path: root/include/asm-powerpc/cacheflush.h
2007-04-13[POWERPC] DEBUG_PAGEALLOC for 32-bitBenjamin Herrenschmidt
Here's an implementation of DEBUG_PAGEALLOC for ppc32. It disables BAT mapping and is only tested with Hash table based processor though it shouldn't be too hard to adapt it to others. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> arch/powerpc/Kconfig.debug | 9 ++++++ arch/powerpc/mm/init_32.c | 4 +++ arch/powerpc/mm/pgtable_32.c | 52 +++++++++++++++++++++++++++++++++++++++ arch/powerpc/mm/ppc_mmu_32.c | 4 ++- include/asm-powerpc/cacheflush.h | 6 ++++ 5 files changed, 74 insertions(+), 1 deletion(-) Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-12-13[PATCH] Optimize D-cache alias handling on forkRalf Baechle
Virtually index, physically tagged cache architectures can get away without cache flushing when forking. This patch adds a new cache flushing function flush_cache_dup_mm(struct mm_struct *) which for the moment I've implemented to do the same thing on all architectures except on MIPS where it's a no-op. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-10[PATCH] powerpc: Merge cacheflush.h and cache.hDavid Gibson
The ppc32 and ppc64 versions of cacheflush.h were almost identical. The two versions of cache.h are fairly similar, except for a bunch of register definitions in the ppc32 version which probably belong better elsewhere. This patch, therefore, merges both headers. Notable points: - there are several functions in cacheflush.h which exist only on ppc32 or only on ppc64. These are handled by #ifdef for now, but these should probably be consolidated, along with the actual code behind them later. - Confusingly, both ppc32 and ppc64 have a flush_dcache_range(), but they're subtly different: it uses dcbf on ppc32 and dcbst on ppc64, ppc64 has a flush_inval_dcache_range() which uses dcbf. These too should be merged and consolidated later. - Also flush_dcache_range() was defined in cacheflush.h on ppc64, and in cache.h on ppc32. In the merged version it's in cacheflush.h - On ppc32 flush_icache_range() is a normal function from misc.S. On ppc64, it was wrapper, testing a feature bit before calling __flush_icache_range() which does the actual flush. This patch takes the ppc64 approach, which amounts to no change on ppc32, since CPU_FTR_COHERENT_ICACHE will never be set there, but does mean renaming flush_icache_range() to __flush_icache_range() in arch/ppc/kernel/misc.S and arch/powerpc/kernel/misc_32.S - The PReP register info from asm-ppc/cache.h has moved to arch/ppc/platforms/prep_setup.c - The 8xx register info from asm-ppc/cache.h has moved to a new asm-powerpc/reg_8xx.h, included from reg.h - flush_dcache_all() was defined on ppc32 (only), but was never called (although it was exported). Thus this patch removes it from cacheflush.h and from ARCH=powerpc (misc_32.S) entirely. It's left in ARCH=ppc for now, with the prototype moved to ppc_ksyms.c. Built for Walnut (ARCH=ppc), 32-bit multiplatform (pmac, CHRP and PReP ARCH=ppc, pmac and CHRP ARCH=powerpc). Built and booted on POWER5 LPAR (ARCH=powerpc and ARCH=ppc64). Built for 32-bit powermac (ARCH=ppc and ARCH=powerpc). Built and booted on POWER5 LPAR (ARCH=powerpc and ARCH=ppc64). Built and booted on G5 (ARCH=powerpc) Signed-off-by: David Gibson <david@gibson.dropbear.id.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
