architectures
commit 6b15f678fb7d5ef54e089e6ace72f007fe6e9895 upstream.
For architectures using __WARN_TAINT, the WARN_ON macro did not print
out the "cut here" string. The other WARN_XXX macros would print "cut
here" inside __warn_printk, which is not called for WARN_ON since it
doesn't have a message to print.
Link: http://lkml.kernel.org/r/20190624154831.163888-1-ddavenport@chromium.org
Fixes: a7bed27af194 ("bug: fix "cut here" location for __WARN_TAINT architectures")
Signed-off-by: Drew Davenport <ddavenport@chromium.org>
Tested-by: Kees Cook <keescook@chromium.org>
Cc: <stable@vger.kernel.org>
Based on 2 normalized pattern(s):
this program is free software you can redistribute it and or modify
it under the terms of the gnu general public license version 2 as
published by the free software foundation
published by the free software foundation #
extracted by the scancode license scanner the SPDX license identifier
GPL-2.0-only
has been chosen to replace the boilerplate/reference in 4122 file(s).
Reviewed-by: Enrico Weigelt <info@metux.net>
Reviewed-by: Allison Randal <allison@lohutok.net>
Cc: linux-spdx@vger.kernel.org
Link: https://lkml.kernel.org/r/20190604081206.933168790@linutronix.de
Based on 1 normalized pattern(s):
this file is released under the gplv2
GPL-2.0-only
has been chosen to replace the boilerplate/reference in 68 file(s).
Reviewed-by: Armijn Hemel <armijn@tjaldur.nl>
Link: https://lkml.kernel.org/r/20190531190114.292346262@linutronix.de
this copyrighted material is made available to anyone wishing to use
modify copy or redistribute it subject to the terms and conditions
of the gnu general public license v 2
GPL-2.0-only
has been chosen to replace the boilerplate/reference in 45 file(s).
Reviewed-by: Richard Fontana <rfontana@redhat.com>
Reviewed-by: Steve Winslow <swinslow@gmail.com>
Reviewed-by: Alexios Zavras <alexios.zavras@intel.com>
Link: https://lkml.kernel.org/r/20190528170027.342746075@linutronix.de
Based on 3 normalized pattern(s):
it under the terms of the gnu general public license as published by
the free software foundation either version 2 of the license or at
your option any later version this program is distributed in the
hope that it will be useful but without any warranty without even
the implied warranty of merchantability or fitness for a particular
purpose see the gnu general public license for more details
your option any later version [author] [kishon] [vijay] [abraham]
[i] [kishon]@[ti] [com] this program is distributed in the hope that
it will be useful but without any warranty without even the implied
warranty of merchantability or fitness for a particular purpose see
your option any later version [author] [graeme] [gregory]
[gg]@[slimlogic] [co] [uk] [author] [kishon] [vijay] [abraham] [i]
[kishon]@[ti] [com] [based] [on] [twl6030]_[usb] [c] [author] [hema]
[hk] [hemahk]@[ti] [com] this program is distributed in the hope
that it will be useful but without any warranty without even the
GPL-2.0-or-later
has been chosen to replace the boilerplate/reference in 1105 file(s).
Link: https://lkml.kernel.org/r/20190527070033.202006027@linutronix.de
GPL-2.0-or-later
has been chosen to replace the boilerplate/reference in 3029 file(s).
Link: https://lkml.kernel.org/r/20190527070032.746973796@linutronix.de
licensed under the gpl 2 or later
GPL-2.0-or-later
has been chosen to replace the boilerplate/reference in 82 file(s).
Link: https://lkml.kernel.org/r/20190524100845.150836982@linutronix.de
the free software foundation either version 2 or at your option any
later version you should have received a copy of the gnu general
public license for example usr src linux copying if not write to the
free software foundation inc 675 mass ave cambridge ma 02139 usa
GPL-2.0-or-later
has been chosen to replace the boilerplate/reference in 20 file(s).
Link: https://lkml.kernel.org/r/20190520170858.552543146@linutronix.de
it under the terms of the gnu general public licence as published by
the free software foundation either version 2 of the licence or at
GPL-2.0-or-later
has been chosen to replace the boilerplate/reference in 114 file(s).
Link: https://lkml.kernel.org/r/20190520170857.552531963@linutronix.de
Pull core fixes from Ingo Molnar:
"This fixes a particularly thorny munmap() bug with MPX, plus fixes a
host build environment assumption in objtool"
* 'core-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
objtool: Allow AR to be overridden with HOSTAR
x86/mpx, mm/core: Fix recursive munmap() corruption
git://git.kernel.org/pub/scm/linux/kernel/git/arnd/asm-generic
Pull nommu generic uaccess updates from Arnd Bergmann:
"asm-generic: kill <asm/segment.h> and improve nommu generic uaccess helpers
Christoph Hellwig writes:
This is a series doing two somewhat interwinded things. It improves
the asm-generic nommu uaccess helper to optionally be entirely
generic and not require any arch helpers for the actual uaccess.
