path: root/include/asm-parisc/mman.h
2007-02-11[PATCH] Remove final references to deprecated "MAP_ANON" page protection flagRobert P. J. Day
Remove the last vestiges of the long-deprecated "MAP_ANON" page protection flag: use "MAP_ANONYMOUS" instead. Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-02-15[PATCH] add asm-generic/mman.hMichael S. Tsirkin
Make new MADV_REMOVE, MADV_DONTFORK, MADV_DOFORK consistent across all arches. The idea is to make it possible to use them portably even before distros include them in libc headers. Move common flags to asm-generic/mman.h Signed-off-by: Michael S. Tsirkin <mst@mellanox.co.il> Cc: Roland Dreier <rolandd@cisco.com> Cc: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-14[PATCH] madvise MADV_DONTFORK/MADV_DOFORKMichael S. Tsirkin
Currently, copy-on-write may change the physical address of a page even if the user requested that the page is pinned in memory (either by mlock or by get_user_pages). This happens if the process forks meanwhile, and the parent writes to that page. As a result, the page is orphaned: in case of get_user_pages, the application will never see any data hardware DMA's into this page after the COW. In case of mlock'd memory, the parent is not getting the realtime/security benefits of mlock. In particular, this affects the Infiniband modules which do DMA from and into user pages all the time. This patch adds madvise options to control whether memory range is inherited across fork. Useful e.g. for when hardware is doing DMA from/into these pages. Could also be useful to an application wanting to speed up its forks by cutting large areas out of consideration. Signed-off-by: Michael S. Tsirkin <mst@mellanox.co.il> Acked-by: Hugh Dickins <hugh@veritas.com> Cc: Michael Kerrisk <mtk-manpages@gmx.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] madvise(MADV_REMOVE): remove pages from tmpfs shm backing storeBadari Pulavarty
Here is the patch to implement madvise(MADV_REMOVE) - which frees up a given range of pages & its associated backing store. Current implementation supports only shmfs/tmpfs and other filesystems return -ENOSYS. "Some app allocates large tmpfs files, then when some task quits and some client disconnect, some memory can be released. However the only way to release tmpfs-swap is to MADV_REMOVE". - Andrea Arcangeli Databases want to use this feature to drop a section of their bufferpool (shared memory segments) - without writing back to disk/swap space. This feature is also useful for supporting hot-plug memory on UML. Concerns raised by Andrew Morton: - "We have no plan for holepunching! If we _do_ have such a plan (or might in the future) then what would the API look like? I think sys_holepunch(fd, start, len), so we should start out with that." - Using madvise is very weird, because people will ask "why do I need to mmap my file before I can stick a hole in it?" - None of the other madvise operations call into the filesystem in this manner. A broad question is: is this capability an MM operation or a filesytem operation? truncate, for example, is a filesystem operation which sometimes has MM side-effects. madvise is an mm operation and with this patch, it gains FS side-effects, only they're really, really significant ones." Comments: - Andrea suggested the fs operation too but then it's more efficient to have it as a mm operation with fs side effects, because they don't immediatly know fd and physical offset of the range. It's possible to fixup in userland and to use the fs operation but it's more expensive, the vmas are already in the kernel and we can use them. Short term plan & Future Direction: - We seem to need this interface only for shmfs/tmpfs files in the short term. We have to add hooks into the filesystem for correctness and completeness. This is what this patch does. - In the future, plan is to support both fs and mmap apis also. This also involves (other) filesystem specific functions to be implemented. - Current patch doesn't support VM_NONLINEAR - which can be addressed in the future. Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Cc: Hugh Dickins <hugh@veritas.com> Cc: Andrea Arcangeli <andrea@suse.de> Cc: Michael Kerrisk <mtk-manpages@gmx.net> Cc: Ulrich Drepper <drepper@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
