path: root/include/asm-mips/page.h
2008-02-08CONFIG_HIGHPTE vs. sub-page page tables.Martin Schwidefsky
Background: I've implemented 1K/2K page tables for s390. These sub-page page tables are required to properly support the s390 virtualization instruction with KVM. The SIE instruction requires that the page tables have 256 page table entries (pte) followed by 256 page status table entries (pgste). The pgstes are only required if the process is using the SIE instruction. The pgstes are updated by the hardware and by the hypervisor for a number of reasons, one of them is dirty and reference bit tracking. To avoid wasting memory the standard pte table allocation should return 1K/2K (31/64 bit) and 2K/4K if the process is using SIE. Problem: Page size on s390 is 4K, page table size is 1K or 2K. That means the s390 version for pte_alloc_one cannot return a pointer to a struct page. Trouble is that with the CONFIG_HIGHPTE feature on x86 pte_alloc_one cannot return a pointer to a pte either, since that would require more than 32 bit for the return value of pte_alloc_one (and the pte * would not be accessible since its not kmapped). Solution: The only solution I found to this dilemma is a new typedef: a pgtable_t. For s390 pgtable_t will be a (pte *) - to be introduced with a later patch. For everybody else it will be a (struct page *). The additional problem with the initialization of the ptl lock and the NR_PAGETABLE accounting is solved with a constructor pgtable_page_ctor and a destructor pgtable_page_dtor. The page table allocation and free functions need to call these two whenever a page table page is allocated or freed. pmd_populate will get a pgtable_t instead of a struct page pointer. To get the pgtable_t back from a pmd entry that has been installed with pmd_populate a new function pmd_pgtable is added. It replaces the pmd_page call in free_pte_range and apply_to_pte_range. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07Cleanup asm/{elf,page,user}.h: #ifdef __KERNEL__ is no longer neededKirill A. Shutemov
asm/elf.h, asm/page.h and asm/user.h don't export to userspace now, so we can drop #ifdef __KERNEL__ for them. [k.shutemov@gmail.com: remove #ifdef __KERNEL_] Signed-off-by: Kirill A. Shutemov <k.shutemov@gmail.com> Reviewed-by: David Woodhouse <dwmw2@infradead.org> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Kirill A. Shutemov <k.shutemov@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-11[MIPS] checkfiles: Fix "need space after that ','" errors.Ralf Baechle
2007-10-11[MIPS] Optimize __alloc_zeroed_user_highpage implementation.Ralf Baechle
2007-10-11[MIPS] Rename CONFIG_BUILD_ELF64 into KBUILD_64BIT_SYM32Franck Bui-Huu
This patch renames it for 3 reasons: - "CONFIG" pattern is used by Kconfig. Now this macro is no more defined by Kconfig but by Kbuild itself make this clear by translating "CONFIG" into "KBUILD". - "ELF32" word is improper because it is irrelevant to ELF format and it makes confusion with CONFIG_BOOT_ELF32. So translate it with SYM32. - Add "64BIT" part to make clear that this macro implies a 64 bits kernel. Signed-off-by: Franck Bui-Huu <fbuihuu@gmail.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-11[MIPS] Automatically set CONFIG_BUILD_ELF64Franck Bui-Huu
We do not rely on user anymore to setup this config correctly. Instead we make our choice depending on the load address. If we want to force Kbuild to use ELF64 format whatever the load address we can still do: $ make BUILD_ELF32=no Signed-off-by: Franck Bui-Huu <fbuihuu@gmail.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-09-27[MIPS] Fix CONFIG_BUILD_ELF64 kernels with symbols in CKSEG0.Ralf Baechle
The __pa() for those did assume that all symbols have XKPHYS values and the math fails for any other address range. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-07-10[MIPS] Fix PHYS_OFFSET for 64-bits kernels with 32-bits symbolsFranck Bui-Huu
The current implementation of __pa() for 64-bits kernels with 32-bits symbols is broken. In this configuration, we need 2 values for PAGE_OFFSET, one in XKPHYS and the other in CKSEG0 space. When the value in CKSEG0 space is used, it doesn't take into account of PHYS_OFFSET. Even worse we can't redefine this value. The patch restores CPHYSADDR() but in __pa()'s implementation because it removes the need of 2 PAGE_OFFSET. OTOH, CPHYSADDR() is quite bad when dealing with mapped kernels. So this patch assumes there's no need to deal with such kernel in 64-bits world. Signed-off-by: Franck Bui-Huu <fbuihuu@gmail.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-07-10[MIPS] Move PHY_OFFSET definition in spaces.hFranck Bui-Huu
