
sch_sfq: fix peek() implementation
isdn: netjet - blacklist Digium TDM400P
via-velocity: don't annotate MAC registers as packed
xen: netfront: hold RTNL when updating features.
sctp: fix memory leak of the ASCONF queue when free asoc
net: make dev_disable_lro use physical device if passed a vlan dev (v2)
net: move is_vlan_dev into public header file (v2)
bug.h: Fix build with CONFIG_PRINTK disabled.
wireless: fix fatal kernel-doc error + warning in mac80211.h
wireless: fix cfg80211.h new kernel-doc warnings
iwlagn: dbg_fixed_rate only used when CONFIG_MAC80211_DEBUGFS enabled
dst: catch uninitialized metrics
be2net: hash key for rss-config cmd not set
bridge: initialize fake_rtable metrics
net: fix __dst_destroy_metrics_generic()
Fix up trivial conflicts in drivers/staging/brcm80211/brcmfmac/wl_cfg80211.c
* git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile: (26 commits)
arch/tile: prefer "tilepro" as the name of the 32-bit architecture
compat: include aio_abi.h for aio_context_t
arch/tile: cleanups for tilegx compat mode
arch/tile: allocate PCI IRQs later in boot
arch/tile: support signal "exception-trace" hook
arch/tile: use better definitions of xchg() and cmpxchg()
include/linux/compat.h: coding-style fixes
tile: add an RTC driver for the Tilera hypervisor
arch/tile: finish enabling support for TILE-Gx 64-bit chip
compat: fixes to allow working with tile arch
arch/tile: update defconfig file to something more useful
tile: do_hardwall_trap: do not play with task->sighand
tile: replace mm->cpu_vm_mask with mm_cpumask()
tile,mn10300: add device parameter to dma_cache_sync()
audit: support the "standard" <asm-generic/unistd.h>
arch/tile: clarify flush_buffer()/finv_buffer() function names
arch/tile: kernel-related cleanups from removing static page size
arch/tile: various header improvements for building drivers
arch/tile: disable GX prefetcher during cache flush
arch/tile: tolerate disabling CONFIG_BLK_DEV_INITRD
Apps are increasingly using more than 1024 file descriptors. See
discussion in several distro bug trackers, e.g. BugLink:
http://bugs.launchpad.net/bugs/663090
https://issues.rpath.com/browse/RPL-2054
You don't want to raise the default soft limit, since that might break
apps that use select(), but it's safe to raise the default hard limit;
that way, apps that know they need lots of file descriptors can raise
their soft limit without needing root, and without user intervention.
Ubuntu is doing this with a kernel change because they have a policy of
not changing kernel defaults in userland.
While 4096 might not be enough for *all* apps, it seems to be plenty for
the apps I've seen lately that are unhappy with 1024.
Signed-off-by: Tim Gardner <tim.gardner@canonical.com>
Cc: Dan Kegel <dank@kegel.com>
The copy_to_user_page() function is supposed to flush the icache on the
memory that was written, but the current asm-generic version lacks that
logic. While normally it isn't a big deal as the asm-generic version of
icache flushing is a stub, it is a deal for ports that want to use the
asm-generic version as a baseline and then overlay its own specific parts
(like icache flushing).
Some of these functions have grown beyond inline sanity, move them
out-of-line.
Requested-by: Andrew Morton <akpm@linux-foundation.org>
Requested-by: Hugh Dickins <hughd@google.com>
Instead of using a single batch (the small on-stack, or an allocated
page), try and extend the batch every time it runs out and only flush once
either the extend fails or we're done.
Requested-by: Nick Piggin <npiggin@kernel.dk>
Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Cc: Jeff Dike <jdike@addtoit.com>
Cc: Richard Weinberger <richard@nod.at>
Cc: Nick Piggin <npiggin@kernel.dk>
Cc: Namhyung Kim <namhyung@gmail.com>
In case other architectures require RCU freed page-tables to implement
gup_fast() and software filled hashes and similar things, provide the
means to do so by moving the logic into generic code.
Requested-by: David Miller <davem@davemloft.net>
Rework the existing mmu_gather infrastructure.
The direct purpose of these patches was to allow preemptible mmu_gather,
but even without that I think these patches provide an improvement to the
status quo.
The first 9 patches rework the mmu_gather infrastructure. For review
purpose I've split them into generic and per-arch patches with the last of
those a generic cleanup.
The next patch provides generic RCU page-table freeing, and the followup
is a patch converting s390 to use this. I've also got 4 patches from
DaveM lined up (not included in this series) that uses this to implement
gup_fast() for sparc64.