For the generic uaccess.h to actually be generically useful I also
had to kill off the mess we made of <asm/segment.h>, which really
shouldn't exist on most architectures"
* tag 'asm-generic-nommu' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/asm-generic:
asm-generic: optimize generic uaccess for 8-byte loads and stores
asm-generic: provide entirely generic nommu uaccess
arch: mostly remove <asm/segment.h>
asm-generic: don't include <asm/segment.h> from <asm/uaccess.h>
Merge more updates from Andrew Morton:
- a couple of hotfixes
- almost all of the rest of MM
- lib/ updates
- binfmt_elf updates
- autofs updates
- quite a lot of misc fixes and updates
- reiserfs, fatfs
- signals
- exec
- cpumask
- rapidio
- sysctl
- pids
- eventfd
- gcov
- panic
- pps
- gdb script updates
- ipc updates
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (126 commits)
mm: memcontrol: fix NUMA round-robin reclaim at intermediate level
mm: memcontrol: fix recursive statistics correctness & scalabilty
mm: memcontrol: move stat/event counting functions out-of-line
mm: memcontrol: make cgroup stats and events query API explicitly local
drivers/virt/fsl_hypervisor.c: prevent integer overflow in ioctl
drivers/virt/fsl_hypervisor.c: dereferencing error pointers in ioctl
mm, memcg: rename ambiguously named memory.stat counters and functions
arch: remove <asm/sizes.h> and <asm-generic/sizes.h>
treewide: replace #include <asm/sizes.h> with #include <linux/sizes.h>
fs/block_dev.c: Remove duplicate header
fs/cachefiles/namei.c: remove duplicate header
include/linux/sched/signal.h: replace `tsk' with `task'
fs/coda/psdev.c: remove duplicate header
ipc: do cyclic id allocation for the ipc object.
ipc: conserve sequence numbers in ipcmni_extend mode
ipc: allow boot time extension of IPCMNI from 32k to 16M
ipc/mqueue: optimize msg_get()
ipc/mqueue: remove redundant wq task assignment
ipc: prevent lockup on alloc_msg and free_msg
scripts/gdb: print cached rate in lx-clk-summary
Now that all instances of #include <asm/sizes.h> have been replaced with
#include <linux/sizes.h>, we can remove these.
Link: http://lkml.kernel.org/r/1553267665-27228-2-git-send-email-yamada.masahiro@socionext.com
The "WITH Linux-syscall-note" should be added to headers exported to the
user-space.
Some kernel-space headers have "WITH Linux-syscall-note", which seems a
mistake.
[1] arch/x86/include/asm/hyperv-tlfs.h
Commit 5a4858032217 ("x86/hyper-v: move hyperv.h out of uapi") moved
this file out of uapi, but missed to update the SPDX License tag.
[2] include/asm-generic/shmparam.h
Commit 76ce2a80a28e ("Rename include/{uapi => }/asm-generic/shmparam.h
really") moved this file out of uapi, but missed to update the SPDX
License tag.
[3] include/linux/qcom-geni-se.h
Commit eddac5af0654 ("soc: qcom: Add GENI based QUP Wrapper driver")
added this file, but I do not see a good reason why its license tag must
include "WITH Linux-syscall-note".
Link: http://lkml.kernel.org/r/1554196104-3522-1-git-send-email-yamada.masahiro@socionext.com
git://git.kernel.org/pub/scm/linux/kernel/git/jeyu/linux
Pull modules updates from Jessica Yu:
- Use a separate table to store symbol types instead of hijacking
fields in struct Elf_Sym
- Trivial code cleanups
* tag 'modules-for-v5.2' of git://git.kernel.org/pub/scm/linux/kernel/git/jeyu/linux:
module: add stubs for within_module functions
kallsyms: store type information in its own array
vmlinux.lds.h: drop unused __vermagic
On systems without CONTIG_ALLOC activated but that support gigantic pages,
boottime reserved gigantic pages can not be freed at all. This patch
simply enables the possibility to hand back those pages to memory
allocator.
Link: http://lkml.kernel.org/r/20190327063626.18421-5-alex@ghiti.fr
Signed-off-by: Alexandre Ghiti <alex@ghiti.fr>
Acked-by: David S. Miller <davem@davemloft.net> [sparc]
Reviewed-by: Mike Kravetz <mike.kravetz@oracle.com>
Cc: Andy Lutomirsky <luto@kernel.org>
Cc: Aneesh Kumar K.V <aneesh.kumar@linux.ibm.com>
Cc: Dave Hansen <dave.hansen@linux.intel.com>
Cc: "H . Peter Anvin" <hpa@zytor.com>
Cc: Michael Ellerman <mpe@ellerman.id.au>
Cc: Rich Felker <dalias@libc.org>
Cc: Yoshinori Sato <ysato@users.sourceforge.jp>
This is a bit of a mess, to put it mildly. But, it's a bug
that only seems to have showed up in 4.20 but wasn't noticed
until now, because nobody uses MPX.
MPX has the arch_unmap() hook inside of munmap() because MPX
uses bounds tables that protect other areas of memory. When
memory is unmapped, there is also a need to unmap the MPX
bounds tables. Barring this, unused bounds tables can eat 80%
of the address space.
But, the recursive do_munmap() that gets called vi arch_unmap()
wreaks havoc with __do_munmap()'s state. It can result in
freeing populated page tables, accessing bogus VMA state,
double-freed VMAs and more.
See the "long story" further below for the gory details.
To fix this, call arch_unmap() before __do_unmap() has a chance
to do anything meaningful. Also, remove the 'vma' argument
and force the MPX code to do its own, independent VMA lookup.
== UML / unicore32 impact ==
Remove unused 'vma' argument to arch_unmap(). No functional
change.
I compile tested this on UML but not unicore32.
