[ Upstream commit cbedfe11347fe418621bd188d58a206beb676218 ]
Commit d66acc39c7ce ("bitops: Optimise get_order()") introduced a
compilation warning because "rx_frag_size" is an "ushort" while
PAGE_SHIFT here is 16.
The commit changed the get_order() to be a multi-line macro where
compilers insist to check all statements in the macro even when
__builtin_constant_p(rx_frag_size) will return false as "rx_frag_size"
is a module parameter.
In file included from ./arch/powerpc/include/asm/page_64.h:107,
from ./arch/powerpc/include/asm/page.h:242,
from ./arch/powerpc/include/asm/mmu.h:132,
from ./arch/powerpc/include/asm/lppaca.h:47,
from ./arch/powerpc/include/asm/paca.h:17,
from ./arch/powerpc/include/asm/current.h:13,
from ./include/linux/thread_info.h:21,
from ./arch/powerpc/include/asm/processor.h:39,
from ./include/linux/prefetch.h:15,
from drivers/net/ethernet/emulex/benet/be_main.c:14:
drivers/net/ethernet/emulex/benet/be_main.c: In function 'be_rx_cqs_create':
./include/asm-generic/getorder.h:54:9: warning: comparison is always
true due to limited range of data type [-Wtype-limits]
(((n) < (1UL << PAGE_SHIFT)) ? 0 : \
drivers/net/ethernet/emulex/benet/be_main.c:3138:33: note: in expansion
of macro 'get_order'
adapter->big_page_size = (1 << get_order(rx_frag_size)) * PAGE_SIZE;
Fix it by moving all of this multi-line macro into a proper function,
and killing __get_order() off.
[akpm@linux-foundation.org: remove __get_order() altogether]
[cai@lca.pw: v2]
Link: http://lkml.kernel.org/r/1564000166-31428-1-git-send-email-cai@lca.pw
Link: http://lkml.kernel.org/r/1563914986-26502-1-git-send-email-cai@lca.pw
Fixes: d66acc39c7ce ("bitops: Optimise get_order()")
Signed-off-by: Qian Cai <cai@lca.pw>
Reviewed-by: Nathan Chancellor <natechancellor@gmail.com>
Cc: Jakub Jelinek <jakub@redhat.com>
Cc: Nick Desaulniers <ndesaulniers@google.com>
Cc: Bill Wendling <morbo@google.com>
Cc: James Y Knight <jyknight@google.com>
commit 427503519739e779c0db8afe876c1b33f3ac60ae upstream.
The architecture implementations of 'arch_futex_atomic_op_inuser()' and
'futex_atomic_cmpxchg_inatomic()' are permitted to return only -EFAULT,
-EAGAIN or -ENOSYS in the case of failure.
Update the comments in the asm-generic/ implementation and also a stray
reference in the robust futex documentation.
[ Upstream commit 1071fc5779d9846fec56a4ff6089ab08cac1ab72 ]
Add three architecture overrideable functions to test if the
p4d, pud, or pmd layer of a page table is folded or not.
Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
commit f76a16adc485699f95bb71fce114f97c832fe664 upstream.
The .orc_unwind section is a packed array of 6-byte structs. It's
currently aligned to 6 bytes, which is causing warnings in the LLD
linker.
Six isn't a power of two, so it's not a valid alignment value. The
actual alignment doesn't matter much because it's an array of packed
structs. An alignment of two is sufficient. In reality it always gets
aligned to four bytes because it comes immediately after the
4-byte-aligned .orc_unwind_ip section.
Fixes: ee9f8fce9964 ("x86/unwind: Add the ORC unwinder")
Reported-by: Nick Desaulniers <ndesaulniers@google.com>
Reported-by: Dmitry Golovin <dima@golovin.in>
Reported-by: Sedat Dilek <sedat.dilek@gmail.com>
Signed-off-by: Josh Poimboeuf <jpoimboe@redhat.com>
Tested-by: Sedat Dilek <sedat.dilek@gmail.com>
Cc: stable@vger.kernel.org
Link: https://github.com/ClangBuiltLinux/linux/issues/218
Link: https://lkml.kernel.org/r/d55027ee95fe73e952dcd8be90aebd31b0095c45.1551892041.git.jpoimboe@redhat.com
[ Upstream commit 6cc65be4f6f2a7186af8f3e09900787c7912dad2 ]
One of my tests compiles the kernel with gcc 4.5.3, and I hit the
following build error:
include/linux/semaphore.h: In function 'sema_init':
include/linux/semaphore.h:35:17: error: unknown field 'val' specified in initializer
include/linux/semaphore.h:35:17: warning: missing braces around initializer
include/linux/semaphore.h:35:17: warning: (near initialization for '(anonymous).raw_lock.<anonymous>.val')
I bisected it down to:
625e88be1f41 ("locking/qspinlock: Merge 'struct __qspinlock' into 'struct qspinlock'")
... which makes qspinlock have an anonymous union, which makes initializing it special
for older compilers. By adding strategic brackets, it makes the build
happy again.
Signed-off-by: Steven Rostedt (VMware) <rostedt@goodmis.org>
Acked-by: Waiman Long <longman@redhat.com>
Cc: Boqun Feng <boqun.feng@gmail.com>
Cc: Peter Zijlstra (Intel) <peterz@infradead.org>
Fixes: 625e88be1f41 ("locking/qspinlock: Merge 'struct __qspinlock' into 'struct qspinlock'")
Link: http://lkml.kernel.org/r/20180621203526.172ab5c4@vmware.local.home
commit 625e88be1f41b53cec55827c984e4a89ea8ee9f9 upstream.
'struct __qspinlock' provides a handy union of fields so that
subcomponents of the lockword can be accessed by name, without having to
manage shifts and masks explicitly and take endianness into account.
This is useful in qspinlock.h and also potentially in arch headers, so
move the 'struct __qspinlock' into 'struct qspinlock' and kill the extra
definition.
Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org>
Acked-by: Boqun Feng <boqun.feng@gmail.com>
Cc: paulmck@linux.vnet.ibm.com
Link: http://lkml.kernel.org/r/1524738868-31318-3-git-send-email-will.deacon@arm.com
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
commit 785a19f9d1dd8a4ab2d0633be4656653bd3de1fc upstream.
The following kernel panic was observed on ARM64 platform due to a stale
TLB entry.
1. ioremap with 4K size, a valid pte page table is set.
2. iounmap it, its pte entry is set to 0.
3. ioremap the same address with 2M size, update its pmd entry with
a new value.
4. CPU may hit an exception because the old pmd entry is still in TLB,
which leads to a kernel panic.
Commit b6bdb7517c3d ("mm/vmalloc: add interfaces to free unmapped page
table") has addressed this panic by falling to pte mappings in the above
case on ARM64.
To support pmd mappings in all cases, TLB purge needs to be performed
in this case on ARM64.
Add a new arg, 'addr', to pud_free_pmd_page() and pmd_free_pte_page()
so that TLB purge can be added later in seprate patches.
