path: root/include/asm-ia64/sn/nodepda.h
2008-04-18include: Remove unnecessary inclusions of asm/semaphore.hMatthew Wilcox
None of these files use any of the functionality promised by asm/semaphore.h. It's possible that they (or some user of them) rely on it dragging in some unrelated header file, but I can't build all these files, so we'll have to fix any build failures as they come up. Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
2005-10-04[IA64-SGI] Remove references to the SN bist_lockDean Roe
Remove all references to the bist_lock in the SN code as it is not used for anything. Signed-off-by: Dean Roe <roe@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2005-08-17[IA64-SGI] - New SN hardware support - ptc_fixesJack Steiner
Shub2 provides a much improved mechanism for issuing internode TLB purges. Add code to support the newer mechanism. There is also some debug code (disabled) that is useful for testing. Collect statistics on the number, type & duration of TLB purges. This data will be useful for making future improvements in the algorithms. Signed-off-by: Jack Steiner <steiner@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2005-05-04[IA64-SGI] move nodepda pointer out of pdaDean Nelson
Remove the p_nodepda and p_subnodepda pointers from the pda_s structure. And then define a new per-cpu pointer to the nodepda and export it so that it can be accessed by kernel modules. Signed-off-by: Dean Nelson <dcn@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2005-04-25[IA64-SGI] Add new MMR definitions/Modify BTE initialiation&copy.Russ Anderson
patch 1: Add new MMR definitions. Modify BTE initialiation. Modify BTE copy. Signed-off-by: Russ Anderson <rja@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
