path: root/include/asm-h8300/signal.h
2005-05-04[PATCH] asm/signal.h unificationAl Viro
New file - asm-generic/signal.h. Contains declarations of __sighandler_t, __sigrestore_t, SIG_DFL, SIG_IGN, SIG_ERR and default definitions of SIG_BLOCK, SIG_UNBLOCK and SIG_SETMASK. asm-*/signal.h switched to including it. The only exception is asm-parisc/signal.h that wants its own declaration of __sighandler_t; that one is left as-is. asm-ppc64/signal.h required one more thing - unlike everybody else it used __sigrestorer_t instead of usual __sigrestore_t. PPC64 switched to common spelling. Signed-off-by: Al Viro <viro@parcelfarce.linux.theplanet.co.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-01[PATCH] move SA_xxx defines to linux/signal.hStas Sergeev
The attached patch moves the IRQ-related SA_xxx flags (namely, SA_PROBE, SA_SAMPLE_RANDOM and SA_SHIRQ) from all the arch-specific headers to linux/signal.h. This looks like a left-over after the irq-handling code was consolidated. The code was moved to kernel/irq/*, but the flags are still left per-arch. Right now, adding a new IRQ flag to the arch-specific header, like this patch does: http://cvs.sourceforge.net/viewcvs.py/*checkout*/alsa/alsa-driver/utils/patches/pcsp-kernel-2.6.10-03.diff?rev=1.1 no longer works, it breaks the compilation for all other arches, unless you add that flag to all the other arch-specific headers too. So I think such a clean-up makes sense. Signed-off-by: Stas Sergeev <stsp@aknet.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