[toshi.kani@hpe.com: merge changes, rewrite patch description]
Fixes: 28ee90fe6048 ("x86/mm: implement free pmd/pte page interfaces")
Signed-off-by: Chintan Pandya <cpandya@codeaurora.org>
Signed-off-by: Toshi Kani <toshi.kani@hpe.com>
Cc: mhocko@suse.com
Cc: akpm@linux-foundation.org
Cc: hpa@zytor.com
Cc: linux-mm@kvack.org
Cc: Joerg Roedel <joro@8bytes.org>
Cc: Michal Hocko <mhocko@suse.com>
Cc: <stable@vger.kernel.org>
Link: https://lkml.kernel.org/r/20180627141348.21777-3-toshi.kani@hpe.com
commit 6c26fcd2abfe0a56bbd95271fce02df2896cfd24 upstream.
pfn_modify_allowed() and arch_has_pfn_modify_check() are outside of the
!__ASSEMBLY__ section in include/asm-generic/pgtable.h, which confuses
assembler on archs that don't have __HAVE_ARCH_PFN_MODIFY_ALLOWED (e.g.
ia64) and breaks build:
include/asm-generic/pgtable.h: Assembler messages:
include/asm-generic/pgtable.h:538: Error: Unknown opcode `static inline bool pfn_modify_allowed(unsigned long pfn,pgprot_t prot)'
include/asm-generic/pgtable.h:540: Error: Unknown opcode `return true'
include/asm-generic/pgtable.h:543: Error: Unknown opcode `static inline bool arch_has_pfn_modify_check(void)'
include/asm-generic/pgtable.h:545: Error: Unknown opcode `return false'
arch/ia64/kernel/entry.S:69: Error: `mov' does not fit into bundle
Move those two static inlines into the !__ASSEMBLY__ section so that they
don't confuse the asm build pass.
Fixes: 42e4089c7890 ("x86/speculation/l1tf: Disallow non privileged high MMIO PROT_NONE mappings")
commit 42e4089c7890725fcd329999252dc489b72f2921 upstream
For L1TF PROT_NONE mappings are protected by inverting the PFN in the page
table entry. This sets the high bits in the CPU's address space, thus
making sure to point to not point an unmapped entry to valid cached memory.
Some server system BIOSes put the MMIO mappings high up in the physical
address space. If such an high mapping was mapped to unprivileged users
they could attack low memory by setting such a mapping to PROT_NONE. This
could happen through a special device driver which is not access
protected. Normal /dev/mem is of course access protected.
To avoid this forbid PROT_NONE mappings or mprotect for high MMIO mappings.
Valid page mappings are allowed because the system is then unsafe anyways.
It's not expected that users commonly use PROT_NONE on MMIO. But to
minimize any impact this is only enforced if the mapping actually refers to
a high MMIO address (defined as the MAX_PA-1 bit being set), and also skip
the check for root.
For mmaps this is straight forward and can be handled in vm_insert_pfn and
in remap_pfn_range().
For mprotect it's a bit trickier. At the point where the actual PTEs are
accessed a lot of state has been changed and it would be difficult to undo
on an error. Since this is a uncommon case use a separate early page talk
walk pass for MMIO PROT_NONE mappings that checks for this condition
early. For non MMIO and non PROT_NONE there are no changes.
Reviewed-by: Josh Poimboeuf <jpoimboe@redhat.com>
Acked-by: Dave Hansen <dave.hansen@intel.com>
[ Upstream commit 173a3efd3edb2ef6ef07471397c5f542a360e9c1 ]
Looking at functions with large stack frames across all architectures
led me discovering that BUG() suffers from the same problem as
fortify_panic(), which I've added a workaround for already.
In short, variables that go out of scope by calling a noreturn function
or __builtin_unreachable() keep using stack space in functions
afterwards.
A workaround that was identified is to insert an empty assembler
statement just before calling the function that doesn't return. I'm
adding a macro "barrier_before_unreachable()" to document this, and
insert calls to that in all instances of BUG() that currently suffer
from this problem.
The files that saw the largest change from this had these frame sizes
before, and much less with my patch:
fs/ext4/inode.c:82:1: warning: the frame size of 1672 bytes is larger than 800 bytes [-Wframe-larger-than=]
fs/ext4/namei.c:434:1: warning: the frame size of 904 bytes is larger than 800 bytes [-Wframe-larger-than=]
fs/ext4/super.c:2279:1: warning: the frame size of 1160 bytes is larger than 800 bytes [-Wframe-larger-than=]
fs/ext4/xattr.c:146:1: warning: the frame size of 1168 bytes is larger than 800 bytes [-Wframe-larger-than=]
fs/f2fs/inode.c:152:1: warning: the frame size of 1424 bytes is larger than 800 bytes [-Wframe-larger-than=]
net/netfilter/ipvs/ip_vs_core.c:1195:1: warning: the frame size of 1068 bytes is larger than 800 bytes [-Wframe-larger-than=]
net/netfilter/ipvs/ip_vs_core.c:395:1: warning: the frame size of 1084 bytes is larger than 800 bytes [-Wframe-larger-than=]
net/netfilter/ipvs/ip_vs_ftp.c:298:1: warning: the frame size of 928 bytes is larger than 800 bytes [-Wframe-larger-than=]
net/netfilter/ipvs/ip_vs_ftp.c:418:1: warning: the frame size of 908 bytes is larger than 800 bytes [-Wframe-larger-than=]
net/netfilter/ipvs/ip_vs_lblcr.c:718:1: warning: the frame size of 960 bytes is larger than 800 bytes [-Wframe-larger-than=]
drivers/net/xen-netback/netback.c:1500:1: warning: the frame size of 1088 bytes is larger than 800 bytes [-Wframe-larger-than=]
In case of ARC and CRIS, it turns out that the BUG() implementation
actually does return (or at least the compiler thinks it does),
resulting in lots of warnings about uninitialized variable use and
leaving noreturn functions, such as:
block/cfq-iosched.c: In function 'cfq_async_queue_prio':
block/cfq-iosched.c:3804:1: error: control reaches end of non-void function [-Werror=return-type]
include/linux/dmaengine.h: In function 'dma_maxpq':
include/linux/dmaengine.h:1123:1: error: control reaches end of non-void function [-Werror=return-type]
This makes them call __builtin_trap() instead, which should normally
dump the stack and kill the current process, like some of the other
architectures already do.
I tried adding barrier_before_unreachable() to panic() and
fortify_panic() as well, but that had very little effect, so I'm not
submitting that patch.
Vineet said:
: For ARC, it is double win.
: 1. Fixes 3 -Wreturn-type warnings
: | ../net/core/ethtool.c:311:1: warning: control reaches end of non-void function
: [-Wreturn-type]
: | ../kernel/sched/core.c:3246:1: warning: control reaches end of non-void function
: [-Wreturn-type]
: | ../include/linux/sunrpc/svc_xprt.h:180:1: warning: control reaches end of
: non-void function [-Wreturn-type]
: 2. bloat-o-meter reports code size improvements as gcc elides the
: generated code for stack return.
Link: https://gcc.gnu.org/bugzilla/show_bug.cgi?id=82365
Link: http://lkml.kernel.org/r/20171219114112.939391-1-arnd@arndb.de
Acked-by: Vineet Gupta <vgupta@synopsys.com> [arch/arc]
Tested-by: Vineet Gupta <vgupta@synopsys.com> [arch/arc]
Cc: Mikael Starvik <starvik@axis.com>
Cc: Jesper Nilsson <jesper.nilsson@axis.com>
Cc: Christopher Li <sparse@chrisli.org>
Cc: Josh Poimboeuf <jpoimboe@redhat.com>
Cc: "Steven Rostedt (VMware)" <rostedt@goodmis.org>
Cc: Mark Rutland <mark.rutland@arm.com>
commit dd709e72cb934eefd44de8d9969097173fbf45dc upstream.
Commit 99492c39f39f ("earlycon: Fix __earlycon_table stride") tried to fix
__earlycon_table stride by forcing the earlycon_id struct alignment to 32
and asking the linker to 32-byte align the __earlycon_table symbol. This
fix was based on commit 07fca0e57fca92 ("tracing: Properly align linker
defined symbols") which tried a similar fix for the tracing subsystem.
However, this fix doesn't quite work because there is no guarantee that
gcc will place structures packed into an array format. In fact, gcc 4.9
chooses to 64-byte align these structs by inserting additional padding
between the entries because it has no clue that they are supposed to be in
an array. If we are unlucky, the linker will assign symbol
"__earlycon_table" to a 32-byte aligned address which does not correspond
to the 64-byte aligned contents of section "__earlycon_table".
