path: root/include/asm-generic
2009-01-26Merge branch 'x86-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (29 commits) xen: unitialised return value in xenbus_write_transaction x86: fix section mismatch warning x86: unmask CPUID levels on Intel CPUs, fix x86: work around PAGE_KERNEL_WC not getting WC in iomap_atomic_prot_pfn. x86: use standard PIT frequency xen: handle highmem pages correctly when shrinking a domain x86, mm: fix pte_free() xen: actually release memory when shrinking domain x86: unmask CPUID levels on Intel CPUs x86: add MSR_IA32_MISC_ENABLE bits to <asm/msr-index.h> x86: fix PTE corruption issue while mapping RAM using /dev/mem x86: mtrr fix debug boot parameter x86: fix page attribute corruption with cpa() Revert "x86: signal: change type of paramter for sys_rt_sigreturn()" x86: use early clobbers in usercopy*.c x86: remove kernel_physical_mapping_init() from init section fix: crash: IP: __bitmap_intersects+0x48/0x73 cpufreq: use work_on_cpu in acpi-cpufreq.c for drv_read and drv_write work_on_cpu: Use our own workqueue. work_on_cpu: don't try to get_online_cpus() in work_on_cpu. ...
2009-01-15alpha: fix RTC on marvelIvan Kokshaysky
Unlike other alphas, marvel doesn't have real PC-style CMOS clock hardware - RTC accesses are emulated via PAL calls. Unfortunately, for unknown reason these calls work only on CPU #0. So current implementation for arbitrary CPU makes CMOS_READ/WRITE to be executed on CPU #0 via IPI. However, for obvious reason this doesn't work with standard get/set_rtc_time() functions, where a bunch of CMOS accesses is done with disabled interrupts. Solved by making the IPI calls for entire get/set_rtc_time() functions, not for individual CMOS accesses. Which is also a lot more effective performance-wise. The patch is largely based on the code from Jay Estabrook. My changes: - tweak asm-generic/rtc.h by adding a couple of #defines to avoid a massive code duplication in arch/alpha/include/asm/rtc.h; - sys_marvel.c: fix get/set_rtc_time() return values (Jay's FIXMEs). NOTE: this fixes *only* LIB_RTC drivers. Legacy (CONFIG_RTC) driver wont't work on marvel. Actually I think that we should just disable CONFIG_RTC on alpha (maybe in 2.6.30?), like most other arches - AFAIK, all modern distributions use LIB_RTC anyway. Signed-off-by: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Richard Henderson <rth@twiddle.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-14byteorder: make swab.h include asm/swab.h like a regular headerHarvey Harrison
Add swab.h to kbuild.asm and remove the individual entries from each arch, mark as unifdef as some arches have some kernel-only bits inside. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-13x86 PAT: change track_pfn_vma_new to take pgprot_t pointer paramvenkatesh.pallipadi@intel.com
Impact: cleanup Change the protection parameter for track_pfn_vma_new() into a pgprot_t pointer. Subsequent patch changes the x86 PAT handling to return a compatible memtype in pgprot_t, if what was requested cannot be allowed due to conflicts. No fuctionality change in this patch. Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-01-13x86, generic: mark complex bitops.h inlines as __always_inlineAndi Kleen
Impact: reduce kernel image size Hugh Dickins noticed that older gcc versions when the kernel is built for code size didn't inline some of the bitops. Mark all complex x86 bitops that have more than a single asm statement or two as always inline to avoid this problem. Probably should be done for other architectures too. Ingo then found a better fix that only requires a single line change, but it unfortunately only works on gcc 4.3. On older gccs the original patch still makes a ~0.3% defconfig difference with CONFIG_OPTIMIZE_INLINING=y. With gcc 4.1 and a defconfig like build: 6116998 1138540 883788 8139326 7c323e vmlinux-oi-with-patch 6137043 1138540 883788 8159371 7c808b vmlinux-optimize-inlining ~20k / 0.3% difference. Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-01-06remove linux/hardirq.h from asm-generic/local.hRussell King
While looking at reducing the amount of architecture namespace pollution in the generic kernel, I found that asm/irq.h is included in the vast majority of compilations on ARM (around 650 files.) Since asm/irq.h includes a sub-architecture include file on ARM, this causes a negative impact on the ccache's ability to re-use the build results from other sub-architectures, so we have a desire to reduce the dependencies on asm/irq.h. It turns out that a major cause of this is the needless include of linux/hardirq.h into asm-generic/local.h. The patch below removes this include, resulting in some 250 to 300 files (around half) of the kernel then omitting asm/irq.h. My test builds still succeed, provided two ARM files are fixed (arch/arm/kernel/traps.c and arch/arm/mm/fault.c) - so there may be negative impacts for this on other architectures. Note that x86 does not include asm/irq.h nor linux/hardirq.h in its asm/local.h, so this patch can be viewed as bringing the generic version into line with the x86 version. [kosaki.motohiro@jp.fujitsu.com: add #include <linux/irqflags.h> to acpi/processor_idle.c] [adobriyan@gmail.com: fix sparc64] Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06documentation: when to BUG(), and when to not BUG()David Brownell