Then there is one patch that extends the generic mmu_gather batching.
After that follow the mm preemptibility patches, these make part of the mm
a lot more preemptible. It converts i_mmap_lock and anon_vma->lock to
mutexes which together with the mmu_gather rework makes mmu_gather
preemptible as well.
Making i_mmap_lock a mutex also enables a clean-up of the truncate code.
This also allows for preemptible mmu_notifiers, something that XPMEM I
think wants.
Furthermore, it removes the new and universially detested unmap_mutex.
This patch:
Remove the first obstacle towards a fully preemptible mmu_gather.
The current scheme assumes mmu_gather is always done with preemption
disabled and uses per-cpu storage for the page batches. Change this to
try and allocate a page for batching and in case of failure, use a small
on-stack array to make some progress.
Preemptible mmu_gather is desired in general and usable once i_mmap_lock
becomes a mutex. Doing it before the mutex conversion saves us from
having to rework the code by moving the mmu_gather bits inside the
pte_lock.
Also avoid flushing the tlb batches from under the pte lock, this is
useful even without the i_mmap_lock conversion as it significantly reduces
pte lock hold times.
[akpm@linux-foundation.org: fix comment tpyo]
Acked-by: Mel Gorman <mel@csn.ul.ie>
Based upon an email by Joe Perches.
Reported-by: Randy Dunlap <randy.dunlap@oracle.com>
* 'for-linus' of git://git390.marist.edu/pub/scm/linux-2.6: (29 commits)
[S390] cpu hotplug: fix external interrupt subclass mask handling
[S390] oprofile: dont access lowcore
[S390] oprofile: add missing irq stats counter
[S390] Ignore sendmmsg system call note wired up warning
[S390] s390,oprofile: fix compile error for !CONFIG_SMP
[S390] s390,oprofile: fix alert counter increment
[S390] Remove unused includes in process.c
[S390] get CPC image name
[S390] sclp: event buffer dissection
[S390] chsc: process channel-path-availability information
[S390] refactor page table functions for better pgste support
[S390] merge page_test_dirty and page_clear_dirty
[S390] qdio: prevent compile warning
[S390] sclp: remove unnecessary sendmask check
[S390] convert old cpumask API into new one
[S390] pfault: cleanup code
[S390] pfault: cpu hotplug vs missing completion interrupts
[S390] smp: add __noreturn attribute to cpu_die()
[S390] percpu: implement arch specific irqsafe_cpu_ops
[S390] vdso: disable gcov profiling
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu
* 'for-2.6.40' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu:
percpu: Unify input section names
percpu: Avoid extra NOP in percpu_cmpxchg16b_double
percpu: Cast away printk format warning
percpu: Always align percpu output section to PAGE_SIZE
Fix up fairly trivial conflict in arch/x86/include/asm/percpu.h as per Tejun
Add a generic mechanism to ratelimit WARN(foo, fmt, ...) messages
using a hidden per call site static struct ratelimit_state.
Also add an __WARN_RATELIMIT variant to be able to use a specific
The page_clear_dirty primitive always sets the default storage key
which resets the access control bits and the fetch protection bit.
That will surprise a KVM guest that sets non-zero access control
bits or the fetch protection bit. Merge page_test_dirty and
page_clear_dirty back to a single function and only clear the
dirty bit from the storage key.
In addition move the function page_test_and_clear_dirty and
page_test_and_clear_young to page.h where they belong. This
requires to change the parameter from a struct page * to a page
frame number.
Commit e66eed651fd1 ("list: remove prefetching from regular list
iterators") removed the include of prefetch.h from list.h, which
uncovered several cases that had apparently relied on that rather
obscure header file dependency.
So this fixes things up a bit, using
grep -L linux/prefetch.h $(git grep -l '[^a-z_]prefetchw*(' -- '*.[ch]')
grep -L 'prefetchw*(' $(git grep -l 'linux/prefetch.h' -- '*.[ch]')
to guide us in finding files that either need <linux/prefetch.h>
inclusion, or have it despite not needing it.
There are more of them around (mostly network drivers), but this gets
many core ones.