== powerpc impact ==
powerpc uses arch_unmap() well to watch for munmap() on the
VDSO and zeroes out 'current->mm->context.vdso_base'. Moving
arch_unmap() makes this happen earlier in __do_munmap(). But,
'vdso_base' seems to only be used in perf and in the signal
delivery that happens near the return to userspace. I can not
find any likely impact to powerpc, other than the zeroing
happening a little earlier.
powerpc does not use the 'vma' argument and is unaffected by
its removal.
I compile-tested a 64-bit powerpc defconfig.
== x86 impact ==
For the common success case this is functionally identical to
what was there before. For the munmap() failure case, it's
possible that some MPX tables will be zapped for memory that
continues to be in use. But, this is an extraordinarily
unlikely scenario and the harm would be that MPX provides no
protection since the bounds table got reset (zeroed).
I can't imagine anyone doing this:
ptr = mmap();
// use ptr
ret = munmap(ptr);
if (ret)
// oh, there was an error, I'll
// keep using ptr.
Because if you're doing munmap(), you are *done* with the
memory. There's probably no good data in there _anyway_.
This passes the original reproducer from Richard Biener as
well as the existing mpx selftests/.
The long story:
munmap() has a couple of pieces:
1. Find the affected VMA(s)
2. Split the start/end one(s) if neceesary
3. Pull the VMAs out of the rbtree
4. Actually zap the memory via unmap_region(), including
freeing page tables (or queueing them to be freed).
5. Fix up some of the accounting (like fput()) and actually
free the VMA itself.
This specific ordering was actually introduced by:
dd2283f2605e ("mm: mmap: zap pages with read mmap_sem in munmap")
during the 4.20 merge window. The previous __do_munmap() code
was actually safe because the only thing after arch_unmap() was
remove_vma_list(). arch_unmap() could not see 'vma' in the
rbtree because it was detached, so it is not even capable of
doing operations unsafe for remove_vma_list()'s use of 'vma'.
Richard Biener reported a test that shows this in dmesg:
[1216548.787498] BUG: Bad rss-counter state mm:0000000017ce560b idx:1 val:551
[1216548.787500] BUG: non-zero pgtables_bytes on freeing mm: 24576
What triggered this was the recursive do_munmap() called via
arch_unmap(). It was freeing page tables that has not been
properly zapped.
But, the problem was bigger than this. For one, arch_unmap()
can free VMAs. But, the calling __do_munmap() has variables
that *point* to VMAs and obviously can't handle them just
getting freed while the pointer is still in use.
I tried a couple of things here. First, I tried to fix the page
table freeing problem in isolation, but I then found the VMA
issue. I also tried having the MPX code return a flag if it
modified the rbtree which would force __do_munmap() to re-walk
to restart. That spiralled out of control in complexity pretty
fast.
Just moving arch_unmap() and accepting that the bonkers failure
case might eat some bounds tables seems like the simplest viable
fix.
This was also reported in the following kernel bugzilla entry:
https://bugzilla.kernel.org/show_bug.cgi?id=203123
There are some reports that this commit triggered this bug:
dd2283f2605 ("mm: mmap: zap pages with read mmap_sem in munmap")
While that commit certainly made the issues easier to hit, I believe
the fundamental issue has been with us as long as MPX itself, thus
the Fixes: tag below is for one of the original MPX commits.
[ mingo: Minor edits to the changelog and the patch. ]
Reported-by: Richard Biener <rguenther@suse.de>
Reported-by: H.J. Lu <hjl.tools@gmail.com>
Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com>
Reviewed-by Thomas Gleixner <tglx@linutronix.de>
Reviewed-by: Yang Shi <yang.shi@linux.alibaba.com>
Acked-by: Michael Ellerman <mpe@ellerman.id.au>
Cc: Anton Ivanov <anton.ivanov@cambridgegreys.com>
Cc: Guan Xuetao <gxt@pku.edu.cn>
Cc: Jeff Dike <jdike@addtoit.com>
Cc: Michal Hocko <mhocko@suse.com>
Cc: Richard Weinberger <richard@nod.at>
Cc: Rik van Riel <riel@surriel.com>
Cc: linux-mm@kvack.org
Cc: linux-um@lists.infradead.org
Cc: linuxppc-dev@lists.ozlabs.org
Cc: stable@vger.kernel.org
Fixes: dd2283f2605e ("mm: mmap: zap pages with read mmap_sem in munmap")
Link: http://lkml.kernel.org/r/20190419194747.5E1AD6DC@viggo.jf.intel.com
git://git.kernel.org/pub/scm/linux/kernel/git/masahiroy/linux-kbuild
Pull Kbuild updates from Masahiro Yamada:
- allow users to invoke 'make' out of the source tree
- refactor scripts/mkmakefile
- deprecate KBUILD_SRC, which was used to track the source tree
location for O= build.
