path: root/include/asm-mips
2008-04-28Merge branch 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linusLinus Torvalds
* 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linus: (45 commits) [MIPS] Pb1200/DBAu1200: move platform code to its proper place [MIPS] Fix handling of trap and breakpoint instructions [MIPS] Pb1200: do register SMC 91C111 [MIPS] DBAu1200: fix bad SMC 91C111 resource size [NET] Kconfig: Rename MIKROTIK_RB500 -> MIKROTIK_RB532 [MIPS] IP27: Fix build bug due to missing include [MIPS] Fix some sparse warnings on traps.c and irq-msc01.c [MIPS] cevt-gt641xx: Kill unnecessary include [MIPS] DS1287: Add clockevent driver [MIPS] add DECstation I/O ASIC clocksource [MIPS] rbtx4938: minor cleanup [MIPS] Alchemy: kill unused PCI_IRQ_TABLE_LOOKUP macro [MIPS] rbtx4938: misc cleanups [MIPS] jmr3927: use generic txx9 gpio [MIPS] rbhma4500: use generic txx9 gpio [MIPS] generic txx9 gpio support [MIPS] make fallback gpio.h gpiolib-friendly [MIPS] unexport null_perf_irq() and make it static [MIPS] unexport rtc_mips_set_time() [MIPS] unexport copy_from_user_page() ...
2008-04-28[MIPS] Pb1200/DBAu1200: move platform code to its proper placeSergei Shtylyov
Since both the IDE interface and SMC 91C111 Ethernet chip are on-board devices, not SOC devices, move the platform device registration form the common to the board specific code. While at it, remove semicolon (which didn't break compilation only by chance) from the AU1XXX_ATA_DDMA_REQ macro and do some renaming: - change 'au1200_ide0_' variable name prefix to the mere 'ide_'; - change 'smc91x_' variable name prefix to 'smc91c111_' since that's the name of the chip used on the boards; - drop 'AU1XXX_' prefix from the names of macros describing IDE and Ethernet on-board devices; - change 'SMC91111_' to 'SMC91C111_', change 'IRQ' to 'INT' in the names of the macros describing the Ethernet chip for consistency with the IDE macros; - change 'ATA_' to 'IDE_' and 'OFFSET' to 'SHIFT' (since this value is indeed a shift count) in the names of the macros describing the IDE interface. Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-04-28[MIPS] IP27: Fix build bug due to missing includeAdrian Bunk
asm-mips/mach-ip27/topology.h must #include <asm-generic/topology.h> This fixes the following compile error: ... CC kernel/sched.o /home/bunk/linux/kernel-2.6/git/linux-2.6/kernel/sched.c: In function 'find_next_best_node': /home/bunk/linux/kernel-2.6/git/linux-2.6/kernel/sched.c:7015: error: implicit declaration of function 'node_to_cpumask_ptr' /home/bunk/linux/kernel-2.6/git/linux-2.6/kernel/sched.c:7015: error: '__tmp__' undeclared (first use in this function) /home/bunk/linux/kernel-2.6/git/linux-2.6/kernel/sched.c:7015: error: (Each undeclared identifier is reported only once /home/bunk/linux/kernel-2.6/git/linux-2.6/kernel/sched.c:7015: error: for each function it appears in.) /home/bunk/linux/kernel-2.6/git/linux-2.6/kernel/sched.c: In function 'sched_domain_node_span': /home/bunk/linux/kernel-2.6/git/linux-2.6/kernel/sched.c:7047: error: 'nodemask' undeclared (first use in this function) /home/bunk/linux/kernel-2.6/git/linux-2.6/kernel/sched.c:7048: warning: ISO C90 forbids mixed declarations and code /home/bunk/linux/kernel-2.6/git/linux-2.6/kernel/sched.c:7059: error: implicit declaration of function 'node_to_cpumask_ptr_next' /home/bunk/linux/kernel-2.6/git/linux-2.6/kernel/sched.c: In function '__build_sched_domains': /home/bunk/linux/kernel-2.6/git/linux-2.6/kernel/sched.c:7605: error: 'pnodemask' undeclared (first use in this function) make[2]: *** [kernel/sched.o] Error 1 <-- snip --> Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-04-28[MIPS] Fix some sparse warnings on traps.c and irq-msc01.cAtsushi Nemoto
* Declare board_bind_eic_interrupt, board_watchpoint_handler in traps.h * Make msc_bind_eic_interrupt static and fix its argument types. * Make msc_levelirq_type, msc_edgeirq_type static. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-04-28[MIPS] DS1287: Add clockevent driverYoichi Yuasa
Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-04-28[MIPS] add DECstation I/O ASIC clocksourceYoichi Yuasa
Add DECstation I/O ASIC clocksource Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-04-28[MIPS] Alchemy: kill unused PCI_IRQ_TABLE_LOOKUP macroSergei Shtylyov
2008-04-28[MIPS] rbtx4938: misc cleanupsAtsushi Nemoto
* Do not use non-standard I/O accessors, such as reg_rd08, etc. * Kill unnecessary wbflush() * Kill tx4938_mips.h * Kill unnecessary includes Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-04-28[MIPS] jmr3927: use generic txx9 gpioAtsushi Nemoto
Use generic txx9 gpio (and gpiolib) for JMR3927 board. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-04-28[MIPS] rbhma4500: use generic txx9 gpioAtsushi Nemoto
Use generic txx9 gpio (and gpiolib) for RBHMA4500 board. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-04-28[MIPS] generic txx9 gpio supportAtsushi Nemoto
This is a board-independent TXx9 gpio API implementation using gpiolib. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-04-28[MIPS] make fallback gpio.h gpiolib-friendlyAtsushi Nemoto
If gpiolib was selected, asm-generic/gpio.h provides some prototypes for gpio API and implementation helpers. With this patch, platform code can implement its GPIO API using gpiolib without custom gpio.h file. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-04-28[MIPS] Alchemy: don't unmask timer IRQ earlySergei Shtylyov
Defer the unmasking of the count/compare interrupt (IRQ5) till the clockevent driver initialization: - only enable the cascaded IRQs 0 thru 4 in arch_init_irq(); kill the ALLINTS macro -- this change is blessed by AMD as I saw it in their own patch; :-) - do not force IRQ5 enabled in plat_time_init() if PM is enabled and there's no 32 KHz crystal. Update the copyrights (taking into account my prior changes), also removing Pete Popov's old email... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-04-28[MIPS] Move arch/mips/philips to arch/mips/nxpDaniel Laird
Signed-off-by: daniel.j.laird <daniel.j.laird@nxp.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-04-28[MIPS] Add support for MIPS CMP platform.Ralf Baechle
Signed-off-by: Chris Dearman <chris@mips.com> Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-04-28[MIPS] Add CoreFPGA5 support; distinguish between SOCit/ROCitChris Dearman
Signed-off-by: Chris Dearman <chris@mips.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-04-28[MIPS] Allow setting of the cache attribute at run time.Chris Dearman
Slightly tacky, but there is a precedent in the sparc archirecture code. Signed-off-by: Chris Dearman <chris@mips.com> Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-04-28[MIPS] Tidy up cache attributesChris Dearman
2008-04-28[MIPS] All MIPS32 processors support64-bit physical addresses.Chris Dearman
Still, only the 4K may actually implement it. Signed-off-by: Chris Dearman <chris@mips.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-04-28serial: add VR41xx SIU setup for serial consoleYoichi Yuasa
Add VR41xx SIU setup for serial console. Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28mm: introduce pte_special pte bitNick Piggin
s390 for one, cannot implement VM_MIXEDMAP with pfn_valid, due to their memory model (which is more dynamic than most). Instead, they had proposed to implement it with an additional path through vm_normal_page(), using a bit in the pte to determine whether or not the page should be refcounted: vm_normal_page() { ... if (unlikely(vma->vm_flags & (VM_PFNMAP|VM_MIXEDMAP))) { if (vma->vm_flags & VM_MIXEDMAP) { #ifdef s390 if (!mixedmap_refcount_pte(pte)) return NULL; #else if (!pfn_valid(pfn)) return NULL; #endif goto out; } ... } This is fine, however if we are allowed to use a bit in the pte to determine