Provide some basic advice about when to use BUG()/BUG_ON(): never, unless there's really no better option. This matches my understanding of the standard policy ... which seems not to be written down so far, outside of LKML messages that I haven't bookmarked. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Hans Verkuil <hverkuil@xs4all.nl> Cc: Ingo Molnar <mingo@elte.hu> Cc: Arjan van de Ven <arjan@infradead.org> Cc: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06mm: remove CONFIG_OUT_OF_LINE_PFN_TO_PAGEKOSAKI Motohiro
No architectures use CONFIG_OUT_OF_LINE_PFN_TO_PAGE - it can be removed. Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-02Merge branch 'cpus4096-for-linus-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'cpus4096-for-linus-2' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (66 commits) x86: export vector_used_by_percpu_irq x86: use logical apicid in x2apic_cluster's x2apic_cpu_mask_to_apicid_and() sched: nominate preferred wakeup cpu, fix x86: fix lguest used_vectors breakage, -v2 x86: fix warning in arch/x86/kernel/io_apic.c sched: fix warning in kernel/sched.c sched: move test_sd_parent() to an SMP section of sched.h sched: add SD_BALANCE_NEWIDLE at MC and CPU level for sched_mc>0 sched: activate active load balancing in new idle cpus sched: bias task wakeups to preferred semi-idle packages sched: nominate preferred wakeup cpu sched: favour lower logical cpu number for sched_mc balance sched: framework for sched_mc/smt_power_savings=N sched: convert BALANCE_FOR_xx_POWER to inline functions x86: use possible_cpus=NUM to extend the possible cpus allowed x86: fix cpu_mask_to_apicid_and to include cpu_online_mask x86: update io_apic.c to the new cpumask code x86: Introduce topology_core_cpumask()/topology_thread_cpumask() x86: xen: use smp_call_function_many() x86: use work_on_cpu in x86/kernel/cpu/mcheck/mce_amd_64.c ... Fixed up trivial conflict in kernel/time/tick-sched.c manually
2008-12-30Merge branch 'core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (63 commits) stacktrace: provide save_stack_trace_tsk() weak alias rcu: provide RCU options on non-preempt architectures too printk: fix discarding message when recursion_bug futex: clean up futex_(un)lock_pi fault handling "Tree RCU": scalable classic RCU implementation futex: rename field in futex_q to clarify single waiter semantics x86/swiotlb: add default swiotlb_arch_range_needs_mapping x86/swiotlb: add default phys<->bus conversion x86: unify pci iommu setup and allow swiotlb to compile for 32 bit x86: add swiotlb allocation functions swiotlb: consolidate swiotlb info message printing swiotlb: support bouncing of HighMem pages swiotlb: factor out copy to/from device swiotlb: add arch hook to force mapping swiotlb: allow architectures to override phys<->bus<->phys conversions swiotlb: add comment where we handle the overflow of a dma mask on 32 bit rcu: fix rcutorture behavior during reboot resources: skip sanity check of busy resources swiotlb: move some definitions to header swiotlb: allow architectures to override swiotlb pool allocation ... Fix up trivial conflicts in arch/x86/kernel/Makefile arch/x86/mm/init_32.c include/linux/hardirq.h as per Ingo's suggestions.
2008-12-28Merge branch 'for-linus' of git://git390.osdl.marist.edu/pub/scm/linux-2.6Linus Torvalds
* 'for-linus' of git://git390.osdl.marist.edu/pub/scm/linux-2.6: (85 commits) [S390] provide documentation for hvc_iucv kernel parameter. [S390] convert ctcm printks to dev_xxx and pr_xxx macros. [S390] convert zfcp printks to pr_xxx macros. [S390] convert vmlogrdr printks to pr_xxx macros. [S390] convert zfcp dumper printks to pr_xxx macros. [S390] convert cpu related printks to pr_xxx macros. [S390] convert qeth printks to dev_xxx and pr_xxx macros. [S390] convert sclp printks to pr_xxx macros. [S390] convert iucv printks to dev_xxx and pr_xxx macros. [S390] convert ap_bus printks to pr_xxx macros. [S390] convert dcssblk and extmem printks messages to pr_xxx macros. [S390] convert monwriter printks to pr_xxx macros. [S390] convert s390 debug feature printks to pr_xxx macros. [S390] convert monreader printks to pr_xxx macros. [S390] convert appldata printks to pr_xxx macros. [S390] convert setup printks to pr_xxx macros. [S390] convert hypfs printks to pr_xxx macros. [S390] convert time printks to pr_xxx macros. [S390] convert cpacf printks to pr_xxx macros. [S390] convert cio printks to pr_xxx macros. ...
2008-12-28Merge branch 'tracing-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'tracing-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (241 commits) sched, trace: update trace_sched_wakeup() tracing/ftrace: don't trace on early stage of a secondary cpu boot, v3 Revert "x86: disable X86_PTRACE_BTS" ring-buffer: prevent false positive warning ring-buffer: fix dangling commit race ftrace: enable format arguments checking x86, bts: memory accounting x86, bts: add fork and exit handling ftrace: introduce tracing_reset_online_cpus() helper tracing: fix warnings in kernel/trace/trace_sched_switch.c tracing: fix warning in kernel/trace/trace.c tracing/ring-buffer: remove unused ring_buffer size trace: fix task state printout ftrace: add not to regex on filtering functions trace: better use of stack_trace_enabled for boot up code trace: add a way to enable or disable the stack tracer x86: entry_64 - introduce FTRACE_ frame macro v2 tracing/ftrace: add the printk-msg-only option tracing/ftrace: use preempt_enable_no_resched_notrace in ring_buffer_time_stamp() x86, bts: correctly report invalid bts records ... Fixed up trivial conflict in scripts/recordmcount.pl due to SH bits being already partly merged by the SH merge.
