path: root/include/asm-ia64
2006-03-26[PATCH] EFI: keep physical table addresses in efi structureBjorn Helgaas
Almost all users of the table addresses from the EFI system table want physical addresses. So rather than doing the pa->va->pa conversion, just keep physical addresses in struct efi. This fixes a DMI bug: the efi structure contained the physical SMBIOS address on x86 but the virtual address on ia64, so dmi_scan_machine() used ioremap() on a virtual address on ia64. This is essentially the same as an earlier patch by Matt Tolentino: http://marc.theaimsgroup.com/?l=linux-kernel&m=112130292316281&w=2 except that this changes all table addresses, not just ACPI addresses. Matt's original patch was backed out because it caused MCAs on HP sx1000 systems. That problem is resolved by the ioremap() attribute checking added for ia64. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Matt Domsch <Matt_Domsch@dell.com> Cc: "Tolentino, Matthew E" <matthew.e.tolentino@intel.com> Cc: "Brown, Len" <len.brown@intel.com> Cc: Andi Kleen <ak@muc.de> Acked-by: "Luck, Tony" <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] ia64: ioremap: check EFI for valid memory attributesBjorn Helgaas
Check the EFI memory map so we can use the correct memory attributes for ioremap(). Previously, we always used uncacheable access, which blows up on some machines for regular system memory. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Matt Domsch <Matt_Domsch@dell.com> Cc: "Tolentino, Matthew E" <matthew.e.tolentino@intel.com> Cc: "Brown, Len" <len.brown@intel.com> Cc: Andi Kleen <ak@muc.de> Acked-by: "Luck, Tony" <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] EFI, /dev/mem: simplify efi_mem_attribute_range()Bjorn Helgaas
Pass the size, not a pointer to the size, to efi_mem_attribute_range(). This function validates memory regions for the /dev/mem read/write/mmap paths. The pointer allows arches to reduce the size of the range, but I think that's unnecessary complexity. Simplifying it will let me use efi_mem_attribute_range() to improve the ia64 ioremap() implementation. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Matt Domsch <Matt_Domsch@dell.com> Cc: "Tolentino, Matthew E" <matthew.e.tolentino@intel.com> Cc: "Brown, Len" <len.brown@intel.com> Cc: Andi Kleen <ak@muc.de> Acked-by: "Luck, Tony" <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] ia64: use i386 dmi_scan.cMatt Domsch
Enable DMI table parsing on ia64. Andi Kleen has a patch in his x86_64 tree which enables the use of i386 dmi_scan.c on x86_64. dmi_scan.c functions are being used by the drivers/char/ipmi/ipmi_si_intf.c driver for autodetecting the ports or memory spaces where the IPMI controllers may be found. This patch adds equivalent changes for ia64 as to what is in the x86_64 tree. In addition, I reworked the DMI detection, such that on EFI-capable systems, it uses the efi.smbios pointer to find the table, rather than brute-force searching from 0xF0000. On non-EFI systems, it continues the brute-force search. My test system, an Intel S870BN4 'Tiger4', aka Dell PowerEdge 7250, with latest BIOS, does not list the IPMI controller in the ACPI namespace, nor does it have an ACPI SPMI table. Also note, currently shipping Dell x8xx EM64T servers don't have these either, so DMI is the only method for obtaining the address of the IPMI controller. Signed-off-by: Matt Domsch <Matt_Domsch@dell.com> Acked-by: "Luck, Tony" <tony.luck@intel.com> Cc: Andi Kleen <ak@muc.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-25Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6: [IA64] New IA64 core/thread detection patch [IA64] Increase max node count on SN platforms [IA64] Increase max node count on SN platforms [IA64] Increase max node count on SN platforms [IA64] Increase max node count on SN platforms [IA64] Tollhouse HP: IA64 arch changes [IA64] cleanup dig_irq_init [IA64] MCA recovery: kernel context recovery table IA64: Use early_parm to handle mvec_name and nomca [IA64] move patchlist and machvec into init section [IA64] add init declaration - nolwsys [IA64] add init declaration - gate page functions [IA64] add init declaration to memory initialization functions [IA64] add init declaration to cpu initialization functions [IA64] add __init declaration to mca functions [IA64] Ignore disabled Local SAPIC Affinity Structure in SRAT [IA64] sn_check_intr: use ia64_get_irr() [IA64] fix ia64 is_hugepage_only_range
