path: root/include/asm-parisc/cacheflush.h
2007-02-17[PARISC] Add prototypes for flush_user_dcache_range and flush_user_icache_rangeMatthew Wilcox
They're called from signal.c, so need to be prototyped Signed-off-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2007-02-17[PARISC] Clean up the cache and tlb headersRandolph Chung
No changes in functionality. Signed-off-by: Randolph Chung <tausq@debian.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2007-01-08[ARM] pass vma for flush_anon_page()Russell King
Since get_user_pages() may be used with processes other than the current process and calls flush_anon_page(), flush_anon_page() has to cope in some way with non-current processes. It may not be appropriate, or even desirable to flush a region of virtual memory cache in the current process when that is different to the process that we want the flush to occur for. Therefore, pass the vma into flush_anon_page() so that the architecture can work out whether the 'vmaddr' is for the current process or not. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-12-13[PATCH] Optimize D-cache alias handling on forkRalf Baechle
Virtually index, physically tagged cache architectures can get away without cache flushing when forking. This patch adds a new cache flushing function flush_cache_dup_mm(struct mm_struct *) which for the moment I've implemented to do the same thing on all architectures except on MIPS where it's a no-op. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-04[PARISC] parisc specific kmap API implementation for pa8800James Bottomley
This patch fixes the pa8800 at a gross level (there are still other subtle incoherency issues which can still cause crashes and HPMCs). What it does is try to force eject inequivalent aliases before they become visible to the L2 cache (which is where we get the incoherence problems). A new function (parisc_requires_coherency) is introduced in asm/processor.h to identify the pa8x00 processors (8800 and 8900) which have the issue. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2006-04-26Don't include linux/config.h from anywhere else in include/David Woodhouse
2006-03-30[PARISC] Add parisc implementation of flush_kernel_dcache_page()James Bottomley
We need to do a little renaming of our original syntax because of the difference in arguments. Signed-off-by: James Bottomley <jejb@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2006-03-30[PARISC] Add parisc implementation of flush_anon_page()James Bottomley
This should now allow SG_IO and fuse to function correctly on our platform. Signed-off-by: James Bottomley <jejb@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2006-01-22[PARISC] Add CONFIG_DEBUG_RODATA to protect read-only dataHelge Deller
Add the parisc version of the "mark rodata section read only" patches. Based on code from and Signed-off-by Arjan van de Ven <arjan@infradead.org>, Ingo Molnar <mingo@elte.hu>, Andi Kleen <ak@muc.de>, Andrew Morton <akpm@osdl.org>, Linus Torvalds <torvalds@osdl.org>. Signed-off-by: Helge Deller <deller@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2005-10-29[PATCH] mm: parisc pte atomicityHugh Dickins
There's a worrying function translation_exists in parisc cacheflush.h, unaffected by split ptlock since flush_dcache_page is using it on some other mm, without any relevant lock. Oh well, make it a slightly more robust by factoring the pfn check within it. And it looked liable to confuse a camouflaged swap or file entry with a good pte: fix that too. Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-10[PATCH] spinlock consolidationIngo Molnar
This patch (written by me and also containing many suggestions of Arjan van de Ven) does a major cleanup of the spinlock code. It does the following things: - consolidates and enhances the spinlock/rwlock debugging code - simplifies the asm/spinlock.h files - encapsulates the raw spinlock type and moves generic spinlock features (such as ->break_lock) into the generic code. - cleans up the spinlock code hierarchy to get rid of the spaghetti. Most notably there's now only a single variant of the debugging code, located in lib/spinlock_debug.c. (previously we had one SMP debugging variant per architecture, plus a separate generic one for UP builds) Also, i've enhanced the rwlock debugging facility, it will now track write-owners. There is new spinlock-owner/CPU-tracking on SMP builds too. All locks have lockup detection now, which will work for both soft and hard spin/rwlock lockups. The arch-level include files now only contain the minimally necessary subset of the spinlock code - all the rest that can be generalized now lives in the generic headers: include/asm-i386/spinlock_types.h | 16 include/asm-x86_64/spinlock_types.h | 16 I have also split up the various spinlock variants into separate files, making it easier to see which does what. The new layout is: SMP | UP ----------------------------|----------------------------------- asm/spinlock_types_smp.h | linux/spinlock_types_up.h linux/spinlock_types.h | linux/spinlock_types.h asm/spinlock_smp.h | linux/spinlock_up.h linux/spinlock_api_smp.h | linux/spinlock_api_up.h linux/spinlock.h | linux/spinlock.h /* * here's the role of the various spinlock/rwlock related include files: * * on SMP builds: * * asm/spinlock_types.h: contains the raw_spinlock_t/raw_rwlock_t and the * initializers * * linux/spinlock_types.h: * defines the generic type and initializers * * asm/spinlock.h: contains the __raw_spin_*()/etc. lowlevel * implementations, mostly inline assembly code * * (also included on UP-debug builds:) * * linux/spinlock_api_smp.h: * contains the prototypes for the _spin_*() APIs. * * linux/spinlock.h: builds the final spin_*() APIs. * * on UP builds: * * linux/spinlock_type_up.h: * contains the generic, simplified UP spinlock type. * (which is an empty structure on non-debug builds) * * linux/spinlock_types.h: * defines the generic type and initializers * * linux/spinlock_up.h: * contains the __raw_spin_*()/etc. version of UP * builds. (which are NOPs on non-debug, non-preempt * builds) * * (included on UP-non-debug builds:) * * linux/spinlock_api_up.h: * builds the _spin_*() APIs. * * linux/spinlock.h: builds the final spin_*() APIs. */ All SMP and UP architectures are converted by this patch. arm, i386, ia64, ppc, ppc64, s390/s390x, x64 was build-tested via crosscompilers. m32r, mips, sh, sparc, have not been tested yet, but should be mostly fine. From: Grant Grundler <grundler@parisc-linux.org> Booted and lightly tested on a500-44 (64-bit, SMP kernel, dual CPU). Builds 32-bit SMP kernel (not booted or tested). I did not try to build non-SMP kernels. That should be trivial to fix up later if necessary. I converted bit ops atomic_hash lock to raw_spinlock_t. Doing so avoids some ugly nesting of linux/*.h and asm/*.h files. Those particular locks are well tested and contained entirely inside arch specific code. I do NOT expect any new issues to arise with them. If someone does ever need to use debug/metrics with them, then they will need to unravel this hairball between spinlocks, atomic ops, and bit ops that exist only because parisc has exactly one atomic instruction: LDCW (load and clear word). From: "Luck, Tony" <tony.luck@intel.com> ia64 fix Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arjan van de Ven <arjanv@infradead.org> Signed-off-by: Grant Grundler <grundler@parisc-linux.org> Cc: Matthew Wilcox <willy@debian.org> Signed-off-by: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Mikael Pettersson <mikpe@csd.uu.se> Signed-off-by: Benoit Boissinot <benoit.boissinot@ens-lyon.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
