path: root/include/asm-i386/thread_info.h
2006-07-09[PATCH] i386: use thread_info flags for debug regs and IO bitmapsStephane Eranian
Use thread info flags to track use of debug registers and IO bitmaps. - add TIF_DEBUG to track when debug registers are active - add TIF_IO_BITMAP to track when I/O bitmap is used - modify __switch_to() to use the new TIF flags Performance tested on Pentium II, ten runs of LMbench context switch benchmark (smaller is better:) before after avg 3.65 3.39 min 3.55 3.33 Signed-off-by: Stephane Eranian <eranian@hpl.hp.com> Signed-off-by: Chuck Ebbert <76306.1226@compuserve.com> Acked-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-27[PATCH] vdso: randomize the i386 vDSO by moving it into a vmaIngo Molnar
Move the i386 VDSO down into a vma and thus randomize it. Besides the security implications, this feature also helps debuggers, which can COW a vma-backed VDSO just like a normal DSO and can thus do single-stepping and other debugging features. It's good for hypervisors (Xen, VMWare) too, which typically live in the same high-mapped address space as the VDSO, hence whenever the VDSO is used, they get lots of guest pagefaults and have to fix such guest accesses up - which slows things down instead of speeding things up (the primary purpose of the VDSO). There's a new CONFIG_COMPAT_VDSO (default=y) option, which provides support for older glibcs that still rely on a prelinked high-mapped VDSO. Newer distributions (using glibc 2.3.3 or later) can turn this option off. Turning it off is also recommended for security reasons: attackers cannot use the predictable high-mapped VDSO page as syscall trampoline anymore. There is a new vdso=[0|1] boot option as well, and a runtime /proc/sys/vm/vdso_enabled sysctl switch, that allows the VDSO to be turned on/off. (This version of the VDSO-randomization patch also has working ELF coredumping, the previous patch crashed in the coredumping code.) This code is a combined work of the exec-shield VDSO randomization code and Gerd Hoffmann's hypervisor-centric VDSO patch. Rusty Russell started this patch and i completed it. [akpm@osdl.org: cleanups] [akpm@osdl.org: compile fix] [akpm@osdl.org: compile fix 2] [akpm@osdl.org: compile fix 3] [akpm@osdl.org: revernt MAXMEM change] Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arjan van de Ven <arjan@infradead.org> Cc: Gerd Hoffmann <kraxel@suse.de> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Zachary Amsden <zach@vmware.com> Cc: Andi Kleen <ak@muc.de> Cc: Jan Beulich <jbeulich@novell.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-27[PATCH] i386: use C code for current_thread_info()Chuck Ebbert
Using C code for current_thread_info() lets the compiler optimize it. With gcc 4.0.2, kernel is smaller: text data bss dec hex filename 3645212 555556 312024 4512792 44dc18 2.6.17-rc6-nb-post/vmlinux 3647276 555556 312024 4514856 44e428 2.6.17-rc6-nb/vmlinux ------- -2064 Signed-off-by: Chuck Ebbert <76306.1226@compuserve.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] i386/x86-64/ia64: Move polling flag into thread_info_statusAndi Kleen
During some profiling I noticed that default_idle causes a lot of memory traffic. I think that is caused by the atomic operations to clear/set the polling flag in thread_info. There is actually no reason to make this atomic - only the idle thread does it to itself, other CPUs only read it. So I moved it into ti->status. Converted i386/x86-64/ia64 for now because that was the easiest way to fix ACPI which also manipulates these flags in its idle function. Cc: Nick Piggin <npiggin@novell.com> Cc: Tony Luck <tony.luck@intel.com> Cc: Len Brown <len.brown@intel.com> Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-26Don't include linux/config.h from anywhere else in include/David Woodhouse
2006-02-17[PATCH] i386: fix singlestepping though a syscallChuck Ebbert
Do not mask TIF_SINGLESTEP bit in _TIF_WORK_MASK. Masking this stopped do_notify_resume() from being called when it should have been. Signed-off-by: Chuck Ebbert <76306.1226@compuserve.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-18[PATCH] Handle TIF_RESTORE_SIGMASK for i386David Howells
Handle TIF_RESTORE_SIGMASK as added by David Woodhouse's patch entitled: [PATCH] 2/3 Add TIF_RESTORE_SIGMASK support for arch/powerpc [PATCH] 3/3 Generic sys_rt_sigsuspend It does the following: (1) Declares TIF_RESTORE_SIGMASK for i386. (2) Invokes it over to do_signal() when TIF_RESTORE_SIGMASK is set. (3) Makes do_signal() support TIF_RESTORE_SIGMASK, using the signal mask saved in current->saved_sigmask. (4) Discards sys_rt_sigsuspend() from the arch, using the generic one instead. (5) Makes sys_sigsuspend() save the signal mask and set TIF_RESTORE_SIGMASK rather than attempting to fudge the return registers. (6) Makes sys_sigsuspend() return -ERESTARTNOHAND rather than looping intrinsically. (7) Makes setup_frame(), setup_rt_frame() and handle_signal() return 0 or -EFAULT rather than true/false to be consistent with the rest of the kernel. Due to the fact do_signal() is then only called from one place: (8) Makes do_signal() no longer have a return value is it was just being ignored; force_sig() takes care of this. (9) Discards the old sigmask argument to do_signal() as it's no longer necessary. (10) Makes do_signal() static. (11) Marks the second argument to do_notify_resume() as unused. The unused argument should remain in the middle as the arguments are passed in as registers, and the ordering is specific in entry.S Given the way do_signal() is now no longer called from sys_{,rt_}sigsuspend(), they no longer need access to the exception frame, and so can just take arguments normally. This patch depends on sys_rt_sigsuspend patch. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-12[PATCH] death of get_thread_info/put_thread_infoAl Viro