- fix recordmcount.pl in case objdump output is localized
- turn unresolved symbols in external modules to errors from warnings
by default; pass KBUILD_MODPOST_WARN=1 to get them back to warnings
- generate modules.builtin.modinfo to collect .modinfo data from
built-in modules
- misc Makefile cleanups
* tag 'kbuild-v5.2' of git://git.kernel.org/pub/scm/linux/kernel/git/masahiroy/linux-kbuild: (21 commits)
.gitignore: add more all*.config patterns
moduleparam: Save information about built-in modules in separate file
Remove MODULE_ALIAS() calls that take undefined macro
.gitignore: add leading and trailing slashes to generated directories
scripts/tags.sh: fix direct execution of scripts/tags.sh
scripts: override locale from environment when running recordmcount.pl
samples: kobject: allow CONFIG_SAMPLE_KOBJECT to become y
samples: seccomp: turn CONFIG_SAMPLE_SECCOMP into a bool option
kbuild: move Documentation to vmlinux-alldirs
kbuild: move samples/ to KBUILD_VMLINUX_OBJS
modpost: make KBUILD_MODPOST_WARN also configurable for external modules
kbuild: check arch/$(SRCARCH)/include/generated before out-of-tree build
kbuild: remove unneeded dependency for include/config/kernel.release
memory: squash drivers/memory/Makefile.asm-offsets
kbuild: use $(srctree) instead of KBUILD_SRC to check out-of-tree build
kbuild: mkmakefile: generate a simple wrapper of top Makefile
kbuild: mkmakefile: do not check the generated Makefile marker
kbuild: allow Kbuild to start from any directory
kbuild: pass $(MAKECMDGOALS) to sub-make as is
kbuild: fix warning "overriding recipe for target 'Makefile'"
git://git.kernel.org/pub/scm/linux/kernel/git/pcmoore/audit
Pull audit updates from Paul Moore:
"We've got a reasonably broad set of audit patches for the v5.2 merge
window, the highlights are below:
- The biggest change, and the source of all the arch/* changes, is
the patchset from Dmitry to help enable some of the work he is
doing around PTRACE_GET_SYSCALL_INFO.
To be honest, including this in the audit tree is a bit of a
stretch, but it does help move audit a little further along towards
proper syscall auditing for all arches, and everyone else seemed to
agree that audit was a "good" spot for this to land (or maybe they
just didn't want to merge it? dunno.).
- We can now audit time/NTP adjustments.
- We continue the work to connect associated audit records into a
single event"
* tag 'audit-pr-20190507' of git://git.kernel.org/pub/scm/linux/kernel/git/pcmoore/audit: (21 commits)
audit: fix a memory leak bug
ntp: Audit NTP parameters adjustment
timekeeping: Audit clock adjustments
audit: purge unnecessary list_empty calls
audit: link integrity evm_write_xattrs record to syscall event
syscall_get_arch: add "struct task_struct *" argument
unicore32: define syscall_get_arch()
Move EM_UNICORE to uapi/linux/elf-em.h
nios2: define syscall_get_arch()
nds32: define syscall_get_arch()
Move EM_NDS32 to uapi/linux/elf-em.h
m68k: define syscall_get_arch()
hexagon: define syscall_get_arch()
Move EM_HEXAGON to uapi/linux/elf-em.h
h8300: define syscall_get_arch()
c6x: define syscall_get_arch()
arc: define syscall_get_arch()
Move EM_ARCOMPACT and EM_ARCV2 to uapi/linux/elf-em.h
audit: Make audit_log_cap and audit_copy_inode static
audit: connect LOGIN record to its syscall record
Problem:
When a kernel module is compiled as a separate module, some important
information about the kernel module is available via .modinfo section of
the module. In contrast, when the kernel module is compiled into the
kernel, that information is not available.
Information about built-in modules is necessary in the following cases:
1. When it is necessary to find out what additional parameters can be
passed to the kernel at boot time.
2. When you need to know which module names and their aliases are in
the kernel. This is very useful for creating an initrd image.
Proposal:
The proposed patch does not remove .modinfo section with module
information from the vmlinux at the build time and saves it into a
separate file after kernel linking. So, the kernel does not increase in
size and no additional information remains in it. Information is stored
in the same format as in the separate modules (null-terminated string
array). Because the .modinfo section is already exported with a separate
modules, we are not creating a new API.
It can be easily read in the userspace:
$ tr '\0' '\n' < modules.builtin.modinfo
ext4.softdep=pre: crc32c
ext4.license=GPL
ext4.description=Fourth Extended Filesystem
ext4.author=Remy Card, Stephen Tweedie, Andrew Morton, Andreas Dilger, Theodore Ts'o and others
ext4.alias=fs-ext4
ext4.alias=ext3
ext4.alias=fs-ext3
ext4.alias=ext2
ext4.alias=fs-ext2
md_mod.alias=block-major-9-*
md_mod.alias=md
md_mod.description=MD RAID framework
md_mod.license=GPL
md_mod.parmtype=create_on_open:bool
md_mod.parmtype=start_dirty_degraded:int
Co-Developed-by: Gleb Fotengauer-Malinovskiy <glebfm@altlinux.org>
Signed-off-by: Gleb Fotengauer-Malinovskiy <glebfm@altlinux.org>
Signed-off-by: Alexey Gladkov <gladkov.alexey@gmail.com>
Acked-by: Jessica Yu <jeyu@kernel.org>
git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux
Pull arm64 updates from Will Deacon:
"Mostly just incremental improvements here:
- Introduce AT_HWCAP2 for advertising CPU features to userspace
- Expose SVE2 availability to userspace
- Support for "data cache clean to point of deep persistence" (DC PODP)
- Honour "mitigations=off" on the cmdline and advertise status via
sysfs
- CPU timer erratum workaround (Neoverse-N1 #1188873)
- Introduce perf PMU driver for the SMMUv3 performance counters
- Add config option to disable the kuser helpers page for AArch32 tasks
