path: root/include/asm-i386/uaccess.h
2006-10-11[PATCH] uaccess.h: match kernel-doc and function namesRandy Dunlap
Place kernel-doc function comment header immediately before the function that is being documented. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] Make copy_from_user_inatomic NOT zero the tail on i386NeilBrown
As described in a previous patch and documented in mm/filemap.h, copy_from_user_inatomic* shouldn't zero out the tail of the buffer after an incomplete copy. This patch implements that change for i386. For the _nocache version, a new __copy_user_intel_nocache is defined similar to copy_user_zeroio_intel_nocache, and this is ultimately used for the copy. For the regular version, __copy_from_user_ll_nozero is defined which uses __copy_user and __copy_user_intel - the later needs casts to reposition the __user annotations. If copy_from_user_atomic is given a constant length of 1, 2, or 4, then we do still zero the destintion on failure. This didn't seem worth the effort of fixing as the places where it is used really don't care. Signed-off-by: Neil Brown <neilb@suse.de> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: William Lee Irwin III <wli@holomorphy.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] Prepare for __copy_from_user_inatomic to not zero missed bytesNeilBrown
The problem is that when we write to a file, the copy from userspace to pagecache is first done with preemption disabled, so if the source address is not immediately available the copy fails *and* *zeros* *the* *destination*. This is a problem because a concurrent read (which admittedly is an odd thing to do) might see zeros rather that was there before the write, or what was there after, or some mixture of the two (any of these being a reasonable thing to see). If the copy did fail, it will immediately be retried with preemption re-enabled so any transient problem with accessing the source won't cause an error. The first copying does not need to zero any uncopied bytes, and doing so causes the problem. It uses copy_from_user_atomic rather than copy_from_user so the simple expedient is to change copy_from_user_atomic to *not* zero out bytes on failure. The first of these two patches prepares for the change by fixing two places which assume copy_from_user_atomic does zero the tail. The two usages are very similar pieces of code which copy from a userspace iovec into one or more page-cache pages. These are changed to remove the assumption. The second patch changes __copy_from_user_inatomic* to not zero the tail. Once these are accepted, I will look at similar patches of other architectures where this is important (ppc, mips and sparc being the ones I can find). This patch: There is a problem with __copy_from_user_inatomic zeroing the tail of the buffer in the case of an error. As it is called in atomic context, the error may be transient, so it results in zeros being written where maybe they shouldn't be. In the usage in filemap, this opens a window for a well timed read to see data (zeros) which is not consistent with any ordering of reads and writes. Most cases where __copy_from_user_inatomic is called, a failure results in __copy_from_user being called immediately. As long as the latter zeros the tail, the former doesn't need to. However in *copy_from_user_iovec implementations (in both filemap and ntfs/file), it is assumed that copy_from_user_inatomic will zero the tail. This patch removes that assumption, so that after this patch it will be safe for copy_from_user_inatomic to not zero the tail. This patch also adds some commentary to filemap.h and asm-i386/uaccess.h. After this patch, all architectures that might disable preempt when kmap_atomic is called need to have their __copy_from_user_inatomic* "fixed". This includes - powerpc - i386 - mips - sparc Signed-off-by: Neil Brown <neilb@suse.de> Cc: David Howells <dhowells@redhat.com> Cc: Anton Altaparmakov <aia21@cantab.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: William Lee Irwin III <wli@holomorphy.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] x86: fix __range_ok constraintRoman Zippel
An immediate operand can't be the destination of the cmpl instruction, so exclude it. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Cc: Mattia Dongili <malattia@linux.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] x86: cache pollution aware __copy_from_user_ll()Hiro Yoshioka