To address this same problem, the fix to the tracing system was
subsequently re-implemented using a more robust table of pointers approach
by commits:
3d56e331b653 ("tracing: Replace syscall_meta_data struct array with pointer array")
654986462939 ("tracepoints: Fix section alignment using pointer array")
e4a9ea5ee7c8 ("tracing: Replace trace_event struct array with pointer array")
Let's use this same "array of pointers to structs" approach for
EARLYCON_TABLE.
Fixes: 99492c39f39f ("earlycon: Fix __earlycon_table stride")
Signed-off-by: Daniel Kurtz <djkurtz@chromium.org>
Suggested-by: Aaron Durbin <adurbin@chromium.org>
Reviewed-by: Rob Herring <robh@kernel.org>
Tested-by: Guenter Roeck <groeck@chromium.org>
Reviewed-by: Guenter Roeck <groeck@chromium.org>
Cc: stable <stable@vger.kernel.org>
[ Upstream commit c58f0bb77ed8bf93dfdde762b01cb67eebbdfc29 ]
Patch series "Do not lose dirty bit on THP pages", v4.
Vlastimil noted that pmdp_invalidate() is not atomic and we can lose
dirty and access bits if CPU sets them after pmdp dereference, but
before set_pmd_at().
The bug can lead to data loss, but the race window is tiny and I haven't
seen any reports that suggested that it happens in reality. So I don't
think it worth sending it to stable.
Unfortunately, there's no way to address the issue in a generic way. We
need to fix all architectures that support THP one-by-one.
All architectures that have THP supported have to provide atomic
pmdp_invalidate() that returns previous value.
If generic implementation of pmdp_invalidate() is used, architecture
needs to provide atomic pmdp_estabish().
pmdp_estabish() is not used out-side generic implementation of
pmdp_invalidate() so far, but I think this can change in the future.
This patch (of 12):
This is an implementation of pmdp_establish() that is only suitable for
an architecture that doesn't have hardware dirty/accessed bits. In this
case we can't race with CPU which sets these bits and non-atomic
approach is fine.
Link: http://lkml.kernel.org/r/20171213105756.69879-2-kirill.shutemov@linux.intel.com
Cc: Michal Hocko <mhocko@kernel.org>
Cc: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
Cc: David Daney <david.daney@cavium.com>
Cc: Nitin Gupta <nitin.m.gupta@oracle.com>
Cc: Vineet Gupta <vgupta@synopsys.com>
commit b6bdb7517c3d3f41f20e5c2948d6bc3f8897394e upstream.
On architectures with CONFIG_HAVE_ARCH_HUGE_VMAP set, ioremap() may
create pud/pmd mappings. A kernel panic was observed on arm64 systems
with Cortex-A75 in the following steps as described by Hanjun Guo.
1. ioremap a 4K size, valid page table will build,
2. iounmap it, pte0 will set to 0;
3. ioremap the same address with 2M size, pgd/pmd is unchanged,
then set the a new value for pmd;
4. pte0 is leaked;
5. CPU may meet exception because the old pmd is still in TLB,
which will lead to kernel panic.
This panic is not reproducible on x86. INVLPG, called from iounmap,
purges all levels of entries associated with purged address on x86. x86
still has memory leak.
The patch changes the ioremap path to free unmapped page table(s) since
doing so in the unmap path has the following issues:
- The iounmap() path is shared with vunmap(). Since vmap() only
supports pte mappings, making vunmap() to free a pte page is an
overhead for regular vmap users as they do not need a pte page freed
up.
- Checking if all entries in a pte page are cleared in the unmap path
is racy, and serializing this check is expensive.
- The unmap path calls free_vmap_area_noflush() to do lazy TLB purges.
Clearing a pud/pmd entry before the lazy TLB purges needs extra TLB
purge.
Add two interfaces, pud_free_pmd_page() and pmd_free_pte_page(), which
clear a given pud/pmd entry and free up a page for the lower level
entries.
This patch implements their stub functions on x86 and arm64, which work
as workaround.
[akpm@linux-foundation.org: fix typo in pmd_free_pte_page() stub]
Link: http://lkml.kernel.org/r/20180314180155.19492-2-toshi.kani@hpe.com
Fixes: e61ce6ade404e ("mm: change ioremap to set up huge I/O mappings")
Reported-by: Lei Li <lious.lilei@hisilicon.com>
Cc: Wang Xuefeng <wxf.wang@hisilicon.com>
Cc: Hanjun Guo <guohanjun@huawei.com>
Cc: Borislav Petkov <bp@suse.de>
Cc: Matthew Wilcox <willy@infradead.org>
Cc: Chintan Pandya <cpandya@codeaurora.org>
commit 613e396bc0d4c7604fba23256644e78454c68cf6 upstream.
init_espfix_bsp() needs to be invoked before the page table isolation
initialization. Move it into mm_init() which is the place where pti_init()
will be added.
While at it get rid of the #ifdeffery and provide proper stub functions.
Cc: Dave Hansen <dave.hansen@linux.intel.com>
Cc: Juergen Gross <jgross@suse.com>
commit c10e83f598d08046dd1ebc8360d4bb12d802d51b upstream.
In order to sanitize the LDT initialization on x86 arch_dup_mmap() must be
allowed to fail. Fix up all instances.
Cc: Andy Lutomirsky <luto@kernel.org>
Cc: Boris Ostrovsky <boris.ostrovsky@oracle.com>
Cc: Borislav Petkov <bpetkov@suse.de>
Cc: Brian Gerst <brgerst@gmail.com>
Cc: David Laight <David.Laight@aculab.com>
Cc: Denys Vlasenko <dvlasenk@redhat.com>
Cc: Eduardo Valentin <eduval@amazon.com>
Cc: Greg KH <gregkh@linuxfoundation.org>
Cc: aliguori@amazon.com
Cc: dan.j.williams@intel.com
Cc: hughd@google.com
Cc: keescook@google.com
Cc: kirill.shutemov@linux.intel.com
commit 11af847446ed0d131cf24d16a7ef3d5ea7a49554 upstream.
Rename the unwinder config options from:
CONFIG_ORC_UNWINDER
CONFIG_FRAME_POINTER_UNWINDER
CONFIG_GUESS_UNWINDER
to:
CONFIG_UNWINDER_ORC
CONFIG_UNWINDER_FRAME_POINTER
CONFIG_UNWINDER_GUESS
... in order to give them a more logical config namespace.
Suggested-by: Ingo Molnar <mingo@kernel.org>
Link: http://lkml.kernel.org/r/73972fc7e2762e91912c6b9584582703d6f1b8cc.1507924831.git.jpoimboe@redhat.com
[ Upstream commit 564c9cc84e2adf8a6671c1937f0a9fe3da2a4b0e ]
Using .text.unlikely for refcount exceptions isn't safe because gcc may
move entire functions into .text.unlikely (e.g. in6_dev_dev()), which
would cause any uses of a protected refcount_t function to stay inline
with the function, triggering the protection unconditionally:
.section .text.unlikely,"ax",@progbits
.type in6_dev_get, @function
in6_dev_getx:
.LFB4673:
.loc 2 4128 0
.cfi_startproc
lock; incl 480(%rbx)
js 111f
.pushsection .text.unlikely
111: lea 480(%rbx), %rcx
112: .byte 0x0f, 0xff
.popsection
113:
This creates a unique .text..refcount section and adds an additional
test to the exception handler to WARN in the case of having none of OF,
SF, nor ZF set so we can see things like this more easily in the future.
The double dot for the section name keeps it out of the TEXT_MAIN macro
namespace, to avoid collisions and so it can be put at the end with
text.unlikely to keep the cold code together.