2008-12-25Merge branch 'core/debug' into core/coreIngo Molnar
2008-12-25[S390] __page_to_pfn warningsMartin Schwidefsky
For CONFIG_SPARSEMEM_VMEMMAP=y on s390 I get warnings like init/main.c: In function 'start_kernel': init/main.c:641: warning: format '%08lx' expects type 'long unsigned int', but argument 2 has type 'int' The warning can be suppressed with a cast to unsigned long in the CONFIG_SPARSEMEM_VMEMMAP=y version of __page_to_pfn. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2008-12-23Merge branches 'x86/apic', 'x86/cleanups', 'x86/cpufeature', ↵Ingo Molnar
'x86/crashdump', 'x86/debug', 'x86/defconfig', 'x86/detect-hyper', 'x86/doc', 'x86/dumpstack', 'x86/early-printk', 'x86/fpu', 'x86/idle', 'x86/io', 'x86/memory-corruption-check', 'x86/microcode', 'x86/mm', 'x86/mtrr', 'x86/nmi-watchdog', 'x86/pat2', 'x86/pci-ioapic-boot-irq-quirks', 'x86/ptrace', 'x86/quirks', 'x86/reboot', 'x86/setup-memory', 'x86/signal', 'x86/sparse-fixes', 'x86/time', 'x86/uv' and 'x86/xen' into x86/core
2008-12-19x86: PAT: move track untrack pfnmap stubs to asm-genericvenkatesh.pallipadi@intel.com
Impact: Cleanup and branch hints only. Move the track and untrack pfn stub routines from memory.c to asm-generic. Also add unlikely to pfnmap related calls in fork and exit path. Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2008-12-19Merge branches 'tracing/ftrace', 'tracing/ring-buffer' and 'tracing/urgent' ↵Ingo Molnar
into tracing/core Conflicts: include/linux/ftrace.h
2008-12-18x86: PAT: add pgprot_writecombine() interface for drivers - v3venkatesh.pallipadi@intel.com
Impact: New mm functionality. Add pgprot_writecombine. pgprot_writecombine will be aliased to pgprot_noncached when not supported by the architecture. Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2008-12-16allow bug table entries to use relative pointers (and use it on x86-64)Jan Beulich
Impact: reduce bug table size This allows reducing the bug table size by half. Perhaps there are other 64-bit architectures that could also make use of this. Signed-off-by: Jan Beulich <jbeulich@novell.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-12-13Merge ../linux-2.6-x86Rusty Russell
Conflicts: arch/x86/kernel/io_apic.c kernel/sched.c kernel/sched_stats.h
2008-12-13cpumask: Introduce cpumask_of_{node,pcibus} to replace {node,pcibus}_to_cpumaskRusty Russell
Impact: New APIs The old node_to_cpumask/node_to_pcibus returned a cpumask_t: these return a pointer to a struct cpumask. Part of removing cpumasks from the stack. This defines them in the generic non-NUMA case. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Tony Luck <tony.luck@intel.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Richard Henderson <rth@twiddle.net>
2008-12-12Merge branch 'sched/core' into cpus4096Ingo Molnar
Conflicts: include/linux/ftrace.h kernel/sched.c
2008-12-12tracing/function-graph-tracer: add a new .irqentry.text sectionFrederic Weisbecker
Impact: let the function-graph-tracer be aware of the irq entrypoints Add a new .irqentry.text section to store the irq entrypoints functions inside the same section. This way, the tracer will be able to signal an interrupts triggering on output by recognizing these entrypoints. Also, make this section recordable for dynamic tracing. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-12-10atomic: fix a typo in atomic_long_xchg()Eric Dumazet
atomic_long_xchg() is not correctly defined for 32bit arches. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Cc: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-12-09[PATCH] asm/generic: fix bug - kernel fails to build when enable some common ↵Mike Frysinger
audit code on Blackfin If you enable some common audit code, the kernel fails to build. In file included from lib/audit.c:17: include/asm-generic/audit_write.h:3: error: '__NR_swapon' undeclared here (not in a function) make[1]: *** [lib/audit.o] Error 1 make: *** [lib] Error 2 So do not use __NR_swapon if it isnt defined for a port. Signed-off-by: Mike Frysinger <vapier.adi@gmail.com> Signed-off-by: Bryan Wu <cooloney@kernel.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-11-28debug warnings: eliminate warn_on_slowpath()Ingo Molnar
Impact: cleanup, eliminate code now that warn_on_slowpath() uses warn_slowpath(...,NULL), we can eliminate warn_on_slowpath() altogether and use warn_slowpath(). Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-11-23trace: profile all if conditionalsSteven Rostedt
Impact: feature to profile if statements This patch adds a branch profiler for all if () statements. The results will be found in: /debugfs/tracing/profile_branch For example: miss hit % Function File Line ------- --------- - -------- ---- ---- 0 1 100 x86_64_start_reservations head64.c 127 0 1 100 copy_bootdata head64.c 69 1 0 0 x86_64_start_kernel head64.c 111 32 0 0 set_intr_gate desc.h 319 1 0 0 reserve_ebda_region head.c 51 1 0 0 reserve_ebda_region head.c 47 0 1 100 reserve_ebda_region head.c 42 0 0 X maxcpus main.c 165 Miss means the branch was not taken. Hit means the branch was taken. The percent is the percentage the branch was taken. This adds a significant amount of overhead and should only be used by those analyzing their system. Signed-off-by: Steven Rostedt <srostedt@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-11-23trace: consolidate unlikely and likely profilerSteven Rostedt
