path: root/include/asm-parisc/page.h
2008-02-08CONFIG_HIGHPTE vs. sub-page page tables.Martin Schwidefsky
Background: I've implemented 1K/2K page tables for s390. These sub-page page tables are required to properly support the s390 virtualization instruction with KVM. The SIE instruction requires that the page tables have 256 page table entries (pte) followed by 256 page status table entries (pgste). The pgstes are only required if the process is using the SIE instruction. The pgstes are updated by the hardware and by the hypervisor for a number of reasons, one of them is dirty and reference bit tracking. To avoid wasting memory the standard pte table allocation should return 1K/2K (31/64 bit) and 2K/4K if the process is using SIE. Problem: Page size on s390 is 4K, page table size is 1K or 2K. That means the s390 version for pte_alloc_one cannot return a pointer to a struct page. Trouble is that with the CONFIG_HIGHPTE feature on x86 pte_alloc_one cannot return a pointer to a pte either, since that would require more than 32 bit for the return value of pte_alloc_one (and the pte * would not be accessible since its not kmapped). Solution: The only solution I found to this dilemma is a new typedef: a pgtable_t. For s390 pgtable_t will be a (pte *) - to be introduced with a later patch. For everybody else it will be a (struct page *). The additional problem with the initialization of the ptl lock and the NR_PAGETABLE accounting is solved with a constructor pgtable_page_ctor and a destructor pgtable_page_dtor. The page table allocation and free functions need to call these two whenever a page table page is allocated or freed. pmd_populate will get a pgtable_t instead of a struct page pointer. To get the pgtable_t back from a pmd entry that has been installed with pmd_populate a new function pmd_pgtable is added. It replaces the pmd_page call in free_pte_range and apply_to_pte_range. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07Cleanup asm/{elf,page,user}.h: #ifdef __KERNEL__ is no longer neededKirill A. Shutemov
asm/elf.h, asm/page.h and asm/user.h don't export to userspace now, so we can drop #ifdef __KERNEL__ for them. [k.shutemov@gmail.com: remove #ifdef __KERNEL_] Signed-off-by: Kirill A. Shutemov <k.shutemov@gmail.com> Reviewed-by: David Woodhouse <dwmw2@infradead.org> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Kirill A. Shutemov <k.shutemov@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-18[PARISC] Kill off ASM_PAGE_SIZE useSam Ravnborg
We have the macro _AC() generally available now so the calculation of PAGE_SIZE can be made assembler compatible. Introduce use of _AC() and kill all users of ASM_PAGE_SIZE. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2007-02-17[PARISC] convert to use CONFIG_64BIT instead of __LP64__Helge Deller
Signed-off-by: Helge Deller <deller@gmx.de> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2006-12-08[PARISC] Reserve 1GB of space for vmalloc/tmpalias space on parisc64Kyle McMartin
2006-10-04[PARISC] parisc specific kmap API implementation for pa8800James Bottomley
This patch fixes the pa8800 at a gross level (there are still other subtle incoherency issues which can still cause crashes and HPMCs). What it does is try to force eject inequivalent aliases before they become visible to the L2 cache (which is where we get the incoherence problems). A new function (parisc_requires_coherency) is introduced in asm/processor.h to identify the pa8x00 processors (8800 and 8900) which have the issue. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2006-09-19[PATCH] headers_check: Clean up asm-parisc/page.h for user headersMatthew Wilcox
Remove definitions of PAGE_* from the user view Delete unnecessary comments referring to the size of pages Only include <asm-generic> if we're in __KERNEL__ Signed-off-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-26Don't include linux/config.h from anywhere else in include/David Woodhouse
2006-04-21[PARISC] Further work for multiple page sizesHelge Deller
More work towards supporing multiple page sizes on 64-bit. Convert some assumptions that 64bit uses 3 level page tables into testing PT_NLEVELS. Also some BUG() to BUG_ON() conversions and some cleanups to assembler. Signed-off-by: Helge Deller <deller@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2006-03-30[PARISC] Add STRICT_MM_TYPECHECKSHelge Deller
Add STRICT_MM_TYPECHECKS to page.h as other architectures do. Signed-off-by: Helge Deller <deller@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2006-03-30[PARISC] Add parisc implementation of flush_kernel_dcache_page()James Bottomley
We need to do a little renaming of our original syntax because of the difference in arguments. Signed-off-by: James Bottomley <jejb@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2006-03-27[PATCH] unify pfn_to_page: parisc pfn_to_pageKAMEZAWA Hiroyuki
PARISC can use generic funcs. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Kyle McMartin <kyle@mcmartin.ca> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PARISC] Add some defines for HugeTLB pagesHelge Deller
Define some constants for HugeTLB pages, not that parisc-linux supports it yet. Signed-off-by: Helge Deller <deller@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2005-09-05[PATCH] mm: consolidate get_orderStephen Rothwell
Someone mentioned that almost all the architectures used basically the same implementation of get_order. This patch consolidates them into asm-generic/page.h and includes that in the appropriate places. The exceptions are ia64 and ppc which have their own (presumably optimised) versions. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
