path: root/include/asm-mips/mach-tx49xx
2007-10-11[MIPS] Split up war.hRalf Baechle
It was getting a little big, ugly and a primary source for merge conflicts. Also the old method was a bit too forgiving in that the workaround did default to off, so now there is an explicit #error forcing platform maintainers to think if they should enable a workaround for a particular platform. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-07-31[MIPS] tx49xx: Add mach specific headersAtsushi Nemoto
Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-07-13[MIPS] Workaround for a sparse warning in include/asm-mips/mach-tx4927/ioremap.hAtsushi Nemoto
include2/asm/mach-tx49xx/ioremap.h:39:52: warning: cast truncates bits from constant value (fff000000 becomes ff000000) Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-07-10[MIPS] Make ioremap() work on TX39/49 special unmapped segmentAtsushi Nemoto
TX39XX and TX49XX have "reserved" segment in CKSEG3 area. 0xff000000-0xff3fffff on TX49XX and 0xff000000-0xfffeffff on TX39XX are reserved (unmapped, uncached). Controllers on these SoCs are placed in this segment. This patch add plat_ioremap() and plat_iounmap() to override default behavior and implement these hooks for TX39/TX49. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