Impact: clean up to make one profiler of like and unlikely tracer The likely and unlikely profiler prints out the file and line numbers of the annotated branches that it is profiling. It shows the number of times it was correct or incorrect in its guess. Having two different files or sections for that matter to tell us if it was a likely or unlikely is pretty pointless. We really only care if it was correct or not. Signed-off-by: Steven Rostedt <srostedt@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-11-16tracepoints: add DECLARE_TRACE() and DEFINE_TRACE()Mathieu Desnoyers
Impact: API *CHANGE*. Must update all tracepoint users. Add DEFINE_TRACE() to tracepoints to let them declare the tracepoint structure in a single spot for all the kernel. It helps reducing memory consumption, especially when declaring a lot of tracepoints, e.g. for kmalloc tracing. *API CHANGE WARNING*: now, DECLARE_TRACE() must be used in headers for tracepoint declarations rather than DEFINE_TRACE(). This is the sane way to do it. The name previously used was misleading. Updates scheduler instrumentation to follow this API change. Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-11-12trace: rename unlikely profiler to branch profilerSteven Rostedt
Impact: name change of unlikely tracer and profiler Ingo Molnar suggested changing the config from UNLIKELY_PROFILE to BRANCH_PROFILING. I never did like the "unlikely" name so I went one step farther, and renamed all the unlikely configurations to a "BRANCH" variant. Signed-off-by: Steven Rostedt <srostedt@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-11-12tracing: profile likely and unlikely annotationsSteven Rostedt
Impact: new unlikely/likely profiler Andrew Morton recently suggested having an in-kernel way to profile likely and unlikely macros. This patch achieves that goal. When configured, every(*) likely and unlikely macro gets a counter attached to it. When the condition is hit, the hit and misses of that condition are recorded. These numbers can later be retrieved by: /debugfs/tracing/profile_likely - All likely markers /debugfs/tracing/profile_unlikely - All unlikely markers. # cat /debug/tracing/profile_unlikely | head correct incorrect % Function File Line ------- --------- - -------- ---- ---- 2167 0 0 do_arch_prctl process_64.c 832 0 0 0 do_arch_prctl process_64.c 804 2670 0 0 IS_ERR err.h 34 71230 5693 7 __switch_to process_64.c 673 76919 0 0 __switch_to process_64.c 639 43184 33743 43 __switch_to process_64.c 624 12740 64181 83 __switch_to process_64.c 594 12740 64174 83 __switch_to process_64.c 590 # cat /debug/tracing/profile_unlikely | \ awk '{ if ($3 > 25) print $0; }' |head -20 44963 35259 43 __switch_to process_64.c 624 12762 67454 84 __switch_to process_64.c 594 12762 67447 84 __switch_to process_64.c 590 1478 595 28 syscall_get_error syscall.h 51 0 2821 100 syscall_trace_leave ptrace.c 1567 0 1 100 native_smp_prepare_cpus smpboot.c 1237 86338 265881 75 calc_delta_fair sched_fair.c 408 210410 108540 34 calc_delta_mine sched.c 1267 0 54550 100 sched_info_queued sched_stats.h 222 51899 66435 56 pick_next_task_fair sched_fair.c 1422 6 10 62 yield_task_fair sched_fair.c 982 7325 2692 26 rt_policy sched.c 144 0 1270 100 pre_schedule_rt sched_rt.c 1261 1268 48073 97 pick_next_task_rt sched_rt.c 884 0 45181 100 sched_info_dequeued sched_stats.h 177 0 15 100 sched_move_task sched.c 8700 0 15 100 sched_move_task sched.c 8690 53167 33217 38 schedule sched.c 4457 0 80208 100 sched_info_switch sched_stats.h 270 30585 49631 61 context_switch sched.c 2619 # cat /debug/tracing/profile_likely | awk '{ if ($3 > 25) print $0; }' 39900 36577 47 pick_next_task sched.c 4397 20824 15233 42 switch_mm mmu_context_64.h 18 0 7 100 __cancel_work_timer workqueue.c 560 617 66484 99 clocksource_adjust timekeeping.c 456 0 346340 100 audit_syscall_exit auditsc.c 1570 38 347350 99 audit_get_context auditsc.c 732 0 345244 100 audit_syscall_entry auditsc.c 1541 38 1017 96 audit_free auditsc.c 1446 0 1090 100 audit_alloc auditsc.c 862 2618 1090 29 audit_alloc auditsc.c 858 0 6 100 move_masked_irq migration.c 9 1 198 99 probe_sched_wakeup trace_sched_switch.c 58 2 2 50 probe_wakeup trace_sched_wakeup.c 227 0 2 100 probe_wakeup_sched_switch trace_sched_wakeup.c 144 4514 2090 31 __grab_cache_page filemap.c 2149 12882 228786 94 mapping_unevictable pagemap.h 50 4 11 73 __flush_cpu_slab slub.c 1466 627757 330451 34 slab_free slub.c 1731 2959 61245 95 dentry_lru_del_init dcache.c 153 946 1217 56 load_elf_binary binfmt_elf.c 904 102 82 44 disk_put_part genhd.h 206 1 1 50 dst_gc_task dst.c 82 0 19 100 tcp_mss_split_point tcp_output.c 1126 As you can see by the above, there's a bit of work to do in rethinking the use of some unlikelys and likelys. Note: the unlikely case had 71 hits that were more than 25%. Note: After submitting my first version of this patch, Andrew Morton showed me a version written by Daniel Walker, where I picked up the following ideas from: 1) Using __builtin_constant_p to avoid profiling fixed values. 2) Using __FILE__ instead of instruction pointers. 3) Using the preprocessor to stop all profiling of likely annotations from vsyscall_64.c. Thanks to Andrew Morton, Arjan van de Ven, Theodore Tso and Ingo Molnar for their feed back on this patch. (*) Not ever unlikely is recorded, those that are used by vsyscalls (a few of them) had to have profiling disabled. Signed-off-by: Steven Rostedt <srostedt@redhat.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Theodore Tso <tytso@mit.edu> Cc: Arjan van de Ven <arjan@infradead.org> Cc: Steven Rostedt <srostedt@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-11-08Fix __pfn_to_page(pfn) for CONFIG_DISCONTIGMEM=yRafael J. Wysocki