- Futex modifications to ensure liveness under contention
- Rework debug exception handling to seperate kernel and user
handlers
- Non-critical fixes and cleanup"
* tag 'arm64-upstream' of git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux: (92 commits)
Documentation: Add ARM64 to kernel-parameters.rst
arm64/speculation: Support 'mitigations=' cmdline option
arm64: ssbs: Don't treat CPUs with SSBS as unaffected by SSB
arm64: enable generic CPU vulnerabilites support
arm64: add sysfs vulnerability show for speculative store bypass
arm64: Fix size of __early_cpu_boot_status
clocksource/arm_arch_timer: Use arch_timer_read_counter to access stable counters
clocksource/arm_arch_timer: Remove use of workaround static key
clocksource/arm_arch_timer: Drop use of static key in arch_timer_reg_read_stable
clocksource/arm_arch_timer: Direcly assign set_next_event workaround
arm64: Use arch_timer_read_counter instead of arch_counter_get_cntvct
watchdog/sbsa: Use arch_timer_read_counter instead of arch_counter_get_cntvct
ARM: vdso: Remove dependency with the arch_timer driver internals
arm64: Apply ARM64_ERRATUM_1188873 to Neoverse-N1
arm64: Add part number for Neoverse N1
arm64: Make ARM64_ERRATUM_1188873 depend on COMPAT
arm64: Restrict ARM64_ERRATUM_1188873 mitigation to AArch32
arm64: mm: Remove pte_unmap_nested()
arm64: Fix compiler warning from pte_unmap() with -Wunused-but-set-variable
arm64: compat: Reduce address limit for 64K pages
Pull mmiowb removal from Will Deacon:
"Remove Mysterious Macro Intended to Obscure Weird Behaviours (mmiowb())
Remove mmiowb() from the kernel memory barrier API and instead, for
architectures that need it, hide the barrier inside spin_unlock() when
MMIO has been performed inside the critical section.
The only relatively recent changes have been addressing review
comments on the documentation, which is in a much better shape thanks
to the efforts of Ben and Ingo.
I was initially planning to split this into two pull requests so that
you could run the coccinelle script yourself, however it's been plain
sailing in linux-next so I've just included the whole lot here to keep
things simple"
* tag 'arm64-mmiowb' of git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux: (23 commits)
docs/memory-barriers.txt: Update I/O section to be clearer about CPU vs thread
docs/memory-barriers.txt: Fix style, spacing and grammar in I/O section
arch: Remove dummy mmiowb() definitions from arch code
net/ethernet/silan/sc92031: Remove stale comment about mmiowb()
i40iw: Redefine i40iw_mmiowb() to do nothing
scsi/qla1280: Remove stale comment about mmiowb()
drivers: Remove explicit invocations of mmiowb()
drivers: Remove useless trailing comments from mmiowb() invocations
Documentation: Kill all references to mmiowb()
riscv/mmiowb: Hook up mmwiob() implementation to asm-generic code
powerpc/mmiowb: Hook up mmwiob() implementation to asm-generic code
ia64/mmiowb: Add unconditional mmiowb() to arch_spin_unlock()
mips/mmiowb: Add unconditional mmiowb() to arch_spin_unlock()
sh/mmiowb: Add unconditional mmiowb() to arch_spin_unlock()
m68k/io: Remove useless definition of mmiowb()
nds32/io: Remove useless definition of mmiowb()
x86/io: Remove useless definition of mmiowb()
arm64/io: Remove useless definition of mmiowb()
ARM/io: Remove useless definition of mmiowb()
mmiowb: Hook up mmiowb helpers to spinlocks and generic I/O accessors
git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux
Pull s390 updates from Martin Schwidefsky:
- Support for kernel address space layout randomization
- Add support for kernel image signature verification
- Convert s390 to the generic get_user_pages_fast code
- Convert s390 to the stack unwind API analog to x86
- Add support for CPU directed interrupts for PCI devices
- Provide support for MIO instructions to the PCI base layer, this will
allow the use of direct PCI mappings in user space code
- Add the basic KVM guest ultravisor interface for protected VMs
- Add AT_HWCAP bits for several new hardware capabilities
- Update the CPU measurement facility counter definitions to SVN 6
- Arnds cleanup patches for his quest to get LLVM compiles working
- A vfio-ccw update with bug fixes and support for halt and clear
- Improvements for the hardware TRNG code
- Another round of cleanup for the QDIO layer
- Numerous cleanups and bug fixes
* tag 's390-5.2-1' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux: (98 commits)
s390/vdso: drop unnecessary cc-ldoption
s390: fix clang -Wpointer-sign warnigns in boot code
s390: drop CONFIG_VIRT_TO_BUS
s390: boot, purgatory: pass $(CLANG_FLAGS) where needed
s390: only build for new CPUs with clang
s390: simplify disabled_wait
s390/ftrace: use HAVE_FUNCTION_GRAPH_RET_ADDR_PTR
s390/unwind: introduce stack unwind API
s390/opcodes: add missing instructions to the disassembler
s390/bug: add entry size to the __bug_table section
s390: use proper expoline sections for .dma code
s390/nospec: rename assembler generated expoline thunks
s390: add missing ENDPROC statements to assembler functions
locking/lockdep: check for freed initmem in static_obj()
s390/kernel: add support for kernel address space layout randomization (KASLR)
s390/kernel: introduce .dma sections
s390/sclp: do not use static sccbs
s390/kprobes: use static buffer for insn_page
s390/kernel: convert SYSCALL and PGM_CHECK handlers to .quad
s390/kernel: build a relocatable kernel
Pull x86 mm updates from Ingo Molnar:
"The changes in here are:
- text_poke() fixes and an extensive set of executability lockdowns,
to (hopefully) eliminate the last residual circumstances under
which we are using W|X mappings even temporarily on x86 kernels.