Use the x86 cache-bypassing copy instructions for copy_from_user(). Some performance data are Total of GLOBAL_POWER_EVENTS (CPU cycle samples) 2.6.12.4.orig 1921587 2.6.12.4.nt 1599424 1599424/1921587=83.23% (16.77% reduction) BSQ_CACHE_REFERENCE (L3 cache miss) 2.6.12.4.orig 57427 2.6.12.4.nt 20858 20858/57427=36.32% (63.7% reduction) L3 cache miss reduction of __copy_from_user_ll samples % 37408 65.1412 vmlinux __copy_from_user_ll 23 0.1103 vmlinux __copy_user_zeroing_intel_nocache 23/37408=0.061% (99.94% reduction) Top 5 of 2.6.12.4.nt Counted GLOBAL_POWER_EVENTS events (time during which processor is not stopped) with a unit mask of 0x01 (mandatory) count 100000 samples % app name symbol name 128392 8.0274 vmlinux __copy_user_zeroing_intel_nocache 64206 4.0143 vmlinux journal_add_journal_head 59746 3.7355 vmlinux do_get_write_access 47674 2.9807 vmlinux journal_put_journal_head 46021 2.8774 vmlinux journal_dirty_metadata pattern9-0-cpu4-0-09011728/summary.out Counted BSQ_CACHE_REFERENCE events (cache references seen by the bus unit) with a unit mask of 0x3f (multiple flags) count 3000 samples % app name symbol name 69755 4.2861 vmlinux __copy_user_zeroing_intel_nocache 55685 3.4215 vmlinux journal_add_journal_head 52371 3.2179 vmlinux __find_get_block 45504 2.7960 vmlinux journal_put_journal_head 36005 2.2123 vmlinux journal_stop pattern9-0-cpu4-0-09011744/summary.out Counted BSQ_CACHE_REFERENCE events (cache references seen by the bus unit) with a unit mask of 0x200 (read 3rd level cache miss) count 3000 samples % app name symbol name 1147 5.4994 vmlinux journal_add_journal_head 881 4.2240 vmlinux journal_dirty_data 872 4.1809 vmlinux blk_rq_map_sg 734 3.5192 vmlinux journal_commit_transaction 617 2.9582 vmlinux radix_tree_delete pattern9-0-cpu4-0-09011731/summary.out iozone results are original 2.6.12.4 CPU time = 207.768 sec cache aware CPU time = 184.783 sec (three times run) 184.783/207.768=88.94% (11.06% reduction) original: pattern9-0-cpu4-0-08191720/iozone.out: CPU Utilization: Wall time 45.997 CPU time 64.527 CPU utilization 140.28 % pattern9-0-cpu4-0-08191741/iozone.out: CPU Utilization: Wall time 46.878 CPU time 71.933 CPU utilization 153.45 % pattern9-0-cpu4-0-08191743/iozone.out: CPU Utilization: Wall time 45.152 CPU time 71.308 CPU utilization 157.93 % cache awre: pattern9-0-cpu4-0-09011728/iozone.out: CPU Utilization: Wall time 44.842 CPU time 62.465 CPU utilization 139.30 % pattern9-0-cpu4-0-09011731/iozone.out: CPU Utilization: Wall time 44.718 CPU time 59.273 CPU utilization 132.55 % pattern9-0-cpu4-0-09011744/iozone.out: CPU Utilization: Wall time 44.367 CPU time 63.045 CPU utilization 142.10 % Signed-off-by: Hiro Yoshioka <hyoshiok@miraclelinux.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-26Don't include linux/config.h from anywhere else in include/David Woodhouse
2006-03-23[PATCH] i386: Add a temporary to make put_user more type safeEric W. Biederman
In some code I am developing I had occasion to change the type of a variable. This made the value put_user was putting to user space wrong. But the code continued to build cleanly without errors. Introducing a temporary fixes this problem and at least with gcc-3.3.5 does not cause gcc any problems with optimizing out the temporary. gcc-4.x using SSA internally ought to be even better at optimizing out temporaries, so I don't expect a temporary to become a problem. Especially because in all correct cases the types on both sides of the assignment to the temporary are the same. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-14[PATCH] mark several functions __always_inlineIngo Molnar
Arjan van de Ven <arjan@infradead.org> Mark a number of functions as 'must inline'. The functions affected by this patch need to be inlined because they use knowledge that their arguments are constant so that most of the function optimizes away. At this point this patch does not change behavior, it's for documentation only (and for future patches in the inline series) Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] remove verify_area(): remove verify_area() from various uaccess.h ↵Jesper Juhl
headers Remove the deprecated (and unused) verify_area() from various uaccess.h headers. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
