path: root/include/asm-parisc/fb.h
2007-07-17fbdev: detect primary display deviceAntonino A. Daplas
Add function helper, fb_is_primary_device(). Given struct fb_info, it will return a nonzero value if the device is the primary display. Currently, only the i386 is supported where the function checks for the IORESOURCE_ROM_SHADOW flag. Signed-off-by: Antonino Daplas <adaplas@gmail.com> Cc: David Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17fbdev: move arch-specific bits to their respective subdirectoriesAntonino A. Daplas
Move arch-specific bits of fb_mmap() to their respective subdirectories [bob.picco@hp.com: efi_range_is_wc is referenced but not declared] [bunk@stusta.de: fix include/asm-m68k/fb.h] Signed-off-by: Antonino Daplas <adaplas@gmail.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