refcountedness, we can use that to _completely_ replace all the vma based schemes. So instead of adding more cases to the already complex vma-based scheme, we can have a clearly seperate and simple pte-based scheme (and get slightly better code generation in the process): vm_normal_page() { #ifdef s390 if (!mixedmap_refcount_pte(pte)) return NULL; return pte_page(pte); #else ... #endif } And finally, we may rather make this concept usable by any architecture rather than making it s390 only, so implement a new type of pte state for this. Unfortunately the old vma based code must stay, because some architectures may not be able to spare pte bits. This makes vm_normal_page a little bit more ugly than we would like, but the 2 cases are clearly seperate. So introduce a pte_special pte state, and use it in mm/memory.c. It is currently a noop for all architectures, so this doesn't actually result in any compiled code changes to mm/memory.o. BTW: I haven't put vm_normal_page() into arch code as-per an earlier suggestion. The reason is that, regardless of where vm_normal_page is actually implemented, the *abstraction* is still exactly the same. Also, while it depends on whether the architecture has pte_special or not, that is the only two possible cases, and it really isn't an arch specific function -- the role of the arch code should be to provide primitive functions and accessors with which to build the core code; pte_special does that. We do not want architectures to know or care about vm_normal_page itself, and we definitely don't want them being able to invent something new there out of sight of mm/ code. If we made vm_normal_page an arch function, then we have to make vm_insert_mixed (next patch) an arch function too. So I don't think moving it to arch code fundamentally improves any abstractions, while it does practically make the code more difficult to follow, for both mm and arch developers, and easier to misuse. [akpm@linux-foundation.org: build fix] Signed-off-by: Nick Piggin <npiggin@suse.de> Acked-by: Carsten Otte <cotte@de.ibm.com> Cc: Jared Hulbert <jaredeh@gmail.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/x86/linux-2.6-generic-bitops-v3 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/x86/linux-2.6-generic-bitops-v3: x86, bitops: select the generic bitmap search functions x86: include/asm-x86/pgalloc.h/bitops.h: checkpatch cleanups - formatting only x86: finalize bitops unification x86, UML: remove x86-specific implementations of find_first_bit x86: optimize find_first_bit for small bitmaps x86: switch 64-bit to generic find_first_bit x86: generic versions of find_first_(zero_)bit, convert i386 bitops: use __fls for fls64 on 64-bit archs generic: implement __fls on all 64-bit archs generic: introduce a generic __fls implementation x86: merge the simple bitops and move them to bitops.h x86, generic: optimize find_next_(zero_)bit for small constant-size bitmaps x86, uml: fix uml with generic find_next_bit for x86 x86: change x86 to use generic find_next_bit uml: Kconfig cleanup uml: fix build error
2008-04-26au1xxx-ide: fix MWDMA supportBartlomiej Zolnierkiewicz
Always use "fast" MWDMA support and remove dma_{black,white}_list (they were based on completely bogus ->ide_dma_check implementation which didn't set neither the host controller timings nor the device for the desired transfer mode). Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-26generic: implement __fls on all 64-bit archsAlexander van Heukelum