2006-03-25[PATCH] POLLRDHUP/EPOLLRDHUP handling for half-closed devices notificationsDavide Libenzi
Implement the half-closed devices notifiation, by adding a new POLLRDHUP (and its alias EPOLLRDHUP) bit to the existing poll/select sets. Since the existing POLLHUP handling, that does not report correctly half-closed devices, was feared to be changed, this implementation leaves the current POLLHUP reporting unchanged and simply add a new bit that is set in the few places where it makes sense. The same thing was discussed and conceptually agreed quite some time ago: http://lkml.org/lkml/2003/7/12/116 Since this new event bit is added to the existing Linux poll infrastruture, even the existing poll/select system calls will be able to use it. As far as the existing POLLHUP handling, the patch leaves it as is. The pollrdhup-2.6.16.rc5-0.10.diff defines the POLLRDHUP for all the existing archs and sets the bit in the six relevant files. The other attached diff is the simple change required to sys/epoll.h to add the EPOLLRDHUP definition. There is "a stupid program" to test POLLRDHUP delivery here: http://www.xmailserver.org/pollrdhup-test.c It tests poll(2), but since the delivery is same epoll(2) will work equally. Signed-off-by: Davide Libenzi <davidel@xmailserver.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Michael Kerrisk <mtk-manpages@gmx.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[IA64] New IA64 core/thread detection patchFenghua Yu
IPF SDM 2.2 changes definition of PAL_LOGICAL_TO_PHYSICAL to add proc_number=-1 to get core/thread mapping info on the running processer. Based on this change, we had better to update existing core/thread detection in IA64 kernel correspondingly. The attached patch implements this change. It simplifies detection code and eliminates potential race condition. It also runs a bit faster and has better scalability especially when cores and threads number grows up in one package. Signed-off-by: Fenghua Yu <fenghua.yu@intel.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2006-03-24[IA64] Increase max node count on SN platformsJack Steiner
Node number are kept in the cpu_to_node_map which is currently defined as u8. Change to u16 to accomodate larger node numbers. Signed-off-by: Jack Steiner <steiner@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
Add support in IA64 acpi for platforms that support more than 256 nodes. Currently, ACPI is limited to 256 nodes because the proximity domain number is 8-bits. Long term, we expect to use ACPI3.0 to support >256 nodes. This patch is an interim solution that works with platforms that pass the high order bits of the proximity domain in "reserved" fields of the ACPI tables. This code is enabled ONLY on SN platforms. Signed-off-by: Jack Steiner <steiner@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
Add a configuration option to allow the maximum number of nodes to be configurable for GENERIC or SN kernels. Signed-off-by: Jack Steiner <steiner@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2006-03-24[IA64] Tollhouse HP: IA64 arch changesPrarit Bhargava
arch/ia64/sn and include/asm-ia64/sn changes required to support Tollhouse system PCI hotplug, fixes the ia64_sn_sysctl_ioboard_get call, and introduces the PRF_HOTPLUG_SUPPORT feature bit. Signed-off-by: Prarit Bhargava <prarit@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2006-03-24[IA64] cleanup dig_irq_initChen, Kenneth W
dig_irq_init is equivalent to machvec_noop, no need to define another empty function. Signed-off-by: Ken Chen <kenneth.w.chen@intel.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2006-03-24[IA64] MCA recovery: kernel context recovery tableRuss Anderson
Memory errors encountered by user applications may surface when the CPU is running in kernel context. The current code will not attempt recovery if the MCA surfaces in kernel context (privilage mode 0). This patch adds a check for cases where the user initiated the load that surfaces in kernel interrupt code. An example is a user process lauching a load from memory and the data in memory had bad ECC. Before the bad data gets to the CPU register, and interrupt comes in. The code jumps to the IVT interrupt entry point and begins execution in kernel context. The process of saving the user registers (SAVE_REST) causes the bad data to be loaded into a CPU register, triggering the