path: root/include/asm-generic
2005-05-04[PATCH] asm/signal.h unificationAl Viro
New file - asm-generic/signal.h. Contains declarations of __sighandler_t, __sigrestore_t, SIG_DFL, SIG_IGN, SIG_ERR and default definitions of SIG_BLOCK, SIG_UNBLOCK and SIG_SETMASK. asm-*/signal.h switched to including it. The only exception is asm-parisc/signal.h that wants its own declaration of __sighandler_t; that one is left as-is. asm-ppc64/signal.h required one more thing - unlike everybody else it used __sigrestorer_t instead of usual __sigrestore_t. PPC64 switched to common spelling. Signed-off-by: Al Viro <viro@parcelfarce.linux.theplanet.co.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-01[PATCH] consolidate SIGEV_PAD_SIZEStephen Rothwell
Discussing with Matthew Wilcox some of his outstanding patches lead me to this patch (among others). The preamble in struct sigevent can be expressed independently of the architecture. Also use __ARCH_SI_PREAMBLE_SIZE on ia64. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-01[PATCH] add EOWNERDEAD and ENOTRECOVERABLE version 2Joe Korty
Add EOWNERDEAD and ENOTRECOVERABLE to all architectures. This is to support the upcoming patches for robust mutexes. We normally don't reserve parts of the name/number space for external patches, but robust mutexes are sufficiently popular and important to justify it in this case. Signed-off-by: Joe Korty <joe.korty@ccur.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-01[PATCH] Exterminate PAGE_BUGMatt Mackall
Remove PAGE_BUG - repalce it with BUG and BUG_ON. Signed-off-by: Matt Mackall <mpm@selenic.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-01[PATCH] remove all kernel BUGsMatt Mackall
This patch eliminates all kernel BUGs, trims about 35k off the typical kernel, and makes the system slightly faster. Signed-off-by: Matt Mackall <mpm@selenic.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-01[PATCH] nice and rt-prio rlimitsMatt Mackall
Add a pair of rlimits for allowing non-root tasks to raise nice and rt priorities. Defaults to traditional behavior. Originally written by Chris Wright. The patch implements a simple rlimit ceiling for the RT (and nice) priorities a task can set. The rlimit defaults to 0, meaning no change in behavior by default. A value of 50 means RT priority levels 1-50 are allowed. A value of 100 means all 99 privilege levels from 1 to 99 are allowed. CAP_SYS_NICE is blanket permission. (akpm: see http://www.uwsg.iu.edu/hypermail/linux/kernel/0503.1/1921.html for tips on integrating this with PAM). Signed-off-by: Matt Mackall <mpm@selenic.com> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-24[PATCH] __get_unaligned() turned into macroAl Viro
Turns __get_unaligned() and __put_unaligned into macros. That is definitely safe; leaving them as inlines breaks on e.g. alpha [try to build ncpfs there and you'll get unresolved symbols since we end up getting __get_unaligned() not inlined]. Signed-off-by: Al Viro <viro@parcelfarce.linux.theplanet.co.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-19[PATCH] freepgt: remove arch pgd_addr_endHugh Dickins
ia64 and sparc64 hurriedly had to introduce their own variants of pgd_addr_end, to leapfrog over the holes in their virtual address spaces which the final clear_page_range suddenly presented when converted from pgd_index to pgd_addr_end. But now that free_pgtables respects the vma list, those holes are never presented, and the arch variants can go. Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-16[PATCH] add Big Endian variants of ioread/iowriteJames Bottomley
In the new io infrastructure, all of our operators are expecting the underlying device to be little endian (because the PCI bus, their main consumer, is LE). However, there are a fair few devices and busses in the world that are actually Big Endian. There's even evidence that some of these BE bus and chip types are attached to LE systems. Thus, there's a need for a BE equivalent of our io{read,write}{16,32} operations. The attached patch adds this as io{read,write}{16,32}be. When it's in, I'll add the first consume (the 53c700 SCSI chip driver). Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