* 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (107 commits)
perf stat: Add more cache-miss percentage printouts
perf stat: Add -d -d and -d -d -d options to show more CPU events
ftrace/kbuild: Add recordmcount files to force full build
ftrace: Add self-tests for multiple function trace users
ftrace: Modify ftrace_set_filter/notrace to take ops
ftrace: Allow dynamically allocated function tracers
ftrace: Implement separate user function filtering
ftrace: Free hash with call_rcu_sched()
ftrace: Have global_ops store the functions that are to be traced
ftrace: Add ops parameter to ftrace_startup/shutdown functions
ftrace: Add enabled_functions file
ftrace: Use counters to enable functions to trace
ftrace: Separate hash allocation and assignment
ftrace: Create a global_ops to hold the filter and notrace hashes
ftrace: Use hash instead for FTRACE_FL_FILTER
ftrace: Replace FTRACE_FL_NOTRACE flag with a hash of ignored functions
perf bench, x86: Add alternatives-asm.h wrapper
x86, 64-bit: Fix copy_[to/from]_user() checks for the userspace address limit
x86, mem: memset_64.S: Optimize memset by enhanced REP MOVSB/STOSB
x86, mem: memmove_64.S: Optimize memmove by enhanced REP MOVSB/STOSB
This patch places every exported symbol in its own section
(i.e. "___ksymtab+printk"). Thus the linker will use its SORT() directive
to sort and finally merge all symbol in the right and final section
(i.e. "__ksymtab").
The symbol prefixed archs use an underscore as prefix for symbols.
To avoid collision we use a different character to create the temporary
section names.
This work was supported by a hardware donation from the CE Linux Forum.
Signed-off-by: Alessio Igor Bogani <abogani@kernel.org>
Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> (folded in '+' fixup)
Tested-by: Dirk Behme <dirk.behme@googlemail.com>
The existing <asm-generic/unistd.h> mechanism doesn't really provide
enough to create the 64-bit "compat" ABI properly in a generic way,
since the compat ABI is a mix of things were you can re-use the 64-bit
versions of syscalls and things where you need a compat wrapper.
To provide this in the most direct way possible, I added two new macros
to go along with the existing __SYSCALL and __SC_3264 macros: __SC_COMP
and SC_COMP_3264. These macros take an additional argument, typically a
"compat_sys_xxx" function, which is passed to __SYSCALL if you define
__SYSCALL_COMPAT when including the header, resulting in a pointer to
the compat function being placed in the generated syscall table.
The change also adds some missing definitions to <linux/compat.h> so that
it actually has declarations for all the compat syscalls, since the
"[nr] = ##call" approach requires proper C declarations for all the
functions included in the syscall table.
Finally, compat.c defines compat_sys_sigpending() and
compat_sys_sigprocmask() even if the underlying architecture doesn't
request it, which tries to pull in undefined compat_old_sigset_t defines.
We need to guard those compat syscall definitions with appropriate
__ARCH_WANT_SYS_xxx ifdefs.
Many of the syscalls mentioned in the audit code are not present
for architectures that implement only the "standard" set of
Linux syscalls (e.g. openat, but not open, etc.). This change
adds proper #ifdefs for all those syscalls.
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-2.6-trace into perf/core
include/linux/perf_event.h
Merge reason: pick up the latest jump-label enhancements, they are cooked ready.
* 'for-linus2' of git://git.profusion.mobi/users/lucas/linux-2.6:
Fix common misspellings
Introduce:
static __always_inline bool static_branch(struct jump_label_key *key);
instead of the old JUMP_LABEL(key, label) macro.
In this way, jump labels become really easy to use:
Define:
struct jump_label_key jump_key;
Can be used as:
if (static_branch(&jump_key))
do unlikely code
enable/disale via:
jump_label_inc(&jump_key);
jump_label_dec(&jump_key);
that's it!
For the jump labels disabled case, the static_branch() becomes an
atomic_read(), and jump_label_inc()/dec() are simply atomic_inc(),
atomic_dec() operations. We show testing results for this change below.
Thanks to H. Peter Anvin for suggesting the 'static_branch()' construct.
Since we now require a 'struct jump_label_key *key', we can store a pointer into
the jump table addresses. In this way, we can enable/disable jump labels, in
basically constant time. This change allows us to completely remove the previous
hashtable scheme. Thanks to Peter Zijlstra for this re-write.
Testing:
I ran a series of 'tbench 20' runs 5 times (with reboots) for 3
configurations, where tracepoints were disabled.
jump label configured in
avg: 815.6
jump label *not* configured in (using atomic reads)
avg: 800.1
jump label *not* configured in (regular reads)
avg: 803.4
LKML-Reference: <20110316212947.GA8792@redhat.com>
Signed-off-by: Jason Baron <jbaron@redhat.com>
Suggested-by: H. Peter Anvin <hpa@linux.intel.com>
Tested-by: David Daney <ddaney@caviumnetworks.com>
Acked-by: Ralf Baechle <ralf@linux-mips.org>
Acked-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com>
The two percpu helper macros have the section names duplicated. So create
a new define to merge the two. This also allows arches who need to link
things more directly themselves to avoid duplicating the input sections in
their linker script.