MCA. The MCA surfaces in kernel context, even though the load was initiated from user context. As suggested by David and Tony, this patch uses an exception table like approach, puting the tagged recovery addresses in a searchable table. One difference from the exception table is that MCAs do not surface in precise places (such as with a TLB miss), so instead of tagging specific instructions, address ranges are registers. A single macro is used to do the tagging, with the input parameter being the label of the starting address and the macro being the ending address. This limits clutter in the code. This patch only tags one spot, the interrupt ivt entry. Testing showed that spot to be a "heavy hitter" with MCAs surfacing while saving user registers. Other spots can be added as needed by adding a single macro. Signed-off-by: Russ Anderson (rja@sgi.com) Signed-off-by: Tony Luck <tony.luck@intel.com>
2006-03-24[PATCH] abstract type/size specification for assemblyJan Beulich
Provide abstraction for generating type and size information of assembly routines and data, while permitting architectures to override these defaults. Signed-off-by: Jan Beulich <jbeulich@novell.com> Cc: "Russell King" <rmk@arm.linux.org.uk> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: "Andi Kleen" <ak@suse.de> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Miles Bader <uclinux-v850@lsi.nec.co.jp> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] s/;;/;/gAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] kill include/linux/platform.h, default_idle() cleanupAdrian Bunk
include/linux/platform.h contained nothing that was actually used except the default_idle() prototype, and is therefore removed by this patch. This patch does the following with the platform specific default_idle() functions on different architectures: - remove the unused function: - parisc - sparc64 - make the needlessly global function static: - arm - h8300 - m68k - m68knommu - s390 - v850 - x86_64 - add a prototype in asm/system.h: - cris - i386 - ia64 Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: Patrick Mochel <mochel@digitalimplant.org> Acked-by: Kyle McMartin <kyle@parisc-linux.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-23[PATCH] atomic: add_unless cmpxchg optimiseNick Piggin
Without branch hints, the very unlikely chance of the loop repeating due to cmpxchg failure is unrolled with gcc-4 that I have tested. Improve this for architectures with a native cas/cmpxchg. llsc archs should try to implement this natively. Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: Andi Kleen <ak@muc.de> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-23[PATCH] Move read_mostly definition to asm/cache.hKyle McMartin
Seems like needless clutter having a bunch of #if defined(CONFIG_$ARCH) in include/linux/cache.h. Move the per architecture section definition to asm/cache.h, and keep the if-not-defined dummy case in linux/cache.h to catch architectures which don't implement the section. Verified that symbols still go in .data.read_mostly on parisc, and the compile doesn't break. Signed-off-by: Kyle McMartin <kyle@parisc-linux.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-22[IA64] add init declaration to cpu initialization functionsChen, Kenneth W
Add init declaration to cpu initialization functions. Signed-off-by: Ken Chen <kenneth.w.chen@intel.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2006-03-22[IA64] fix ia64 is_hugepage_only_rangeChen, Kenneth W
fix is_hugepage_only_range() definition to be "overlaps" instead of "within architectural restricted hugetlb address range". Simplify the ia64 specific code that used to use is_hugepage_only_range() to just check which region the address is in. Signed-off-by: Ken Chen <kenneth.w.chen@intel.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2006-03-22[PATCH] hugepage: is_aligned_hugepage_range() cleanupDavid Gibson