See commit:
cb87481ee89db ("kbuild: linker script do not match C names unless LD_DEAD_CODE_DATA_ELIMINATION is configured")
... which matches C names: [a-zA-Z0-9_] but not ".".
Reported-by: Mike Galbraith <efault@gmx.de>
Cc: Ard Biesheuvel <ard.biesheuvel@linaro.org>
Cc: Elena <elena.reshetova@intel.com>
Cc: linux-arch <linux-arch@vger.kernel.org>
Fixes: 7a46ec0e2f48 ("locking/refcounts, x86/asm: Implement fast refcount overflow protection")
Link: http://lkml.kernel.org/r/1504382986-49301-2-git-send-email-keescook@chromium.org
commit 1501899a898dfb5477c55534bdfd734c046da06d upstream.
Currently only get_user_pages_fast() can safely handle the writable gup
case due to its use of pud_access_permitted() to check whether the pud
entry is writable. In the gup slow path pud_write() is used instead of
pud_access_permitted() and to date it has been unimplemented, just calls
BUG_ON().
kernel BUG at ./include/linux/hugetlb.h:244!
RIP: 0010:follow_devmap_pud+0x482/0x490
Call Trace:
follow_page_mask+0x28c/0x6e0
__get_user_pages+0xe4/0x6c0
get_user_pages_unlocked+0x130/0x1b0
get_user_pages_fast+0x89/0xb0
iov_iter_get_pages_alloc+0x114/0x4a0
nfs_direct_read_schedule_iovec+0xd2/0x350
? nfs_start_io_direct+0x63/0x70
nfs_file_direct_read+0x1e0/0x250
nfs_file_read+0x90/0xc0
For now this just implements a simple check for the _PAGE_RW bit similar
to pmd_write. However, this implies that the gup-slow-path check is
missing the extra checks that the gup-fast-path performs with
pud_access_permitted. Later patches will align all checks to use the
'access_permitted' helper if the architecture provides it.
Note that the generic 'access_permitted' helper fallback is the simple
_PAGE_RW check on architectures that do not define the
'access_permitted' helper(s).
[dan.j.williams@intel.com: fix powerpc compile error]
Link: http://lkml.kernel.org/r/151129126165.37405.16031785266675461397.stgit@dwillia2-desk3.amr.corp.intel.com
Link: http://lkml.kernel.org/r/151043109938.2842.14834662818213616199.stgit@dwillia2-desk3.amr.corp.intel.com
Fixes: a00cc7d9dd93 ("mm, x86: add support for PUD-sized transparent hugepages")
Acked-by: Thomas Gleixner <tglx@linutronix.de> [x86]
Cc: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
As raw_cpu_generic_read() is a plain read from a raw_cpu_ptr() address,
it's possible (albeit unlikely) that the compiler will split the access
across multiple instructions.
In this_cpu_generic_read() we disable preemption but not interrupts
before calling raw_cpu_generic_read(). Thus, an interrupt could be taken
in the middle of the split load instructions. If a this_cpu_write() or
RMW this_cpu_*() op is made to the same variable in the interrupt
handling path, this_cpu_read() will return a torn value.
For native word types, we can avoid tearing using READ_ONCE(), but this
won't work in all cases (e.g. 64-bit types on most 32-bit platforms).
This patch reworks this_cpu_generic_read() to use READ_ONCE() where
possible, otherwise falling back to disabling interrupts.
Signed-off-by: Mark Rutland <mark.rutland@arm.com>
Cc: Christoph Lameter <cl@linux.com>
Cc: Pranith Kumar <bobby.prani@gmail.com>
Cc: Tejun Heo <tj@kernel.org>
Pull misc leftovers from Al Viro.
* 'work.misc' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
fix the __user misannotations in asm-generic get_user/put_user
fput: Don't reinvent the wheel but use existing llist API
namespace.c: Don't reinvent the wheel but use existing llist API
Pull MTD updates from Boris Brezillon:
"General updates:
- Constify pci_device_id in various drivers
- Constify device_type
- Remove pad control code from the Gemini driver
- Use %pOF to print OF node full_name
- Various fixes in the physmap_of driver
- Remove unused vars in mtdswap
- Check devm_kzalloc() return value in the spear_smi driver
- Check clk_prepare_enable() return code in the st_spi_fsm driver
- Create per MTD device debugfs enties
NAND updates, from Boris Brezillon:
- Fix memory leaks in the core
- Remove unused NAND locking support
- Rename nand.h into rawnand.h (preparing support for spi NANDs)
- Use NAND_MAX_ID_LEN where appropriate
- Fix support for 20nm Hynix chips
- Fix support for Samsung and Hynix SLC NANDs
- Various cleanup, improvements and fixes in the qcom driver
- Fixes for bugs detected by various static code analysis tools
- Fix mxc ooblayout definition
- Add a new part_parsers to tmio and sharpsl platform data in order
to define a custom list of partition parsers
- Request the reset line in exclusive mode in the sunxi driver
- Fix a build error in the orion-nand driver when compiled for ARMv4
- Allow 64-bit mvebu platforms to select the PXA3XX driver
SPI NOR updates, from Cyrille Pitchen and Marek Vasut:
- add support to the JEDEC JESD216B specification (SFDP tables).
- add support to the Intel Denverton SPI flash controller.
- fix error recovery for Spansion/Cypress SPI NOR memories.
- fix 4-byte address management for the Aspeed SPI controller.
- add support to some Microchip SST26 memory parts
- remove unneeded pinctrl header Write a message for tag:"
* tag 'for-linus-20170904' of git://git.infradead.org/linux-mtd: (74 commits)
mtd: nand: complain loudly when chip->bits_per_cell is not correctly initialized
mtd: nand: make Samsung SLC NAND usable again
mtd: nand: tmio: Register partitions using the parsers
mfd: tmio: Add partition parsers platform data
mtd: nand: sharpsl: Register partitions using the parsers
mtd: nand: sharpsl: Add partition parsers platform data
mtd: nand: qcom: Support for IPQ8074 QPIC NAND controller
mtd: nand: qcom: support for IPQ4019 QPIC NAND controller
dt-bindings: qcom_nandc: IPQ8074 QPIC NAND documentation
dt-bindings: qcom_nandc: IPQ4019 QPIC NAND documentation
dt-bindings: qcom_nandc: fix the ipq806x device tree example
mtd: nand: qcom: support for different DEV_CMD register offsets
mtd: nand: qcom: QPIC data descriptors handling
mtd: nand: qcom: enable BAM or ADM mode
mtd: nand: qcom: erased codeword detection configuration
mtd: nand: qcom: support for read location registers
mtd: nand: qcom: support for passing flags in DMA helper functions
mtd: nand: qcom: add BAM DMA descriptor handling
mtd: nand: qcom: allocate BAM transaction
mtd: nand: qcom: DMA mapping support for register read buffer
Soft dirty bit is designed to keep tracked over page migration. This
patch makes it work in the same manner for thp migration too.
Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Signed-off-by: Zi Yan <zi.yan@cs.rutgers.edu>
Cc: Anshuman Khandual <khandual@linux.vnet.ibm.com>
Cc: David Nellans <dnellans@nvidia.com>
Cc: Mel Gorman <mgorman@techsingularity.net>
Cc: Minchan Kim <minchan@kernel.org>
When THP migration is being used, memory management code needs to handle
pmd migration entries properly. This patch uses !pmd_present() or
is_swap_pmd() (depending on whether pmd_none() needs separate code or
not) to check pmd migration entries at the places where a pmd entry is
present.
