path: root/include/asm-mips/mach-au1x00/au1000.h
2008-10-11MIPS: Move headfiles to new location below arch/mips/includeRalf Baechle
2008-06-16[MIPS] Alchemy: Add au1500 reserved interruptbruno randolf
In the conversion done in the commits 95c4eb3ef4484ca85da5c98780d358cffd546b90 9d360ab4a7568a8d177280f651a8a772ae52b9b9 [MIPS] Alchemy: Renumber interrupts so irq_cpu can work. one reserved interrupt on au1500 was missed. this broke the au1000 ethernet driver. Signed-off-by: Bruno Randolf <br1@einfach.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-05-24fix parenthesis in include/asm-mips/mach-au1x00/au1000.hMariusz Kozlowski
Parenthesis fix in include/asm-mips/mach-au1x00/au1000.h Signed-off-by: Mariusz Kozlowski <m.kozlowski@tuxland.pl> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-12[MIPS] Alchemy common headers style cleanupSergei Shtylyov
Fix several errors and warnings given by checkpatch.pl: - space after opening and before closing parentheses; - opening brace following 'struct' not on the same line; - leading spaces instead of tabs; - use of C99 // comments; - macros with complex values not enclosed in parentheses; - missing space between the type and asterisk in a variable declaration; - space between asterisk and function name; - including <asm/io.h> instead of <linux/io.h> and <asm/irq.h> instead of <linux/irq.h>; - use of '__inline__' instead of 'inline'; - space between function name and opening parenthesis; - line over 80 characters. In addition to these changes, also do the following: - remove needless parentheses; - insert spaces between operator and its operands; - replace spaces after the macro name with tabs in the #define directives and after the type in the structure field declarations; - remove excess tabs after the macro name in the #define directives and in the 'extern' variable declarations; - remove excess spaces between # and define for the SSI_*_MASK macros to align with other such macros; - put '||' operator on the same line with its first operand; - properly indent multi-line function prototypes; - make the multi-line comment style consistent with the kernel style elsewhere by adding empty first line and/or adding space/asterisk on their left side; - make two-line comments that only have one line of text one-line; - convert the large multi-line comment in au1xxx_ide.h into several one-liners, replace spaces with tabs there; - fix typos/errors, capitalize acronyms, etc. in the comments; - insert missing and remove excess new lines; - update MontaVista copyright; - remove Pete Popov's and Steve Longerbeam's old email addresses... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-04-28[MIPS] Alchemy: kill unused PCI_IRQ_TABLE_LOOKUP macroSergei Shtylyov
2008-04-28[MIPS] Alchemy: don't unmask timer IRQ earlySergei Shtylyov
Defer the unmasking of the count/compare interrupt (IRQ5) till the clockevent driver initialization: - only enable the cascaded IRQs 0 thru 4 in arch_init_irq(); kill the ALLINTS macro -- this change is blessed by AMD as I saw it in their own patch; :-) - do not force IRQ5 enabled in plat_time_init() if PM is enabled and there's no 32 KHz crystal. Update the copyrights (taking into account my prior changes), also removing Pete Popov's old email... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-04-01[MIPS] Alchemy: work around clock misdetection on early Au1000Sergei Shtylyov
Work around the CPU clock miscalculation on Au1000DA/HA/HB due the sys_cpupll register being write-only, i.e. actually do what the comment before cal_r4off() function advertised for years but the code failed at. This is achieved by just giving user a chance to define the clock explicitly in the board config. via CONFIG_SOC_AU1000_FREQUENCY option, defaulting to 396 MHz if the option is not given... The patch is based on the AMD's big unpublished patch, the issue seems to be an undocumented errata (or feature :-)... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-12-14[MIPS] Alchemy: fix PCI resource conflictSergei Shtylyov
... by getting the PCI resources back into the 32-bit range -- there's no need therefore for CONFIG_RESOURCES_64BIT either. This makes Alchemy PCI work again while currently the kernel skips the bus scan. Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-12-06[MIPS] Alchemy: fix IRQ basesSergei Shtylyov