2007-05-11[MIPS] Remove LIMITED_DMA supportFranck Bui-Huu
This code was needed only by Jaguar ATX. Signed-off-by: Franck Bui-Huu <fbuihuu@gmail.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-02-06[MIPS] FLATMEM: introduce PHYS_OFFSET.Franck Bui-Huu
The old code was assuming that min_low_pfn was always 0. This means that platforms having a big hole at their memory start paid the price of wasting some memory for the allocation of unused entries in mem_map[]. This patch prevents this waste. It introduces PHYS_OFFSET define which is the start of the physical memory and uses it wherever needed. Specially when converting physical/virtual addresses into virtual/physical ones. Currently all platforms defines PHYS_OFFSET to 0. Signed-off-by: Franck Bui-Huu <fbuihuu@gmail.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-12-13[PATCH] MIPS: Fix COW D-cache aliasing on forkAtsushi Nemoto
Provide a custom copy_user_highpage() to deal with aliasing issues on MIPS. It uses kmap_coherent() to map an user page for kernel with same color. Rewrite copy_to_user_page() and copy_from_user_page() with the new interfaces to avoid extra cache flushing. The main part of this patch was originally written by Ralf Baechle; Atushi Nemoto did the the debugging. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-30[MIPS] Introduce __pa_symbol()Franck Bui-Huu
This patch introduces __pa_symbol() macro which should be used to calculate the physical address of kernel symbols. It also relies on RELOC_HIDE() to avoid any compiler's oddities when doing arithmetics on symbols. Signed-off-by: Franck Bui-Huu <fbuihuu@gmail.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-11-30[MIPS] Make __pa() aware of XKPHYS/CKSEG0 address mix for 64 bit kernelsFranck Bui-Huu
During early boot mem init, some configs couldn't use __pa() to convert virtual into physical addresses. Specially for 64 bit kernel cases when CONFIG_BUILD_ELF64=n. This patch make __pa() work for _all_ configs and thus make CPHYSADDR() useless. Signed-off-by: Franck Bui-Huu <fbuihuu@gmail.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-11-30[MIPS] page.h: remove __pa() usages.Franck Bui-Huu
__pa() was used by virt_to_page() and virt_addr_valid(). These latter are used when kernel is initialised so __pa() is not appropriate, we use virt_to_phys() instead. Futhermore __pa() is going to take care of CKSEG0/XKPHYS address mix for 64 bit kernels. This makes __pa() more complex than virt_to_phys() and this extra work is not needed by virt_to_page() and virt_addr_valid(). Eventually it consolidates virt_to_phys() prototype by making its argument 'const'. this avoids some warnings that was due to some virt_to_page() usages which pass const pointer. Signed-off-by: Franck Bui-Huu <fbuihuu@gmail.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-09-27[MIPS] Do not lose upper 32-bit on MIPS32 with 64-bit addresses in __pte().Ralf Baechle
2006-09-27[MIPS] Retire flush_icache_page from mm use.Ralf Baechle
On the 34K the redundant cache operations were causing excessive stalls resulting in realtime code running on the second VPE missing its deadline. For all other platforms this patch is just a significant performance improvment as illustrated by below benchmark numbers. Processor, Processes - times in microseconds - smaller is better ------------------------------------------------------------------------------ Host OS Mhz null null open slct sig sig fork exec sh call I/O stat clos TCP inst hndl proc proc proc --------- ------------- ---- ---- ---- ---- ---- ---- ---- ---- ---- ---- ---- 25Kf 2.6.18-rc4 533 0.49 1.16 7.57 33.4 30.5 1.34 12.4 5497 17.K 54.K 25Kf 2.6.18-rc4-p 533 0.49 1.16 6.68 23.0 30.7 1.36 8.55 5030 16.K 48.K 4Kc 2.6.18-rc4 80 4.21 15.0 131. 289. 261. 16.5 258. 18.K 70.K 227K 4Kc 2.6.18-rc4-p 80 4.34 13.1 128. 285. 262. 18.2 258. 12.K 52.K 176K 34Kc 2.6.18-rc4 40 5.01 14.0 61.6 90.0 477. 17.9 94.7 29.K 108K 342K 34Kc 2.6.18-rc4-p 40 4.98 13.9 61.2 89.7 475. 17.6 93.7 8758 44.K 158K BCM1480 2.6.18-rc4 700 0.28 0.60 3.68 5.92 16.0 0.78 5.08 931. 3163 15.K BCM1480 2.6.18-rc4-p 700 0.28 0.61 3.65 5.85 16.0 0.79 5.20 395. 1464 8385 TX49-16K 2.6.18-rc3 197 0.73 2.41 19.0 37.8 82.9 2.94 17.5 4438 14.K 56.K TX49-16K 2.6.18-rc3-p 197 0.73 2.40 19.9 36.3 82.9 2.94 23.4 2577 9103 38.K TX49-32K 2.6.18-rc3 396 0.36 1.19 6.80 11.8 41.0 1.46 8.17 2738 8465 32.K TX49-32K 2.6.18-rc3-p 396 0.36 1.19 6.82 10.2 41.0 1.46 8.18 1330 4638 18.K Original patch by me with enhancements by Atsushi Nemoto. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp>