The define to use ({0;}) for the !CONFIG_SMP case of WARN_ON_SMP()
can be confusing. As the WARN_ON_SMP() needs to be a nop when
CONFIG_SMP is not set, including all its parameters must not be
evaluated, and that it must work as both a stand alone statement
and inside an if condition, we define it to a funky ({0;}).
A simple "0" will not work as it causes gcc to give the warning that
the statement has no effect.
As this strange definition has raised a few eyebrows from some
major kernel developers, it is wise to document why we create such
a work of art.
Cc: Alexey Dobriyan <adobriyan@gmail.com>
* 'core-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
futex: Fix WARN_ON() test for UP
WARN_ON_SMP(): Allow use in if() statements on UP
x86, dumpstack: Use %pB format specifier for stack trace
vsprintf: Introduce %pB format specifier
lockdep: Remove unused 'factor' variable from lockdep_stats_show()
Both WARN_ON() and WARN_ON_SMP() should be able to be used in
an if statement.
if (WARN_ON_SMP(foo)) { ... }
Because WARN_ON_SMP() is defined as a do { } while (0) on UP,
it can not be used this way.
Convert it to the same form that WARN_ON() is, even when
CONFIG_SMP is off.
Acked-by: Peter Zijlstra <peterz@infradead.org>
Acked-by: Darren Hart <dvhart@linux.intel.com>
Cc: Lai Jiangshan <laijs@cn.fujitsu.com>
LKML-Reference: <20110317192208.444147791@goodmis.org>
Percpu allocator honors alignment request upto PAGE_SIZE and both the
percpu addresses in the percpu address space and the translated kernel
addresses should be aligned accordingly. The calculation of the
former depends on the alignment of percpu output section in the kernel
image.
The linker script macros PERCPU_VADDR() and PERCPU() are used to
define this output section and the latter takes @align parameter.
Several architectures are using @align smaller than PAGE_SIZE breaking
percpu memory alignment.
This patch removes @align parameter from PERCPU(), renames it to
PERCPU_SECTION() and makes it always align to PAGE_SIZE. While at it,
add PCPU_SETUP_BUG_ON() checks such that alignment problems are
reliably detected and remove percpu alignment comment recently added
in workqueue.c as the condition would trigger BUG way before reaching
there.
For um, this patch raises the alignment of percpu area. As the area
is in .init, there shouldn't be any noticeable difference.
This problem was discovered by David Howells while debugging boot
failure on mn10300.
Cc: uclinux-dist-devel@blackfin.uclinux.org
Cc: user-mode-linux-devel@lists.sourceforge.net
minix bit operations are only used by minix filesystem and useless by
other modules. Because byte order of inode and block bitmaps is different
on each architecture like below:
m68k:
big-endian 16bit indexed bitmaps
h8300, microblaze, s390, sparc, m68knommu:
big-endian 32 or 64bit indexed bitmaps
m32r, mips, sh, xtensa:
big-endian 32 or 64bit indexed bitmaps for big-endian mode
little-endian bitmaps for little-endian mode
Others:
In order to move minix bit operations from asm/bitops.h to architecture
independent code in minix filesystem, this provides two config options.
CONFIG_MINIX_FS_BIG_ENDIAN_16BIT_INDEXED is only selected by m68k.
CONFIG_MINIX_FS_NATIVE_ENDIAN is selected by the architectures which use
native byte order bitmaps (h8300, microblaze, s390, sparc, m68knommu,
m32r, mips, sh, xtensa). The architectures which always use little-endian
bitmaps do not select these options.
Finally, we can remove minix bit operations from asm/bitops.h for all
architectures.
Acked-by: Greg Ungerer <gerg@uclinux.org>
Cc: Roman Zippel <zippel@linux-m68k.org>
Cc: Andreas Schwab <schwab@linux-m68k.org>
Cc: Yoshinori Sato <ysato@users.sourceforge.jp>
Cc: Hirokazu Takata <takata@linux-m32r.org>
Acked-by: Paul Mundt <lethal@linux-sh.org>
Cc: Chris Zankel <chris@zankel.net>