Implement __fls on all 64-bit archs: alpha has an implementation of fls64. Added __fls(x) = fls64(x) - 1. ia64 has fls, but not __fls. Added __fls based on code of fls. mips and powerpc have __ilog2, which is the same as __fls. Added __fls = __ilog2. parisc, s390, sh and sparc64: Include generic __fls. x86_64 already has __fls. Signed-off-by: Alexander van Heukelum <heukelum@fastmail.fm> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-18Merge git://git.kernel.org/pub/scm/linux/kernel/git/bart/ide-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/bart/ide-2.6: (58 commits) ide: remove ide_init_default_irq() macro ide: move default IDE ports setup to ide_generic host driver ide: remove obsoleted "idex=noprobe" kernel parameter (take 2) ide: remove needless hwif->irq check from ide_hwif_configure() ide: init hwif->{io_ports,irq} explicitly in legacy VLB host drivers ide: limit legacy VLB host drivers to alpha, x86 and mips cmd640: init hwif->{io_ports,irq} explicitly cmd640: cleanup setup_device_ptrs() ide: add ide-4drives host driver (take 3) ide: remove ppc ifdef from init_ide_data() ide: remove ide_default_io_ctl() macro ide: remove CONFIG_IDE_ARCH_OBSOLETE_INIT ide: add CONFIG_IDE_ARCH_OBSOLETE_DEFAULTS (take 2) ppc/pmac: remove no longer needed IDE quirk ppc: don't include <linux/ide.h> ppc: remove ppc_ide_md ppc/pplus: remove ppc_ide_md.ide_init_hwif hook ppc/sandpoint: remove ppc_ide_md hooks ppc/lopec: remove ppc_ide_md hooks ppc/mpc8xx: remove ppc_ide_md hooks ...
2008-04-18ide: remove ide_init_default_irq() macroBartlomiej Zolnierkiewicz
* Use ide_default_irq() instead of ide_init_default_irq() in ide_generic host driver (so the correct IRQ is always set regardless of CONFIG_PCI / CONFIG_BLK_DEV_IDEPCI). * Remove no longer needed ide_init_default_irq() macro. Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-18ide: remove ide_default_io_ctl() macroBartlomiej Zolnierkiewicz
It is always == '((base) + 0x206)' if CONFIG_IDE_ARCH_OBSOLETE_DEFAULTS=y and it is not needed otherwise (arm, blackfin, parisc, ppc64, sh, sparc[64]). Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-18ide: add CONFIG_IDE_ARCH_OBSOLETE_DEFAULTS (take 2)Bartlomiej Zolnierkiewicz
* Add CONFIG_IDE_ARCH_OBSOLETE_DEFAULTS to drivers/ide/Kconfig and use it instead of defining IDE_ARCH_OBSOLETE_DEFAULTS in <arch/ide.h>. v2: * Define ide_default_irq() in ide-probe.c/ns87415.c if not already defined and drop defining ide_default_irq() for CONFIG_IDE_ARCH_OBSOLETE_DEFAULTS=n. [ Thanks to Stephen Rothwell and David Miller for noticing the problem. ] Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: David Miller <davem@davemloft.net> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-17Generic semaphore implementationMatthew Wilcox
Semaphores are no longer performance-critical, so a generic C implementation is better for maintainability, debuggability and extensibility. Thanks to Peter Zijlstra for fixing the lockdep warning. Thanks to Harvey Harrison for pointing out that the unlikely() was unnecessary. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Acked-by: Ingo Molnar <mingo@elte.hu>
2008-04-17Pb1200/DBAu1200: fix bad IDE resource sizeSergei Shtylyov
The header files for the Pb1200/DBAu1200 boards have wrong definition for the IDE interface's decoded range length -- it should be 512 bytes according to what the IDE driver does. In addition, the IDE platform device claims 1 byte too many for its memory resource -- fix the platform code and the IDE driver in accordance. Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-17Au1200: kill IDE driver function prototypesSergei Shtylyov
Fix these warnings emitted when compiling drivers/ide/mips/au1xxx-ide.c: include/asm/mach-au1x00/au1xxx_ide.h:137: warning: 'auide_tune_drive' declared `static' but never defined include/asm/mach-au1x00/au1xxx_ide.h:138: warning: 'auide_tune_chipset' declared `static' but never defined by wiping out the whole "function prototyping" section from the header file <asm-mips/mach-au1x00/au1xxx_ide.h> as it mostly declared functions that are already dead in the IDE driver; move the only useful prototype into the driver. Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
2008-04-07[MIPS] Handle aliases in vmalloc correctly.Ralf Baechle
