path: root/include/asm-mips/mach-pnx8550
2007-10-11[MIPS] checkfiles: Fix "need space after that ','" errors.Ralf Baechle
2007-10-11[MIPS] Fix "no space between function name and open parenthesis" warnings.Ralf Baechle
2007-10-11[MIPS] Split up war.hRalf Baechle
It was getting a little big, ugly and a primary source for merge conflicts. Also the old method was a bit too forgiving in that the workaround did default to off, so now there is an explicit #error forcing platform maintainers to think if they should enable a workaround for a particular platform. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-10-04[MIPS] PNX8550 fixupsVitaly Wool
This patch fixes the compilation errors on PNX8550 and hard-to-track bug in interrupt handling. It also corresponds to the latest changes in PNX8550 serial driver. Signed-off-by: Vitaly Wool <vitalywool@gmail.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2005-10-29Philips PNX8550 support: MIPS32-like core with 2 Trimedias on it.Pete Popov