Quite a long time back, prepare_hugepage_range() replaced is_aligned_hugepage_range() as the callback from mm/mmap.c to arch code to verify if an address range is suitable for a hugepage mapping. is_aligned_hugepage_range() stuck around, but only to implement prepare_hugepage_range() on archs which didn't implement their own. Most archs (everything except ia64 and powerpc) used the same implementation of is_aligned_hugepage_range(). On powerpc, which implements its own prepare_hugepage_range(), the custom version was never used. In addition, "is_aligned_hugepage_range()" was a bad name, because it suggests it returns true iff the given range is a good hugepage range, whereas in fact it returns 0-or-error (so the sense is reversed). This patch cleans up by abolishing is_aligned_hugepage_range(). Instead prepare_hugepage_range() is defined directly. Most archs use the default version, which simply checks the given region is aligned to the size of a hugepage. ia64 and powerpc define custom versions. The ia64 one simply checks that the range is in the correct address space region in addition to being suitably aligned. The powerpc version (just as previously) checks for suitable addresses, and if necessary performs low-level MMU frobbing to set up new areas for use by hugepages. No libhugetlbfs testsuite regressions on ppc64 (POWER5 LPAR). Signed-off-by: David Gibson <david@gibson.dropbear.id.au> Signed-off-by: Zhang Yanmin <yanmin.zhang@intel.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: William Lee Irwin III <wli@holomorphy.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-22[PATCH] hugepage: Move hugetlb_free_pgd_range() prototype to hugetlb.hDavid Gibson
The optional hugepage callback, hugetlb_free_pgd_range() is presently implemented non-trivially only on ia64 (but I plan to add one for powerpc shortly). It has its own prototype for the function in asm-ia64/pgtable.h. However, since the function is called from generic code, it make sense for its prototype to be in the generic hugetlb.h header file, as the protypes other arch callbacks already are (prepare_hugepage_range(), set_huge_pte_at(), etc.). This patch makes it so. Signed-off-by: David Gibson <dwg@au1.ibm.com> Cc: William Lee Irwin III <wli@holomorphy.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-22[PATCH] hugepage: Fix hugepage logic in free_pgtables()David Gibson
free_pgtables() has special logic to call hugetlb_free_pgd_range() instead of the normal free_pgd_range() on hugepage VMAs. However, the test it uses to do so is incorrect: it calls is_hugepage_only_range on a hugepage sized range at the start of the vma. is_hugepage_only_range() will return true if the given range has any intersection with a hugepage address region, and in this case the given region need not be hugepage aligned. So, for example, this test can return true if called on, say, a 4k VMA immediately preceding a (nicely aligned) hugepage VMA. At present we get away with this because the powerpc version of hugetlb_free_pgd_range() is just a call to free_pgd_range(). On ia64 (the only other arch with a non-trivial is_hugepage_only_range()) we get away with it for a different reason; the hugepage area is not contiguous with the rest of the user address space, and VMAs are not permitted in between, so the test can't return a false positive there. Nonetheless this should be fixed. We do that in the patch below by replacing the is_hugepage_only_range() test with an explicit test of the VMA using is_vm_hugetlb_page(). This in turn changes behaviour for platforms where is_hugepage_only_range() returns false always (everything except powerpc and ia64). We address this by ensuring that hugetlb_free_pgd_range() is defined to be identical to free_pgd_range() (instead of a no-op) on everything except ia64. Even so, it will prevent some otherwise possible coalescing of calls down to free_pgd_range(). Since this only happens for hugepage VMAs, removing this small optimization seems unlikely to cause any trouble. This patch causes no regressions on the libhugetlbfs testsuite - ppc64 POWER5 (8-way), ppc64 G5 (2-way) and i386 Pentium M (UP). Signed-off-by: David Gibson <dwg@au1.ibm.com> Cc: William Lee Irwin III <wli@holomorphy.com> Acked-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-22[PATCH] Enable mprotect on huge pagesZhang, Yanmin