Fix the __pfn_to_page(pfn) macro so that it doesn't evaluate its argument twice in the CONFIG_DISCONTIGMEM=y case, because 'pfn' may be a result of a funtion call having side effects. For example, the hibernation code applies pfn_to_page(pfn) to the result of a function returning the pfn corresponding to the next set bit in a bitmap and the current bit position is modified on each call. This leads to "interesting" failures for CONFIG_DISCONTIGMEM=y due to the current behavior of __pfn_to_page(pfn). Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-27asm-generic: define DIE_OOPS in asm-genericJonas Bonn
Impact: build fix DIE_OOPS is now used in the generic trace handling code so it needs to be defined for all architectures. Define it in asm-generic so that it's available to all by default and doesn't cause build errors for architectures that rely on the generic implementation. Signed-off-by: Jonas Bonn <jonas.bonn@gmail.com> Acked-by: Steven Rostedt <srostedt@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-23mutex: speed up generic mutex implementationsNick Piggin
- atomic operations which both modify the variable and return something imply full smp memory barriers before and after the memory operations involved (failing atomic_cmpxchg, atomic_add_unless, etc don't imply a barrier because they don't modify the target). See Documentation/atomic_ops.txt. So remove extra barriers and branches. - All architectures support atomic_cmpxchg. This has no relation to __HAVE_ARCH_CMPXCHG. We can just take the atomic_cmpxchg path unconditionally This reduces a simple single threaded fastpath lock+unlock test from 590 cycles to 203 cycles on a ppc970 system. Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20fix WARN() for PPCArjan van de Ven
powerpc doesn't use the generic WARN_ON infrastructure. The newly introduced WARN() as a result didn't print the message, this patch adds the printk for this specific case. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20Merge branch 'tracing-v28-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'tracing-v28-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (131 commits) tracing/fastboot: improve help text tracing/stacktrace: improve help text tracing/fastboot: fix initcalls disposition in bootgraph.pl tracing/fastboot: fix bootgraph.pl initcall name regexp tracing/fastboot: fix issues and improve output of bootgraph.pl tracepoints: synchronize unregister static inline tracepoints: tracepoint_synchronize_unregister() ftrace: make ftrace_test_p6nop disassembler-friendly markers: fix synchronize marker unregister static inline tracing/fastboot: add better resolution to initcall debug/tracing trace: add build-time check to avoid overrunning hex buffer ftrace: fix hex output mode of ftrace tracing/fastboot: fix initcalls disposition in bootgraph.pl tracing/fastboot: fix printk format typo in boot tracer ftrace: return an error when setting a nonexistent tracer ftrace: make some tracers reentrant ring-buffer: make reentrant ring-buffer: move page indexes into page headers tracing/fastboot: only trace non-module initcalls ftrace: move pc counter in irqtrace ... Manually fix conflicts: - init/main.c: initcall tracing - kernel/module.c: verbose level vs tracepoints - scripts/bootgraph.pl: fallout from cherry-picking commits.
2008-10-20rtc: use bcd2bin/bin2bcdAdrian Bunk
Change various rtc related code to use the new bcd2bin/bin2bcd functions instead of the obsolete BCD_TO_BIN/BIN_TO_BCD/BCD2BIN/BIN2BCD macros. Signed-off-by: Adrian Bunk <bunk@kernel.org> Acked-by: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6: (46 commits) UIO: Fix mapping of logical and virtual memory UIO: add automata sercos3 pci card support UIO: Change driver name of uio_pdrv UIO: Add alignment warnings for uio-mem Driver core: add bus_sort_breadthfirst() function NET: convert the phy_device file to use bus_find_device_by_name kobject: Cleanup kobject_rename and !CONFIG_SYSFS kobject: Fix kobject_rename and !CONFIG_SYSFS sysfs: Make dir and name args to sysfs_notify() const platform: add new device registration helper sysfs: use ilookup5() instead of ilookup5_nowait() PNP: create device attributes via default device attributes Driver core: make bus_find_device_by_name() more robust usb: turn dev_warn+WARN_ON combos into dev_WARN debug: use dev_WARN() rather than WARN_ON() in device_pm_add() debug: Introduce a dev_WARN() function sysfs: fix deadlock device model: Do a quickcheck for driver binding before doing an expensive check Driver core: Fix cleanup in device_create_vargs(). Driver core: Clarify device cleanup. ...