This required a broad range of surgery in text patching facilities,
module loading, trampoline handling and other bits.
- tweak page fault messages to be more informative and more
structured.
- remove DISCONTIGMEM support on x86-32 and make SPARSEMEM the
default.
- reduce KASLR granularity on 5-level paging kernels from 512 GB to
1 GB.
- misc other changes and updates"
* 'x86-mm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (36 commits)
x86/mm: Initialize PGD cache during mm initialization
x86/alternatives: Add comment about module removal races
x86/kprobes: Use vmalloc special flag
x86/ftrace: Use vmalloc special flag
bpf: Use vmalloc special flag
modules: Use vmalloc special flag
mm/vmalloc: Add flag for freeing of special permsissions
mm/hibernation: Make hibernation handle unmapped pages
x86/mm/cpa: Add set_direct_map_*() functions
x86/alternatives: Remove the return value of text_poke_*()
x86/jump-label: Remove support for custom text poker
x86/modules: Avoid breaking W^X while loading modules
x86/kprobes: Set instruction page as executable
x86/ftrace: Set trampoline pages as executable
x86/kgdb: Avoid redundant comparison of patched code
x86/alternatives: Use temporary mm for text poking
x86/alternatives: Initialize temporary mm for patching
fork: Provide a function for copying init_mm
uprobes: Initialize uprobes earlier
x86/mm: Save debug registers when loading a temporary mm
Pull locking updates from Ingo Molnar:
"Here are the locking changes in this cycle:
- rwsem unification and simpler micro-optimizations to prepare for
more intrusive (and more lucrative) scalability improvements in
v5.3 (Waiman Long)
- Lockdep irq state tracking flag usage cleanups (Frederic
Weisbecker)
- static key improvements (Jakub Kicinski, Peter Zijlstra)
- misc updates, cleanups and smaller fixes"
* 'locking-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (26 commits)
locking/lockdep: Remove unnecessary unlikely()
locking/static_key: Don't take sleeping locks in __static_key_slow_dec_deferred()
locking/static_key: Factor out the fast path of static_key_slow_dec()
locking/static_key: Add support for deferred static branches
locking/lockdep: Test all incompatible scenarios at once in check_irq_usage()
locking/lockdep: Avoid bogus Clang warning
locking/lockdep: Generate LOCKF_ bit composites
locking/lockdep: Use expanded masks on find_usage_*() functions
locking/lockdep: Map remaining magic numbers to lock usage mask names
locking/lockdep: Move valid_state() inside CONFIG_TRACE_IRQFLAGS && CONFIG_PROVE_LOCKING
locking/rwsem: Prevent unneeded warning during locking selftest
locking/rwsem: Optimize rwsem structure for uncontended lock acquisition
locking/rwsem: Enable lock event counting
locking/lock_events: Don't show pvqspinlock events on bare metal
locking/lock_events: Make lock_events available for all archs & other locks
locking/qspinlock_stat: Introduce generic lockevent_*() counting APIs
locking/rwsem: Enhance DEBUG_RWSEMS_WARN_ON() macro
locking/rwsem: Add debug check for __down_read*()
locking/rwsem: Micro-optimize rwsem_try_read_lock_unqueued()
locking/rwsem: Move rwsem internal function declarations to rwsem-xadd.h
Pull unified TLB flushing from Ingo Molnar:
"This contains the generic mmu_gather feature from Peter Zijlstra,
which is an all-arch unification of TLB flushing APIs, via the
following (broad) steps:
- enhance the <asm-generic/tlb.h> APIs to cover more arch details
- convert most TLB flushing arch implementations to the generic
<asm-generic/tlb.h> APIs.
- remove leftovers of per arch implementations
After this series every single architecture makes use of the unified
TLB flushing APIs"
* 'core-mm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
mm/resource: Use resource_overlaps() to simplify region_intersects()
ia64/tlb: Eradicate tlb_migrate_finish() callback
asm-generic/tlb: Remove tlb_table_flush()
asm-generic/tlb: Remove tlb_flush_mmu_free()
asm-generic/tlb: Remove CONFIG_HAVE_GENERIC_MMU_GATHER
asm-generic/tlb: Remove arch_tlb*_mmu()
s390/tlb: Convert to generic mmu_gather
asm-generic/tlb: Introduce CONFIG_HAVE_MMU_GATHER_NO_GATHER=y
arch/tlb: Clean up simple architectures
um/tlb: Convert to generic mmu_gather
sh/tlb: Convert SH to generic mmu_gather
ia64/tlb: Convert to generic mmu_gather
arm/tlb: Convert to generic mmu_gather
asm-generic/tlb, arch: Invert CONFIG_HAVE_RCU_TABLE_INVALIDATE
asm-generic/tlb, ia64: Conditionally provide tlb_migrate_finish()
asm-generic/tlb: Provide generic tlb_flush() based on flush_tlb_mm()
asm-generic/tlb, arch: Provide generic tlb_flush() based on flush_tlb_range()
asm-generic/tlb, arch: Provide generic VIPT cache flush
asm-generic/tlb, arch: Provide CONFIG_HAVE_MMU_GATHER_PAGE_SIZE
asm-generic/tlb: Provide a comment
Poking-mm initialization might require to duplicate the PGD in early
stage. Initialize the PGD cache earlier to prevent boot failures.