2006-09-13[PATCH] headers_check: fix userspace build of asm-mips/page.hDavid Woodhouse
MIPS asm/page.h unconditionally includes <asm-generic/memory_model.h>, which doesn't exist in userspace. Move an #endif /* __KERNEL__ */ down a few lines to prevent that. Also, remove the broken definition of PAGE_SIZE which is never going to be correct -- in the absence of PAGE_SIZE, non-broken userspace will fall back to using sysconf() or getpagesize() instead. Signed-off-by: David Woodhouse <dwmw2@infradead.org> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-13[MIPS] Sparsemem fixesAtsushi Nemoto
1. MIPS should select SPARSEMEM_STATIC since allocating bootmem in memory_present() will corrupt bootmap area. 2. pfn_valid() for SPARSEMEM is defined in linux/mmzone.h Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-06-20Merge git://git.infradead.org/hdrcleanup-2.6Linus Torvalds
* git://git.infradead.org/hdrcleanup-2.6: (63 commits) [S390] __FD_foo definitions. Switch to __s32 types in joystick.h instead of C99 types for consistency. Add <sys/types.h> to headers included for userspace in <linux/input.h> Move inclusion of <linux/compat.h> out of user scope in asm-x86_64/mtrr.h Remove struct fddi_statistics from user view in <linux/if_fddi.h> Move user-visible parts of drivers/s390/crypto/z90crypt.h to include/asm-s390 Revert include/media changes: Mauro says those ioctls are only used in-kernel(!) Include <linux/types.h> and use __uXX types in <linux/cramfs_fs.h> Use __uXX types in <linux/i2o_dev.h>, include <linux/ioctl.h> too Remove private struct dx_hash_info from public view in <linux/ext3_fs.h> Include <linux/types.h> and use __uXX types in <linux/affs_hardblocks.h> Use __uXX types in <linux/divert.h> for struct divert_blk et al. Use __u32 for elf_addr_t in <asm-powerpc/elf.h>, not u32. It's user-visible. Remove PPP_FCS from user view in <linux/ppp_defs.h>, remove __P mess entirely Use __uXX types in user-visible structures in <linux/nbd.h> Don't use 'u32' in user-visible struct ip_conntrack_old_tuple. Use __uXX types for S390 DASD volume label definitions which are user-visible S390 BIODASDREADCMB ioctl should use __u64 not u64 type. Remove unneeded inclusion of <linux/time.h> from <linux/ufs_fs.h> Fix private integer types used in V4L2 ioctls. ... Manually resolve conflict in include/linux/mtd/physmap.h
2006-06-19[MIPS] Consolidate definitions of pfn_valid in one file.Ralf Baechle
2006-06-06[MIPS] Fix sparsemem support.Chad Reese
Move memory_present() in arch/mips/kernel/setup.c. When using sparsemem extreme, this function does an allocate for bootmem. This would always fail since init_bootmem hasn't been called yet. Move memory_present after free_bootmem. This only marks actual memory ranges as present instead of the entire address space. Signed-off-by: Chad Reese <creese@caviumnetworks.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-04-26Don't include linux/config.h from anywhere else in include/David Woodhouse
2006-03-27[PATCH] unify pfn_to_page: mips pfn_to_pageKAMEZAWA Hiroyuki
MIPS can use generic funcs. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-29Fixup a few lose ends in explicit support for MIPS R1/R2.Ralf Baechle
2005-10-29Rename CONFIG_CPU_MIPS{32,64} to CONFIG_CPU_MIPS{32|64}_R1.Ralf Baechle
2005-10-29Update MIPS to use the 4-level pagetable code thereby getting rid ofRalf Baechle
the compacrapability headers. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2005-09-05[PATCH] mm: consolidate get_orderStephen Rothwell
Someone mentioned that almost all the architectures used basically the same implementation of get_order. This patch consolidates them into asm-generic/page.h and includes that in the appropriate places. The exceptions are ia64 and ppc which have their own (presumably optimised) versions. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] mips: add MIPS-specific support for flatmem/discontigmemYoichi Yuasa
2.6.12-git6 doesn't boot on some MIPS machines. They need the support of flat memory and discontig memory. Signed-off-by: Yoichi Yuasa <yuasa@hh.iij4u.or.jp> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