flush_cache_vmap / flush_cache_vunmap were calling flush_cache_all which - having been deprecated - turned into a nop ... Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-04-04Merge branch 'upstream' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ralf/upstream-linus * 'upstream' of git://git.kernel.org/pub/scm/linux/kernel/git/ralf/upstream-linus: [MIPS] Make KGDB compile on UP [MIPS] Pb1200: Fix header breakage
2008-04-04[MIPS] Pb1200: Fix header breakageSergei Shtylyov
2008-04-02kvm: provide kvm.h for all architecture: fixes headers_installChristian Borntraeger
Currently include/linux/kvm.h is not considered by make headers_install, because Kbuild cannot handle " unifdef-$(CONFIG_FOO) += foo.h. This problem was introduced by commit fb56dbb31c4738a3918db81fd24da732ce3b4ae6 Author: Avi Kivity <avi@qumranet.com> Date: Sun Dec 2 10:50:06 2007 +0200 KVM: Export include/linux/kvm.h only if $ARCH actually supports KVM Currently, make headers_check barfs due to <asm/kvm.h>, which <linux/kvm.h> includes, not existing. Rather than add a zillion <asm/kvm.h>s, export kvm. only if the arch actually supports it. Signed-off-by: Avi Kivity <avi@qumranet.com> which makes this an 2.6.25 regression. One way of solving the issue is to enhance Kbuild, but Avi and David conviced me, that changing headers_install is not the way to go. This patch changes the definition for linux/kvm.h to unifdef-y. If  unifdef-y is used for linux/kvm.h "make headers_check" will fail on all architectures without asm/kvm.h. Therefore, this patch also provides asm/kvm.h on all architectures. Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Acked-by: Avi Kivity <avi@qumranet.com> Cc: Sam Ravnborg <sam@ravnborg.org Cc: David Woodhouse <dwmw2@infradead.org> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-01[MIPS] Alchemy: work around clock misdetection on early Au1000Sergei Shtylyov
Work around the CPU clock miscalculation on Au1000DA/HA/HB due the sys_cpupll register being write-only, i.e. actually do what the comment before cal_r4off() function advertised for years but the code failed at. This is achieved by just giving user a chance to define the clock explicitly in the board config. via CONFIG_SOC_AU1000_FREQUENCY option, defaulting to 396 MHz if the option is not given... The patch is based on the AMD's big unpublished patch, the issue seems to be an undocumented errata (or feature :-)... Signed-off-by: Sergei Shtylyov <sshtylyov@ru.mvista.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-03-12[MIPS] Clocksource: Only install r4k counter as clocksource if present.Ralf Baechle
2008-03-12[MIPS] Lasat: fix LASAT_CASCADE_IRQYoichi Yuasa
2008-03-12[MIPS] Fix yosemite build errorRalf Baechle
<linux/mm.h> didn't pickup the definition of PKMAP_BASE from fixmap.h, ugh. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-03-12[MIPS] Fix loads of section missmatchesRalf Baechle
2008-03-12[MIPS] IP27: Tighten up CPU description to fix warnings.Ralf Baechle
2008-03-12[MIPS] Fix plat_ioremap for JMR3927Atsushi Nemoto
TX39XX's "reserved" segment in CKSEG3 area is 0xff000000-0xfffeffff. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-02-24Alchemy: compile fixManuel Lauss
Commit 8b798c4d16b762d15f4055597ff8d87f73b35552 broke alchemy build, fix it. Pointed out by Adrian Bunk. Signed-off-by: Manuel Lauss <mano@roarinelk.homelinux.net> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2008-02-19[MIPS] RM: fix EISA=n compilationAdrian Bunk
This patch fixes the following build error with CONFIG_EISA=n caused by commit 231a35d37293ab88d325a9cb94e5474c156282c0: <-- snip --> ... LD .tmp_vmlinux1 arch/mips/sni/built-in.o: In function `snirm_a20r_setup_devinit': a20r.c:(.init.text+0x42c): undefined reference to `sni_eisa_root_init' a20r.c:(.init.text+0x42c): relocation truncated to fit: R_MIPS_26 against `sni_eisa_root_init' arch/mips/sni/built-in.o: In function `snirm_setup_devinit': rm200.c:(.init.text+0x52c): undefined reference to `sni_eisa_root_init' rm200.c:(.init.text+0x52c): relocation truncated to fit: R_MIPS_26 against `sni_eisa_root_init' make[1]: *** [.tmp_vmlinux1] Error 1 <-- snip --> Signed-off-by: Adrian Bunk <bunk@kernel.org> Acked-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-02-19[MIPS] Qemu: finish platform removalAdrian Bunk
