path: root/include/asm-mips/sni.h
2008-02-19[MIPS] RM: fix EISA=n compilationAdrian Bunk
This patch fixes the following build error with CONFIG_EISA=n caused by commit 231a35d37293ab88d325a9cb94e5474c156282c0: <-- snip --> ... LD .tmp_vmlinux1 arch/mips/sni/built-in.o: In function `snirm_a20r_setup_devinit': a20r.c:(.init.text+0x42c): undefined reference to `sni_eisa_root_init' a20r.c:(.init.text+0x42c): relocation truncated to fit: R_MIPS_26 against `sni_eisa_root_init' arch/mips/sni/built-in.o: In function `snirm_setup_devinit': rm200.c:(.init.text+0x52c): undefined reference to `sni_eisa_root_init' rm200.c:(.init.text+0x52c): relocation truncated to fit: R_MIPS_26 against `sni_eisa_root_init' make[1]: *** [.tmp_vmlinux1] Error 1 <-- snip --> Signed-off-by: Adrian Bunk <bunk@kernel.org> Acked-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-01-29[MIPS] RM: Collected changesThomas Bogendoerfer
- EISA support for non PCI RMs (RM200 and RM400-xxx). The major part is the splitting of the EISA and onboard ISA of the RM200, which makes the EISA bus on the RM200 look like on other RMs. - 64bit kernel support - system type detection is now common for big and little endian - moved sniprom code to arch/mips/fw - added call_o32 function to arch/mips/fw/lib, which uses a private stack for calling prom functions - fix problem with ISA interrupts, which makes using PIT clockevent possible Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-19[MIPS] Kill duplicated setup_irq() for cp0 timerAtsushi Nemoto
Also many plat_timer_setup() can be killed too. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-11[MIPS] Fix "no space between function name and open parenthesis" warnings.Ralf Baechle
2007-07-10[MIPS] SNI RM updatesThomas Bogendoerfer
- use RTC_CLASS instead of GEN_RTC - get rid of ds1216 in favour of a RTC_CLASS driver - use correct console device for older RM400 - use physical addresses for 82596 device - use 128 byte L1 cache line size (this is needed because most of the SNI caches are using 128 L2 cache lines) Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-02-26[MIPS] SNI: MIPS_CPU_IRQ_BASE cleanupThomas Bogendoerfer
Use MIPS_CPU_IRQ_BASE instead of own define. Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-02-18[MIPS] Support for several more SNI RM models.Thomas Bogendoerfer
2006-06-19[MIPS] Support SNI RM200C SNI in big endian mode and R5000 processors.Thomas Bogendoerfer
Added support for RM200C machines with big endian firmware Added support for RM200-C40 (R5000 support) Signed-off-by: Florian Lohoff <flo@rfc822.org> Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