2.6.16-rc3 uses hugetlb on-demand paging, but it doesn_t support hugetlb mprotect. From: David Gibson <david@gibson.dropbear.id.au> Remove a test from the mprotect() path which checks that the mprotect()ed range on a hugepage VMA is hugepage aligned (yes, really, the sense of is_aligned_hugepage_range() is the opposite of what you'd guess :-/). In fact, we don't need this test. If the given addresses match the beginning/end of a hugepage VMA they must already be suitably aligned. If they don't, then mprotect_fixup() will attempt to split the VMA. The very first test in split_vma() will check for a badly aligned address on a hugepage VMA and return -EINVAL if necessary. From: "Chen, Kenneth W" <kenneth.w.chen@intel.com> On i386 and x86-64, pte flag _PAGE_PSE collides with _PAGE_PROTNONE. The identify of hugetlb pte is lost when changing page protection via mprotect. A page fault occurs later will trigger a bug check in huge_pte_alloc(). The fix is to always make new pte a hugetlb pte and also to clean up legacy code where _PAGE_PRESENT is forced on in the pre-faulting day. Signed-off-by: Zhang Yanmin <yanmin.zhang@intel.com> Cc: David Gibson <david@gibson.dropbear.id.au> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: William Lee Irwin III <wli@holomorphy.com> Signed-off-by: Ken Chen <kenneth.w.chen@intel.com> Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com> Cc: Andi Kleen <ak@muc.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-21Pull sn2-reduce-kmalloc-wrap into release branchTony Luck
2006-03-21Pull icc-cleanup into release branchTony Luck
2006-03-21Pull sn2-mmio-writes into release branchTony Luck
Hand-fixed conflicts: include/asm-ia64/machvec_sn2.h Signed-off-by: Tony Luck <tony.luck@intel.com>
2006-03-21Pull altix-ce1.0-asic into release branchTony Luck
2006-03-21Pull delete-sigdelayed into release branchTony Luck
2006-03-21Pull ia64-mutex-primitives into release branchTony Luck
2006-03-21Pull bsp-removal into release branchTony Luck
2006-02-27[IA64-SGI] Make number of TIO nodes configurableJack Steiner
Make the limit for the number of TIO nodes a function of the number of C/M nodes in the system instead of a hardcoded constant. The number of TIO nodes should be the same as the number of C/M nodes. Signed-off-by: Jack Steiner <steiner@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2006-02-27[IA64-SGI] SN2-XP reduce kmalloc wrapper inliningJes Sorensen
Take advantage of kzalloc() as well as reduce the size of code generated for the error returns in xpc_setup_infrastructure(). Signed-off-by: Jes Sorensen <jes@sgi.com> Acked-by: Dean Nelson <dcn@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2006-02-17Merge branch 'release' of ↵Linus Torvalds
2006-02-15[PATCH] add asm-generic/mman.hMichael S. Tsirkin
Make new MADV_REMOVE, MADV_DONTFORK, MADV_DOFORK consistent across all arches. The idea is to make it possible to use them portably even before distros include them in libc headers. Move common flags to asm-generic/mman.h Signed-off-by: Michael S. Tsirkin <mst@mellanox.co.il> Cc: Roland Dreier <rolandd@cisco.com> Cc: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-15Pull fix-cpu-possible-map into release branchTony Luck
2006-02-15[IA64] ia64: simplify and fix udelay()hawkes@sgi.com
The original ia64 udelay() was simple, but flawed for platforms without synchronized ITCs: a preemption and migration to another CPU during the while-loop likely resulted in too-early termination or very, very lengthy looping. The first fix (now in 2.6.15) broke the delay loop into smaller, non-preemptible chunks, reenabling preemption between the chunks. This fix is flawed in that the total udelay is computed to be the sum of just the non-premptible while-loop pieces, i.e., not counting the time spent in the interim preemptible periods. If an interrupt or a migration occurs during one of these interim periods, then that time is invisible and only serves to lengthen the effective udelay(). This new fix backs out the current flawed fix and returns to a simple udelay(), fully preemptible and interruptible. It implements two simple alternative udelay() routines: one a default generic version that uses ia64_get_itc(), and the other an sn-specific version that uses that platform's RTC. Signed-off-by: John Hawkes <hawkes@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2006-02-15[IA64-SGI] enforce proper ordering of callouts by XPCDean Nelson
Fix XPC so that it does not deliver any messages until the connected callout has returned, as well as, prevent the disconnected callout to occur before the disconnecting callout has returned. Signed-off-by: Dean Nelson <dcn@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2006-02-15[IA64-SGI] fix the size of __sn_cnodeid_to_nasidDean Roe
The __sn_cnodeid_to_nasid array was incorrectly sized at MAX_NUMNODES. On a large system, this array could overflow. The following patch corrects this by defining it to MAX_COMPACT_NODES. Signed-off-by: Dean Roe <roe@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2006-02-15[IA64] remove obsolete corporate addressJes Sorensen
