path: root/include/asm-powerpc/eeh.h
2006-12-04[POWERPC] Merge 32 and 64 bits asm-powerpc/io.hBenjamin Herrenschmidt
powerpc: Merge 32 and 64 bits asm-powerpc/io.h The rework on io.h done for the new hookable accessors made it easier, so I just finished the work and merged 32 and 64 bits io.h for arch/powerpc. arch/ppc still uses the old version in asm-ppc, there is just too much gunk in there that I really can't be bothered trying to cleanup. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-12-04[POWERPC] Allow hooking of PCI MMIO & PIO accessors on 64 bitsBenjamin Herrenschmidt
This patch reworks the way iSeries hooks on PCI IO operations (both MMIO and PIO) and provides a generic way for other platforms to do so (we have need to do that for various other platforms). While reworking the IO ops, I ended up doing some spring cleaning in io.h and eeh.h which I might want to split into 2 or 3 patches (among others, eeh.h had a lot of useless stuff in it). A side effect is that EEH for PIO should work now (it used to pass IO ports down to the eeh address check functions which is bogus). Also, new are MMIO "repeat" ops, which other archs like ARM already had, and that we have too now: readsb, readsw, readsl, writesb, writesw, writesl. In the long run, I might also make EEH use the hooks instead of wrapping at the toplevel, which would make things even cleaner and relegate EEH completely in platforms/iseries, but we have to measure the performance impact there (though it's really only on MMIO reads) Since I also need to hook on ioremap, I shuffled the functions a bit there. I introduced ioremap_flags() to use by drivers who want to pass explicit flags to ioremap (and it can be hooked). The old __ioremap() is still there as a low level and cannot be hooked, thus drivers who use it should migrate unless they know they want the low level version. The patch "arch provides generic iomap missing accessors" (should be number 4 in this series) is a pre-requisite to provide full iomap API support with this patch. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-09-13[POWERPC] Fix MMIO ops to provide expected barrier behaviourPaul Mackerras
This changes the writeX family of functions to have a sync instruction before the MMIO store rather than after, because the generally expected behaviour is that the device receiving the MMIO store can be guaranteed to see the effects of any preceding writes to normal memory. To preserve ordering between writeX and readX, and to preserve ordering between preceding stores and the readX, the readX family of functions have had an sync added before the load. Although writeX followed by spin_unlock is not officially guaranteed to keep the writeX inside the spin-locked region unless an mmiowb() is used, there are currently drivers that depend on the previous behaviour on powerpc, which was that the mmiowb wasn't actually required. Therefore we have a per-cpu flag that is set by writeX, cleared by __raw_spin_lock and mmiowb, and tested by __raw_spin_unlock. If it is set, __raw_spin_unlock does a sync and clears it. This changes both 32-bit and 64-bit readX/writeX. 32-bit already has a sync in __raw_spin_unlock (since lwsync doesn't exist on 32-bit), and thus doesn't need the per-cpu flag. Tested on G5 (PPC970) and POWER5. Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-06-22Merge git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpcLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc: (139 commits) [POWERPC] re-enable OProfile for iSeries, using timer interrupt [POWERPC] support ibm,extended-*-frequency properties [POWERPC] Extra sanity check in EEH code [POWERPC] Dont look for class-code in pci children [POWERPC] Fix mdelay badness on shared processor partitions [POWERPC] disable floating point exceptions for init [POWERPC] Unify ppc syscall tables [POWERPC] mpic: add support for serial mode interrupts [POWERPC] pseries: Print PCI slot location code on failure [POWERPC] spufs: one more fix for 64k pages [POWERPC] spufs: fail spu_create with invalid flags [POWERPC] spufs: clear class2 interrupt status before wakeup [POWERPC] spufs: fix Makefile for "make clean" [POWERPC] spufs: remove stop_code from struct spu [POWERPC] spufs: fix spu irq affinity setting [POWERPC] spufs: further abstract priv1 register access [POWERPC] spufs: split the Cell BE support into generic and platform dependant parts [POWERPC] spufs: dont try to access SPE channel 1 count [POWERPC] spufs: use kzalloc in create_spu [POWERPC] spufs: fix initial state of wbox file ... Manually resolved conflicts in: drivers/net/phy/Makefile include/asm-powerpc/spu.h
2006-04-26Don't include linux/config.h from anywhere else in include/David Woodhouse
2006-04-22[PATCH] powerpc: remove io_page_maskAnton Blanchard