Reported-by: kernel test robot <lkp@intel.com>
Signed-off-by: Nadav Amit <namit@vmware.com>
Cc: Rick Edgecombe <rick.p.edgecombe@intel.com>
Fixes: 4fc19708b165 ("x86/alternatives: Initialize temporary mm for patching")
Link: http://lkml.kernel.org/r/20190505011124.39692-1-namit@vmware.com
x86 has an nmi_uaccess_okay(), but other architectures do not.
Arch-independent code might need to know whether access to user
addresses is ok in an NMI context or in other code whose execution
context is unknown. Specifically, this function is needed for
bpf_probe_write_user().
Add a default implementation of nmi_uaccess_okay() for architectures
that do not have such a function.
Signed-off-by: Rick Edgecombe <rick.p.edgecombe@intel.com>
Cc: <akpm@linux-foundation.org>
Cc: <ard.biesheuvel@linaro.org>
Cc: <deneen.t.dock@intel.com>
Cc: <kernel-hardening@lists.openwall.com>
Cc: <kristen@linux.intel.com>
Cc: <linux_dti@icloud.com>
Cc: <will.deacon@arm.com>
Link: https://lkml.kernel.org/r/20190426001143.4983-23-namit@vmware.com
The following warning occurred on s390:
WARNING: CPU: 0 PID: 804 at kernel/locking/lockdep.c:1025 lockdep_register_key+0x30/0x150
This is because the check in static_obj() assumes that all memory within
[_stext, _end] belongs to static objects, which at least for s390 isn't
true. The init section is also part of this range, and freeing it allows
the buddy allocator to allocate memory from it. We have virt == phys for
the kernel on s390, so that such allocations would then have addresses
within the range [_stext, _end].
To fix this, introduce arch_is_kernel_initmem_freed(), similar to
arch_is_kernel_text/data(), and add it to the checks in static_obj().
This will always return 0 on architectures that do not define
arch_is_kernel_initmem_freed. On s390, it will return 1 if initmem has
been freed and the address is in the range [__init_begin, __init_end].
Signed-off-by: Gerald Schaefer <gerald.schaefer@de.ibm.com>
Reviewed-by: Heiko Carstens <heiko.carstens@de.ibm.com>
The architecture implementations of 'arch_futex_atomic_op_inuser()' and
'futex_atomic_cmpxchg_inatomic()' are permitted to return only -EFAULT,
-EAGAIN or -ENOSYS in the case of failure.
Update the comments in the asm-generic/ implementation and also a stray
reference in the robust futex documentation.
On 64-bit architectures we can also use the direct load/store trick for
8-byte values.
Move the code to implement uaccess using memcpy or direct loads and
stores to asm-generic/uaccess.h and make it selectable kconfig option.
A few architectures use <asm/segment.h> internally, but nothing in
common code does. Remove all the empty or almost empty versions of it,
including the asm-generic one.
<asm/segment.h> is an odd x86 legacy that we shouldn't force on other
architectures. arc used it to bring in mm_context_t, but we can do
that inside the arc code easily.
Now that no driver code is using mmiowb() directly, remove the dummy
definitions remaining in architectures that don't make use of
asm-generic/io.h, as well as the definition in asm-generic/io.h itself.
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
Removing explicit calls to mmiowb() from driver code means that we must
now call into the generic mmiowb_spin_{lock,unlock}() functions from the
core spinlock code. In order to elide barriers following critical
sections without any I/O writes, we also hook into the asm-generic I/O
routines.
In preparation for removing all explicit mmiowb() calls from driver
code, implement a tracking system in asm-generic based loosely on the
PowerPC implementation. This allows architectures with a non-empty
mmiowb() definition to have the barrier automatically inserted in
spin_unlock() following a critical section containing an I/O write.
After removing the start and count arguments of syscall_get_arguments() it
seems reasonable to remove them from syscall_set_arguments(). Note, as of
today, there are no users of syscall_set_arguments(). But we are told that
there will be soon. But for now, at least make it consistent with
syscall_get_arguments().
Link: http://lkml.kernel.org/r/20190327222014.GA32540@altlinux.org
Cc: Dominik Brodowski <linux@dominikbrodowski.net>
Cc: Dave Martin <dave.martin@arm.com>
Cc: "Dmitry V. Levin" <ldv@altlinux.org>
Cc: x86@kernel.org
Cc: linux-snps-arc@lists.infradead.org
Cc: linux-c6x-dev@linux-c6x.org
Cc: uclinux-h8-devel@lists.sourceforge.jp
Cc: linux-hexagon@vger.kernel.org
Cc: linux-ia64@vger.kernel.org
Cc: linux-mips@vger.kernel.org
Cc: nios2-dev@lists.rocketboards.org
Cc: openrisc@lists.librecores.org
Cc: linux-parisc@vger.kernel.org
Cc: linux-riscv@lists.infradead.org
Cc: linux-s390@vger.kernel.org
Cc: linux-sh@vger.kernel.org
Cc: sparclinux@vger.kernel.org
Cc: linux-xtensa@linux-xtensa.org
Acked-by: Max Filippov <jcmvbkbc@gmail.com> # For xtensa changes
Acked-by: Will Deacon <will.deacon@arm.com> # For the arm64 bits
Reviewed-by: Thomas Gleixner <tglx@linutronix.de> # for x86
Reviewed-by: Dmitry V. Levin <ldv@altlinux.org>
Signed-off-by: Steven Rostedt (VMware) <rostedt@goodmis.org>
At Linux Plumbers, Andy Lutomirski approached me and pointed out that the
function call syscall_get_arguments() implemented in x86 was horribly
written and not optimized for the standard case of passing in 0 and 6 for
the starting index and the number of system calls to get. When looking at
all the users of this function, I discovered that all instances pass in only
0 and 6 for these arguments. Instead of having this function handle
different cases that are never used, simply rewrite it to return the first 6
arguments of a system call.
