path: root/include/asm-h8300/irq.h
2008-02-23h8300: IRQ handling updateYoshinori Sato
- add missing file and declare. - remove unused file and macros. - some cleanup. Signed-off-by: Yoshinori Sato <ysato@users.sourceforge.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-22take declarations of enable_irq() et.al. to linux/interrupt.hAl Viro
Now that the last inlined instances are gone, all that is left to do is turning disable_irq_nosync on arm26 and m68k from defines to aliases and we are all set - we can make these externs in linux/interrupt.h uncoditional and kill remaining instances in asm/irq.h Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07h8300 generic irqYoshinori Sato
h8300 using generic irq handler patch. Signed-off-by: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-06-23[PATCH] adjust handle_IRR_event() return typeJan Beulich
Correct the return type of handle_IRQ_event() (inconsistency noticed during Xen development), and remove redundant declarations. The return type adjustment required breaking out the definition of irqreturn_t into a separate header, in order to satisfy current include order dependencies. Signed-off-by: Jan Beulich <jbeulich@novell.com> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Ian Molton <spyro@f2s.com> Cc: Mikael Starvik <starvik@axis.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Hirokazu Takata <takata.hirokazu@renesas.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: William Lee Irwin III <wli@holomorphy.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Miles Bader <uclinux-v850@lsi.nec.co.jp> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] m68knommu: remove enable_irq_nosync()Christoph Hellwig
m68k, m68knommu and h8300 define this, but it's not actually used anywhere. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