Since pmd-related code uses split_huge_page(), split_huge_pmd(),
pmd_trans_huge(), pmd_trans_unstable(), or
pmd_none_or_trans_huge_or_clear_bad(), this patch:
1. adds pmd migration entry split code in split_huge_pmd(),
2. takes care of pmd migration entries whenever pmd_trans_huge() is present,
3. makes pmd_none_or_trans_huge_or_clear_bad() pmd migration entry aware.
Since split_huge_page() uses split_huge_pmd() and pmd_trans_unstable()
is equivalent to pmd_none_or_trans_huge_or_clear_bad(), we do not change
them.
Until this commit, a pmd entry should be:
1. pointing to a pte page,
2. is_swap_pmd(),
3. pmd_trans_huge(),
4. pmd_devmap(), or
5. pmd_none().
Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Pull x86 mm changes from Ingo Molnar:
"PCID support, 5-level paging support, Secure Memory Encryption support
The main changes in this cycle are support for three new, complex
hardware features of x86 CPUs:
- Add 5-level paging support, which is a new hardware feature on
upcoming Intel CPUs allowing up to 128 PB of virtual address space
and 4 PB of physical RAM space - a 512-fold increase over the old
limits. (Supercomputers of the future forecasting hurricanes on an
ever warming planet can certainly make good use of more RAM.)
Many of the necessary changes went upstream in previous cycles,
v4.14 is the first kernel that can enable 5-level paging.
This feature is activated via CONFIG_X86_5LEVEL=y - disabled by
default.
(By Kirill A. Shutemov)
- Add 'encrypted memory' support, which is a new hardware feature on
upcoming AMD CPUs ('Secure Memory Encryption', SME) allowing system
RAM to be encrypted and decrypted (mostly) transparently by the
CPU, with a little help from the kernel to transition to/from
encrypted RAM. Such RAM should be more secure against various
attacks like RAM access via the memory bus and should make the
radio signature of memory bus traffic harder to intercept (and
decrypt) as well.
This feature is activated via CONFIG_AMD_MEM_ENCRYPT=y - disabled
by default.
(By Tom Lendacky)
- Enable PCID optimized TLB flushing on newer Intel CPUs: PCID is a
hardware feature that attaches an address space tag to TLB entries
and thus allows to skip TLB flushing in many cases, even if we
switch mm's.
(By Andy Lutomirski)
All three of these features were in the works for a long time, and
it's coincidence of the three independent development paths that they
are all enabled in v4.14 at once"
* 'x86-mm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (65 commits)
x86/mm: Enable RCU based page table freeing (CONFIG_HAVE_RCU_TABLE_FREE=y)
x86/mm: Use pr_cont() in dump_pagetable()
x86/mm: Fix SME encryption stack ptr handling
kvm/x86: Avoid clearing the C-bit in rsvd_bits()
x86/CPU: Align CR3 defines
x86/mm, mm/hwpoison: Clear PRESENT bit for kernel 1:1 mappings of poison pages
acpi, x86/mm: Remove encryption mask from ACPI page protection type
x86/mm, kexec: Fix memory corruption with SME on successive kexecs
x86/mm/pkeys: Fix typo in Documentation/x86/protection-keys.txt
x86/mm/dump_pagetables: Speed up page tables dump for CONFIG_KASAN=y
x86/mm: Implement PCID based optimization: try to preserve old TLB entries using PCID
x86: Enable 5-level paging support via CONFIG_X86_5LEVEL=y
x86/mm: Allow userspace have mappings above 47-bit
x86/mm: Prepare to expose larger address space to userspace
x86/mpx: Do not allow MPX if we have mappings above 47-bit
x86/mm: Rename tasksize_32bit/64bit to task_size_32bit/64bit()
x86/xen: Redefine XEN_ELFNOTE_INIT_P2M using PUD_SIZE * PTRS_PER_PUD
x86/mm/dump_pagetables: Fix printout of p4d level
x86/mm/dump_pagetables: Generalize address normalization
x86/boot: Fix memremap() related build failure
Pull locking updates from Ingo Molnar:
- Add 'cross-release' support to lockdep, which allows APIs like
completions, where it's not the 'owner' who releases the lock, to be
tracked. It's all activated automatically under
CONFIG_PROVE_LOCKING=y.
- Clean up (restructure) the x86 atomics op implementation to be more
readable, in preparation of KASAN annotations. (Dmitry Vyukov)
- Fix static keys (Paolo Bonzini)
- Add killable versions of down_read() et al (Kirill Tkhai)
- Rework and fix jump_label locking (Marc Zyngier, Paolo Bonzini)
- Rework (and fix) tlb_flush_pending() barriers (Peter Zijlstra)
- Remove smp_mb__before_spinlock() and convert its usages, introduce
smp_mb__after_spinlock() (Peter Zijlstra)
* 'locking-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (56 commits)
locking/lockdep/selftests: Fix mixed read-write ABBA tests
sched/completion: Avoid unnecessary stack allocation for COMPLETION_INITIALIZER_ONSTACK()
acpi/nfit: Fix COMPLETION_INITIALIZER_ONSTACK() abuse
locking/pvqspinlock: Relax cmpxchg's to improve performance on some architectures
smp: Avoid using two cache lines for struct call_single_data
locking/lockdep: Untangle xhlock history save/restore from task independence
locking/refcounts, x86/asm: Disable CONFIG_ARCH_HAS_REFCOUNT for the time being
futex: Remove duplicated code and fix undefined behaviour
Documentation/locking/atomic: Finish the document...
locking/lockdep: Fix workqueue crossrelease annotation
workqueue/lockdep: 'Fix' flush_work() annotation
locking/lockdep/selftests: Add mixed read-write ABBA tests
mm, locking/barriers: Clarify tlb_flush_pending() barriers
locking/lockdep: Make CONFIG_LOCKDEP_CROSSRELEASE and CONFIG_LOCKDEP_COMPLETIONS truly non-interactive
locking/lockdep: Explicitly initialize wq_barrier::done::map
locking/lockdep: Rename CONFIG_LOCKDEP_COMPLETE to CONFIG_LOCKDEP_COMPLETIONS
locking/lockdep: Reword title of LOCKDEP_CROSSRELEASE config
locking/lockdep: Make CONFIG_LOCKDEP_CROSSRELEASE part of CONFIG_PROVE_LOCKING
locking/lockdep: Fix the rollback and overwrite detection logic in crossrelease
Pull x86 asm updates from Ingo Molnar:
- Introduce the ORC unwinder, which can be enabled via
CONFIG_ORC_UNWINDER=y.
The ORC unwinder is a lightweight, Linux kernel specific debuginfo
implementation, which aims to be DWARF done right for unwinding.
Objtool is used to generate the ORC unwinder tables during build, so
the data format is flexible and kernel internal: there's no
dependency on debuginfo created by an external toolchain.
The ORC unwinder is almost two orders of magnitude faster than the
(out of tree) DWARF unwinder - which is important for perf call graph
profiling. It is also significantly simpler and is coded defensively:
there has not been a single ORC related kernel crash so far, even
with early versions. (knock on wood!)
But the main advantage is that enabling the ORC unwinder allows
CONFIG_FRAME_POINTERS to be turned off - which speeds up the kernel
measurably:
With frame pointers disabled, GCC does not have to add frame pointer
instrumentation code to every function in the kernel. The kernel's
.text size decreases by about 3.2%, resulting in better cache
utilization and fewer instructions executed, resulting in a broad
kernel-wide speedup. Average speedup of system calls should be
roughly in the 1-3% range - measurements by Mel Gorman [1] have shown
a speedup of 5-10% for some function execution intense workloads.
The main cost of the unwinder is that the unwinder data has to be
stored in RAM: the memory cost is 2-4MB of RAM, depending on kernel
config - which is a modest cost on modern x86 systems.
Given how young the ORC unwinder code is it's not enabled by default
- but given the performance advantages the plan is to eventually make
it the default unwinder on x86.
