path: root/include/asm-powerpc/kvm.h
2008-04-27KVM: ppc: PowerPC 440 KVM implementationHollis Blanchard
This functionality is definitely experimental, but is capable of running unmodified PowerPC 440 Linux kernels as guests on a PowerPC 440 host. (Only tested with 440EP "Bamboo" guests so far, but with appropriate userspace support other SoC/board combinations should work.) See Documentation/powerpc/kvm_440.txt for technical details. [stephen: build fix] Signed-off-by: Hollis Blanchard <hollisb@us.ibm.com> Acked-by: Paul Mackerras <paulus@samba.org> Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Avi Kivity <avi@qumranet.com>
2008-04-02kvm: provide kvm.h for all architecture: fixes headers_installChristian Borntraeger
Currently include/linux/kvm.h is not considered by make headers_install, because Kbuild cannot handle " unifdef-$(CONFIG_FOO) += foo.h. This problem was introduced by commit fb56dbb31c4738a3918db81fd24da732ce3b4ae6 Author: Avi Kivity <avi@qumranet.com> Date: Sun Dec 2 10:50:06 2007 +0200 KVM: Export include/linux/kvm.h only if $ARCH actually supports KVM Currently, make headers_check barfs due to <asm/kvm.h>, which <linux/kvm.h> includes, not existing. Rather than add a zillion <asm/kvm.h>s, export kvm. only if the arch actually supports it. Signed-off-by: Avi Kivity <avi@qumranet.com> which makes this an 2.6.25 regression. One way of solving the issue is to enhance Kbuild, but Avi and David conviced me, that changing headers_install is not the way to go. This patch changes the definition for linux/kvm.h to unifdef-y. If  unifdef-y is used for linux/kvm.h "make headers_check" will fail on all architectures without asm/kvm.h. Therefore, this patch also provides asm/kvm.h on all architectures. Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Acked-by: Avi Kivity <avi@qumranet.com> Cc: Sam Ravnborg <sam@ravnborg.org Cc: David Woodhouse <dwmw2@infradead.org> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