2008-10-16gpiolib: request/free hooksDavid Brownell
Add a new internal mechanism to gpiolib to support low power operations by letting gpio_chip instances see when their GPIOs are in use. When no GPIOs are active, chips may be able to enter lower powered runtime states by disabling clocks and/or power domains. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: "Magnus Damm" <magnus.damm@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16gpiolib: gpio_to_irq() hooksDavid Brownell
Add a new gpiolib mechanism: gpio_chip instances can provide mappings between their (input) GPIOs and any associated IRQs. This makes it easier for platforms to support IRQs that are provided by board-specific external chips instead of as part of their core (such as SOC-integrated GPIOs). Also update the irq_to_gpio() description, saying to avoid it because it's not always supported. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16gpio: make gpiochip label constDmitry Baryshkov
Mark gpiochip label as a const char pointer. Fixes things like arch/arm/common/scoop.c: In function `scoop_probe': arch/arm/common/scoop.c:250: warning: assignment discards qualifiers from pointer target type Signed-off-by: Dmitry Baryshkov <dbaryshkov@gmail.com> Acked-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16include: replace __FUNCTION__ with __func__Harvey Harrison
2008-10-16driver core: basic infrastructure for per-module dynamic debug messagesJason Baron
Base infrastructure to enable per-module debug messages. I've introduced CONFIG_DYNAMIC_PRINTK_DEBUG, which when enabled centralizes control of debugging statements on a per-module basis in one /proc file, currently, <debugfs>/dynamic_printk/modules. When, CONFIG_DYNAMIC_PRINTK_DEBUG, is not set, debugging statements can still be enabled as before, often by defining 'DEBUG' for the proper compilation unit. Thus, this patch set has no affect when CONFIG_DYNAMIC_PRINTK_DEBUG is not set. The infrastructure currently ties into all pr_debug() and dev_dbg() calls. That is, if CONFIG_DYNAMIC_PRINTK_DEBUG is set, all pr_debug() and dev_dbg() calls can be dynamically enabled/disabled on a per-module basis. Future plans include extending this functionality to subsystems, that define their own debug levels and flags. Usage: Dynamic debugging is controlled by the debugfs file, <debugfs>/dynamic_printk/modules. This file contains a list of the modules that can be enabled. The format of the file is as follows: <module_name> <enabled=0/1> . . . <module_name> : Name of the module in which the debug call resides <enabled=0/1> : whether the messages are enabled or not For example: snd_hda_intel enabled=0 fixup enabled=1 driver enabled=0 Enable a module: $echo "set enabled=1 <module_name>" > dynamic_printk/modules Disable a module: $echo "set enabled=0 <module_name>" > dynamic_printk/modules Enable all modules: $echo "set enabled=1 all" > dynamic_printk/modules Disable all modules: $echo "set enabled=0 all" > dynamic_printk/modules Finally, passing "dynamic_printk" at the command line enables debugging for all modules. This mode can be turned off via the above disable command. [gkh: minor cleanups and tweaks to make the build work quietly] Signed-off-by: Jason Baron <jbaron@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-10-14ftrace: create __mcount_loc sectionSteven Rostedt
This patch creates a section in the kernel called "__mcount_loc". This will hold a list of pointers to the mcount relocation for each call site of mcount. For example: objdump -dr init/main.o [...] Disassembly of section .text: 0000000000000000 <do_one_initcall>: 0: 55 push %rbp [...] 000000000000017b <init_post>: 17b: 55 push %rbp 17c: 48 89 e5 mov %rsp,%rbp 17f: 53 push %rbx 180: 48 83 ec 08 sub $0x8,%rsp 184: e8 00 00 00 00 callq 189 <init_post+0xe> 185: R_X86_64_PC32 mcount+0xfffffffffffffffc [...] We will add a section to point to each function call. .section __mcount_loc,"a",@progbits [...] .quad .text + 0x185 [...] The offset to of the mcount call site in init_post is an offset from the start of the section, and not the start of the function init_post. The mcount relocation is at the call site 0x185 from the start of the .text section. .text + 0x185 == init_post + 0xa We need a way to add this __mcount_loc section in a way that we do not lose the relocations after final link. The .text section here will be attached to all other .text sections after final link and the offsets will be meaningless. We need to keep track of where these .text sections are. To do this, we use the start of the first function in the section. do_one_initcall. We can make a tmp.s file with this function as a reference to the start of the .text section. .section __mcount_loc,"a",@progbits [...] .quad do_one_initcall + 0x185 [...] Then we can compile the tmp.s into a tmp.o gcc -c tmp.s -o tmp.o And link it into back into main.o. ld -r main.o tmp.o -o tmp_main.o mv tmp_main.o main.o But we have a problem. What happens if the first function in a section is not exported, and is a static function. The linker will not let the tmp.o use it. This case exists in main.o as well. Disassembly of section .init.text: 0000000000000000 <set_reset_devices>: 0: 55 push %rbp 1: 48 89 e5 mov %rsp,%rbp 4: e8 00 00 00 00 callq 9 <set_reset_devices+0x9> 5: R_X86_64_PC32 mcount+0xfffffffffffffffc The first function in .init.text is a static function. 