See Documentation/x86/orc-unwinder.txt for more details.
- Remove lguest support: its intended role was that of a temporary
proof of concept for virtualization, plus its removal will enable the
reduction (removal) of the paravirt API as well, so Rusty agreed to
its removal. (Juergen Gross)
- Clean up and fix FSGS related functionality (Andy Lutomirski)
- Clean up IO access APIs (Andy Shevchenko)
- Enhance the symbol namespace (Jiri Slaby)
* 'x86-asm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (47 commits)
objtool: Handle GCC stack pointer adjustment bug
x86/entry/64: Use ENTRY() instead of ALIGN+GLOBAL for stub32_clone()
x86/fpu/math-emu: Add ENDPROC to functions
x86/boot/64: Extract efi_pe_entry() from startup_64()
x86/boot/32: Extract efi_pe_entry() from startup_32()
x86/lguest: Remove lguest support
x86/paravirt/xen: Remove xen_patch()
objtool: Fix objtool fallthrough detection with function padding
x86/xen/64: Fix the reported SS and CS in SYSCALL
objtool: Track DRAP separately from callee-saved registers
objtool: Fix validate_branch() return codes
x86: Clarify/fix no-op barriers for text_poke_bp()
x86/switch_to/64: Rewrite FS/GS switching yet again to fix AMD CPUs
selftests/x86/fsgsbase: Test selectors 1, 2, and 3
x86/fsgsbase/64: Report FSBASE and GSBASE correctly in core dumps
x86/fsgsbase/64: Fully initialize FS and GS state in start_thread_common
x86/asm: Fix UNWIND_HINT_REGS macro for older binutils
x86/asm/32: Fix regs_get_register() on segment registers
x86/xen/64: Rearrange the SYSCALL entries
x86/asm/32: Remove a bunch of '& 0xffff' from pt_regs segment reads
Pull perf updates from Ingo Molnar:
"Kernel side changes:
- Add branch type profiling/tracing support. (Jin Yao)
- Add the PERF_SAMPLE_PHYS_ADDR ABI to allow the tracing/profiling of
physical memory addresses, where the PMU supports it. (Kan Liang)
- Export some PMU capability details in the new
/sys/bus/event_source/devices/cpu/caps/ sysfs directory. (Andi
Kleen)
- Aux data fixes and updates (Will Deacon)
- kprobes fixes and updates (Masami Hiramatsu)
- AMD uncore PMU driver fixes and updates (Janakarajan Natarajan)
On the tooling side, here's a (limited!) list of highlights - there
were many other changes that I could not list, see the shortlog and
git history for details:
UI improvements:
- Implement a visual marker for fused x86 instructions in the
annotate TUI browser, available now in 'perf report', more work
needed to have it available as well in 'perf top' (Jin Yao)
Further explanation from one of Jin's patches:
│ ┌──cmpl $0x0,argp_program_version_hook
81.93 │ ├──je 20
│ │ lock cmpxchg %esi,0x38a9a4(%rip)
│ │↓ jne 29
│ │↓ jmp 43
11.47 │20:└─→cmpxch %esi,0x38a999(%rip)
That means the cmpl+je is a fused instruction pair and they should
be considered together.
- Record the branch type and then show statistics and info about in
callchain entries (Jin Yao)
Example from one of Jin's patches:
# perf record -g -j any,save_type
# perf report --branch-history --stdio --no-children
38.50% div.c:45 [.] main div
---main div.c:42 (RET CROSS_2M cycles:2)
compute_flag div.c:28 (cycles:2)
compute_flag div.c:27 (RET CROSS_2M cycles:1)
rand rand.c:28 (cycles:1)
rand rand.c:28 (RET CROSS_2M cycles:1)
__random random.c:298 (cycles:1)
__random random.c:297 (COND_BWD CROSS_2M cycles:1)
__random random.c:295 (cycles:1)
__random random.c:295 (COND_BWD CROSS_2M cycles:1)
__random random.c:295 (RET CROSS_2M cycles:9)
namespaces support:
- Add initial support for namespaces, using setns to access files in
namespaces, grabbing their build-ids, etc. (Krister Johansen)
perf trace enhancements:
- Beautify pkey_{alloc,free,mprotect} arguments in 'perf trace'
(Arnaldo Carvalho de Melo)
- Add initial 'clone' syscall args beautifier in 'perf trace'
- Ignore 'fd' and 'offset' args for MAP_ANONYMOUS in 'perf trace'
- Beautifiers for the 'cmd' arg of several ioctl types, including:
sound, DRM, KVM, vhost virtio and perf_events. (Arnaldo Carvalho de
Melo)
- Add PERF_SAMPLE_CALLCHAIN and PERF_RECORD_MMAP[2] to 'perf data'
CTF conversion, allowing CTF trace visualization tools to show
callchains and to resolve symbols (Geneviève Bastien)
- Beautify the fcntl syscall, which is an interesting one in the
sense that infrastructure had to be put in place to change the
formatters of some arguments according to the value in a previous
one, i.e. cmd dictates how arg and the syscall return will be
formatted. (Arnaldo Carvalho de Melo
perf stat enhancements:
- Use group read for event groups in 'perf stat', reducing overhead
when groups are defined in the event specification, i.e. when using
{} to enclose a list of events, asking them to be read at the same
time, e.g.: "perf stat -e '{cycles,instructions}'" (Jiri Olsa)
pipe mode improvements:
- Process tracing data in 'perf annotate' pipe mode (David
Carrillo-Cisneros)
- Add header record types to pipe-mode, now this command:
$ perf record -o - -e cycles sleep 1 | perf report --stdio --header
Will show the same as in non-pipe mode, i.e. involving a perf.data
file (David Carrillo-Cisneros)
Vendor specific hardware event support updates/enhancements:
- Update POWER9 vendor events tables (Sukadev Bhattiprolu)
- Add POWER9 PMU events Sukadev (Bhattiprolu)
- Support additional POWER8+ PVR in PMU mapfile (Shriya)
- Add Skylake server uncore JSON vendor events (Andi Kleen)
- Support exporting Intel PT data to sqlite3 with python perf
scripts, this is in addition to the postgresql support that was
already there (Adrian Hunter)"
* 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (253 commits)
perf symbols: Fix plt entry calculation for ARM and AARCH64
perf probe: Fix kprobe blacklist checking condition
perf/x86: Fix caps/ for !Intel
perf/core, x86: Add PERF_SAMPLE_PHYS_ADDR
perf/core, pt, bts: Get rid of itrace_started
perf trace beauty: Beautify pkey_{alloc,free,mprotect} arguments
tools headers: Sync cpu features kernel ABI headers with tooling headers
perf tools: Pass full path of FEATURES_DUMP
perf tools: Robustify detection of clang binary
tools lib: Allow external definition of CC, AR and LD
perf tools: Allow external definition of flex and bison binary names
tools build tests: Don't hardcode gcc name
perf report: Group stat values on global event id
perf values: Zero value buffers
perf values: Fix allocation check
perf values: Fix thread index bug
perf report: Add dump_read function
perf record: Set read_format for inherit_stat
perf c2c: Fix remote HITM detection for Skylake
perf tools: Fix static build with newer toolchains
Pull RCU updates from Ingo Molnad:
"The main RCU related changes in this cycle were:
- Removal of spin_unlock_wait()
- SRCU updates
- RCU torture-test updates
- RCU Documentation updates
- Extend the sys_membarrier() ABI with the MEMBARRIER_CMD_PRIVATE_EXPEDITED variant
- Miscellaneous RCU fixes
- CPU-hotplug fixes"
* 'core-rcu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (63 commits)
arch: Remove spin_unlock_wait() arch-specific definitions
locking: Remove spin_unlock_wait() generic definitions
drivers/ata: Replace spin_unlock_wait() with lock/unlock pair
ipc: Replace spin_unlock_wait() with lock/unlock pair
exit: Replace spin_unlock_wait() with lock/unlock pair
completion: Replace spin_unlock_wait() with lock/unlock pair
doc: Set down RCU's scheduling-clock-interrupt needs
doc: No longer allowed to use rcu_dereference on non-pointers
doc: Add RCU files to docbook-generation files
doc: Update memory-barriers.txt for read-to-write dependencies
doc: Update RCU documentation
membarrier: Provide expedited private command
rcu: Remove exports from rcu_idle_exit() and rcu_idle_enter()
rcu: Add warning to rcu_idle_enter() for irqs enabled
rcu: Make rcu_idle_enter() rely on callers disabling irqs
rcu: Add assertions verifying blocked-tasks list
rcu/tracing: Set disable_rcu_irq_enter on rcu_eqs_exit()
rcu: Add TPS() protection for _rcu_barrier_trace strings
rcu: Use idle versions of swait to make idle-hack clear
swait: Add idle variants which don't contribute to load average
mm/page_alloc.c
When !NUMA, cpumask_of_node(@node) equals cpu_online_mask regardless of
@node. The assumption seems that if !NUMA, there shouldn't be more than
one node and thus reporting cpu_online_mask regardless of @node is
correct. However, that assumption was broken years ago to support
DISCONTIGMEM and whether a system has multiple nodes or not is
separately controlled by NEED_MULTIPLE_NODES.