Two files were omitted from the recent removal of the qemu platform. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-02-19[MIPS] Wire up the timerfd_*() o32 system callsDmitri Vorobiev
This patch enables the system calls timerfd_create(), timerfd_settime() and timerfd_gettime() for MIPS architecture. Please see the following Bugzilla entry for more details: http://bugzilla.kernel.org/show_bug.cgi?id=10038 This was tested using a Malta 4Kc board in both little-endian and big-endian modes. The unit test program is available from the URL above. Signed-off-by: Dmitri Vorobiev <dmitri.vorobiev@gmail.com> [Ralf: Added N64, N32 and O32 bits on 64-bit kernels.] Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-02-19[MIPS] IP27: Add missing ~ in DMA code.Ralf Baechle
Harmless since this function is not being called on I/O coherent systems such as IP27. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-02-08CONFIG_HIGHPTE vs. sub-page page tables.Martin Schwidefsky
Background: I've implemented 1K/2K page tables for s390. These sub-page page tables are required to properly support the s390 virtualization instruction with KVM. The SIE instruction requires that the page tables have 256 page table entries (pte) followed by 256 page status table entries (pgste). The pgstes are only required if the process is using the SIE instruction. The pgstes are updated by the hardware and by the hypervisor for a number of reasons, one of them is dirty and reference bit tracking. To avoid wasting memory the standard pte table allocation should return 1K/2K (31/64 bit) and 2K/4K if the process is using SIE. Problem: Page size on s390 is 4K, page table size is 1K or 2K. That means the s390 version for pte_alloc_one cannot return a pointer to a struct page. Trouble is that with the CONFIG_HIGHPTE feature on x86 pte_alloc_one cannot return a pointer to a pte either, since that would require more than 32 bit for the return value of pte_alloc_one (and the pte * would not be accessible since its not kmapped). Solution: The only solution I found to this dilemma is a new typedef: a pgtable_t. For s390 pgtable_t will be a (pte *) - to be introduced with a later patch. For everybody else it will be a (struct page *). The additional problem with the initialization of the ptl lock and the NR_PAGETABLE accounting is solved with a constructor pgtable_page_ctor and a destructor pgtable_page_dtor. The page table allocation and free functions need to call these two whenever a page table page is allocated or freed. pmd_populate will get a pgtable_t instead of a struct page pointer. To get the pgtable_t back from a pmd entry that has been installed with pmd_populate a new function pmd_pgtable is added. It replaces the pmd_page call in free_pte_range and apply_to_pte_range. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08asm-*/posix_types.h: scrub __GLIBC__Mike Frysinger
Some arches (like alpha and ia64) already have a clean posix_types.h header. This brings all the others in line by removing all references to __GLIBC__ (and some undocumented __USE_ALL). Signed-off-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: Ulrich Drepper <drepper@redhat.com> Cc: Roland McGrath <roland@redhat.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08aout: move STACK_TOP[_MAX] to asm/processor.hDavid Howells
Move STACK_TOP[_MAX] out of asm/a.out.h and into asm/processor.h as they're required whether or not A.OUT format is available. Signed-off-by: David Howells <dhowells@redhat.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