Remove obsolete SGI address Signed-off-by: Jes Sorensen <jes@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2006-02-15[IA64-SGI] sn2 minor fixes and cleanupsJes Sorensen
General SN2 code cleanup: - Do not initialize global variables to zero - Use kzalloc instead of kmalloc+memset - Check kmalloc return values - Do not obfuscate spin lock calls - Remove some unused code - Various formatting cleanups Signed-off-by: Jes Sorensen <jes@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2006-02-14[PATCH] madvise MADV_DONTFORK/MADV_DOFORKMichael S. Tsirkin
Currently, copy-on-write may change the physical address of a page even if the user requested that the page is pinned in memory (either by mlock or by get_user_pages). This happens if the process forks meanwhile, and the parent writes to that page. As a result, the page is orphaned: in case of get_user_pages, the application will never see any data hardware DMA's into this page after the COW. In case of mlock'd memory, the parent is not getting the realtime/security benefits of mlock. In particular, this affects the Infiniband modules which do DMA from and into user pages all the time. This patch adds madvise options to control whether memory range is inherited across fork. Useful e.g. for when hardware is doing DMA from/into these pages. Could also be useful to an application wanting to speed up its forks by cutting large areas out of consideration. Signed-off-by: Michael S. Tsirkin <mst@mellanox.co.il> Acked-by: Hugh Dickins <hugh@veritas.com> Cc: Michael Kerrisk <mtk-manpages@gmx.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-14[IA64] Count disabled cpus as potential hot-pluggable CPUsAshok Raj
Have a facility to account for potentially hot-pluggable CPUs. ACPI doesnt give a determinstic method to find hot-pluggable CPUs. Hence we use 2 methods to assist. - BIOS can mark potentially hot-pluggable CPUs as disabled in the MADT tables. - User can specify the number of hot-pluggable CPUs via parameter additional_cpus=X The option is enabled only if ACPI_CONFIG_HOTPLUG_CPU=y which enables the physical hotplug option. Without which user can still use logical onlining and offlining of CPUs by enabling CONFIG_HOTPLUG_CPU=y Adds more bits to cpu_possible_map for potentially hot-pluggable cpus. Signed-off-by: Ashok Raj <ashok.raj@intel.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2006-02-09Pull new-syscalls into release branchTony Luck
2006-02-08[IA64] unshare system call registration for ia64Janak Desai
Registers system call for the ia64 architecture. Reserves space for ppoll and pselect, and adds unshare at system call number 1296. Signed-off-by: Janak Desai <janak@us.ibm.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2006-02-07[IA64-SGI] - Eliminate SN pio_phys_xxx macros. Move to assemblyJack Steiner
Rewrite the SN pio_phys_xxx macros in assembly language. This avoids issues with the Intel icc compiler. Function call overhead is not an issue - the functions reference PIOs and take 100's nsec to complete. In addition, the functions should likely be in assembly language anyway - they reference memory using physical addressing mode. One function executes with psr.ic disabled. Signed-off-by: Jack Steiner <steiner@sgi.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2006-02-07[IA64] use icc defined constantChen, Kenneth W
Use icc defined constant instead of magic number. Signed-off-by: Ken Chen <kenneth.w.chen@intel.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2006-02-07[IA64] add __builtin_trap definition for icc buildChen, Kenneth W
Map __builtin_trap function to break 0 instruction. Signed-off-by: HJ Lu <hongjiu.lu@intel.com> Signed-off-by: Ken Chen <kenneth.w.chen@intel.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2006-02-07[IA64] clean up asm/intel_intrin.hChen, Kenneth W
Include intrinsic header file from icc compiler. Remove duplicate definition from kernel source. Signed-off-by: HJ Lu <hongjiu.lu@intel.com> Signed-off-by: Ken Chen <kenneth.w.chen@intel.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2006-02-07[IA64] map ia64_hint definition to intel compiler intrinsicChen, Kenneth W
Map ia64_hint() to internal intel compiler intrinsic. Signed-off-by: Ken Chen <kenneth.w.chen@intel.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
