path: root/include/asm-powerpc/keylargo.h
2006-01-09[PATCH] powerpc: sanitize header files for user space includesArnd Bergmann
include/asm-ppc/ had #ifdef __KERNEL__ in all header files that are not meant for use by user space, include/asm-powerpc does not have this yet. This patch gets us a lot closer there. There are a few cases where I was not sure, so I left them out. I have verified that no CONFIG_* symbols are used outside of __KERNEL__ any more and that there are no obvious compile errors when including any of the headers in user space libraries. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-01-09[PATCH] powerpc: Remove device_node addrs/n_addrBenjamin Herrenschmidt
The pre-parsed addrs/n_addrs fields in struct device_node are finally gone. Remove the dodgy heuristics that did that parsing at boot and remove the fields themselves since we now have a good replacement with the new OF parsing code. This patch also fixes a bunch of drivers to use the new code instead, so that at least pmac32, pseries, iseries and g5 defconfigs build. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2005-10-20powerpc: Merge various powermac-related header files.Paul Mackerras
Except for smu.h, which moved from asm-ppc64 to asm-powerpc, all of these moved from asm-ppc to asm-powerpc. In each case the asm-ppc64 version (if there was one) was just a single line including the asm-ppc version. Signed-off-by: Paul Mackerras <paulus@samba.org>