00000000000000a8 t __setup_set_reset_devices 000000000000105f t __setup_str_set_reset_devices 0000000000000000 t set_reset_devices The lowercase 't' means that set_reset_devices is local and is not exported. If we simply try to link the tmp.o with the set_reset_devices we end up with two symbols: one local and one global. .section __mcount_loc,"a",@progbits .quad set_reset_devices + 0x10 00000000000000a8 t __setup_set_reset_devices 000000000000105f t __setup_str_set_reset_devices 0000000000000000 t set_reset_devices U set_reset_devices We still have an undefined reference to set_reset_devices, and if we try to compile the kernel, we will end up with an undefined reference to set_reset_devices, or even worst, it could be exported someplace else, and then we will have a reference to the wrong location. To handle this case, we make an intermediate step using objcopy. We convert set_reset_devices into a global exported symbol before linking it with tmp.o and set it back afterwards. 00000000000000a8 t __setup_set_reset_devices 000000000000105f t __setup_str_set_reset_devices 0000000000000000 T set_reset_devices 00000000000000a8 t __setup_set_reset_devices 000000000000105f t __setup_str_set_reset_devices 0000000000000000 T set_reset_devices 00000000000000a8 t __setup_set_reset_devices 000000000000105f t __setup_str_set_reset_devices 0000000000000000 t set_reset_devices Now we have a section in main.o called __mcount_loc that we can place somewhere in the kernel using vmlinux.ld.S and access it to convert all these locations that call mcount into nops before starting SMP and thus, eliminating the need to do this with kstop_machine. Note, A well documented perl script (scripts/recordmcount.pl) is used to do all this in one location. Signed-off-by: Steven Rostedt <srostedt@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-14tracing: Kernel TracepointsMathieu Desnoyers
Implementation of kernel tracepoints. Inspired from the Linux Kernel Markers. Allows complete typing verification by declaring both tracing statement inline functions and probe registration/unregistration static inline functions within the same macro "DEFINE_TRACE". No format string is required. See the tracepoint Documentation and Samples patches for usage examples. Taken from the documentation patch : "A tracepoint placed in code provides a hook to call a function (probe) that you can provide at runtime. A tracepoint can be "on" (a probe is connected to it) or "off" (no probe is attached). When a tracepoint is "off" it has no effect, except for adding a tiny time penalty (checking a condition for a branch) and space penalty (adding a few bytes for the function call at the end of the instrumented function and adds a data structure in a separate section). When a tracepoint is "on", the function you provide is called each time the tracepoint is executed, in the execution context of the caller. When the function provided ends its execution, it returns to the caller (continuing from the tracepoint site). You can put tracepoints at important locations in the code. They are lightweight hooks that can pass an arbitrary number of parameters, which prototypes are described in a tracepoint declaration placed in a header file." Addition and removal of tracepoints is synchronized by RCU using the scheduler (and preempt_disable) as guarantees to find a quiescent state (this is really RCU "classic"). The update side uses rcu_barrier_sched() with call_rcu_sched() and the read/execute side uses "preempt_disable()/preempt_enable()". We make sure the previous array containing probes, which has been scheduled for deletion by the rcu callback, is indeed freed before we proceed to the next update. It therefore limits the rate of modification of a single tracepoint to one update per RCU period. The objective here is to permit fast batch add/removal of probes on _different_ tracepoints. Changelog : - Use #name ":" #proto as string to identify the tracepoint in the tracepoint table. This will make sure not type mismatch happens due to connexion of a probe with the wrong type to a tracepoint declared with the same name in a different header. - Add tracepoint_entry_free_old. - Change __TO_TRACE to get rid of the 'i' iterator. Masami Hiramatsu <mhiramat@redhat.com> : Tested on x86-64. Performance impact of a tracepoint : same as markers, except that it adds about 70 bytes of instructions in an unlikely branch of each instrumented function (the for loop, the stack setup and the function call). It currently adds a memory read, a test and a conditional branch at the instrumentation site (in the hot path). Immediate values will eventually change this into a load immediate, test and branch, which removes the memory read which will make the i-cache impact smaller (changing the memory read for a load immediate removes 3-4 bytes per site on x86_32 (depending on mov prefixes), or 7-8 bytes on x86_64, it also saves the d-cache hit). About the performance impact of tracepoints (which is comparable to markers), even without immediate values optimizations, tests done by Hideo Aoki on ia64 show no regression. His test case was using hackbench on a kernel where scheduler instrumentation (about 5 events in code scheduler code) was added. Quoting Hideo Aoki about Markers : I evaluated overhead of kernel marker using linux-2.6-sched-fixes git tree, which includes several markers for LTTng, using an ia64 server. While the immediate trace mark feature isn't implemented on ia64, there is no major performance regression. So, I think that we don't