This means that, on a system with !NUMA && NEED_MULTIPLE_NODES,
cpumask_of_node() will report cpu_online_mask for all possible nodes,
indicating that the CPUs are associated with multiple nodes which is an
impossible configuration.
This bug has been around forever but doesn't look like it has caused any
noticeable symptoms. However, it triggers a WARN recently added to
workqueue to verify NUMA affinity configuration.
Fix it by reporting empty cpumask on non-zero nodes if !NUMA.
Reported-and-tested-by: Geert Uytterhoeven <geert@linux-m68k.org>
Merge v4.13-rc7 back to resolve merge conflicts in
drivers/mtd/nand/nandsim.c and include/asm-generic/vmlinux.lds.h.
arch/x86/kernel/head64.c
arch/x86/mm/mmap.c
There is code duplicated over all architecture's headers for
futex_atomic_op_inuser. Namely op decoding, access_ok check for uaddr,
and comparison of the result.
Remove this duplication and leave up to the arches only the needed
assembly which is now in arch_futex_atomic_op_inuser.
This effectively distributes the Will Deacon's arm64 fix for undefined
behaviour reported by UBSAN to all architectures. The fix was done in
commit 5f16a046f8e1 (arm64: futex: Fix undefined behaviour with
FUTEX_OP_OPARG_SHIFT usage). Look there for an example dump.
And as suggested by Thomas, check for negative oparg too, because it was
also reported to cause undefined behaviour report.
Note that s390 removed access_ok check in d12a29703 ("s390/uaccess:
remove pointless access_ok() checks") as access_ok there returns true.
We introduce it back to the helper for the sake of simplicity (it gets
optimized away anyway).
Acked-by: Russell King <rmk+kernel@armlinux.org.uk>
Acked-by: Michael Ellerman <mpe@ellerman.id.au> (powerpc)
Acked-by: Heiko Carstens <heiko.carstens@de.ibm.com> [s390]
Acked-by: Chris Metcalf <cmetcalf@mellanox.com> [for tile]
Reviewed-by: Darren Hart (VMware) <dvhart@infradead.org>
Reviewed-by: Will Deacon <will.deacon@arm.com> [core/arm64]
Cc: linux-mips@linux-mips.org
Cc: Rich Felker <dalias@libc.org>
Cc: linux-ia64@vger.kernel.org
Cc: linux-sh@vger.kernel.org
Cc: peterz@infradead.org
Cc: Max Filippov <jcmvbkbc@gmail.com>
Cc: sparclinux@vger.kernel.org
Cc: Jonas Bonn <jonas@southpole.se>
Cc: linux-s390@vger.kernel.org
Cc: Yoshinori Sato <ysato@users.sourceforge.jp>
Cc: linux-hexagon@vger.kernel.org
Cc: Helge Deller <deller@gmx.de>
Cc: "James E.J. Bottomley" <jejb@parisc-linux.org>
Cc: Matt Turner <mattst88@gmail.com>
Cc: linux-snps-arc@lists.infradead.org
Cc: linux-xtensa@linux-xtensa.org
Cc: Stefan Kristiansson <stefan.kristiansson@saunalahti.fi>
Cc: openrisc@lists.librecores.org
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Cc: Stafford Horne <shorne@gmail.com>
Cc: Richard Henderson <rth@twiddle.net>
Cc: Chris Zankel <chris@zankel.net>
Cc: linux-parisc@vger.kernel.org
Cc: Richard Kuo <rkuo@codeaurora.org>
Cc: linux-alpha@vger.kernel.org
Cc: linuxppc-dev@lists.ozlabs.org
Link: http://lkml.kernel.org/r/20170824073105.3901-1-jslaby@suse.cz
git://git.kernel.org/pub/scm/linux/kernel/git/masahiroy/linux-kbuild
Pull Kbuild fixes from Masahiro Yamada:
- fix linker script regression caused by dead code elimination support
- fix typos and outdated comments
- specify kselftest-clean as a PHONY target
- fix "make dtbs_install" when $(srctree) includes shell special
characters like '~'
- Move -fshort-wchar to the global option list because defining it
partially emits warnings
* tag 'kbuild-fixes-v4.13' of git://git.kernel.org/pub/scm/linux/kernel/git/masahiroy/linux-kbuild:
kbuild: update comments of Makefile.asm-generic
kbuild: Do not use hyphen in exported variable name
Makefile: add kselftest-clean to PHONY target list
Kbuild: use -fshort-wchar globally
fixdep: trivial: typo fix and correction
kbuild: trivial cleanups on the comments
git://git.kernel.org/pub/scm/linux/kernel/git/paulmck/linux-rcu into core/rcu
Pull RCU updates from Paul E. McKenney:
- SRCU updates
- Torture-test updates
- Documentation updates
- Miscellaneous fixes
- CPU-hotplug fixes
- Miscellaneous non-RCU fixes
We need the ASM_UNREACHABLE() macro for a dependent patch.
There is no agreed-upon definition of spin_unlock_wait()'s semantics,
and it appears that all callers could do just as well with a lock/unlock
pair. This commit therefore removes spin_unlock_wait() and related
definitions from core code.
Cc: Alan Stern <stern@rowland.harvard.edu>
Cc: Andrea Parri <parri.andrea@gmail.com>
When XIP_KERNEL is enabled, some functions are defined in the .data
ELF section because we require them to be in RAM whenever we communicate
with the flash chip. However this causes problems when FTRACE is
enabled and gcc emits calls to __gnu_mcount_nc in the function
prolog:
drivers/built-in.o: In function `cfi_chip_setup':
:(.data+0x272fc): relocation truncated to fit: R_ARM_CALL against symbol `__gnu_mcount_nc' defined in .text section in arch/arm/kernel/built-in.o
drivers/built-in.o: In function `cfi_probe_chip':
:(.data+0x27de8): relocation truncated to fit: R_ARM_CALL against symbol `__gnu_mcount_nc' defined in .text section in arch/arm/kernel/built-in.o
/tmp/ccY172rP.s: Assembler messages:
/tmp/ccY172rP.s:70: Warning: ignoring changed section attributes for .data
/tmp/ccY172rP.s: Error: 1 warning, treating warnings as errors
make[5]: *** [drivers/mtd/chips/cfi_probe.o] Error 1
/tmp/ccK4rjeO.s: Assembler messages:
/tmp/ccK4rjeO.s:421: Warning: ignoring changed section attributes for .data
/tmp/ccK4rjeO.s: Error: 1 warning, treating warnings as errors
make[5]: *** [drivers/mtd/chips/cfi_util.o] Error 1
/tmp/ccUvhCYR.s: Assembler messages:
/tmp/ccUvhCYR.s:1895: Warning: ignoring changed section attributes for .data
/tmp/ccUvhCYR.s: Error: 1 warning, treating warnings as errors
Specifically, this does not work because the .data section is not
marked executable, which leads LD to not generate trampolines for
long calls.