This should help out the performance of tracing system calls by ptrace,
ftrace and perf.
Link: http://lkml.kernel.org/r/20161107213233.754809394@goodmis.org
Cc: x86@kernel.org
Acked-by: Paul Burton <paul.burton@mips.com> # MIPS parts
Reported-by: Andy Lutomirski <luto@amacapital.net>
As the generic rwsem-xadd code is using the appropriate acquire and
release versions of the atomic operations, the arch specific rwsem.h
files will not be that much faster than the generic code as long as the
atomic functions are properly implemented. So we can remove those arch
specific rwsem.h and stop building asm/rwsem.h to reduce maintenance
effort.
Currently, only x86, alpha and ia64 have implemented architecture
specific fast paths. I don't have access to alpha and ia64 systems for
testing, but they are legacy systems that are not likely to be updated
to the latest kernel anyway.
By using a rwsem microbenchmark, the total locking rates on a 4-socket
56-core 112-thread x86-64 system before and after the patch were as
follows (mixed means equal # of read and write locks):
Before Patch After Patch
# of Threads wlock rlock mixed wlock rlock mixed
1 29,201 30,143 29,458 28,615 30,172 29,201
2 6,807 13,299 1,171 7,725 15,025 1,804
4 6,504 12,755 1,520 7,127 14,286 1,345
8 6,762 13,412 764 6,826 13,652 726
16 6,693 15,408 662 6,599 15,938 626
32 6,145 15,286 496 5,549 15,487 511
64 5,812 15,495 60 5,858 15,572 60
There were some run-to-run variations for the multi-thread tests. For
x86-64, using the generic C code fast path seems to be a little bit
faster than the assembly version with low lock contention. Looking at
the assembly version of the fast paths, there are assembly to/from C
code wrappers that save and restore all the callee-clobbered registers
(7 registers on x86-64). The assembly generated from the generic C
code doesn't need to do that. That may explain the slight performance
gain here.
The generic asm rwsem.h can also be merged into kernel/locking/rwsem.h
with no code change as no other code other than those under
kernel/locking needs to access the internal rwsem macros and functions.
Signed-off-by: Waiman Long <longman@redhat.com>
Cc: Davidlohr Bueso <dave@stgolabs.net>
Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Cc: Tim Chen <tim.c.chen@linux.intel.com>
Cc: linux-m68k@lists.linux-m68k.org
Link: https://lkml.kernel.org/r/20190322143008.21313-2-longman@redhat.com
Only ia64-sn2 uses this as an optimization, and there it is of
questionable correctness due to the mm_users==1 test.
Remove it entirely.
No change in behavior intended.
There are no external users of this API (nor should there be); remove it.
As the comment notes; it is a potentially dangerous operation. Just
use tlb_flush_mmu(), that will skip the (double) TLB invalidate if
it really isn't needed anyway.
Since all architectures are now using it, it is redundant.
Add the Kconfig option HAVE_MMU_GATHER_NO_GATHER to the generic
mmu_gather code. If the option is set the mmu_gather will not
track individual pages for delayed page free anymore. A platform
that enables the option needs to provide its own implementation
of the __tlb_remove_page_size() function to free pages.
Cc: aneesh.kumar@linux.vnet.ibm.com
Cc: heiko.carstens@de.ibm.com
Cc: linux@armlinux.org.uk
Cc: npiggin@gmail.com
Link: http://lkml.kernel.org/r/20180918125151.31744-2-schwidefsky@de.ibm.com
Make issuing a TLB invalidate for page-table pages the normal case.
The reason is twofold:
- too many invalidates is safer than too few,
- most architectures use the linux page-tables natively
and would thus require this.
Make it an opt-out, instead of an opt-in.
Needed for ia64 -- alternatively we drop the entire hook.
Cc: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
Cc: Nick Piggin <npiggin@gmail.com>
When an architecture does not have (an efficient) flush_tlb_range(),
but instead always uses full TLB invalidates, the current generic
tlb_flush() is sub-optimal, for it will generate extra flushes in
order to keep the range small.
But if we cannot do range flushes, that is a moot concern. Optionally
provide this simplified default.
Provide a generic tlb_flush() implementation that relies on
flush_tlb_range(). This is a little awkward because flush_tlb_range()
assumes a VMA for range invalidation, but we no longer have one.
Audit of all flush_tlb_range() implementations shows only vma->vm_mm
and vma->vm_flags are used, and of the latter only VM_EXEC (I-TLB
invalidates) and VM_HUGETLB (large TLB invalidate) are used.
Therefore, track VM_EXEC and VM_HUGETLB in two more bits, and create a
'fake' VMA.
This allows architectures that have a reasonably efficient
flush_tlb_range() to not require any additional effort.