have any issues to propose merging marker point patches into Linus's tree from the viewpoint of performance impact. I prepared two kernels to evaluate. The first one was compiled without CONFIG_MARKERS. The second one was enabled CONFIG_MARKERS. I downloaded the original hackbench from the following URL: http://devresources.linux-foundation.org/craiger/hackbench/src/hackbench.c I ran hackbench 5 times in each condition and calculated the average and difference between the kernels. The parameter of hackbench: every 50 from 50 to 800 The number of CPUs of the server: 2, 4, and 8 Below is the results. As you can see, major performance regression wasn't found in any case. Even if number of processes increases, differences between marker-enabled kernel and marker- disabled kernel doesn't increase. Moreover, if number of CPUs increases, the differences doesn't increase either. Curiously, marker-enabled kernel is better than marker-disabled kernel in more than half cases, although I guess it comes from the difference of memory access pattern. * 2 CPUs Number of | without | with | diff | diff | processes | Marker [Sec] | Marker [Sec] | [Sec] | [%] | -------------------------------------------------------------- 50 | 4.811 | 4.872 | +0.061 | +1.27 | 100 | 9.854 | 10.309 | +0.454 | +4.61 | 150 | 15.602 | 15.040 | -0.562 | -3.6 | 200 | 20.489 | 20.380 | -0.109 | -0.53 | 250 | 25.798 | 25.652 | -0.146 | -0.56 | 300 | 31.260 | 30.797 | -0.463 | -1.48 | 350 | 36.121 | 35.770 | -0.351 | -0.97 | 400 | 42.288 | 42.102 | -0.186 | -0.44 | 450 | 47.778 | 47.253 | -0.526 | -1.1 | 500 | 51.953 | 52.278 | +0.325 | +0.63 | 550 | 58.401 | 57.700 | -0.701 | -1.2 | 600 | 63.334 | 63.222 | -0.112 | -0.18 | 650 | 68.816 | 68.511 | -0.306 | -0.44 | 700 | 74.667 | 74.088 | -0.579 | -0.78 | 750 | 78.612 | 79.582 | +0.970 | +1.23 | 800 | 85.431 | 85.263 | -0.168 | -0.2 | -------------------------------------------------------------- * 4 CPUs Number of | without | with | diff | diff | processes | Marker [Sec] | Marker [Sec] | [Sec] | [%] | -------------------------------------------------------------- 50 | 2.586 | 2.584 | -0.003 | -0.1 | 100 | 5.254 | 5.283 | +0.030 | +0.56 | 150 | 8.012 | 8.074 | +0.061 | +0.76 | 200 | 11.172 | 11.000 | -0.172 | -1.54 | 250 | 13.917 | 14.036 | +0.119 | +0.86 | 300 | 16.905 | 16.543 | -0.362 | -2.14 | 350 | 19.901 | 20.036 | +0.135 | +0.68 | 400 | 22.908 | 23.094 | +0.186 | +0.81 | 450 | 26.273 | 26.101 | -0.172 | -0.66 | 500 | 29.554 | 29.092 | -0.461 | -1.56 | 550 | 32.377 | 32.274 | -0.103 | -0.32 | 600 | 35.855 | 35.322 | -0.533 | -1.49 | 650 | 39.192 | 38.388 | -0.804 | -2.05 | 700 | 41.744 | 41.719 | -0.025 | -0.06 | 750 | 45.016 | 44.496 | -0.520 | -1.16 | 800 | 48.212 | 47.603 | -0.609 | -1.26 | -------------------------------------------------------------- * 8 CPUs Number of | without | with | diff | diff | processes | Marker [Sec] | Marker [Sec] | [Sec] | [%] | -------------------------------------------------------------- 50 | 2.094 | 2.072 | -0.022 | -1.07 | 100 | 4.162 | 4.273 | +0.111 | +2.66 | 150 | 6.485 | 6.540 | +0.055 | +0.84 | 200 | 8.556 | 8.478 | -0.078 | -0.91 | 250 | 10.458 | 10.258 | -0.200 | -1.91 | 300 | 12.425 | 12.750 | +0.325 | +2.62 | 350 | 14.807 | 14.839 | +0.032 | +0.22 | 400 | 16.801 | 16.959 | +0.158 | +0.94 | 450 | 19.478 | 19.009 | -0.470 | -2.41 | 500 | 21.296 | 21.504 | +0.208 | +0.98 | 550 | 23.842 | 23.979 | +0.137 | +0.57 | 600 | 26.309 | 26.111 | -0.198 | -0.75 | 650 | 28.705 | 28.446 | -0.259 | -0.9 | 700 | 31.233 | 31.394 | +0.161 | +0.52 | 750 | 34.064 | 33.720 | -0.344 | -1.01 | 800 | 36.320 | 36.114 | -0.206 | -0.57 | -------------------------------------------------------------- Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Acked-by: Masami Hiramatsu <mhiramat@redhat.com> Acked-by: 'Peter Zijlstra' <peterz@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-13Merge branch 'master' of ↵David Woodhouse
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 Conflicts: include/asm-x86/statfs.h
2008-10-12Merge branch 'x86/urgent' into core/signalIngo Molnar
Conflicts: arch/x86/kernel/signal_64.c
2008-10-11Merge branch 'x86/unify-cpu-detect' into x86-v28-for-linus-phase4-DIngo Molnar
Conflicts: arch/x86/kernel/cpu/common.c arch/x86/kernel/signal_64.c include/asm-x86/cpufeature.h
2008-09-23signals: demultiplexing SIGTRAP signalSrinivasa Ds
Currently a SIGTRAP can denote any one of below reasons. - Breakpoint hit - H/W debug register hit - Single step - Signal sent through kill() or rasie() Architectures like powerpc/parisc provides infrastructure to demultiplex SIGTRAP signal by passing down the information for receiving SIGTRAP through si_code of siginfot_t structure. Here is an attempt is generalise this infrastructure by extending it to x86 and x86_64 archs. Signed-off-by: Srinivasa DS <srinivasa@in.ibm.com> Cc: Roland McGrath <roland@redhat.com> Cc: akpm@linux-foundation.org Cc: paulus@samba.org Cc: linuxppc-dev@ozlabs.org Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-09-16warn: Turn the netdev timeout WARN_ON() into a WARN()Arjan van de Ven
this patch turns the netdev timeout WARN_ON_ONCE() into a WARN_ONCE(), so that the device and driver names are inside the warning message. This helps automated tools like kerneloops.org to collect the data and do statistics, as well as making it more likely that humans cut-n-paste the important message as part of a bugreport. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