Do what the commits commits f3e8d1da389fe2e514e31f6e93c690c8e1243849 and 9d360ab4a7568a8d177280f651a8a772ae52b9b9 failed to achieve -- actually convert the Alchemy code to irq_cpu. Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-17[MIPS] Alchemy: Renumber interrupts so irq_cpu can work.Ralf Baechle
2007-10-17[MIPS] Alchemy: Fix build by conversion to irq_cpu.c.Ralf Baechle
2007-10-16[MIPS] Alchemy: Get rid of au1xxx_irq_map_t.Ralf Baechle
2007-10-16[MIPS] Alchemy: Get rid of au_ffz().Ralf Baechle
There were no users - and why have a private version anyway. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-16[MIPS] Alchemy: Get rid of au_ffs().Ralf Baechle
It was plain a bad idea ... Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-11[MIPS] Fix "no space between function name and open parenthesis" warnings.Ralf Baechle
2007-02-06[MIPS] Alchemy: Fix PCI-memory accessAlexander Bigga
The problem was introduced in 2.6.18.3 with the casting of some 36bit-defines (PCI memory) in au1000.h to resource_size_t which may be u32 or u64 depending on the experimental CONFIG_RESOURCES_64BIT. With unset CONFIG_RESOURCES_64BIT, the pci-memory cannot be accessed because the ioremap in arch/mips/au1000/common/pci.c already used the truncated addresses. With set CONFIG_RESOURCES_64BIT, things get even worse, because PCI-scan aborts, due to resource conflict: request_resource() in arch/mips/pci/pci.c fails because the maximum iomem-address is 0xffffffff (32bit) but the pci-memory-start-address is 0x440000000 (36bit). To get pci working again, I propose the following patch: 1. remove the resource_size_t-casting from au1000.h again 2. make the casting in arch/mips/au1000/common/pci.c (it's allowed and necessary here. The 36bit-handling will be done in __fixup_bigphys_addr). With this patch pci works again like in 2.6.18.2, the gcc-compile warnings in pci.c are gone and it doesn't depend on CONFIG_EXPERIMENTAL. Signed-off-by: Alexander Bigga <ab@mycable.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-02-06[MIPS] Alchemy: Fix bunch of warningsRalf Baechle
CC arch/mips/au1000/common/pci.o arch/mips/au1000/common/pci.c:42: warning: large integer implicitly truncated to unsigned type arch/mips/au1000/common/pci.c:43: warning: large integer implicitly truncated to unsigned type arch/mips/au1000/common/pci.c:49: warning: large integer implicitly truncated to unsigned type arch/mips/au1000/common/pci.c:50: warning: large integer implicitly truncated to unsigned type arch/mips/au1000/common/pci.c: In function ‘au1x_pci_setup’: arch/mips/au1000/common/pci.c:82: warning: ISO C90 forbids mixed declarations and code Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-04-26Don't include linux/config.h from anywhere else in include/David Woodhouse
2006-02-07[MIPS] Au1200: Make KGDB compileSergei Shtylylov
AMD Au1200 SOC just doesn't have UART3, so KGDB won't even compile for it as is, here's the fix to make KGDB use UART1. Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-01-10MIPS: Au1550: Fix OHCI memory map sizeSergei Shtylyov
USB OpenHCI host controller on Au1550 only decodes memory addresses from 0x14020000 to 0x1407FFFF according to the databook, which gives 0x60000 (on the prior Au1x00 chips the map size was 1MB). Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Acked-by: Jordan Crouse <jordan.crouse@amd.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2005-10-29Removed __ilog2 since it's no longer needed and conflicts with thePete Popov
generic one. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2005-10-29* use 'unsigned long' as address supplied to au_write[bwl]()Pete Popov
* remove two already unused and commented structures * added an ULL suffix to several address constants that use bits 35-32 Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2005-10-29Au1100 FB driver uplift for 2.6.Pete Popov
Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Acked-by: Antonino Daplas <adaplas@pol.net>
2005-10-29Moved irq_tab_alchemy to the board specific irqmap.c files.Pete Popov
Cleaned up a to of warnings in dbdma.c. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2005-10-29Base Au1200 2.6 support.Pete Popov
2005-09-05[PATCH] mips: nuke trailing whitespaceRalf Baechle
Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
