path: root/include/asm-powerpc/lmb.h
2008-04-17[POWERPC] Use lowmem_end_addr to limit lmb allocations on ppc32Kumar Gala
Now that we have a proper variable that is the address of the top of low memory we can use it to limit the lmb allocations. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-02-13[LIB]: Make PowerPC LMB code generic so sparc64 can use it too.David S. Miller
2008-01-23[POWERPC] Fix handling of memreserve if the range lands in highmemKumar Gala
There were several issues if a memreserve range existed and happened to be in highmem: * The bootmem allocator is only aware of lowmem so calling reserve_bootmem with a highmem address would cause a BUG_ON * All highmem pages were provided to the buddy allocator Added a lmb_is_reserved() api that we now use to determine if a highem page should continue to be PageReserved or provided to the buddy allocator. Also, we incorrectly reported the amount of pages reserved since all highmem pages are initally marked reserved and we clear the PageReserved flag as we "free" up the highmem pages. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-08-17[POWERPC] Update lmb.h include protection to ASM_POWERPCBecky Bruce
This file was protected by _PPC64_LMB_H, which is confusing, as the 32-bit code also uses the lmb these days. Changed to _ASM_POWERPC_LMB_H. Signed-off-by: Becky Bruce <becky.bruce@freescale.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-03-22[PATCH] powerpc: Remove calculation of io holeMichael Ellerman
In mm_init_ppc64() we calculate the location of the "IO hole", but then no one ever looks at the value. So don't bother. That's actually all mm_init_ppc64() does, so get rid of it too. Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-02-07[PATCH] powerpc: Put parameter names in lmb.h prototypesMichael Ellerman
Prototypes aren't so useful without parameter names, add them to lmb.h based on the names in lmb.c Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-02-07[PATCH] powerpc: Move LMB_ALLOC_ANYWHERE out of lmb.hMichael Ellerman
LMB_ALLOC_ANYWHERE doesn't need to be part of the API, it's only used in lmb.c - so move it out of the header file. Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-02-07[PATCH] powerpc: Always panic if lmb_alloc() failsMichael Ellerman
Currently most callers of lmb_alloc() don't check if it worked or not, if it ever does weird bad things will probably happen. The few callers who do check just panic or BUG_ON. So make lmb_alloc() panic internally, to catch bugs at the source. The few callers who did check the result no longer need to. The only caller that did anything interesting with the return result was careful_allocation(). For it we create __lmb_alloc_base() which _doesn't_ panic automatically, a little messy, but passable. Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-01-09[PATCH] powerpc: sanitize header files for user space includesArnd Bergmann
include/asm-ppc/ had #ifdef __KERNEL__ in all header files that are not meant for use by user space, include/asm-powerpc does not have this yet. This patch gets us a lot closer there. There are a few cases where I was not sure, so I left them out. I have verified that no CONFIG_* symbols are used outside of __KERNEL__ any more and that there are no obvious compile errors when including any of the headers in user space libraries. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Paul Mackerras <paulus@samba.org>
2005-10-06powerpc: Merge in the ppc64 version of the prom code.Paul Mackerras
This brings in the ppc64 version of prom_init.c, prom.c and btext.c and makes them work for ppc32. This also brings in the new calling convention, where the first entry to the kernel (with r5 != 0) goes to the prom_init code, which then restarts from the beginning (with r5 == 0) after it has done its stuff. For now this also brings in the ppc32 version of setup.c. It also merges lmb.h. Signed-off-by: Paul Mackerras <paulus@samba.org>
