path: root/include/asm-powerpc/nvram.h
2008-02-05include/asm-powerpc/nvram.h needs list.hAndrew Morton
CC [M] sound/ppc/awacs.o In file included from sound/ppc/awacs.c:24: include/asm/nvram.h:62: error: field 'partition' has incomplete type Reported-by: Mariusz Kozlowski <m.kozlowski@tuxland.pl> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-12-20[POWERPC] Cleanup calling mmio_nvram_initIshizaki Kou
This makes mmio_nvram_init() callable unconditionally by providing a dummy definition when CONFIG_MMIO_NVRAM is not defined. Signed-off-by: Kou Ishizaki <Kou.Ishizaki@toshiba.co.jp> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-08-17[POWERPC] pseries: Eliminate global error_log_cnt variableLinas Vepstas
Eliminate the use of error_log_cnt as a global var shared across different directories. Pass it as a parameter instead. Signed-off-by: Linas Vepstas <linas@austin.ibm.com> ---- Respin of earlier patch, with the CONFIG_PSERIES junk removed from the header file. arch/powerpc/kernel/nvram_64.c | 10 +++++----- arch/powerpc/platforms/pseries/rtasd.c | 7 ++++--- include/asm-powerpc/nvram.h | 6 ++++-- 3 files changed, 13 insertions(+), 10 deletions(-) Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-01-09[PATCH] powerpc: sanitize header files for user space includesArnd Bergmann
include/asm-ppc/ had #ifdef __KERNEL__ in all header files that are not meant for use by user space, include/asm-powerpc does not have this yet. This patch gets us a lot closer there. There are a few cases where I was not sure, so I left them out. I have verified that no CONFIG_* symbols are used outside of __KERNEL__ any more and that there are no obvious compile errors when including any of the headers in user space libraries. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Paul Mackerras <paulus@samba.org>
2005-11-15powerpc: Remove an extraneous and incorrect declaration of pmac_nvram_init.Paul Mackerras
2005-11-14powerpc: Move a bunch of ppc64 headers to include/asm-powerpcPaul Mackerras
... and also delete some that are no longer used because we already had an include/asm-powerpc version of the header. Signed-off-by: Paul Mackerras <paulus@samba.org>
