path: root/include/asm-powerpc/dbdma.h
2006-12-04[POWERPC] Xserve cpu-meter driverBenjamin Herrenschmidt
This is a small driver for the Xserve G5 CPU-meter blue LEDs on the front-panel. It might work on the Xserve G4 as well though that was not tested. It's pretty basic and could use some improvements if somebody cares doing them. :) Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2005-10-20powerpc: Merge various powermac-related header files.Paul Mackerras
Except for smu.h, which moved from asm-ppc64 to asm-powerpc, all of these moved from asm-ppc to asm-powerpc. In each case the asm-ppc64 version (if there was one) was just a single line including the asm-ppc version. Signed-off-by: Paul Mackerras <paulus@samba.org>