This moves the __xipram functions into their own .xiptext section instead.
The section is still placed next to .data and located in RAM but is marked
executable, which avoids the build errors.
Also, we only need to place the XIP functions into a separate section
if both CONFIG_XIP_KERNEL and CONFIG_MTD_XIP are set: When only MTD_XIP
is used, the whole kernel is still in RAM and we do not need to worry
about pulling out the rug under it. When only XIP_KERNEL but not MTD_XIP
is set, the kernel is in some form of ROM, but we never write to it.
Note that MTD_XIP has been broken on ARM since around 2011 or 2012. I
have sent another patch[2] to fix compilation, which I plan to merge
through arm-soc unless there are objections. The obvious alternative
to that would be to completely rip out the MTD_XIP support from the
kernel, since obviously nobody has been using it in a long while.
Link: [1] https://patchwork.kernel.org/patch/8109771/
Link: [2] https://patchwork.kernel.org/patch/9855225/
Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com>
include/linux/mm_types.h
mm/huge_memory.c
I removed the smp_mb__before_spinlock() like the following commit does:
8b1b436dd1cc ("mm, locking: Rework {set,clear,mm}_tlb_flush_pending()")
and fixed up the affected commits.
Nadav reported parallel MADV_DONTNEED on same range has a stale TLB
problem and Mel fixed it[1] and found same problem on MADV_FREE[2].
Quote from Mel Gorman:
"The race in question is CPU 0 running madv_free and updating some PTEs
while CPU 1 is also running madv_free and looking at the same PTEs.
CPU 1 may have writable TLB entries for a page but fail the pte_dirty
check (because CPU 0 has updated it already) and potentially fail to
flush.
Hence, when madv_free on CPU 1 returns, there are still potentially
writable TLB entries and the underlying PTE is still present so that a
subsequent write does not necessarily propagate the dirty bit to the
underlying PTE any more. Reclaim at some unknown time at the future
may then see that the PTE is still clean and discard the page even
though a write has happened in the meantime. I think this is possible
but I could have missed some protection in madv_free that prevents it
happening."
This patch aims for solving both problems all at once and is ready for
other problem with KSM, MADV_FREE and soft-dirty story[3].
TLB batch API(tlb_[gather|finish]_mmu] uses [inc|dec]_tlb_flush_pending
and mmu_tlb_flush_pending so that when tlb_finish_mmu is called, we can
catch there are parallel threads going on. In that case, forcefully,
flush TLB to prevent for user to access memory via stale TLB entry
although it fail to gather page table entry.
I confirmed this patch works with [4] test program Nadav gave so this
patch supersedes "mm: Always flush VMA ranges affected by zap_page_range
v2" in current mmotm.
NOTE:
This patch modifies arch-specific TLB gathering interface(x86, ia64,
s390, sh, um). It seems most of architecture are straightforward but
s390 need to be careful because tlb_flush_mmu works only if
mm->context.flush_mm is set to non-zero which happens only a pte entry
really is cleared by ptep_get_and_clear and friends. However, this
problem never changes the pte entries but need to flush to prevent
memory access from stale tlb.
[1] http://lkml.kernel.org/r/20170725101230.5v7gvnjmcnkzzql3@techsingularity.net
[2] http://lkml.kernel.org/r/20170725100722.2dxnmgypmwnrfawp@suse.de
[3] http://lkml.kernel.org/r/BD3A0EBE-ECF4-41D4-87FA-C755EA9AB6BD@gmail.com
[4] https://patchwork.kernel.org/patch/9861621/
[minchan@kernel.org: decrease tlb flush pending count in tlb_finish_mmu]
Link: http://lkml.kernel.org/r/20170808080821.GA31730@bbox
Link: http://lkml.kernel.org/r/20170802000818.4760-7-namit@vmware.com
Signed-off-by: Minchan Kim <minchan@kernel.org>
Signed-off-by: Nadav Amit <namit@vmware.com>
Reported-by: Nadav Amit <namit@vmware.com>
Reported-by: Mel Gorman <mgorman@techsingularity.net>
Acked-by: Mel Gorman <mgorman@techsingularity.net>
Cc: Russell King <linux@armlinux.org.uk>
Cc: Jeff Dike <jdike@addtoit.com>
Cc: Nadav Amit <nadav.amit@gmail.com>
Cc: Sergey Senozhatsky <sergey.senozhatsky@gmail.com>
This patch is a preparatory patch for solving race problems caused by
TLB batch. For that, we will increase/decrease TLB flush pending count
of mm_struct whenever tlb_[gather|finish]_mmu is called.
Before making it simple, this patch separates architecture specific part
and rename it to arch_tlb_[gather|finish]_mmu and generic part just
calls it.
It shouldn't change any behavior.
Link: http://lkml.kernel.org/r/20170802000818.4760-5-namit@vmware.com
Generate irqentry and softirqentry text sections without
any Kconfig dependencies. This will add extra sections, but
there should be no performace impact.
Signed-off-by: Masami Hiramatsu <mhiramat@kernel.org>
Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com>
Cc: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com>
Cc: David S . Miller <davem@davemloft.net>
Cc: Francis Deslauriers <francis.deslauriers@efficios.com>
Cc: linux-cris-kernel@axis.com
Cc: mathieu.desnoyers@efficios.com
Link: http://lkml.kernel.org/r/150172789110.27216.3955739126693102122.stgit@devbox
Those architectures that have a special atomic_set implementation also
need a special atomic_set_release(), because for the very same reason
WRITE_ONCE() is broken for them, smp_store_release() is too.
The vast majority is architectures that have spinlock hash based atomic
implementation except hexagon which seems to have a hardware 'feature'.
The spinlock based atomics should be SC, that is, none of them appear to
place extra barriers in atomic_cmpxchg() or any of the other SC atomic
primitives and therefore seem to rely on their spinlock implementation
being SC (I did not fully validate all that).
Therefore, the normal atomic_set() is SC and can be used at
atomic_set_release().
Cc: Paul McKenney <paulmck@linux.vnet.ibm.com>
Cc: davem@davemloft.net
Cc: james.hogan@imgtec.com
Cc: jejb@parisc-linux.org
Cc: rkuo@codeaurora.org
Cc: vgupta@synopsys.com
Link: http://lkml.kernel.org/r/20170609110506.yod47flaav3wgoj5@hirez.programming.kicks-ass.net
The .data and .bss sections were modified in the generic linker script to
pull in sections named .data.<C identifier>, which are generated by gcc with
-ffunction-sections and -fdata-sections options.
The problem with this pattern is it can also match section names that Linux
defines explicitly, e.g., .data.unlikely. This can cause Linux sections to
get moved into the wrong place.
The way to avoid this is to use ".." separators for explicit section names
(the dot character is valid in a section name but not a C identifier).
However currently there are sections which don't follow this rule, so for
now just disable the wild card by default.
Example: http://marc.info/?l=linux-arm-kernel&m=150106824024221&w=2
Cc: <stable@vger.kernel.org> # 4.9
Fixes: b67067f1176df ("kbuild: allow archs to select link dead code/data elimination")
Signed-off-by: Nicholas Piggin <npiggin@gmail.com>