Cleanup patch which removes the io_page_mask. It fixes the reset on some e1000 devices which is needed for clean kexec reboots. The legacy devices which broke with this patch (parallel port and PC speaker) have now been fixed in Linus' tree. Signed-off-by: Anton Blanchard <anton@samba.org> Acked-by: Michael Neuling <mikey@neuling.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-04-01[PATCH] powerpc/pseries: EEH CleanupNathan Fontenot
This patch removes unnecessary exports, marks functions as static when possible, and simplifies some list-related code. Signed-off-by: Nathan Fontenot <nfont@austin.ibm.com> Signed-off-by: Linas Vepstas <linas@austin.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-03-08[PATCH] powerpc: restore eeh_add_device_late() prototype stubMark Fasheh
We fixed this: arch/powerpc/platforms/pseries/eeh.c: In function `eeh_add_device_tree_late': arch/powerpc/platforms/pseries/eeh.c:901: warning: implicit declaration of function `eeh_add_device_late' arch/powerpc/platforms/pseries/eeh.c: At top level: arch/powerpc/platforms/pseries/eeh.c:918: error: conflicting types for 'eeh_add_device_late' arch/powerpc/platforms/pseries/eeh.c:901: error: previous implicit declaration of 'eeh_add_device_late' was here make[2]: *** [arch/powerpc/platforms/pseries/eeh.o] Error 1 But we forgot the !CONFIG_EEH stub. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com> Cc: Paul Mackerras <paulus@samba.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-01[PATCH] fix build breakage in eeh.c in 2.6.16-rc5-git5Greg KH
This patch should fixe a problem with eeh_add_device_late() not being defined in the ppc64 build process, causing the build to break. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-28[PATCH] powerpc: fix dynamic PCI probe regressionJohn Rose
Some hotplug driver functions were migrated to the kernel for use by EEH in commit 2bf6a8fa21570f37fd1789610da30f70a05ac5e3. Previously, the PCI Hotplug module had been changed to use the new OFDT-based PCI probe when appropriate: 5fa80fcdca9d20d30c9ecec30d4dbff4ed93a5c6 When rpaphp_pci_config_slot() was moved from the rpaphp driver to the new kernel function pcibios_add_pci_devices(), the OFDT-based probe stuff was dropped. This patch restores it. Signed-off-by: John Rose <johnrose@austin.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-01-10[PATCH] powerpc: PCI Error Recovery: PPC64 core recovery routinesLinas Vepstas
Various PCI bus errors can be signaled by newer PCI controllers. The core error recovery routines are architecture dependent. This patch adds a recovery infrastructure for the PPC64 pSeries systems. Signed-off-by: Linas Vepstas <linas@austin.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org> (cherry picked from e8ca11b460c4c9c7fa6b529be221529ebd770e38 commit)
2006-01-09[PATCH] Small fix in eeh definitions when CONFIG_EEH not enabledHaren Myneni
Undefined symbols (eeh_add_device_tree_early and eeh_remove_bus_device) when EEH is not enabled. This small patch will fix this. Acked-by: Linas Vepstas <linas@austin.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-01-09[PATCH] powerpc: sanitize header files for user space includesArnd Bergmann
include/asm-ppc/ had #ifdef __KERNEL__ in all header files that are not meant for use by user space, include/asm-powerpc does not have this yet. This patch gets us a lot closer there. There are a few cases where I was not sure, so I left them out. I have verified that no CONFIG_* symbols are used outside of __KERNEL__ any more and that there are no obvious compile errors when including any of the headers in user space libraries. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-01-09[PATCH] powerpc: PCI hotplug common code eliminationLinas Vepstas
20-rpaphp-eeh-cleanup.patch This patch move some code from the rpaphp directory, to the powerpc directory, where it should have been all along (Among other things, I need it in the powerpc directory for the PCI error recovery.) Please note that patch affects TWO maintainers: Paul, after applying the powerpc part, please ask that GregKH appli the PCI part. It is safe to have the powerpc part go in first. It would be bad to have the PCI part go in first. Signed-off-by: Linas Vepstas <linas@austin.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2005-11-17[PATCH] Avoid use of uninitialised spinlock in EEH.David Woodhouse
If the kernel supports both G5 and pSeries, and CONFIG_EEH is enabled, eeh_init() is (quite reasonably) never called when we boot on a G5. Yet eeh_check_failure() still gets called. We should avoid doing that if !eeh_subsystem_enabled. Signed-off-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2005-11-14powerpc: Move a bunch of ppc64 headers to include/asm-powerpcPaul Mackerras
... and also delete some that are no longer used because we already had an include/asm-powerpc version of the header. Signed-off-by: Paul Mackerras <paulus@samba.org>