{get,put}_thread_info() were introduced in 2.5.4 and never had been called by anything in the tree. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09kbuild: full dependency check on asm-offsets.hSam Ravnborg
Building asm-offsets.h has been moved to a seperate Kbuild file located in the top-level directory. This allow us to share the functionality across the architectures. The old rules in architecture specific Makefiles will die in subsequent patches. Furhtermore the usual kbuild dependency tracking is now used when deciding to rebuild asm-offsets.s. So we no longer risk to fail a rebuild caused by asm-offsets.c dependencies being touched. With this common rule-set we now force the same name across all architectures. Following patches will fix the rest. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2005-09-05[PATCH] UML Support - Ptrace: adds the host SYSEMU support, for UML and ↵Laurent Vivier
general usage Jeff Dike <jdike@addtoit.com>, Paolo 'Blaisorblade' Giarrusso <blaisorblade_spam@yahoo.it>, Bodo Stroesser <bstroesser@fujitsu-siemens.com> Adds a new ptrace(2) mode, called PTRACE_SYSEMU, resembling PTRACE_SYSCALL except that the kernel does not execute the requested syscall; this is useful to improve performance for virtual environments, like UML, which want to run the syscall on their own. In fact, using PTRACE_SYSCALL means stopping child execution twice, on entry and on exit, and each time you also have two context switches; with SYSEMU you avoid the 2nd stop and so save two context switches per syscall. Also, some architectures don't have support in the host for changing the syscall number via ptrace(), which is currently needed to skip syscall execution (UML turns any syscall into getpid() to avoid it being executed on the host). Fixing that is hard, while SYSEMU is easier to implement. * This version of the patch includes some suggestions of Jeff Dike to avoid adding any instructions to the syscall fast path, plus some other little changes, by myself, to make it work even when the syscall is executed with SYSENTER (but I'm unsure about them). It has been widely tested for quite a lot of time. * Various fixed were included to handle the various switches between various states, i.e. when for instance a syscall entry is traced with one of PT_SYSCALL / _SYSEMU / _SINGLESTEP and another one is used on exit. Basically, this is done by remembering which one of them was used even after the call to ptrace_notify(). * We're combining TIF_SYSCALL_EMU with TIF_SYSCALL_TRACE or TIF_SINGLESTEP to make do_syscall_trace() notice that the current syscall was started with SYSEMU on entry, so that no notification ought to be done in the exit path; this is a bit of a hack, so this problem is solved in another way in next patches. * Also, the effects of the patch: "Ptrace - i386: fix Syscall Audit interaction with singlestep" are cancelled; they are restored back in the last patch of this series. Detailed descriptions of the patches doing this kind of processing follow (but I've already summed everything up). * Fix behaviour when changing interception kind #1. In do_syscall_trace(), we check the status of the TIF_SYSCALL_EMU flag only after doing the debugger notification; but the debugger might have changed the status of this flag because he continued execution with PTRACE_SYSCALL, so this is wrong. This patch fixes it by saving the flag status before calling ptrace_notify(). * Fix behaviour when changing interception kind #2: avoid intercepting syscall on return when using SYSCALL again. A guest process switching from using PTRACE_SYSEMU to PTRACE_SYSCALL crashes. The problem is in arch/i386/kernel/entry.S. The current SYSEMU patch inhibits the syscall-handler to be called, but does not prevent do_syscall_trace() to be called after this for syscall completion interception. The appended patch fixes this. It reuses the flag TIF_SYSCALL_EMU to remember "we come from PTRACE_SYSEMU and now are in PTRACE_SYSCALL", since the flag is unused in the depicted situation. * Fix behaviour when changing interception kind #3: avoid intercepting syscall on return when using SINGLESTEP. When testing 2.6.9 and the skas3.v6 patch, with my latest patch and had problems with singlestepping on UML in SKAS with SYSEMU. It looped receiving SIGTRAPs without moving forward. EIP of the traced process was the same for all SIGTRAPs. What's missing is to handle switching from PTRACE_SYSCALL_EMU to PTRACE_SINGLESTEP in a way very similar to what is done for the change from PTRACE_SYSCALL_EMU to PTRACE_SYSCALL_TRACE. I.e., after calling ptrace(PTRACE_SYSEMU), on the return path, the debugger is notified and then wake ups the process; the syscall is executed (or skipped, when do_syscall_trace() returns 0, i.e. when using PTRACE_SYSEMU), and do_syscall_trace() is called again. Since we are on the return path of a SYSEMU'd syscall, if the wake up is performed through ptrace(PTRACE_SYSCALL), we must still avoid notifying the parent of the syscall exit. Now, this behaviour is extended even to resuming with PTRACE_SINGLESTEP. Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-23[PATCH] streamline preempt_count type across archsJesper Juhl
The preempt_count member of struct thread_info is currently either defined as int, unsigned int or __s32 depending on arch. This patch makes the type of preempt_count an int on all archs. Having preempt_count be an unsigned type prevents the catching of preempt_count < 0 bugs, and using int on some archs and __s32 on others is not exactely "neat" - much nicer when it's just int all over. A previous version of this patch was already ACK'ed by Robert Love, and the only change in this version of the patch compared to the one he ACK'ed is that this one also makes sure the preempt_count member is consistently commented. Signed-off-by: Jesper Juhl <juhl-lkml@dif.dk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
